Debug the Cortex-M33 on iMX93EVK
5,005 次查看
Sander-ET
I am trying to get a debug connection to the Cortex-M33 on the iMX93EVK board, using a SEGGER J-Link. I want to be able to debug while Linux is running on the A55.
I tried debugging the hello_world demo app on the M33 while the A55 is in U-Boot, following the instructions in AN14120. The U-Boot commands:
fatload mmc 1:1 80000000 sdk20-app.bin
cp.b 0x80000000 0x201e0000 0x10000
bootaux 0x1ffe0000
start the firmware and the output shows up on the serial port. But when I try to connect using the SEGGER JLinkGDBServerExe it fails to find the device. The log shows this:
02-00000000-00-00000041-004D: TB9DF640 005:451.096 ******************************************************
02-00000000-00-00000041-004A: TB9DF640 005:451.097 J-Link script: i.MX93 Cortex-M33 core J-Link script
02-00000000-00-00000041-004D: TB9DF640 005:451.098 ******************************************************
02-00000000-00-00000042-0034: TB9DF640 005:451.523 InitTarget() end - Took 426us
02-00000000-00-00000042-004D: TB9DF640 005:452.146 TotalIRLen = ?, IRPrint = 0x..000000000000000000000000
02-00000000-00-00000044-005B: TB9DF640 005:453.793 Failed to identify target. Resetting via Reset pin and trying again.
It uses the iMX93 J-Link script but fails to connect to the target. Attach from VS Code (with MCUXpresso extension) also does not work.
I get the same result when I try to debug while the A55 is in Linux (after changing the kernel DTS to disable lpuart5).
Only when I put the BOOT_MODE to Cortex-M33 (Infinite Loop) can the J-Link find the device, and I can debug the demo app using VS Code.
Why doesn't the J-Link detect the target with the A55 in U-Boot or Linux?
Sander
4,848 次查看
Sander-ET
The solution to this problem was to switch off the UART5 from JTAG on the board with the DIP switches SW101.
5 回复数
4,849 次查看
Sander-ET
4,982 次查看
Chavira
HI @Sander-ET!
What BSP are you using?
Do you tried to right-click the project in the MCUXpresso for VS Code and choose "Attach to debug the project"?
Also you can update the environment of u-boot like we recommend in this post.
Best Regards!
Chavira
4,969 次查看
Sander-ET
For the Cortex-M33 we are using the MCUXpresso SDK from git (MCUX_2.16.100). We try to start the debugger from Visual Studio Code, using the MCUXpresso extension. We tried the right-click Attach and Debug, both fail to connect but reset the board.
For the Cortex-A we build an image using imx-docker (MACHINE="imx93-11x11-lpddr4x-evk", DISTRO="fsl-imx-xwayland", IMAGES="imx-image-core"). We boot this from SD card. The device tree has been modified to disable lpuart5. Is there a way to verify from Linux that lpuart5 really is disabled?
We also tried to debug booting the original (demo) image in eMMC with the A55 in U-Boot. We get no JTAG connection with this image either.
The suggested change of the u-boot environment did not help.
Sander
4,964 次查看
Chavira
HI @Sander-ET!
What kernel version are you compiling in Yocto and what pre-build image are you using?
You can corroborate if the UART5 is not working if the UART is not listed in the folder /dev/ of the iMX
4,960 次查看
Sander-ET
The kernel version we build is imx-6.6.36-2.1.0.
I do not know which pre-build image, it came pre-installed when we bought the EVK. It prints "NXP i.MX Release Distro 6.6-scarthgap imx93evk ttyLP0" on startup, and "Linux version 6.6.36-lts-next-gd23d64eea511" on /proc/version
Under which name would the UART5 show up in /dev? There is a /dev/ttyLP0, would the UART5 show up as /dev/ttyLP5 or some other number?
%3CLINGO-SUB%20id%3D%22lingo-sub-1989036%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9C%A8%20iMX93EVK%20%E4%B8%8A%E8%B0%83%E8%AF%95%20Cortex-M33%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1989036%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20SEGGER%20J-Link%20%E4%B8%8E%20iMX93EVK%20%E6%9D%BF%E4%B8%8A%E7%9A%84%20Cortex-M33%20%E5%BB%BA%E7%AB%8B%E8%B0%83%E8%AF%95%E8%BF%9E%E6%8E%A5%E3%80%82%E6%88%91%E5%B8%8C%E6%9C%9B%E8%83%BD%E5%A4%9F%E5%9C%A8%20Linux%20%E5%9C%A8%20A55%20%E4%B8%8A%E8%BF%90%E8%A1%8C%E6%97%B6%E8%BF%9B%E8%A1%8C%E8%B0%83%E8%AF%95%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E5%9C%A8%20A55%20%E5%A4%84%E4%BA%8E%20U-Boot%20%E6%97%B6%E6%8C%89%E7%85%A7%20AN14120%20%E4%B8%AD%E7%9A%84%E8%AF%B4%E6%98%8E%E5%9C%A8%20M33%20%E4%B8%8A%E8%B0%83%E8%AF%95%20hello_world%20%E6%BC%94%E7%A4%BA%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82U-Boot%20%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3Efatload%20mmc%201%3A1%2080000000%20sdk20-app.bin%3C%2FP%3E%3CP%3Ecp.b%200x80000000%200x201e0000%200x10000%3C%2FP%3E%3CP%3Ebootaux%200x1ffe0000%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E5%90%AF%E5%8A%A8%E5%9B%BA%E4%BB%B6%EF%BC%8C%E8%BE%93%E5%87%BA%E6%98%BE%E7%A4%BA%E5%9C%A8%E4%B8%B2%E8%A1%8C%E7%AB%AF%E5%8F%A3%E4%B8%8A%E3%80%82%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20SEGGER%20JLinkGDBServerExe%20%E8%BF%9E%E6%8E%A5%E6%97%B6%EF%BC%8C%E6%97%A0%E6%B3%95%E6%89%BE%E5%88%B0%E8%AF%A5%E8%AE%BE%E5%A4%87%E3%80%82%E6%97%A5%E5%BF%97%E6%98%BE%E7%A4%BA%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E02-00000000-00-00000041-004D%3A%20TB9DF640%20005%3A451.096%20********************************************************%3CBR%20%2F%3E%2002-00000000-00-00000041-004A%EF%BC%9ATB9DF640%20005%EF%BC%9A451.097%20J-Link%20%E8%84%9A%E6%9C%AC%EF%BC%9Ai.MX93%20Cortex-M33%20%E6%A0%B8%E5%BF%83%20J-Link%20%E8%84%9A%E6%9C%AC%3CBR%20%2F%3E02-00000000-00-00000041-004D%3A%20TB9DF640%20005%3A451.098%20********************************************************%3CBR%20%2F%3E%2002-00000000-00-00000042-0034%EF%BC%9ATB9DF640%20005%EF%BC%9A451.523%20InitTarget%EF%BC%88%EF%BC%89%E7%BB%93%E6%9D%9F%20-%20%E8%8A%B1%E4%BA%86%20426us%3CBR%20%2F%3E%2002-00000000-00-00000042-004D%3A%20TB9DF640%20005%3A452.146%20TotalIRLen%20%3D%20%3F%2C%20IRPrint%20%3D%200x..000000000000000000000000%3CBR%20%2F%3E%2002-00000000-00-00000044-005B%EF%BC%9ATB9DF640%20005%EF%BC%9A453.793%3CSTRONG%3E%E6%97%A0%E6%B3%95%E8%AF%86%E5%88%AB%E7%9B%AE%E6%A0%87%E3%80%82%3C%2FSTRONG%3E%E9%80%9A%E8%BF%87%E9%87%8D%E7%BD%AE%E5%AF%86%E7%A0%81%E9%87%8D%E7%BD%AE%E5%B9%B6%E9%87%8D%E8%AF%95%E3%80%82%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E5%AE%83%E4%BD%BF%E7%94%A8%20iMX93%20J-Link%20%E8%84%9A%E6%9C%AC%E4%BD%86%E6%97%A0%E6%B3%95%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%9B%AE%E6%A0%87%E3%80%82%E4%BB%8E%20VS%20Code%EF%BC%88%E5%B8%A6%E6%9C%89%20MCUXpresso%20%E6%89%A9%E5%B1%95%EF%BC%89%3CEM%3E%E9%99%84%E5%8A%A0%3C%2FEM%3E%E4%B9%9F%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E5%9C%A8%20A55%20%E5%9C%A8%20Linux%20%E4%B8%AD%E8%BF%9B%E8%A1%8C%E8%B0%83%E8%AF%95%E6%97%B6%EF%BC%88%E5%9C%A8%E6%9B%B4%E6%94%B9%E5%86%85%E6%A0%B8%20DTS%20%E4%BB%A5%E7%A6%81%E7%94%A8%20lpuart5%20%E4%B9%8B%E5%90%8E%EF%BC%89%EF%BC%8C%E6%88%91%E5%BE%97%E5%88%B0%E4%BA%86%E7%9B%B8%E5%90%8C%E7%9A%84%E7%BB%93%E6%9E%9C%E3%80%82%3C%2FP%3E%3CP%3E%E5%8F%AA%E6%9C%89%E5%BD%93%E6%88%91%E5%B0%86%20BOOT_MODE%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%20Cortex-M33%EF%BC%88%E6%97%A0%E9%99%90%E5%BE%AA%E7%8E%AF%EF%BC%89%E6%97%B6%EF%BC%8CJ-Link%20%E6%89%8D%E8%83%BD%E6%89%BE%E5%88%B0%E8%AF%A5%E8%AE%BE%E5%A4%87%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%88%91%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20VS%20Code%20%E8%B0%83%E8%AF%95%E6%BC%94%E7%A4%BA%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%BA%E4%BB%80%E4%B9%88%20J-Link%20%E6%97%A0%E6%B3%95%E5%9C%A8%20U-Boot%20%E6%88%96%20Linux%20%E4%B8%AD%E6%A3%80%E6%B5%8B%E5%88%B0%E5%B8%A6%E6%9C%89%20A55%20%E7%9A%84%E7%9B%AE%E6%A0%87%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%A1%91%E5%BE%B7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1992000%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20iMX93EVK%20%E4%B8%8A%E8%B0%83%E8%AF%95%20Cortex-M33%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1992000%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A7%A3%E5%86%B3%E6%AD%A4%E9%97%AE%E9%A2%98%E7%9A%84%E6%96%B9%E6%B3%95%E6%98%AF%E4%BD%BF%E7%94%A8%20DIP%20%E5%BC%80%E5%85%B3%20SW101%20%E5%85%B3%E9%97%AD%E6%9D%BF%E4%B8%8A%20JTAG%20%E7%9A%84%20UART5%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1990239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20iMX93EVK%20%E4%B8%8A%E8%B0%83%E8%AF%95%20Cortex-M33%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1990239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BB%AC%E6%9E%84%E5%BB%BA%E7%9A%84%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC%E6%98%AFimx-6.6.36-2.1.0%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E5%93%AA%E4%B8%AA%E9%A2%84%E6%9E%84%E5%BB%BA%E5%9B%BE%E5%83%8F%EF%BC%8C%E5%AE%83%E6%98%AF%E5%9C%A8%E6%88%91%E4%BB%AC%E8%B4%AD%E4%B9%B0%20EVK%20%E6%97%B6%E9%A2%84%E5%85%88%E5%AE%89%E8%A3%85%E7%9A%84%E3%80%82%E5%AE%83%E5%9C%A8%E5%90%AF%E5%8A%A8%E6%97%B6%E6%89%93%E5%8D%B0%E2%80%9CNXP%20i.MX%20Release%20Distro%206.6-scarthgap%20imx93evk%20ttyLP0%E2%80%9D%EF%BC%8C%E5%B9%B6%E5%9C%A8%2Fproc%2Fversion%E4%B8%8A%E6%89%93%E5%8D%B0%E2%80%9CLinux%20version%206.6.36-lts-next-gd23d64eea511%E2%80%9D%3C%2FP%3E%3CP%3EUART5%20%E4%BC%9A%E4%BB%A5%E4%BB%80%E4%B9%88%E5%90%8D%E7%A7%B0%E5%87%BA%E7%8E%B0%E5%9C%A8%20%2Fdev%20%E4%B8%AD%EF%BC%9F%E6%9C%89%E4%B8%80%E4%B8%AA%20%2Fdev%2FttyLP0%EF%BC%8CUART5%20%E4%BC%9A%E6%98%BE%E7%A4%BA%E4%B8%BA%20%2Fdev%2FttyLP5%20%E8%BF%98%E6%98%AF%E5%85%B6%E4%BB%96%E6%95%B0%E5%AD%97%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1990217%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20iMX93EVK%20%E4%B8%8A%E8%B0%83%E8%AF%95%20Cortex-M33%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1990217%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F243013%22%20target%3D%22_blank%22%3E%40Sander-ET%3C%2FA%3E!%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%82%A8%E5%9C%A8%20Yocto%20%E4%B8%AD%E7%BC%96%E8%AF%91%E5%93%AA%E4%B8%AA%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC%E4%BB%A5%E5%8F%8A%E4%BD%BF%E7%94%A8%E5%93%AA%E4%B8%AA%E9%A2%84%E6%9E%84%E5%BB%BA%E6%98%A0%E5%83%8F%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%20UART%20%E6%9C%AA%E5%9C%A8%20iMX%20%E7%9A%84%20%2Fdev%2F%20%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%E5%88%97%E5%87%BA%EF%BC%8C%E5%88%99%E5%8F%AF%E4%BB%A5%E7%A1%AE%E8%AE%A4%20UART5%20%E6%98%AF%E5%90%A6%E5%B7%A5%E4%BD%9C%E6%AD%A3%E5%B8%B8%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1990001%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20iMX93EVK%20%E4%B8%8A%E8%B0%83%E8%AF%95%20Cortex-M33%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1990001%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%AF%B9%E4%BA%8E%20Cortex-M33%EF%BC%8C%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%E6%9D%A5%E8%87%AA%20git%20%E7%9A%84%20MCUXpresso%20SDK%EF%BC%88%20%3CSPAN%3EMCUX_2.16.100%EF%BC%89%3C%2FSPAN%3E%20%E3%80%82%E6%88%91%E4%BB%AC%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20MCUXpresso%20%E6%89%A9%E5%B1%95%E4%BB%8E%20Visual%20Studio%20Code%20%E5%90%AF%E5%8A%A8%E8%B0%83%E8%AF%95%E5%99%A8%E3%80%82%E6%88%91%E4%BB%AC%E5%B0%9D%E8%AF%95%E4%BA%86%E5%8F%B3%E9%94%AE%E5%8D%95%E5%87%BB%E2%80%9C%E8%BF%9E%E6%8E%A5%E2%80%9D%E5%92%8C%E2%80%9C%E8%B0%83%E8%AF%95%E2%80%9D%EF%BC%8C%E4%BD%86%E9%83%BD%E6%97%A0%E6%B3%95%E8%BF%9E%E6%8E%A5%EF%BC%8C%E4%BD%86%E9%87%8D%E7%BD%AE%E4%BA%86%E7%94%B5%E8%B7%AF%E6%9D%BF%E3%80%82%3C%2FP%3E%3CP%3E%E5%AF%B9%E4%BA%8E%20Cortex-A%EF%BC%8C%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%20imx-docker%20(MACHINE%3D%22imx93-11x11-lpddr4x-evk%22%E3%80%81DISTRO%3D%22fsl-imx-xwayland%22%E3%80%81IMAGES%3D%22imx-image-core%22)%20%E6%9E%84%E5%BB%BA%E4%B8%80%E4%B8%AA%E5%9B%BE%E5%83%8F%E3%80%82%E6%88%91%E4%BB%AC%E4%BB%8E%20SD%20%E5%8D%A1%E5%90%AF%E5%8A%A8%E5%AE%83%E3%80%82%E8%AE%BE%E5%A4%87%E6%A0%91%E5%B7%B2%E8%A2%AB%E4%BF%AE%E6%94%B9%E4%BB%A5%E7%A6%81%E7%94%A8%20lpuart5%E3%80%82%E6%9C%89%E6%B2%A1%E6%9C%89%E5%8A%9E%E6%B3%95%E4%BB%8E%20Linux%20%E9%AA%8C%E8%AF%81%20lpuart5%20%E6%98%AF%E5%90%A6%E7%9C%9F%E7%9A%84%E8%A2%AB%E7%A6%81%E7%94%A8%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E8%BF%98%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20U-Boot%20%E4%B8%AD%E7%9A%84%20A55%20%E8%B0%83%E8%AF%95%E5%90%AF%E5%8A%A8%20eMMC%20%E4%B8%AD%E7%9A%84%E5%8E%9F%E5%A7%8B%EF%BC%88%E6%BC%94%E7%A4%BA%EF%BC%89%E6%98%A0%E5%83%8F%E3%80%82%E6%88%91%E4%BB%AC%E4%B9%9F%E6%B2%A1%E6%9C%89%E4%B8%8E%E8%AF%A5%E5%9B%BE%E5%83%8F%E5%BB%BA%E7%AB%8B%20JTAG%20%E8%BF%9E%E6%8E%A5%E3%80%82%3C%2FP%3E%3CP%3E%E5%BB%BA%E8%AE%AE%E6%9B%B4%E6%94%B9%20u-boot%20%E7%8E%AF%E5%A2%83%E6%B2%A1%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%A1%91%E5%BE%B7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1989543%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20iMX93EVK%20%E4%B8%8A%E8%B0%83%E8%AF%95%20Cortex-M33%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1989543%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F243013%22%20target%3D%22_blank%22%3E%40Sander-ET%3C%2FA%3E!%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E4%BB%80%E4%B9%88%20BSP%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E5%B0%9D%E8%AF%95%E8%BF%87%E5%8F%B3%E9%94%AE%E5%8D%95%E5%87%BB%20MCUXpresso%20for%20VS%20Code%20%E4%B8%AD%E7%9A%84%E9%A1%B9%E7%9B%AE%E5%B9%B6%E9%80%89%E6%8B%A9%E2%80%9C%E9%99%84%E5%8A%A0%E5%88%B0%E8%B0%83%E8%AF%95%E9%A1%B9%E7%9B%AE%E2%80%9D%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%82%A8%E8%BF%98%E5%8F%AF%E4%BB%A5%E6%8C%89%E7%85%A7%E6%88%91%E4%BB%AC%E5%9C%A8%E6%9C%AC%E6%96%87%E4%B8%AD%E7%9A%84%E5%BB%BA%E8%AE%AE%E6%9B%B4%E6%96%B0%20u-boot%20%E7%9A%84%E7%8E%AF%E5%A2%83%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FiMX93-A-core-M-core-cannot-be-activated-simultaneously%2Fm-p%2F1886555%22%20target%3D%22_self%22%3E%E3%80%82%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%81%3C%2FP%3E%0A%3CP%3EChavira%3C%2FP%3E%3C%2FLINGO-BODY%3E
