bsp:real-time-edge-3.1.0.xml
The /etc/net-debug.sh file is executed regularly in /etc/crontab, but now this script doesn't run. What is the reason?
解決済! 解決策の投稿を見る。
Common Reasons for a Failed Cron Job
chmod +x /path/to/your/script.sh.PATH. Commands within the script may not be found.
ls, use /bin/ls).user field is missing in the /etc/crontab file, which requires a user name before the command.
* * * * * /path/to/your/script.sh >> /var/log/your_script.log 2>&1
ls -l /path/to/your/script.sh to verify the script has execute (x) permissions. If not, run chmod +x /path/to/your/script.sh./bin/grep instead of grep).PATH and other necessary variables at the top of your cron entry or script to define the environment./etc/crontab and ensure there is a new line character after the last command in your entry./etc/crontab, ensure the user field is present (e.g., root).cron.d: For root-owned jobs, consider placing them in /etc/cron.d/ instead of directly editing /etc/crontab for better organizationRegards
