Creating bootable SD for Linux on iMX28 EVM
4,233 次查看
dennisg
I am running the mk_mx28_sd as described in 5.1.3.1 of the users guide. I am able to determine my SD card is /dev/sdb via the method described. However after removing the card as instructed and running ./mk_mx28_sd /dev/sdb it does nothing (no prompting) and just returns immediately to the shell prompt.
I think I am missing something obvious but at a loss to see it right now. Any pointers would be appreciated.
TIA
标记 (1)
6 回复数
3,697 次查看
RogerioNunes
Hi Matt,
One more thing that helps is to support mmcblk.
I've fixed the script you shared to support this kind of device as well.
Pls find attached the new file.
Regards.
Rogerio Nunes.
Matt Clemens said:
The version in the attached should work. We're working on getting this updated on the main MX28 pages on freescale.com.
3,697 次查看
dennisg
I prefer chmod 755 ;-)
3,697 次查看
iMxGuy
chmod +x mk_mx28_sd
3,697 次查看
dennisg
Thanks much !
3,696 次查看
mdc
3,696 次查看
daiane_angolini
