Clock setting for MIPI-CSI
3,101 次查看
ko-hey
Senior Contributor II
Hi all
I have a question about clock selection when I use MIPI-CSI.
According to the 37.4.3.6.2 Non-Gated Mode in reference manual, there is a following comment.
When working with MIPI, the non-gated mode should be configured.
Does user set CLK_SEL field of CSI2IPU_SW_RST to "Non-Gated Mode” in above case ?
Ko-hey
2,738 次查看
joanxie
for clock settings, pls refer to the document as below:
https://community.nxp.com/docs/DOC-339925
2,640 次查看
dimitarmaznekov
Where is that document, link is unavaible?
