Capture 16-bit YUV image data
3,760件の閲覧回数
khang_letruong
Senior Contributor III
Dear Community,
I would like to know if it is possible to use the iMX6Q (or some alternative) for capturing the 16-bit YUV data output from the THC63LVD1024 converter which converts LVDS signal from the Sony FCB-EV9520L camera.
I saw similar questions but without solutions, however :
https://community.nxp.com/t5/i-MX-Processors/Could-not-configure-CSI0-bt-1120-on-i-MX6Q/m-p/750813
https://community.nxp.com/t5/i-MX-Processors/imx6q-ipu2-csi-2-16-bit-yuv-video/m-p/898111
Thanks in advance and best regards,
Khang
8 返答(返信)
3,714件の閲覧回数
joanxie
pls check your mail
3,677件の閲覧回数
khang_letruong
Hi @joanxie,
Please check your private message inbox!
Khang
3,651件の閲覧回数
joanxie
what image do you need for capture? BT1120 interlaced?
3,632件の閲覧回数
khang_letruong
Hi @joanxie,
Attached is the video output of the camera :
3,630件の閲覧回数
joanxie
if you connect THC63LVD1024 to imx6q, I need to know what output format you use? is it BT1120?
3,608件の閲覧回数
khang_letruong
Hi @joanxie,
According to the attached picture, it is 16-bit YCbCr.
Khang
3,555件の閲覧回数
joanxie
do you mind sharing more detailed information? the link you attach is about BT1120, if you just use yuv 16bits, imx6q can support it, and how you connect your camera? mipi csi port or parallel port?
3,524件の閲覧回数
khang_letruong
Hi @joanxie,
The camera manufacturer confirmed that its output is compliant with BT709 :
And we plan to connect the camera to the iMX6Q via the THC63LVD1024 to convert LVDS signals to LVCMOS parallel.
Khang
