CSI2 Bridge Driver for IMX8MM on Linux Kernel V6.6
424 次查看
alexval1323
I am trying to implement a (any) CSI2 driver on the IMX8M Mini from Compulab and have been having issues getting the Media Pipeline setup correctly. Looking over the imx8mm.dtsi i see the bridge is supported by the following drivers.
compatible = "fsl,imx8mm-csi", "fsl,imx8mq-csi", "fsl,imx6s-csi";
When i search through the kernel sources for "fsl,imx8mm-csi" nothing returns. Seems as if this driver doesn't exist in the 6.6 kernel as the grep command only comes up with a few dtsi files.
When I boot, i see that the imx7-csi driver (compatible="fsl,imx8mq") tries to probe the bridge but fails due to "mclk" not being defined although by default it is in the imx8mm.dtsi.
Kernel continues to the imx6s-csi driver where it claims the bridge is initializing but then never returns anything seeming as if it hung somewhere.
At this point I have no /dev/media0 node and when my camera driver binds correctly, I am still unable to load get any frames to user space. What is the correct setup for this that will allow the entire bridge to probe correctly?
348 次查看
pengyong_zhang
Hi @alexval1323
Please share your dts file. and the boot log file.
B.R
392 次查看
pengyong_zhang
Hi @alexval1323
what is your camera? please share me your boot full log file.
B.R
379 次查看
alexval1323
I am trying to set up two different cameras and have the same issue with both.
A) I am using an SiOnyx XQE-1350, it is as SCC complaint device so I have been working with the scc-generic drivers (Written for kernel v5.10, and I have ported to v6.6) - still need to finish implementation on this.
B) Using the Allied Vision 1500 C501-c camera with their supplied Alvium Drivers (written for kernel v5.15 and i have ported to v6.6)
Because the SiOnyx drivers are still being worked on I have attached the boot log with the DT using the Alvium Drivers. Note the camera is not plugged at boot time thus the driver does not load but I want the media pipeline initialize correctly.
Thank you.
%3CLINGO-SUB%20id%3D%22lingo-sub-2147112%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELinux%20%E5%86%85%E6%A0%B8%20V6.6%20%E4%B8%8A%20IMX8MM%20%E7%9A%84%20CSI2%20%E6%A1%A5%E6%8E%A5%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2147112%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E8%AF%95%E5%9B%BE%3CSPAN%3E%E5%9C%A8%20Compulab%20%E7%9A%84%20IMX8M%20Mini%20%E4%B8%8A%3C%2FSPAN%3E%E5%AE%9E%E7%8E%B0%EF%BC%88%E4%BB%BB%E4%BD%95%EF%BC%89CSI2%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E4%BD%86%E5%9C%A8%E6%AD%A3%E7%A1%AE%E8%AE%BE%E7%BD%AE%E5%AA%92%E4%BD%93%E7%AE%A1%E9%81%93%E6%96%B9%E9%9D%A2%E9%81%87%E5%88%B0%E4%BA%86%E9%97%AE%E9%A2%98%E3%80%82%E9%80%9A%E8%BF%87%E6%9F%A5%E7%9C%8B%20imx8mm.dtsi%EF%BC%8C%E6%88%91%E5%8F%91%E7%8E%B0%E6%A1%A5%E6%8E%A5%E5%99%A8%E7%94%B1%E4%BB%A5%E4%B8%8B%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSPAN%3E%E5%85%BC%E5%AE%B9%20%3D%22FSL%2CIMX8MM-CSI%22%2C%22FSL%2CIMX8MQ-CSI%22%2C%22FSL%2CIMX6S-CSI%22%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E5%BD%93%E6%88%91%E5%9C%A8%E5%86%85%E6%A0%B8%E6%BA%90%E4%BB%A3%E7%A0%81%E4%B8%AD%E6%90%9C%E7%B4%A2%22fsl%2Cimx8mm-csi%22%20%E6%97%B6%EF%BC%8C%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E7%BB%93%E6%9E%9C%E3%80%82%E4%BC%BC%E4%B9%8E%206.6%20%E5%86%85%E6%A0%B8%E4%B8%AD%E4%B8%8D%E5%AD%98%E5%9C%A8%E8%BF%99%E4%B8%AA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%9B%A0%E4%B8%BA%20grep%20%E5%91%BD%E4%BB%A4%E5%8F%AA%E6%98%BE%E7%A4%BA%E4%BA%86%E5%87%A0%E4%B8%AA%20dtsi%20%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E5%90%AF%E5%8A%A8%E6%97%B6%EF%BC%8C%E6%88%91%E7%9C%8B%E5%88%B0%20imx7-csi%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%88compatible%3D%20%22%20fsl%EF%BC%8Cimx8mq%20%22%EF%BC%89%E5%B0%9D%E8%AF%95%E6%8E%A2%E6%B5%8B%E7%BD%91%E6%A1%A5%EF%BC%8C%E4%BD%86%E7%94%B1%E4%BA%8E%E6%9C%AA%E5%AE%9A%E4%B9%89%20%22%20mclk%20%22%20%E8%80%8C%E5%A4%B1%E8%B4%A5%EF%BC%8C%E5%B0%BD%E7%AE%A1%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%E5%AE%83%E4%BD%8D%E4%BA%8E%20imx8mm.dtsi%20%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%E5%86%85%E6%A0%B8%E7%BB%A7%E7%BB%AD%E8%BF%90%E8%A1%8C%20imx6s-csi%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%AE%83%E5%A3%B0%E7%A7%B0%E7%BD%91%E6%A1%A5%E6%AD%A3%E5%9C%A8%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%8C%E4%BD%86%E5%8D%B4%E6%B2%A1%E6%9C%89%E8%BF%94%E5%9B%9E%E4%BB%BB%E4%BD%95%E4%BF%A1%E6%81%AF%EF%BC%8C%E5%A5%BD%E5%83%8F%E5%9C%A8%E4%BB%80%E4%B9%88%E5%9C%B0%E6%96%B9%E6%8C%82%E8%B5%B7%E4%BA%86%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%AD%A4%E6%97%B6%EF%BC%8C%E6%88%91%E6%B2%A1%E6%9C%89%20%2Fdev%2Fmedia0%20%E8%8A%82%E7%82%B9%EF%BC%8C%E5%BD%93%E6%88%91%E7%9A%84%E6%91%84%E5%83%8F%E5%A4%B4%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%BB%91%E5%AE%9A%E6%AD%A3%E7%A1%AE%E6%97%B6%EF%BC%8C%E6%88%91%E4%BB%8D%E7%84%B6%E6%97%A0%E6%B3%95%E5%90%91%E7%94%A8%E6%88%B7%E7%A9%BA%E9%97%B4%E5%8A%A0%E8%BD%BD%E4%BB%BB%E4%BD%95%E5%B8%A7%E3%80%82%E5%A6%82%E4%BD%95%E6%AD%A3%E7%A1%AE%E8%AE%BE%E7%BD%AE%E6%89%8D%E8%83%BD%E8%AE%A9%E6%95%B4%E5%BA%A7%E6%A1%A5%E6%AD%A3%E7%A1%AE%E6%8E%A2%E6%B5%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2152111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CSI2%20Bridge%20Driver%20for%20IMX8MM%20on%20Linux%20Kernel%20V6.6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2152111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253111%22%20target%3D%22_blank%22%3E%40alexval1323%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%85%B1%E4%BA%AB%E6%82%A8%E7%9A%84%20dts%20%E6%96%87%E4%BB%B6%E3%80%82%E5%92%8C%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CSI2%20Bridge%20Driver%20for%20IMX8MM%20on%20Linux%20Kernel%20V6.6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%AE%89%E8%A3%85%E4%B8%A4%E5%8F%B0%E4%B8%8D%E5%90%8C%E7%9A%84%E6%91%84%E5%83%8F%E6%9C%BA%EF%BC%8C%E4%BD%86%E4%B8%A4%E8%80%85%E9%83%BD%E6%9C%89%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E7%AD%94)%20%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20SionyX%20XQE-1350%EF%BC%8C%E5%AE%83%E6%98%AF%20SCC%20%E6%8A%95%E8%AF%89%E8%AE%BE%E5%A4%87%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E4%B8%80%E7%9B%B4%E5%9C%A8%E4%BD%BF%E7%94%A8%20scc%20%E9%80%9A%E7%94%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%88%E4%B8%BA%E5%86%85%E6%A0%B8%20v5.10%20%E7%BC%96%E5%86%99%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E7%A7%BB%E6%A4%8D%E5%88%B0%20v6.6%EF%BC%89%E2%80%94%E2%80%94%E8%BF%98%E9%9C%80%E8%A6%81%E5%AE%8C%E6%88%90%E8%BF%99%E4%B8%AA%E7%9A%84%E5%AE%9E%E7%8E%B0%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3EB)%20%E4%BD%BF%E7%94%A8%20Allied%20Vision%201500%20C501-c%20%E6%91%84%E5%83%8F%E5%A4%B4%E5%8F%8A%E5%85%B6%E6%8F%90%E4%BE%9B%E7%9A%84%20Alvium%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%88%E4%B8%BA%E5%86%85%E6%A0%B8%205.15%20%E7%89%88%E7%BC%96%E5%86%99%EF%BC%8C%E6%88%91%E5%B7%B2%E5%B0%86%E5%85%B6%E7%A7%BB%E6%A4%8D%E5%88%B0%206.6%20%E7%89%88%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E7%94%B1%E4%BA%8E%20SionyX%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%BB%8D%E5%9C%A8%E5%BC%80%E5%8F%91%E4%B8%AD%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E4%BD%BF%E7%94%A8%20Alvium%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B0%86%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%E9%99%84%E5%9C%A8%20DT%20%E4%B8%8A%E3%80%82%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E6%91%84%E5%83%8F%E6%9C%BA%E5%9C%A8%E5%90%AF%E5%8A%A8%E6%97%B6%E6%9C%AA%E6%8F%92%E5%85%A5%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%97%A0%E6%B3%95%E5%8A%A0%E8%BD%BD%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E4%BD%86%E6%88%91%E5%B8%8C%E6%9C%9B%E5%AA%92%E4%BD%93%E7%AE%A1%E9%81%93%E6%AD%A3%E7%A1%AE%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2148905%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CSI2%20Bridge%20Driver%20for%20IMX8MM%20on%20Linux%20Kernel%20V6.6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2148905%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253111%22%20target%3D%22_blank%22%3E%40alexval1323%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E7%9A%84%E7%9B%B8%E6%9C%BA%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%E8%AF%B7%E6%8A%8A%E4%BD%A0%E7%9A%84%E5%90%AF%E5%8A%A8%E5%AE%8C%E6%95%B4%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%E5%88%86%E4%BA%AB%E7%BB%99%E6%88%91%E3%80%82%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E
