Config Tool
Config Tool
vlintilhac
I'm using a IMX6SLL processor for a custom board and I'm trying to initialize the DDR3. I wanted to use the Config tool for that part but this processor is not supported by the tool yet.
Do you know when this feature will be implemented? And what can I use to customize the imximage.cfg file?
Best,
Vincent
nxf63675
Hi vlintilhac,
As you mention, for the moment on the config tool there is no support on the DDR part, but you can use the RPA tool and the DDR tool, and the stress tool to get the .cfg file, please use the links below:
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/i-MX-6-7-DDR-Stress-Test-Tool/ta-p/11082...
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/i-MX-6-7-Series-DDR-Tool-Release/ta-p/12...
Hope this helps you.
Israel.
nxf63675
Hi vlintilhac,
Israel.
