Hi. I am using VMware for Ubuntu-14.04.3-desktop-amd64.iso
and I install L3.0.35_4.1.0_130816_source.tar.gz
I tried to patch and refer to Compile L3.0.35_4.1.0 on Ubuntu 13.10 64bit OS
But When i write $ git apply 0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.
There are Errors about patch Fail.
Help me Please
kyg@ubuntu:~/ltib$ git apply 0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.patch
0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.patch:106: trailing whitespace.
%patch1 -p1
0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.patch:144: trailing whitespace.
0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.patch:164: trailing whitespace.
0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.patch:166: trailing whitespace.
0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.patch:169: trailing whitespace.
error: patch failed: bin/Ltibutils.pm:359
error: bin/Ltibutils.pm: patch does not apply
error: patch failed: dist/lfs-5.1/base_libs/base_libs.spec:296
error: dist/lfs-5.1/base_libs/base_libs.spec: patch does not apply
error: patch failed: dist/lfs-5.1/m4/m4.spec:9
error: dist/lfs-5.1/m4/m4.spec: patch does not apply
error: patch failed: dist/lfs-5.1/ncurses/ncurses.spec:31
error: dist/lfs-5.1/ncurses/ncurses.spec: patch does not apply
error: patch failed: dist/lfs-5.1/openssl/openssl.spec:10
error: dist/lfs-5.1/openssl/openssl.spec: patch does not apply
error: patch failed: dist/lfs-5.1/xorg-server/xorg-server.spec:11
error: dist/lfs-5.1/xorg-server/xorg-server.spec: patch does not apply
error: pkgs/m4-1.4.16-1383761043.patch: already exists in working directory
error: pkgs/m4-1.4.16-1383761043.patch.md5: already exists in working directory
error: pkgs/openssl-1.0.1c-1398677566.patch: already exists in working directory
error: pkgs/openssl-1.0.1c-1398677566.patch.md5: already exists in working directory
error: pkgs/xorg-server-1.6.1-1398785267.patch: already exists in working directory
error: pkgs/xorg-server-1.6.1-1398785267.patch.md5: already exists in working directory
