Display rotation
Display rotation
2,022 次查看
pigi
Hi, we have an i.MX8MM with LVDS.
We had to run several applications on it and we had to rotate the display 180 degrees.
We have tried several canonical approaches but without success.
How can we rotate the display?
6 回复数
2,003 次查看
joanxie
what bsp do you use? linux or android?
1,995 次查看
pigi
we are using Linux with 5.4.142 kernel onboard.
1,973 次查看
joanxie
you can change "transform" in the weston.ini
1,950 次查看
pigi
Thank you for your reply, but we choose to don't use weston.
Are there a lower level way?
1,909 次查看
joanxie
you can try to use GPU 2D to rotate, you can refer to the G2D api from gpu user guide, you can download the user guide from:
"https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat..."
1,887 次查看
pigi
Thank you, I'll give it a try.
