Debug the Cortex-M33 on iMX93EVK
4,997件の閲覧回数
Sander-ET
I am trying to get a debug connection to the Cortex-M33 on the iMX93EVK board, using a SEGGER J-Link. I want to be able to debug while Linux is running on the A55.
I tried debugging the hello_world demo app on the M33 while the A55 is in U-Boot, following the instructions in AN14120. The U-Boot commands:
fatload mmc 1:1 80000000 sdk20-app.bin
cp.b 0x80000000 0x201e0000 0x10000
bootaux 0x1ffe0000
start the firmware and the output shows up on the serial port. But when I try to connect using the SEGGER JLinkGDBServerExe it fails to find the device. The log shows this:
02-00000000-00-00000041-004D: TB9DF640 005:451.096 ******************************************************
02-00000000-00-00000041-004A: TB9DF640 005:451.097 J-Link script: i.MX93 Cortex-M33 core J-Link script
02-00000000-00-00000041-004D: TB9DF640 005:451.098 ******************************************************
02-00000000-00-00000042-0034: TB9DF640 005:451.523 InitTarget() end - Took 426us
02-00000000-00-00000042-004D: TB9DF640 005:452.146 TotalIRLen = ?, IRPrint = 0x..000000000000000000000000
02-00000000-00-00000044-005B: TB9DF640 005:453.793 Failed to identify target. Resetting via Reset pin and trying again.
It uses the iMX93 J-Link script but fails to connect to the target. Attach from VS Code (with MCUXpresso extension) also does not work.
I get the same result when I try to debug while the A55 is in Linux (after changing the kernel DTS to disable lpuart5).
Only when I put the BOOT_MODE to Cortex-M33 (Infinite Loop) can the J-Link find the device, and I can debug the demo app using VS Code.
Why doesn't the J-Link detect the target with the A55 in U-Boot or Linux?
Sander
4,840件の閲覧回数
Sander-ET
The solution to this problem was to switch off the UART5 from JTAG on the board with the DIP switches SW101.
5 返答(返信)
4,841件の閲覧回数
Sander-ET
4,974件の閲覧回数
Chavira
HI @Sander-ET!
What BSP are you using?
Do you tried to right-click the project in the MCUXpresso for VS Code and choose "Attach to debug the project"?
Also you can update the environment of u-boot like we recommend in this post.
Best Regards!
Chavira
4,961件の閲覧回数
Sander-ET
For the Cortex-M33 we are using the MCUXpresso SDK from git (MCUX_2.16.100). We try to start the debugger from Visual Studio Code, using the MCUXpresso extension. We tried the right-click Attach and Debug, both fail to connect but reset the board.
For the Cortex-A we build an image using imx-docker (MACHINE="imx93-11x11-lpddr4x-evk", DISTRO="fsl-imx-xwayland", IMAGES="imx-image-core"). We boot this from SD card. The device tree has been modified to disable lpuart5. Is there a way to verify from Linux that lpuart5 really is disabled?
We also tried to debug booting the original (demo) image in eMMC with the A55 in U-Boot. We get no JTAG connection with this image either.
The suggested change of the u-boot environment did not help.
Sander
4,956件の閲覧回数
Chavira
HI @Sander-ET!
What kernel version are you compiling in Yocto and what pre-build image are you using?
You can corroborate if the UART5 is not working if the UART is not listed in the folder /dev/ of the iMX
4,952件の閲覧回数
Sander-ET
The kernel version we build is imx-6.6.36-2.1.0.
I do not know which pre-build image, it came pre-installed when we bought the EVK. It prints "NXP i.MX Release Distro 6.6-scarthgap imx93evk ttyLP0" on startup, and "Linux version 6.6.36-lts-next-gd23d64eea511" on /proc/version
Under which name would the UART5 show up in /dev? There is a /dev/ttyLP0, would the UART5 show up as /dev/ttyLP5 or some other number?
%3CLINGO-SUB%20id%3D%22lingo-sub-1989036%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECortex-M33%E3%82%92iMX93EVK%E3%81%A7%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1989036%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESEGGER%20J-Link%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81iMX93EVK%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AECortex-M33%E3%81%B8%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E6%8E%A5%E7%B6%9A%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82Linux%E3%81%8CA55%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E9%96%93%E3%81%AB%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EAN14120%E3%81%AE%E6%8C%87%E7%A4%BA%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81A55%E3%81%8CU-Boot%E3%81%AB%E3%81%82%E3%82%8B%E9%96%93%E3%81%AB%E3%80%81M33%E3%81%A7hello_world%E3%83%87%E3%83%A2%E3%82%A2%E3%83%97%E3%83%AA%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82U-Boot%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%E8%84%82%E8%82%AA%E8%B2%A0%E8%8D%B7MMC%201%3A1%2080000000%20sdk20-app.bin%3C%2FP%3E%3CP%3Ecp.b%200x80000000%200x201e0000%200x10000%3C%2FP%3E%3CP%3Ebootaux%200x1ffe0000%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E5%87%BA%E5%8A%9B%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81SEGGER%20JLinkGDBServerExe%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%8E%A5%E7%B6%9A%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%AD%E3%82%B0%E3%81%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E02-00000000-00-0000041-004D%3A%20TB9DF640%20005%3A451.096%20******************************************************%3CBR%20%2F%3E02-00000000-00-00000041-004A%3ATB9DF640%20005%3A451.097%20J-Link%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%3Ai.MX93%20Cortex-M33%E3%82%B3%E3%82%A2J-Link%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%3CBR%20%2F%3E02-00000000-00-00000041-004D%3A%20TB9DF640%20005%3A451.098%20******************************************************%3CBR%20%2F%3E02-00000000-00-00000042-0034%3ATB9DF640%20005%3A451.523%20InitTarget()%E7%B5%82%E4%BA%86%20-%20426us%E3%82%92%E8%A6%81%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E02-00000000-00-00000042-004D%3A%20TB9DF640%20005%3A452.146%20TotalIRLen%20%3D%20%3F%2C%20IRPrint%20%3D%200x..000000000000000000000000%3CBR%20%2F%3E02-00000000-00-0000044-005B%3A%20TB9DF640%20005%3A453.793%20%3CSTRONG%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AE%E8%AD%98%E5%88%A5%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSTRONG%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%83%94%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%80%81%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3EiMX93%20J-Link%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%B8%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82VS%20Code(MCUXpresso%E6%8B%A1%E5%BC%B5%E5%AD%90%E4%BB%98%E3%81%8D)%E3%81%8B%E3%82%89%E3%81%AE%3CEM%3E%E3%82%A2%E3%82%BF%E3%83%83%E3%83%81%3C%2FEM%3E%E3%82%82%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3EA55%E3%81%8CLinux%E3%81%AB%E3%81%82%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8(%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%ABDTS%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6lpuart5%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%9F%E5%BE%8C)%E3%80%81%E5%90%8C%E3%81%98%E7%B5%90%E6%9E%9C%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ECortex-M33(%E7%84%A1%E9%99%90%E3%83%AB%E3%83%BC%E3%83%97)%E3%81%ABBOOT_MODE%E3%82%92%E7%BD%AE%E3%81%84%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AB%E3%81%AE%E3%81%BF%E3%80%81J-Link%E3%81%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%80%81VS%20Code%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%87%E3%83%A2%E3%82%A2%E3%83%97%E3%83%AA%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EJ-Link%E3%81%8CU-Boot%E3%81%BE%E3%81%9F%E3%81%AFLinux%E3%81%AEA55%E3%81%A7%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%97%E3%81%AA%E3%81%84%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%B3%E3%83%80%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1992000%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AiMX93EVK%E3%81%A7%E3%81%AECortex-M33%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1992000%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E3%80%81DIP%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81SW101%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AEJTAG%E3%81%8B%E3%82%89UART5%E3%82%92%E3%82%AA%E3%83%95%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1990239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AiMX93EVK%E3%81%A7%E3%81%AECortex-M33%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1990239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AFimx-6.6.36-2.1.0%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%AE%E3%83%97%E3%83%AC%E3%83%93%E3%83%AB%E3%83%89%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81EVK%E3%82%92%E8%B3%BC%E5%85%A5%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E3%83%97%E3%83%AA%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%AB%E3%81%AF%E3%80%8CNXP%20i.MX%20Release%20Distro%206.6-scarthgap%20imx93evk%20ttyLP0%E3%80%8D%E3%82%92%E3%80%81%2Fproc%2Fversion%20%E3%81%AB%E3%81%AF%E3%80%8CLinux%20version%206.6.36-lts-next-gd23d64eea511%E3%80%8D%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EUART5%20%E3%81%AF%20%2Fdev%20%E3%81%AB%E3%81%A9%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%A7%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F%2Fdev%2FttyLP0%20%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81UART5%20%E3%81%AF%20%2Fdev%2FttyLP5%20%E3%81%BE%E3%81%9F%E3%81%AF%E4%BB%96%E3%81%AE%E7%95%AA%E5%8F%B7%E3%81%A8%E3%81%97%E3%81%A6%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1990217%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AiMX93EVK%E3%81%A7%E3%81%AECortex-M33%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1990217%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F243013%22%20target%3D%22_blank%22%3E%40Sander-ET%3C%2FA%3E!%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EYocto%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A8%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%83%97%E3%83%AC%E3%83%93%E3%83%AB%E3%83%89%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EUART5%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E3%80%81UART%E3%81%8CiMX%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%2Fdev%2F%E3%81%AB%E3%83%AA%E3%82%B9%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AB%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1990001%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AiMX93EVK%E3%81%A7%E3%81%AECortex-M33%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1990001%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ECortex-M33%20%E3%81%A7%E3%81%AF%E3%80%81git%20(%3CSPAN%3EMCUX_2.16.100)%3C%2FSPAN%3E%20%E3%81%AE%20MCUXpresso%20SDK%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82MCUXpresso%E6%8B%A1%E5%BC%B5%E6%A9%9F%E8%83%BD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81Visual%20Studio%20Code%E3%81%8B%E3%82%89%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%8F%B3%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%AE%5B%E3%82%A2%E3%82%BF%E3%83%83%E3%83%81%5D%E3%81%A8%5B%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%5D%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%A9%E3%81%A1%E3%82%89%E3%82%82%E6%8E%A5%E7%B6%9A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3ECortex-A%E3%81%A7%E3%81%AF%E3%80%81imx-docker(MACHINE%3D%22imx93-11x11-lpddr4x-evk%22%2C%20DISTRO%3D%22fsl-imx-xwayland%22%2C%20IMAGES%3D%22imx-image-core%22)%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%92SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AF%E3%80%81lpuart5%20%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82Linux%E3%81%8B%E3%82%89lpuart5%E3%81%8C%E6%9C%AC%E5%BD%93%E3%81%AB%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81U-Boot%20%E3%81%AE%20A55%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20eMMC%20%E3%81%A7%E5%85%83%E3%81%AE%20(%E3%83%87%E3%83%A2)%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%82%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%A8%E3%81%AEJTAG%E6%8E%A5%E7%B6%9A%E3%82%82%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3Eu-boot%20%E7%92%B0%E5%A2%83%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E6%8F%90%E6%A1%88%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E5%8A%A9%E3%81%91%E3%81%AB%E3%81%AF%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%B3%E3%83%80%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1989543%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AiMX93EVK%E3%81%A7%E3%81%AECortex-M33%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1989543%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F243013%22%20target%3D%22_blank%22%3E%40Sander-ET%3C%2FA%3E!%3C%2FP%3E%0A%3CP%3E%E3%81%A9%E3%81%AEBSP%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3EVS%20Code%20%E3%81%AE%20MCUXpresso%20%E3%81%A7%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E5%8F%B3%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%80%81%5B%E3%82%A2%E3%82%BF%E3%83%83%E3%83%81%E3%81%97%E3%81%A6%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%5D%20%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%A7%E6%8E%A8%E5%A5%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81u-boot%E3%81%AE%E7%92%B0%E5%A2%83%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FiMX93-A-core-M-core-cannot-be-activated-simultaneously%2Fm-p%2F1886555%22%20target%3D%22_self%22%3E%E3%80%82%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%0A%3CP%3EChavira%3C%2FP%3E%3C%2FLINGO-BODY%3E
