bsp:real-time-edge-3.1.0.xml
The /etc/net-debug.sh file is executed regularly in /etc/crontab, but now this script doesn't run. What is the reason?
Solved! Go to Solution.
Common Reasons for a Failed Cron Job
chmod +x /path/to/your/script.sh
.PATH
. Commands within the script may not be found.
ls
, use /bin/ls
).user
field is missing in the /etc/crontab
file, which requires a user name before the command.
* * * * * /path/to/your/script.sh >> /var/log/your_script.log 2>&1
ls -l /path/to/your/script.sh
to verify the script has execute (x
) permissions. If not, run chmod +x /path/to/your/script.sh
./bin/grep
instead of grep
).PATH
and other necessary variables at the top of your cron entry or script to define the environment./etc/crontab
and ensure there is a new line character after the last command in your entry./etc/crontab
, ensure the user field is present (e.g., root
).cron.d
: For root-owned jobs, consider placing them in /etc/cron.d/
instead of directly editing /etc/crontab
for better organizationRegards
.PATH
ls
, use /bin/ls
).user
./bin/grep
instead of grep
).PATH
).cron.d
