using battery on QSB
PaulMcGregor
I am planing on connecting a battery the the QSB and want to know what configurations have worked for other. Also dose anyone know if the LVSD display port stays powered on battery?
SrikanthKotagir
Hi Paul,
   I haven't tried using a battery with QSB. When i was researching about using a backup battery for time, I found that the PMIC da9053-30 used on the QSB does not support battery charging.
  You may want to confirm this.
Srikanth
