Custom IMX8MM board with DDR4 + Yocto
9,116件の閲覧回数
AlekseyM
Hi! I created a my custom IMX8MM board with DDR4. All DDR4 tests passed successfully in Configuration tools for IMX.
I am trying to make a u-boot for my board by Yocto. I take an IMX8MM_DDR4_EVK as starting point. But it is my first experience with Yocto.
Which files and where should I change or/and add to layers? It looks like I should change the Device Tree and config file for DDR4.
Can anyone give me a hint?
9,077件の閲覧回数
joanxie
pls download yocto bsp according to the enclosed file, you can find all of source code there
7 返答(返信)
9,097件の閲覧回数
joanxie
pls refer to the enclosed file
9,088件の閲覧回数
AlekseyM
The same question for 3.2.1 Changing the DCD table for i.MX DDR initialization
I try to find mx6q.cfg
Also, step 6 says, what I should change SPL. Where I can find a guide?
9,091件の閲覧回数
AlekseyM
Okay. When I do step 5:
Edit the machine configuration file with device trees listed in the KERNEL_DEVICETREE.
Below code from evk board:
KERNEL_DEVICETREE_BASENAME = "${MACHINE}"
KERNEL_DEVICETREE:append:use-nxp-bsp = " \
    freescale/${KERNEL_DEVICETREE_BASENAME}-revb.dtb \
    freescale/${KERNEL_DEVICETREE_BASENAME}-revb-rm67191.dtb \
    freescale/${KERNEL_DEVICETREE_BASENAME}-revb-rm67191-cmd-ram.dtb \
    freescale/${KERNEL_DEVICETREE_BASENAME}-revb-rm67199.dtb \
    freescale/${KERNEL_DEVICETREE_BASENAME}-revb-rm67199-cmd-ram.dtb \
Where I can find this files? Search in dir imx-yocto-bsp doesn't help
9,078件の閲覧回数
joanxie
9,067件の閲覧回数
AlekseyM
Thanks. What do I need to change the device tree? Do you have some guides for this or tools? Appnote AN5125 acceptable for IMX8MM?
9,057件の閲覧回数
joanxie
yes, this AN is available for imx8mm, what kind of DDR4 do you use?
8,878件の閲覧回数
AlekseyM
AS4C512M16D4-75BCN
