Display sub-system as module iMX8m Processor
1,916件の閲覧回数
saurav-pandya
Is it possible to make display sub-system as module and install using insmod command or modprobe command?
I need install after display sub-system after boot process done.
Saurav
3 返答(返信)
1,898件の閲覧回数
jimmychan
What you mean " display sub-system"?
1,892件の閲覧回数
saurav-pandya
As display subsystem, nwl-dsi module and mxsfb module and mipi-dsi module.
Saurav
1,884件の閲覧回数
jimmychan
I think you can try to build the driver as module and then run 'insmod' to load them after boot.
