Change Screen Resolution Dynamically in WEC7
ソリューションへジャンプ
3,579件の閲覧回数
akhil
Currently we are using a HVGA display with resolution 320x480. Is there any method to change the screen resolution dynamically (without reboot)? Is there any driver support for this in Wince 7? The processor used is imx53/imx6.
ラベル(4)
3,046件の閲覧回数
justin_jiang
Hi Akhil,
It depends on how many resolution your panel can support.
If you pannel only support 320*480, then it can't by change dynamically.
The panel settings is different for diffrent resolution.
B.R
Justin
4 返答(返信)
3,047件の閲覧回数
justin_jiang
Hi Akhil,
B.R
Justin
3,046件の閲覧回数
YixingKong
Senior Contributor IV
Akhil
Had your issue got resolved? If yes, we are going to close the discussion in 3 days. If you still need help, please feel free to reply with an update to this discussion.
Yixing
3,046件の閲覧回数
akhil
We still have the issue, as there is no BSP support for dynamic display resolution changing.
3,046件の閲覧回数
YixingKong
Akhil
I will branch your discussion into an internal group and assign an engineer to work on it.
Yixing
