Display sub-system as module iMX8m Processor
saurav-pandya
Is it possible to make display sub-system as module and install using insmod command or modprobe command?
I need install after display sub-system after boot process done.
Saurav
jimmychan
What you mean " display sub-system"?
saurav-pandya
As display subsystem, nwl-dsi module and mxsfb module and mipi-dsi module.
Saurav
jimmychan
I think you can try to build the driver as module and then run 'insmod' to load them after boot.
