Content in imx93 timer is not executed.
xiang_1001
bsp:real-time-edge-3.1.0.xml
The /etc/net-debug.sh file is executed regularly in /etc/crontab, but now this script doesn't run. What is the reason?
Bio_TICFSL
Common Reasons for a Failed Cron Job
  • Permissions: The script lacks execute permissions. You need to make the script executable using chmod +x /path/to/your/script.sh.
  • Path Environment Variable: Cron runs scripts in a minimal environment with a restricted PATH. Commands within the script may not be found.
  • Missing or Incorrect Paths:
    • The crontab entry itself might use relative paths, which is problematic for cron.
    • The script might not specify the full path to commands it calls (e.g., instead of ls, use /bin/ls).
  • Crontab Syntax Errors:
    • There must be a newline character after the last command in the crontab file.
    • The user field is missing in the /etc/crontab file, which requires a user name before the command.
  •   Issues:
    • The script may rely on environment variables that are not set in the minimal cron environment.
    • Scripts containing non-text characters can cause failures
Troubleshooting Steps
  1. Log Script Output: Redirect the script's output to a log file to see any error messages.
    bash
  • * * * * * /path/to/your/script.sh >> /var/log/your_script.log 2>&1
  • Check Permissions: Use ls -l /path/to/your/script.sh to verify the script has execute (x) permissions. If not, run chmod +x /path/to/your/script.sh.
  • Use Full Paths: In your script, replace relative path commands with their full paths (e.g., /bin/grep instead of grep).
  • Set Environment Variables: Add PATH and other necessary variables at the top of your cron entry or script to define the environment.
  • Check for Newline: Open /etc/crontab and ensure there is a new line character after the last command in your entry.
  • Verify User Field: For /etc/crontab, ensure the user field is present (e.g., root).
  • Use cron.d: For root-owned jobs, consider placing them in /etc/cron.d/ instead of directly editing /etc/crontab for better organization
Bio_TICFSL
  •   Issues:
    bash
xiang_1001
I can use the timing function by putting the crontab file into the /etc/cron.d/ file.
%3CLINGO-SUB%20id%3D%22lingo-sub-2177861%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EContent%20in%20imx93%20timer%20is%20not%20executed.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2177861%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ebsp%EF%BC%9Areal-time-edge-3.1.0.xml%3C%2FP%3E%3CP%3EThe%20%2Fetc%2Fnet-debug.sh%20file%20is%20executed%20regularly%20in%20%2Fetc%2Fcrontab%2C%20but%20now%20this%20script%20doesn't%20run.%20What%20is%20the%20reason%3F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22xiang_1001_0-1759204650814.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xiang_1001_0-1759204650814.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F358985i98A632736428BB9A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22xiang_1001_0-1759204650814.png%22%20alt%3D%22xiang_1001_0-1759204650814.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2183402%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Content%20in%20imx93%20timer%20is%20not%20executed.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183402%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EI%20can%20use%20the%20timing%20function%20by%20putting%20the%20crontab%20file%20into%20the%20%2Fetc%2Fcron.d%2F%20file.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2178264%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Content%20in%20imx93%20timer%20is%20not%20executed.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2178264%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3ECommon%20Reasons%20for%20a%20Failed%20Cron%20Job%3C%2FP%3E%0A%3CDIV%20class%3D%22Y3BBE%22%20data-hveid%3D%22CAIQAA%22%20data-processed%3D%22true%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%20data-hveid%3D%22CAMQAA%22%20data-processed%3D%22true%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-processed%3D%22true%22%3EPermissions%3CSTRONG%20class%3D%22Yjhzub%22%20data-processed%3D%22true%22%3E%3A%3C%2FSTRONG%3E%20The%20script%20lacks%20execute%20permissions.%20You%20need%20to%20make%20the%20script%20executable%20using%20%3CCODE%20class%3D%22o8j0Mc%22%20data-processed%3D%22true%22%3Echmod%20%2Bx%20%2Fpath%2Fto%2Fyour%2Fscript.sh%3C%2FCODE%3E.%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20data-hveid%3D%22CAMQAQ%22%20data-processed%3D%22true%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-processed%3D%22true%22%3EPath%20Environment%20Variable%3A%20Cron%20runs%20scripts%20in%20a%20minimal%20environment%20with%20a%20restricted%20%3CSPAN%20data-processed%3D%22true%22%3E%3CCODE%20class%3D%22o8j0Mc%22%20data-processed%3D%22true%22%3EPATH%3C%2FCODE%3E%3C%2FSPAN%3E%3CSPAN%20data-processed%3D%22true%22%3E.%20Commands%20within%20the%20script%20may%20not%20be%20found.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%20data-hveid%3D%22CAMQAg%22%20data-processed%3D%22true%22%3E%3CSPAN%20class%3D%22T286Pc%22%3EMissing%20or%20Incorrect%20Paths%3A%3C%2FSPAN%3E%0A%3CUL%20class%3D%22U6u95%22%3E%0A%3CLI%20data-hveid%3D%22CAMQAw%22%3E%3CSPAN%20class%3D%22T286Pc%22%3EThe%20crontab%20entry%20itself%20might%20use%20relative%20paths%2C%20which%20is%20problematic%20for%20cron.%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20data-hveid%3D%22CAMQBA%22%3E%3CSPAN%20class%3D%22T286Pc%22%3EThe%20script%20might%20not%20specify%20the%20full%20path%20to%20commands%20it%20calls%20(e.g.%2C%20instead%20of%20%3CCODE%20class%3D%22o8j0Mc%22%3Els%3C%2FCODE%3E%2C%20use%20%3CCODE%20class%3D%22o8j0Mc%22%3E%2Fbin%2Fls%3C%2FCODE%3E).%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CUL%3E%0A%3CLI%20data-hveid%3D%22CAMQBQ%22%20data-processed%3D%22true%22%3E%3CSPAN%20class%3D%22T286Pc%22%3ECrontab%20Syntax%20Errors%3A%3C%2FSPAN%3E%0A%3CUL%20class%3D%22U6u95%22%3E%0A%3CLI%20data-hveid%3D%22CAMQBg%22%3E%3CSPAN%20class%3D%22T286Pc%22%3EThere%20must%20be%20a%20newline%20character%20after%20the%20last%20command%20in%20the%20crontab%20file.%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20data-hveid%3D%22CAMQBw%22%3E%3CSPAN%20class%3D%22T286Pc%22%3EThe%20%3CCODE%20class%3D%22o8j0Mc%22%3Euser%3C%2FCODE%3E%20field%20is%20missing%20in%20the%20%3CCODE%20class%3D%22o8j0Mc%22%3E%2Fetc%2Fcrontab%3C%2FCODE%3E%20file%2C%20which%20requires%20a%20user%20name%20before%20the%20command.%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CUL%3E%0A%3CLI%20data-hveid%3D%22CAMQCA%22%20data-processed%3D%22true%22%3E%3CSPAN%20class%3D%22T286Pc%22%3E%3CSTRONG%20class%3D%22Yjhzub%22%3E%26nbsp%3B%26nbsp%3BIssues%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%0A%3CUL%20class%3D%22U6u95%22%3E%0A%3CLI%20data-hveid%3D%22CAMQCg%22%3E%3CSPAN%20class%3D%22T286Pc%22%3EThe%20script%20may%20rely%20on%20environment%20variables%20that%20are%20not%20set%20in%20the%20minimal%20cron%20environment.%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20data-hveid%3D%22CAMQCw%22%3E%3CSPAN%20class%3D%22T286Pc%22%3EScripts%20containing%20non-text%20characters%20can%20cause%20failures%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CDIV%20class%3D%22Y3BBE%22%20data-hveid%3D%22CAQQAA%22%20data-processed%3D%22true%22%3E%3CSTRONG%20class%3D%22Yjhzub%22%3ETroubleshooting%20Steps%3C%2FSTRONG%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22Y3BBE%22%20data-hveid%3D%22CAQQAA%22%20data-processed%3D%22true%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3COL%20class%3D%22VimKh%22%20data-processed%3D%22true%22%3E%0A%3CLI%20data-hveid%3D%22CAcQAA%22%3E%3CSPAN%20class%3D%22T286Pc%22%3ELog%20Script%20Output%3CSTRONG%20class%3D%22Yjhzub%22%3E%3A%3C%2FSTRONG%3E%20Redirect%20the%20script's%20output%20to%20a%20log%20file%20to%20see%20any%20error%20messages.%3C%2FSPAN%3E%0A%3CDIV%20class%3D%22r1PmQe%22%20data-wiz-uids%3D%22GKze5d_4e%2CGKze5d_4f%2CGKze5d_4g%22%20data-hveid%3D%22CAcQAQ%22%3E%0A%3CDIV%3E%0A%3CDIV%20class%3D%22pHpOfb%22%20data-animation-atomic%3D%22%22%3E%0A%3CDIV%20class%3D%22vVRw1d%22%3Ebash%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%3CLI-WRAPPER%3E%3C%2FLI-WRAPPER%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%20data-hveid%3D%22CAcQAA%22%3E%0A%3CDIV%20class%3D%22r1PmQe%22%20data-wiz-uids%3D%22GKze5d_4e%2CGKze5d_4f%2CGKze5d_4g%22%20data-hveid%3D%22CAcQAQ%22%3E%0A%3CDIV%3E%0A%3CDIV%20class%3D%22pHpOfb%22%20data-animation-atomic%3D%22%22%3E%0A%3CDIV%20class%3D%22pCTyYe%22%3E%0A%3CPRE%3E%3CCODE%3E%3CSPAN%20class%3D%22undefined%22%3E*%20*%20*%20*%20*%20%2Fpath%2Fto%2Fyour%2Fscript.sh%20%26gt%3B%26gt%3B%20%2Fvar%2Flog%2Fyour_script.log%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22tnfcCf%22%3E2%3C%2FSPAN%3E%3CSPAN%20class%3D%22undefined%22%3E%26gt%3B%26amp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22tnfcCf%22%3E1%3C%2FSPAN%3E%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FLI%3E%0A%3CLI%20data-hveid%3D%22CAcQAw%22%3E%3CSPAN%20class%3D%22T286Pc%22%3ECheck%20Permissions%3A%20Use%20%3CCODE%20class%3D%22o8j0Mc%22%3Els%20-l%20%2Fpath%2Fto%2Fyour%2Fscript.sh%3C%2FCODE%3E%20to%20verify%20the%20script%20has%20execute%20(%3CCODE%20class%3D%22o8j0Mc%22%3Ex%3C%2FCODE%3E)%20permissions.%20If%20not%2C%20run%20%3CCODE%20class%3D%22o8j0Mc%22%3Echmod%20%2Bx%20%2Fpath%2Fto%2Fyour%2Fscript.sh%3C%2FCODE%3E.%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20data-hveid%3D%22CAcQBA%22%3E%3CSPAN%20class%3D%22T286Pc%22%3EUse%20Full%20Paths%3A%20In%20your%20script%2C%20replace%20relative%20path%20commands%20with%20their%20full%20paths%20(e.g.%2C%20%3CCODE%20class%3D%22o8j0Mc%22%3E%2Fbin%2Fgrep%3C%2FCODE%3E%20instead%20of%20%3CCODE%20class%3D%22o8j0Mc%22%3Egrep%3C%2FCODE%3E).%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20data-hveid%3D%22CAcQBQ%22%3E%3CSPAN%20class%3D%22T286Pc%22%3ESet%20Environment%20Variables%3A%20Add%20%3CCODE%20class%3D%22o8j0Mc%22%3EPATH%3C%2FCODE%3E%20and%20other%20necessary%20variables%20at%20the%20top%20of%20your%20cron%20entry%20or%20script%20to%20define%20the%20environment.%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20data-hveid%3D%22CAcQBg%22%3E%3CSPAN%20class%3D%22T286Pc%22%3ECheck%20for%20Newline%3CSTRONG%20class%3D%22Yjhzub%22%3E%3A%3C%2FSTRONG%3E%20Open%20%3CCODE%20class%3D%22o8j0Mc%22%3E%2Fetc%2Fcrontab%3C%2FCODE%3E%20and%20ensure%20there%20is%20a%20new%20line%20character%20after%20the%20last%20command%20in%20your%20entry.%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20data-hveid%3D%22CAcQBw%22%3E%3CSPAN%20class%3D%22T286Pc%22%3EVerify%20User%20Field%3CSTRONG%20class%3D%22Yjhzub%22%3E%3A%3C%2FSTRONG%3E%20For%20%3CCODE%20class%3D%22o8j0Mc%22%3E%2Fetc%2Fcrontab%3C%2FCODE%3E%2C%20ensure%20the%20user%20field%20is%20present%20(e.g.%2C%20%3CCODE%20class%3D%22o8j0Mc%22%3Eroot%3C%2FCODE%3E).%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20data-hveid%3D%22CAcQCA%22%3E%3CSPAN%20class%3D%22T286Pc%22%3EUse%20%3CSTRONG%20class%3D%22Yjhzub%22%3E%3CCODE%20class%3D%22o8j0Mc%22%3Ecron.d%3C%2FCODE%3E%3A%3C%2FSTRONG%3E%20For%20root-owned%20jobs%2C%20consider%20placing%20them%20in%20%3CCODE%20class%3D%22o8j0Mc%22%3E%2Fetc%2Fcron.d%2F%3C%2FCODE%3E%20instead%20of%20directly%20editing%20%3CCODE%20class%3D%22o8j0Mc%22%3E%2Fetc%2Fcrontab%3C%2FCODE%3E%20for%20better%20organization%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%20class%3D%22T286Pc%22%3ERegards%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
