Hi team,
I am using the imx6-sabresd board with kernel 5.10.175 version and u-boot 2021-04 and vivante GPU version imx-gpu-viv6.4.3 version.
I am running the Qt6 application in the board and wanted to take observations about GPU usage by that Qt6 application.
How to check the GPU usage by the application or whether GPU is really being used by that application or not ? Any log file to where we can see and confirm about that usage.
Currently i am using the gmem_info script to test the GPU usage and getting below o/p.
gmem_info
Pid Total Reserved Contiguous Virtual Nonpaged Name
755 46,923,520 3,538,944 43,384,576 0 0 /usr/lib/xorg/Xorg
1 46,923,520 3,538,944 43,384,576 0 0 Summary
- - 130,678,784 - - - Available
GPU Idle time: 45.942692 ms
Here i am getting the Contiguous value getting incresese as we use more Qt6 applications. Is this the right way to confirm about the GPU usage ?
Please give a short explanation about GPU usage and its log files to debug.it will be really helpful for me to understand it better.
Rk
