Display rotation
Display rotation
pigi
Hi, we have an i.MX8MM with LVDS.
We had to run several applications on it and we had to rotate the display 180 degrees.
We have tried several canonical approaches but without success.
How can we rotate the display?
joanxie
what bsp do you use? linux or android?
pigi
we are using Linux with 5.4.142 kernel onboard.
joanxie
you can change "transform" in the weston.ini
pigi
Thank you for your reply, but we choose to don't use weston.
Are there a lower level way?
joanxie
you can try to use GPU 2D to rotate, you can refer to the G2D api from gpu user guide, you can download the user guide from:
"https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat..."
pigi
Thank you, I'll give it a try.
