DDR3 size
DDR3 size
2,616 次查看
Arm7
In the i.MX6 SOLO is there a way to read the size of the chip DDR3 ?
2,608 次查看
Manuel_Salas
Hello!
You can do it in U-boot with the command bdinfo.
That command will show to you information about of the board, including the DRAM size.
Look for "size" under of DRAM bank section.
I hope this can help to you.
2,609 次查看
Manuel_Salas
Hello!
2,600 次查看
Arm7
Hello @Manuel_Salas, Thanks for your answer,
So, I have another questions, same topic:
Is there a way to automatically detect different types of DDR3 in SPL/u-boot ?
2,578 次查看
Manuel_Salas
Hello @Arm7 ,
Unfortunately, in U-boot that is not possible, but for IMX6 Solo the supported interfaces are 16/32-bit DDR3-800, and LV-DDR3-800.
Best regards!
