Custom Camera Interface Through CSI Parallel Port
1,773 次查看
prasadadireddy
We are using a camera in which sensor is interfaced with FPGA.
The FPGA out (8 bit digital data, Frame Signals , clock and I2C signals) are connected to the esomimx6-micro board through CSI parallel port(CN10), please suggest how to stream video from CSI parallel port and store it into sd card
标记 (1)
1,610 次查看
joanxie
what camera and detailed mode do you  use? like gated clock mode or bt565 8bit mode?
