Card init failed
Card init failed
1,753 次查看
RichardHuang88
Dear NXP,
I just want to test my MIMXRT595-EVK.
However, I tried all the SD Card examples and the result was: card init failed.
I have confirmed that my SD Card is ok, it can be read and written on other platforms.
I don't know where the problem is, please help me. Thanks
1,733 次查看
jeremyzhou
Before answering your question, I'd like to know whether you already
populated the R691~R697, meanwhile removed R611~R620, R660, R661 on the EVK-MIMXRT595 board.
TIC
1,734 次查看
jeremyzhou
TIC
