DRAM_SDCLK0 of i.MX7D is about 270MHz,  it's slow !
1,575件の閲覧回数
tamotsu
Contributor V
Hi.
When CCM_ANALOG_PLL_DDR is set to 0x0000302C, DRAM_SDCLK0 is 132MHz.
So when the TEST_DIV_SELECT bit of CCM_ANALOG_PLL_DDR is set to 0x01 and set to 0x0020302C, DRAM_SDCLK0 is about 270MHz.
It is half of 533Mhz.
DRAM_PHYM_ALT_CLK_ROOT and DRAM_ALT_CLK_ROOT are set to DDR_PLL_DIV2.
Is there a setting to set it to 1/2?
Best regards.
1,480件の閲覧回数
joanxie
the driver I showed just tell you the formula, you need read the register CCM_ANALOG_PLL_DDR, CCM_ANALOG_PLL_DDR_NUM and  CCM_ANALOG_PLL_DDR_DENOM, to check if they are correct
6 返答(返信)
1,558件の閲覧回数
joanxie
>what do you mean? do you mean you need 533Mhz for DRAM_SDCLK, right?
refer to the figure 5-7, The dedicate DRAM_PLL is used to generate 2x clock at 1066MHz, and use a divider to divide it by 2 to get 533MHz clock with good duty cycle. This 533MHz clock will be
used as the PHY_MCLK. Meanwhile, the 1066MHz clock will also be divided by 2 with
the 1/N divider to get 533MHz as the PHY_CLK, there is a 1/N divider used to divide the PHY clockdown to lower frequency such as 266MHz or 133MHz. The 1/N divider is a 3-bit divider
so N can be 2 to 8. so just set this 1/N to 1/2, you can get 533Mhz
1,541件の閲覧回数
tamotsu
Contributor V
Hi Joanxie.
I understand the diagram you explained.
However, the reference manual does not explain which register FASTMIX is.
Please tell me the register name.
In this case, should TEST_DIV_SELECT of CCM_ANALOG_PLL_DDRn be set to 0x00?
Best regards.
1,530件の閲覧回数
joanxie
I checked the source code as below
https://github.com/nxp-imx/uboot-imx/blob/lf_v2025.04/arch/arm/mach-imx/mx7/clock.c#L162
checked the function decode_pll
case PLL_DDR:
reg = readl(&ccm_anatop->pll_ddr);
if (reg & CCM_ANALOG_PLL_DDR_POWERDOWN_MASK)
return 0;
num = ccm_anatop->pll_ddr_num;
denom = ccm_anatop->pll_ddr_denom;
if (reg & CCM_ANALOG_PLL_DDR_BYPASS_MASK)
return MXC_HCLK;
div_sel = (reg & CCM_ANALOG_PLL_DDR_DIV_SELECT_MASK) >>
CCM_ANALOG_PLL_DDR_DIV_SELECT_SHIFT;
return infreq * (div_sel + num / denom);
so the formula is 24M*(DIV_SELECT+(NUM/DENOM)), div_sel is from CCM_ANALOG_PLL_DDR, mum is from CCM_ANALOG_PLL_DDR_NUM) and denom is from CCM_ANALOG_PLL_DDR_DENOM
1,501件の閲覧回数
tamotsu
Contributor V
Hi Joanxie.
I'm building uboot-2022.01.
The code you showed is get_ddrc_clk(void).
What I found in this code
   reg = readl(&ccm_reg->root[DRAM_CLK_ROOT].target_root;
DRAM_CLK_ROOT, which is not written in "Fugure 5-7.DRAM_Clock Structure", is loaded into reg.
The initial value of DRAM_CLK_ROOT was 0x00000001.
Clearing DRAM_CLK_ROOT made it display correctly.
However, DRAM_SDCKE0 is 270MHz. Is this correct? I checked it with an oscilloscope.
Best regards.
1,481件の閲覧回数
joanxie
1,468件の閲覧回数
tamotsu
Contributor V
Hi Joanxie.
Thank you.
There is a 1/2 difference between the calculated result and the actual DDR_SDCKE.
I don't know why, but I'll end it here for now.
As the frequency increases, the voltage level of DDR_SDCLKE decreases.
So I think about lowering the frequency.
Best regards.
%3CLINGO-SUB%20id%3D%22lingo-sub-2148956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX7D%20%E3%81%AE%20DRAM_SDCLK0%20%E3%81%AF%E7%B4%84%20270MHz%20%E3%81%A7%E9%81%85%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2148956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%3C%2FP%3E%3CP%3ECCM_ANALOG_PLL_DDR%20%E3%81%8C%200x0000302C%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81DRAM_SDCLK0%20%E3%81%AF%20132MHz%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESO%E3%80%81CCM_ANALOG_PLL_DDR%20%E3%81%AE%20TEST_DIV_SELECT%20%E3%83%93%E3%83%83%E3%83%88%E3%81%8C%200x01%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%80%810x0020302C%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81DRAM_SDCLK0%20%E3%81%AF%E7%B4%84%20270MHz%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E533Mhz%E3%81%AE%E5%8D%8A%E5%88%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EDRAM_PHYM_ALT_CLK_ROOT%20%E3%81%A8%20DRAM_ALT_CLK_ROOT%20%E3%81%AF%20DDR_PLL_DIV2%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E1%2F2%E3%81%AB%E3%81%99%E3%82%8B%E8%A8%AD%E5%AE%9A%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2152566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DRAM_SDCLK0%20of%20i.MX7D%20is%20about%20270MHz%2C%20%E3%80%80it's%20slow%20!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2152566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B8%E3%83%A7%E3%82%A2%E3%83%B3%E3%82%B7%E3%83%BC%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%A8%88%E7%AE%97%E7%B5%90%E6%9E%9C%E3%81%A8%E5%AE%9F%E9%9A%9B%E3%81%AE%20DDR_SDCKE%20%E3%81%AB%E3%81%AF%201%2F2%20%E3%81%AE%E5%B7%AE%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%90%86%E7%94%B1%E3%81%AF%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%81%A8%E3%82%8A%E3%81%82%E3%81%88%E3%81%9A%E3%81%93%E3%81%93%E3%81%A7%E7%B5%82%E3%82%8F%E3%82%8A%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%8C%E9%AB%98%E3%81%8F%E3%81%AA%E3%82%8B%E3%81%A8%E3%80%81DDR_SDCLKE%20%E3%81%AE%E9%9B%BB%E5%9C%A7%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AF%E4%BD%8E%E4%B8%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESO%E3%80%81%E9%A0%BB%E5%BA%A6%E3%82%92%E4%B8%8B%E3%81%92%E3%82%88%E3%81%86%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2151938%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DRAM_SDCLK0%20of%20i.MX7D%20is%20about%20270MHz%2C%20%E3%80%80it's%20slow%20!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2151938%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%8C%E7%A4%BA%E3%81%97%E3%81%9F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E5%BC%8F%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%82%8C%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%20%3CSPAN%3ECCM_ANALOG_PLL_DDR%E3%80%81CCM_ANALOG_PLL_DDR_NUM%E3%80%81CCM_ANALOG_PLL_DDR_DENOM%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%81%A3%E3%81%A6%E3%80%81%E6%AD%A3%E3%81%97%E3%81%84%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%3C%2FSPAN%3E%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2151226%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DRAM_SDCLK0%20of%20i.MX7D%20is%20about%20270MHz%2C%20%E3%80%80it's%20slow%20!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2151226%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B8%E3%83%A7%E3%82%A2%E3%83%B3%E3%82%B7%E3%83%BC%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3Euboot-2022.01%E3%82%92%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%A4%BA%E3%81%97%E3%81%9F%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%20get_ddrc_clk(void)%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%9F%E3%82%82%E3%81%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Ereg%20%3D%20readl(%26amp%3Bccm_reg-%26gt%3Broot%5BDRAM_CLK_ROOT%5D.target_root%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%80%8C%E5%9B%B35-7.DRAM_Clock%E6%A7%8B%E9%80%A0%E3%80%8D%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84DRAM_CLK_ROOT%E3%81%8Creg%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EDRAM_CLK_ROOT%E3%81%AE%E5%88%9D%E6%9C%9F%E5%80%A4%E3%81%AF0x00000001%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EDRAM_CLK_ROOT%20%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%99%E3%82%8B%E3%81%A8%E6%AD%A3%E3%81%97%E3%81%8F%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81DRAM_SDCKE0%20%E3%81%AF%20270MHz%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E3%81%93%E3%82%8C%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E3%82%AA%E3%82%B7%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2149942%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DRAM_SDCLK0%20of%20i.MX7D%20is%20about%20270MHz%2C%20%E3%80%80it's%20slow%20!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2149942%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fuboot-imx%2Fblob%2Flf_v2025.04%2Farch%2Farm%2Fmach-imx%2Fmx7%2Fclock.c%23L162%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Fuboot-imx%2Fblob%2Flf_v2025.04%2Farch%2Farm%2Fmach-imx%2Fmx7%2Fclock.c%23L162%3C%2FA%3E%3C%2FP%3E%0A%3CP%3Edecode_pll%E9%96%A2%E6%95%B0%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%9F%3C%2FP%3E%0A%3CP%3ECASE%20PLL_DDR%3A%3CBR%20%2F%3E%20reg%20%3D%20readl(%26amp%3Bccm_anatop-%26gt%3Bpll_ddr)%3B%3C%2FP%3E%0A%3CP%3E(reg%20%26amp%3B%20CCM_ANALOG_PLL_DDR_POWERDOWN_MASK)%20%E3%81%AE%E5%A0%B4%E5%90%88%3CBR%20%2F%3E0%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3Enum%20%3D%20ccm_anatop-%26gt%3Bpll_ddr_num%3B%3CBR%20%2F%3E%20denom%20%3D%20ccm_anatop-%26gt%3Bpll_ddr_denom%3B%3C%2FP%3E%0A%3CP%3E(reg%20%26amp%3B%20CCM_ANALOG_PLL_DDR_BYPASS_MASK)%20%E3%81%AE%E5%A0%B4%E5%90%88%3CBR%20%2F%3EMXC_HCLK%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3Ediv_sel%20%3D%20(reg%20%26amp%3B%20CCM_ANALOG_PLL_DDR_DIV_SELECT_MASK)%20%26gt%3B%26gt%3B%3CBR%20%2F%3E%20CCM_ANALOG_PLL_DDR_DIV_SELECT_SHIFT%3B%3C%2FP%3E%0A%3CP%3E%E9%A0%BB%E5%BA%A6%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%20*%20(div_sel%20%2B%20num%20%2F%20denom)%3B%3C%2FP%3E%0A%3CP%3ESO%E3%80%81%E5%BC%8F%E3%81%AF%3CSPAN%3E24M%3C%2FSPAN%3E%20%3CSPAN%3E*(DIV_SELECT%2B(NUM%2FDENOM))%E3%80%81div_sel%E3%81%AF%3CSPAN%20class%3D%22test-id__field-value%20slds-form-element__static%20slds-grow%20word-break-ie11%22%3ECCM_ANALOG_PLL_DDR%E3%81%8B%E3%82%89%E3%80%81mum%E3%81%AFCCM_ANALOG_PLL_DDR_NUM%E3%81%8B%E3%82%89%E3%80%81denom%E3%81%AFCCM_ANALOG_PLL_DDR_DENOM%E3%81%8B%E3%82%89%E5%8F%96%E5%BE%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2149549%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DRAM_SDCLK0%20of%20i.MX7D%20is%20about%20270MHz%2C%20%E3%80%80it's%20slow%20!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2149549%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B8%E3%83%A7%E3%82%A2%E3%83%B3%E3%82%B7%E3%83%BC%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%84%E3%81%9F%E5%9B%B3%E3%81%AF%E7%90%86%E8%A7%A3%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AB%E3%81%AF%E3%80%81FASTMIX%20%E3%81%8C%E3%81%A9%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%A7%E3%81%82%E3%82%8B%E3%81%8B%E3%81%AF%E8%AA%AC%E6%98%8E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%83%BC%E5%90%8D%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%81%AECASE%E3%80%81CCM_ANALOG_PLL_DDRn%20%E3%81%AE%20TEST_DIV_SELECT%20%E3%82%92%200x00%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2149461%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DRAM_SDCLK0%20of%20i.MX7D%20is%20about%20270MHz%2C%20%E3%80%80it's%20slow%20!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2149461%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E1%2F2%E3%81%AB%E3%81%99%E3%82%8B%E8%A8%AD%E5%AE%9A%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%26gt%3B%E3%81%A9%E3%81%86%E3%81%84%E3%81%86%E6%84%8F%E5%91%B3%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%20%3CSPAN%20class%3D%22lia-message-read%22%3EDRAM_SDCLK%E3%81%AB533Mhz%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A0%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22joanxie_0-1754714689138.png%22%20style%3D%22width%3A%20608px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22joanxie_0-1754714689138.png%22%20style%3D%22width%3A%20608px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F351636i41FF8E6A7C302508%2Fimage-dimensions%2F608x222%3Fv%3Dv2%22%20width%3D%22608%22%20height%3D%22222%22%20role%3D%22button%22%20title%3D%22joanxie_0-1754714689138.png%22%20alt%3D%22joanxie_0-1754714689138.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%9B%B35-7%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%B0%82%E7%94%A8%E3%81%AEDRAM_PLL%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A61066MHz%E3%81%AE2%E5%80%8D%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%80%81%E5%88%86%E5%91%A8%E5%99%A8%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%9D%E3%82%8C%E3%82%922%E3%81%A7%E5%88%86%E5%89%B2%E3%81%97%E3%81%A6%E3%80%81%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%81%8C%E8%89%AF%E5%A5%BD%E3%81%AA533MHz%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE533MHz%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AF%3CBR%20%2F%3EPHY_MCLK%20%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E4%B8%80%E6%96%B9%E3%80%811066MHz%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%822%E3%81%A7%E5%89%B2%E3%82%89%E3%82%8C%E3%80%81%3CBR%20%2F%3E%201%2FN%20%E5%88%86%E5%91%A8%E5%99%A8%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20533MHz%20%E3%82%92%20PHY_CLK%20%E3%81%A8%E3%81%97%E3%81%A6%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%BB%E3%81%8B%E3%80%81PHY%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%20266MHz%20%E3%82%84%20133MHz%20%E3%81%AA%E3%81%A9%E3%81%AE%E4%BD%8E%E3%81%84%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AB%E5%88%86%E5%89%B2%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%201%2FN%20%E5%88%86%E5%91%A8%E5%99%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%821%2FN%E9%99%A4%E7%AE%97%E5%99%A8%E3%81%AF3%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E9%99%A4%E7%AE%97%E5%99%A8%E3%81%A7%E3%81%82%E3%82%8B%3CBR%20%2F%3EN%E3%81%AF2%E3%81%8B%E3%82%898%E3%81%BE%E3%81%A7%E3%81%AE%E7%AF%84%E5%9B%B2%E3%81%A7%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82SO%E3%80%811%2FN%E3%82%921%2F2%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8533MHz%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
