CAAM and kernel crypto tests
11,541件の閲覧回数
EricNelson
Senior Contributor II
Hi all,
We're seeing some disconcerting error messages on various versions of Linux and various boards when enabling CAAM and
the kernel self-tests.
Testing on SABRE-SD with 3.10.31-alpha
root@imx6qsabresd:~# dmesg
alg: hash: Test 1 failed for hmac-sha1-caam
00000000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000010: f1 46 be 00
alg: hash: Test 1 failed for sha1-caam
00000010: 9c d0 d8 9d
alg: hash: Test 1 failed for hmac-sha224-caam
00000010: 47 b4 b1 16 99 12 ba 4f 53 68 4b 22
alg: hash: Test 1 failed for sha224-caam
00000010: 2a ad bc e4 bd a0 b3 f7 e3 6c 9d a7
root@imx6qsabresd:~# cat /proc/cmdline
console=ttymxc0,115200 ip=dhcp root=/dev/mmcblk0p2 rootwait caam
The kernel configuration is essentially the same as the stock v7_defconfig with a few additional debug flags:
~/linux-imx6$ make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- savedefconfig
scripts/kconfig/conf --savedefconfig=defconfig Kconfig
~/linux-imx6$ diff defconfig arch/arm/configs/imx_v7_defconfig
253a254
> CONFIG_USB_PHY=y
329d329
< CONFIG_DEBUG_LOCK_ALLOC=y
334d333
< # CONFIG_CRYPTO_MANAGER_DISABLE_TESTS is not set
We've seen the same results with kernel 3.0.35_4.1.0 and 3.10.17-1.0.0-ga on Nitrogen6x.
Does anyone have some insight about this?
Thanks in advance,
Eric
ラベル(2)
タグ(3)
9,522件の閲覧回数
EricNelson
Thanks to Steve Cornelius and others at Freescale, we've been able to show that this issue has to do with cache coherency.
In particular, the CAAM drivers expect all inputs and outputs to be aligned with on a cache line boundary (32 bytes on i.MX6).
Since the testmgr code was originally created to test software implementations, as of kernel 3.10.17, it didn't ensure any particular alignment, which caused the failures, and a simple update to address this prevents the errors:
         crypto testmgr: Align result buffer on cache-line · e3e7ad4 · boundarydevices/linux-imx6 · GitHub
As mentioned in the commit log, this requirement for inputs and outputs also exists in userspace code, so applications will need to take care in allocations.
14 返答(返信)
4,306件の閲覧回数
cryptolover
SecretCryptos is your one-stop solution for anonymous crypto transactions. Whether you're looking to use a crypto mixer or trade on a secure exchange, SecretCryptos ensures full privacy and anonymity for all your transactions.
SecretCryptos Crypto Mixer and Exchange
All Mixer Pages (per coin)
SecretCryptos Crypto Mixer | Bitcoin (BTC) Mixer | Ethereum (ETH) Mixer | Tether (USDT) Mixer | USD Coin (USDC) Mixer | BNB (BSC) Mixer | Litecoin (LTC) Mixer | Dogecoin (DOGE) Mixer | XRP (Ripple) Mixer | Solana (SOL) Mixer | TRON (TRX) Mixer | TON (Toncoin) Mixer | Polygon (MATIC) Mixer | Avalanche (AVAX) Mixer | Cardano (ADA) Mixer | Polkadot (DOT) Mixer | Shiba Inu (SHIB) Mixer
Instant Crypto Exchange
Crypto Exchange
62a314_66eab6e98f404d46a2d43c76933e6802~mv262a314_66eab6e98f404d46a2d43c76933e6802~mv2
9,523件の閲覧回数
EricNelson
9,522件の閲覧回数
jonnettleton
There are actually proper fixes to this problem in Herbert Xu's crypto-2.6 tree.  Specifically LKML: Herbert Xu: Crypto Fixes for 3.13 and LKML: Herbert Xu: Re: Crypto Fixes for 3.13 fix the problems.  They would need to be backported to 3.10.xx
9,522件の閲覧回数
EricNelson
Many thanks, Jon
9,522件の閲覧回数
EricNelson
Additional notes:
The values shown in the test failures:
  1. alg: hash: Test 1 failed for hmac-sha1-caam
  2. 00000000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  3. 00000010: f1 46 be 00
Appear to be similar to the expected results. This is the first test vector for hmac-sha1 in crypto/testmgr.c:
static struct hash_testvec hmac_sha1_tv_template[] = {
  .key = "\x0b\x0b\x0b\x0b\x0b\x0b\x0b\x0b\x0b\x0b\x0b\x0b\x0b\x0b\x0b\x0b\x0b\x0b\x0b\x0b",
  .ksize = 20,
  .plaintext = "Hi There",
  .psize = 8,
  .digest = "\xb6\x17\x31\x86\x55\x05\x72\x64"
   "\xe2\x8b\xc0\xb6\xfb\x37\x8c\x8e\xf1"
   "\x46\xbe",
Note that the sequence "f1 46 be" matches the expected value.
Also note that the first 16 bytes of each of the failed tests is showing as zero.
9,522件の閲覧回数
EricNelson
Yet more information regarding these tests...
A udelay(20) call at the end of caam_jr_enqueue() allows the tests to succeed, so it appears to be some form of timing bug.
~/linux-imx6$ git diff
diff --git a/drivers/crypto/caam/jr.c b/drivers/crypto/caam/jr.c
index 80ddddb..c8c4a7e 100644
--- a/drivers/crypto/caam/jr.c
+++ b/drivers/crypto/caam/jr.c
@@ -288,6 +288,7 @@ int caam_jr_enqueue(struct device *dev, u32 *desc,
        spin_unlock_bh(&jrp->inplock);
+       udelay(20);
        return 0;
EXPORT_SYMBOL(caam_jr_enqueue);
9,522件の閲覧回数
EricNelson
9,522件の閲覧回数
karina_valencia
NXP Apps Support
NXP Apps Support
jamesbone can you continue with the follow up on this case?
9,522件の閲覧回数
seungwonkim
Is this problem fixed?? or, solution is just delay???
I have the problem too. but, I need to change delay value up to 100usec for successful test.
It is big problem.
9,522件の閲覧回数
EricNelson
Not fixed yet.
9,522件の閲覧回数
karina_valencia
NXP Apps Support
NXP Apps Support
jamesbone do you have an update of this case?
9,522件の閲覧回数
EricNelson
Further update: In a subsequent boot on 3.10.17-1.0.0-ga, I'm seeing only 8 bytes of zeros:
00000000: 00 00 00 00 00 00 00 00 e2 8b c0 b6 fb 37 8c 8e
9,522件の閲覧回数
EricNelson
Hi Jaime,
I think you missed that we're testing against 3.0.35_4.1.0, 3.10.17-1.0.0-ga, and 3.10.31_1.0.0-alpha.
Each of them already contains the patches from the other page:
Patch to dma_map_sg_chained:
     http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/commit/?h=imx_3.0.35_4.0.0&id=b30237c790...
3.10.17 sources:
     https://github.com/boundarydevices/linux-imx6/blob/boundary-imx_3.10.17_1.0.0_ga/drivers/crypto/caam...
Patch to driver_algs:
     http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/commit/?h=imx_3.0.35_4.0.0&id=6068d7a77b...
3.10.17 sources:
I also wasn't clear that the problem we're seeing is only with the hash algorithms.
Eric
9,522件の閲覧回数
jamesbone
Dear Eric,
On linux 3.0.35 there is a need for some patches in order to get  proper functionality of CAAM
Q&amp;A: Why is CAAM Driver Not Functioning in Linux for iMX6?
Jaime
%3CLINGO-SUB%20id%3D%22lingo-sub-307488%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECAAM%E3%81%A8%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E6%9A%97%E5%8F%B7%E3%83%86%E3%82%B9%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-307488%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E7%9A%86%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELinux%E3%81%AE%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%84%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7CAAM%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E4%B8%8D%E5%AE%89%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E8%87%AA%E5%B7%B1%E3%83%86%E3%82%B9%E3%83%88%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESABRE-SD%203.10.31-alpha%20%E3%81%A7%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14013157025046584%20jive_text_macro%20jive_macro_code%22%20jivemacro_uid%3D%22_14013157025046584%22%20modifiedtitle%3D%22true%22%3E%0A%3CP%3Eroot%40imx6qsabresd%3A~%23%20dmesg%3C%2FP%3E%0A%3CP%3E...%3C%2FP%3E%0A%3CP%3Ealg%3A%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%3A%20hmac-sha1-caam%20%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%201%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%0A%3CP%3E00000000%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%3C%2FP%3E%0A%3CP%3E00000010%3A%20f1%2046%20%E3%81%AF%2000%20%E3%81%A7%E3%81%99%3C%2FP%3E%0A%3CP%3Ealg%3A%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%3A%20sha1-caam%20%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%201%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%0A%3CP%3E00000000%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%3C%2FP%3E%0A%3CP%3E00000010%3A%209c%20d0%20d8%209d%3C%2FP%3E%0A%3CP%3Ealg%3A%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%3A%20hmac-sha224-caam%20%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%201%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%0A%3CP%3E00000000%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%3C%2FP%3E%0A%3CP%3E00000010%3A%2047%20b4%20b1%2016%2099%2012%20ba%204f%2053%2068%204b%2022%3C%2FP%3E%0A%3CP%3Ealg%3A%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%3A%20sha224-caam%20%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%201%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%0A%3CP%3E00000000%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%3C%2FP%3E%0A%3CP%3E00000010%3A%202a%20ad%20bc%20e4%20bd%20a0%20b3%20f7%20e3%206c%209d%20a7%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3Eroot%40imx6qsabresd%3A~%23%20cat%20%2Fproc%2Fcmdline%3C%2FP%3E%0A%3CP%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%3Dttymxc0%2C115200%20ip%3Ddhcp%20%E3%83%AB%E3%83%BC%E3%83%88%3D%2Fdev%2Fmmcblk0p2%20rootwait%20caam%3C%2FP%3E%0A%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E6%A7%8B%E6%88%90%E3%81%AF%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%95%E3%83%A9%E3%82%B0%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%9F%E6%A8%99%E6%BA%96%E3%81%AE%20v7_defconfig%20%E3%81%A8%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AB%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_text_macro%20jive_macro_code%20_jivemacro_uid_14013158290519725%22%20jivemacro_uid%3D%22_14013158290519725%22%20modifiedtitle%3D%22true%22%3E%0A%3CP%3E~%2Flinux-imx6%24%20ARCH%3Darm%20CROSS_COMPILE%3Darm-linux-gnueabihf-%20savedefconfig%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CP%3E%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%2Fkconfig%2Fconf%20--savedefconfig%3Ddefconfig%20Kconfig%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E~%2Flinux-imx6%24%20diff%20defconfig%20arch%2Farm%2Fconfigs%2Fimx_v7_defconfig%3C%2FP%3E%0A%3CP%3E253a254%3C%2FP%3E%0A%3CP%3E%26gt%3B%20CONFIG_USB_PHY%3Dy%3C%2FP%3E%0A%3CP%3E329d329%3C%2FP%3E%0A%3CP%3E%26lt%3B%20CONFIG_DEBUG_LOCK_ALLOC%3Dy%3C%2FP%3E%0A%3CP%3E334d333%3C%2FP%3E%0A%3CP%3E%26lt%3B%20%23%20CONFIG_CRYPTO_MANAGER_DISABLE_TESTS%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%0A%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB3.0.35_4.1.0%E3%81%A7%E3%82%82%E5%90%8C%E3%81%98%E7%B5%90%E6%9E%9C%E3%81%8C%E5%87%BA%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8A%E3%82%88%E3%81%B3%20Nitrogen6x%20%E4%B8%8A%E3%81%AE%203.10.17-1.0.0-ga%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E4%BD%95%E3%81%8B%E7%9F%A5%E8%A6%8B%E3%82%92%E3%81%8A%E6%8C%81%E3%81%A1%E3%81%AE%E6%96%B9%E3%81%AF%E3%81%84%E3%82%89%E3%81%A3%E3%81%97%E3%82%83%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%AA%E3%83%83%E3%82%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-307488%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6_%E3%81%99%E3%81%B9%E3%81%A6%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2170575%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20and%20kernel%20crypto%20tests%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2170575%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESecretCryptos%20%E3%81%AF%E3%80%81%E5%8C%BF%E5%90%8D%E3%81%AE%E6%9A%97%E5%8F%B7%E5%8F%96%E5%BC%95%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E3%83%AF%E3%83%B3%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%20%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%99%E3%80%82%E6%9A%97%E5%8F%B7%E3%83%9F%E3%82%AD%E3%82%B5%E3%81%AE%E4%BD%BF%E7%94%A8%E3%82%84%E5%AE%89%E5%85%A8%E3%81%AA%E5%8F%96%E5%BC%95%E6%89%80%E3%81%A7%E3%81%AE%E5%8F%96%E5%BC%95%E3%82%92%E3%81%8A%E8%80%83%E3%81%88%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%A7%E3%82%82%E3%80%81SecretCryptos%20%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E5%8F%96%E5%BC%95%E3%81%AE%E5%AE%8C%E5%85%A8%E3%81%AA%E3%83%97%E3%83%A9%E3%82%A4%E3%83%90%E3%82%B7%E3%83%BC%E3%81%A8%E5%8C%BF%E5%90%8D%E6%80%A7%E3%82%92%E4%BF%9D%E8%A8%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3ESecretCryptos%20%E6%9A%97%E5%8F%B7%E3%83%9F%E3%82%AD%E3%82%B5%E3%81%A8%E5%8F%96%E5%BC%95%E6%89%80%3C%2FU%3E%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%9A%E3%83%BC%E3%82%B8%EF%BC%88%E3%82%B3%E3%82%A4%E3%83%B3%E3%81%82%E3%81%9F%E3%82%8A%EF%BC%89%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3ESecretCryptos%20%E6%9A%97%E5%8F%B7%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%3C%2FU%3E%3C%2FA%3E%7C%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Fbitcoin%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3E%E3%83%93%E3%83%83%E3%83%88%E3%82%B3%E3%82%A4%E3%83%B3%20(BTC)%20%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%3C%2FU%3E%3C%2FA%3E%7C%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Fethereum%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3E%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%AA%E3%82%A2%E3%83%A0%20(ETH)%20%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%3C%2FU%3E%3C%2FA%3E%7C%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Ftether%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3E%E3%83%86%E3%82%B6%E3%83%BC%20(USDT)%20%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%3C%2FU%3E%3C%2FA%3E%7C%20%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Fusdc%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3EUSD%20%E3%82%B3%E3%82%A4%E3%83%B3%20(USDC)%20%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%3C%2FU%3E%3C%2FA%3E%7C%20%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Fbnb%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3EBNB%20(BSC)%20%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%3C%2FU%3E%3C%2FA%3E%7C%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Flitecoin%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3E%E3%83%A9%E3%82%A4%E3%83%88%E3%82%B3%E3%82%A4%E3%83%B3%20(LTC)%20%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%3C%2FU%3E%3C%2FA%3E%7C%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Fdogecoin%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3E%E3%83%89%E3%83%BC%E3%82%B8%E3%82%B3%E3%82%A4%E3%83%B3%20(DOGE)%20%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%3C%2FU%3E%3C%2FA%3E%7C%20%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Fxrp%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3EXRP%20(%E3%83%AA%E3%83%83%E3%83%97%E3%83%AB)%20%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%3C%2FU%3E%3C%2FA%3E%7C%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Fsolana%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3E%E3%82%BD%E3%83%A9%E3%83%8A%20(SOL)%20%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%3C%2FU%3E%3C%2FA%3E%7C%20%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Ftron%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3ETRON%20(TRX)%20%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%3C%2FU%3E%3C%2FA%3E%7C%20%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Ftoncoin%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3ETON%20(%E3%83%88%E3%83%B3%E3%82%B3%E3%82%A4%E3%83%B3)%20%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%3C%2FU%3E%3C%2FA%3E%7C%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Fpolygon%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3E%E3%83%9D%E3%83%AA%E3%82%B4%E3%83%B3%20(MATIC)%20%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%3C%2FU%3E%3C%2FA%3E%7C%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Favalanche%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3E%E3%82%A2%E3%83%90%E3%83%A9%E3%83%B3%E3%83%81%20(AVAX)%20%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%3C%2FU%3E%3C%2FA%3E%7C%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Fcardano%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3E%E3%82%AB%E3%83%AB%E3%83%80%E3%83%8E%20(ADA)%20%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%3C%2FU%3E%3C%2FA%3E%7C%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Fpolkadot%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3E%E3%83%9D%E3%83%AB%E3%82%AB%E3%83%89%E3%83%83%E3%83%88%20(DOT)%20%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%3C%2FU%3E%3C%2FA%3E%7C%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fmixer%2Fshiba-inu%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3E%E6%9F%B4%E7%8A%AC%20(SHIB)%20%E3%83%9F%E3%82%AD%E3%82%B5%E3%83%BC%3C%2FU%3E%3C%2FA%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1975522908%22%20id%3D%22toc-hId-2001443962%22%3E%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%88%E6%9A%97%E5%8F%B7%E9%80%9A%E8%B2%A8%E5%8F%96%E5%BC%95%3C%2FH3%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2Fcrypto-exchange%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CU%3E%E6%9A%97%E5%8F%B7%E9%80%9A%E8%B2%A8%E5%8F%96%E5%BC%95%E6%89%80%3C%2FU%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20title%3D%22%E6%9A%97%E5%8F%B7%E3%83%9F%E3%82%AD%E3%82%B5%E3%81%A8%E5%8F%96%E5%BC%95%E6%89%80%22%20href%3D%22https%3A%2F%2Fsecretcryptos.com%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2262a314_66eab6e98f404d46a2d43c76933e6802~mv2%22%20style%3D%22width%3A%20761px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2262a314_66eab6e98f404d46a2d43c76933e6802~mv2%22%20style%3D%22width%3A%20761px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F357178iC6E0EBA8FB05CCD8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2262a314_66eab6e98f404d46a2d43c76933e6802~mv2%22%20alt%3D%2262a314_66eab6e98f404d46a2d43c76933e6802~mv2%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E62a314_66eab6e98f404d46a2d43c76933e6802~mv2%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-307501%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20and%20kernel%20crypto%20tests%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-307501%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-307500%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20and%20kernel%20crypto%20tests%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-307500%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E9%81%A9%E5%88%87%E3%81%AA%E4%BF%AE%E6%AD%A3%E3%81%AF%E3%80%81Herbert%20Xu%E3%81%AEcrypto-2.6%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E6%9C%A8%E3%80%82%E5%85%B7%E4%BD%93%E7%9A%84%E3%81%AB%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Flkml.org%2Flkml%2F2013%2F12%2F3%2F240%22%20title%3D%22https%3A%2F%2Flkml.org%2Flkml%2F2013%2F12%2F3%2F240%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ELKML%3A%20Herbert%20Xu%3A%20Crypto%20Fixes%20for%203.13%3C%2FA%3E%E3%81%8A%E3%82%88%E3%81%B3%3CA%20href%3D%22https%3A%2F%2Flkml.org%2Flkml%2F2013%2F12%2F9%2F314%22%20title%3D%22https%3A%2F%2Flkml.org%2Flkml%2F2013%2F12%2F9%2F314%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ELKML%3A%20Herbert%20Xu%3A%20Re%3A%20Crypto%20Fixes%20for%203.13%20%E3%81%A7%3C%2FA%3E%E5%95%8F%E9%A1%8C%E3%81%8C%E4%BF%AE%E6%AD%A3%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%823.10.xx%E3%81%AB%E3%83%90%E3%83%83%E3%82%AF%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-307499%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20and%20kernel%20crypto%20tests%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-307499%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EFreescale%20%E3%81%AE%20Steve%20Cornelius%20%E6%B0%8F%E3%81%A8%E4%BB%96%E3%81%AE%E4%BA%BA%E3%80%85%E3%81%AE%E3%81%8A%E3%81%8B%E3%81%92%E3%81%A7%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E4%B8%80%E8%B2%AB%E6%80%A7%E3%81%A8%E9%96%A2%E4%BF%82%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%89%B9%E3%81%AB%E3%80%81CAAM%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E5%85%A5%E5%8A%9B%E3%81%A8%E5%87%BA%E5%8A%9B%E3%81%8C%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%A9%E3%82%A4%E3%83%B3%E5%A2%83%E7%95%8C%20(i.MX6%20%E3%81%A7%E3%81%AF%2032%20%E3%83%90%E3%82%A4%E3%83%88)%20%E3%81%AB%E6%8F%83%E3%81%88%E3%82%89%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%83%B3%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Etestmgr%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E5%85%83%E3%80%85%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E5%AE%9F%E8%A3%85%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%203.10.17%20%E6%99%82%E7%82%B9%E3%81%A7%E3%81%AF%E7%89%B9%E5%AE%9A%E3%81%AE%E9%85%8D%E7%BD%AE%E3%81%8C%E4%BF%9D%E8%A8%BC%E3%81%95%E3%82%8C%E3%81%9A%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E9%9A%9C%E5%AE%B3%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%A8%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E7%B0%A1%E5%8D%98%E3%81%AA%E6%9B%B4%E6%96%B0%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E9%98%B2%E3%81%90%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fboundarydevices%2Flinux-imx6%2Fcommit%2Fe3e7ad4294491f44826780f691a063677f3c4932%22%20title%3D%22https%3A%2F%2Fgithub.com%2Fboundarydevices%2Flinux-imx6%2Fcommit%2Fe3e7ad4294491f44826780f691a063677f3c4932%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ecrypto%20testmgr%3A%20%E7%B5%90%E6%9E%9C%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%82%8B%20%C2%B7%20e3e7ad4%20%C2%B7%20boundarydevices%2Flinux-imx6%20%C2%B7%20GitHub%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%20%E3%83%AD%E3%82%B0%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E5%85%A5%E5%8A%9B%E3%81%A8%E5%87%BA%E5%8A%9B%E3%81%AE%E3%81%93%E3%81%AE%E8%A6%81%E4%BB%B6%E3%81%AF%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E7%A9%BA%E9%96%93%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E3%82%82%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-307498%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20and%20kernel%20crypto%20tests%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-307498%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20_jive_internal%3D%22true%22%20class%3D%22jiveTT-hover-user%20jive-link-profile-small%22%20data-containerid%3D%22-1%22%20data-containertype%3D%22-1%22%20data-content-finding%3D%22Community%22%20data-objectid%3D%2214228%22%20data-objecttype%3D%223%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fjamesbone%22%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%236a737b%3B%20text-decoration%3A%20underline%3B%22%20target%3D%22_blank%22%3Ejamesbone%E3%81%95%E3%82%93%E3%80%81%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E3%81%93%E3%81%AECASE%E3%81%AE%E6%9C%80%E6%96%B0%E6%83%85%E5%A0%B1%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-307497%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20and%20kernel%20crypto%20tests%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-307497%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%BE%E3%81%A0%E4%BF%AE%E6%AD%A3%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-307496%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20and%20kernel%20crypto%20tests%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-307496%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E4%BF%AE%E6%AD%A3%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%20%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%81%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E3%81%9F%E3%81%A0%E9%81%85%E5%BB%B6%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E7%A7%81%E3%82%82%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%82%92%E6%8A%B1%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E6%88%90%E5%8A%9F%E3%81%95%E3%81%9B%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E9%81%85%E5%BB%B6%E5%80%A4%E3%82%92%E6%9C%80%E5%A4%A7%20100usec%20%E3%81%BE%E3%81%A7%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%AF%E5%A4%A7%E3%81%8D%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-307495%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20and%20kernel%20crypto%20tests%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-307495%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fjamesbone%22%20target%3D%22_blank%22%3Ejamesbone%E3%81%95%E3%82%93%E3%80%81%3C%2FA%3E%E3%81%93%E3%81%AECASE%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E7%B6%9A%E3%81%91%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-307494%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Re%3A%20CAAM%20and%20kernel%20crypto%20tests%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-307494%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%95%E3%82%89%E3%81%AB%E8%A9%B3%E3%81%97%E3%81%8F%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23990000%3B%20font-family%3A%20Consolas%2C%20'Liberation%20Mono'%2C%20Courier%2C%20monospace%3B%20font-size%3A%2012px%3B%20font-weight%3A%20bold%3B%22%3Ecaam_jr_dequeue%3C%2FSPAN%3E%20()%20%E3%81%AE%E6%AC%A1%E3%81%AE%202%20%E3%81%A4%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AE%E3%81%A9%E3%81%A1%E3%82%89%E3%81%AB%E3%82%82%E5%90%8C%E3%81%98%20udelay(20)%20%E3%81%8C%E3%81%82%E3%81%A3%E3%81%A6%E3%82%82%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%E3%81%AF%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fboundarydevices%2Flinux-imx6%2Fblob%2Fboundary-imx_3.10.17_1.0.0_ga%2Fdrivers%2Fcrypto%2Fcaam%2Fjr.c%23L66%22%20title%3D%22https%3A%2F%2Fgithub.com%2Fboundarydevices%2Flinux-imx6%2Fblob%2Fboundary-imx_3.10.17_1.0.0_ga%2Fdrivers%2Fcrypto%2Fcaam%2Fjr.c%23L66%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ELinux-imx6%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2Fcrypto%2Fcaam%2Fjr.c%20at%20boundary-imx_3.10.17_1.0.0_ga%20%C2%B7%20boundarydevices%2FLinux-imx6%20%C2%B7%20GitHub%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fboundarydevices%2Flinux-imx6%2Fblob%2Fboundary-imx_3.10.17_1.0.0_ga%2Fdrivers%2Fcrypto%2Fcaam%2Fjr.c%23L128%22%20title%3D%22https%3A%2F%2Fgithub.com%2Fboundarydevices%2Flinux-imx6%2Fblob%2Fboundary-imx_3.10.17_1.0.0_ga%2Fdrivers%2Fcrypto%2Fcaam%2Fjr.c%23L128%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ELinux-imx6%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2Fcrypto%2Fcaam%2Fjr.c%20at%20boundary-imx_3.10.17_1.0.0_ga%20%C2%B7%20boundarydevices%2FLinux-imx6%20%C2%B7%20GitHub%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-307493%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Re%3A%20CAAM%20and%20kernel%20crypto%20tests%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-307493%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%81%95%E3%82%89%E3%81%AB%E8%A9%B3%E3%81%97%E3%81%84%E6%83%85%E5%A0%B1%E3%81%AF%E2%80%A6%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ecaam_jr_enqueue()%20%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AB%E3%81%82%E3%82%8B%20udelay(20)%20%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%AB%E3%82%88%E3%82%8A%E3%83%86%E3%82%B9%E3%83%88%E3%81%AF%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82SO%E3%80%81%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%20%E3%83%90%E3%82%B0%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_text_macro%20jive_macro_code%20_jivemacro_uid_14013942705871488%22%20jivemacro_uid%3D%22_14013942705871488%22%3E%0A%3CP%3E~%2Flinux-imx6%24%20git%20diff%3C%2FP%3E%0A%3CP%3Ediff%20--git%20a%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2Fcrypto%2Fcaam%2Fjr.c%20b%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2Fcrypto%2Fcaam%2Fjr.c%3C%2FP%3E%0A%3CP%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%2080ddddb..c8c4a7e%20100644%3C%2FP%3E%0A%3CP%3E---%20a%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2Fcrypto%2Fcaam%2Fjr.c%3C%2FP%3E%0A%3CP%3E%2B%2B%2B%20b%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2Fcrypto%2Fcaam%2Fjr.c%3C%2FP%3E%0A%3CP%3E%40%40%20-288%2C6%20%2B288%2C7%20%40%40%20int%20caam_jr_enqueue(%E6%A7%8B%E9%80%A0%E4%BD%93%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20*dev%2C%20u32%20*desc%2C%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3Espin_unlock_bh(%26amp%3Bjrp-%26gt%3Binplock)%3B%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%2B%20%E9%81%85%E5%BB%B6(20)%3B%3C%2FP%3E%0A%3CP%3E0%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%20%7D%3C%2FP%3E%0A%3CP%3E%20EXPORT_SYMBOL(caam_jr_enqueue)%3B%3C%2FP%3E%0A%3C%2FPRE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-307492%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Re%3A%20CAAM%20and%20kernel%20crypto%20tests%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-307492%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%95%E3%82%89%E3%81%AA%E3%82%8B%E6%9B%B4%E6%96%B0%3A%203.10.17-1.0.0-ga%20%E3%81%A7%E3%81%AE%E3%81%9D%E3%81%AE%E5%BE%8C%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%A7%E3%81%AF%E3%80%81%E3%82%BC%E3%83%AD%E3%81%AE%208%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%A0%E3%81%91%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_text_macro%20jive_macro_code%20_jivemacro_uid_14013882538833347%22%20jivemacro_uid%3D%22_14013882538833347%22%3E%0A%3CP%3Ealg%3A%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%3A%20hmac-sha1-caam%20%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%201%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%0A%3CP%3E00000000%3A%2000%2000%2000%2000%2000%2000%2000%2000%20e2%208b%20c0%20b6%20fb%2037%208c%208e%3C%2FP%3E%0A%3CP%3E00000010%3A%20f1%2046%20%E3%81%AF%2000%20%E3%81%A7%E3%81%99%3C%2FP%3E%0A%3CP%3Ealg%3A%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%3A%20sha1-caam%20%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%201%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%0A%3C%2FPRE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-307491%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20and%20kernel%20crypto%20tests%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-307491%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%BD%E5%8A%A0%E3%83%A1%E3%83%A2%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%86%E3%82%B9%E3%83%88%E5%A4%B1%E6%95%97%E6%99%82%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E5%80%A4%3A%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_text_macro%20jive_macro_code%20_jivemacro_uid_14013867085051833%22%20jivemacro_uid%3D%22_14013867085051833%22%3E%3COL%20class%3D%22dp-c%22%20start%3D%221%22%20style%3D%22font-size%3A%2012px%3B%20font-family%3A%20Consolas%2C%20'Courier%20New'%2C%20Courier%2C%20mono%2C%20serif%3B%20list-style-position%3A%20initial%3B%20list-style-image%3A%20initial%3B%20color%3A%20%235c5c5c%3B%20margin-bottom%3A%201px%20!important%3B%20margin-left%3A%2045px%20!important%3B%22%3E%0A%3CLI%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20color%3A%20black%3B%20background-color%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3Ealg%3A%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%3A%20hmac-sha1-caam%20%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%201%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20color%3A%20black%3B%20background-color%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E00000000%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%20%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20color%3A%20black%3B%20background-color%3A%20inherit%3B%20font-size%3A%209pt%20!important%3B%22%3E00000010%3A%20f1%2046%20%E3%81%AF%2000%20%E3%81%A7%E3%81%99%20%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FOL%3E%3C%2FPRE%3E%3CP%3E%E4%BA%88%E6%83%B3%E3%81%95%E3%82%8C%E3%81%9F%E7%B5%90%E6%9E%9C%E3%81%A8%E4%BC%BC%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81crypto%2Ftestmgr.c%20%E3%81%AE%20hmac-sha1%20%E3%81%AE%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%20%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_text_macro%20jive_macro_code%20_jivemacro_uid_14013868909418798%22%20jivemacro_uid%3D%22_14013868909418798%22%20modifiedtitle%3D%22true%22%3E%0A%3CP%3E%E9%9D%99%E7%9A%84%E6%A7%8B%E9%80%A0%E4%BD%93hash_testvec%20hmac_sha1_tv_template%5B%5D%20%3D%20%7B%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%20%7B%3C%2FP%3E%0A%3CP%3E.key%20%3D%20%22%5Cx0b%5Cx0b%5Cx0b%5Cx0b%5Cx0b%5Cx0b%5Cx0b%5Cx0b%5Cx0b%5Cx0b%5Cx0b%5Cx0b%5Cx0b%5Cx0b%5Cx0b%5Cx0b%5Cx0b%5Cx0b%5Cx0b%5Cx0b%22%2C%3C%2FP%3E%0A%3CP%3E.ksize%20%3D%2020%2C%3C%2FP%3E%0A%3CP%3E.plaintext%20%3D%20%22%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%22%2C%3C%2FP%3E%0A%3CP%3E.psize%20%3D%208%2C%3C%2FP%3E%0A%3CP%3E.%E3%83%80%E3%82%A4%E3%82%B8%E3%82%A7%E3%82%B9%E3%83%88%20%3D%20%22%5Cxb6%5Cx17%5Cx31%5Cx86%5Cx55%5Cx05%5Cx72%5Cx64%22%3C%2FP%3E%0A%3CP%3E%E3%80%8C%5Cxe2%5Cx8b%5Cxc0%5Cxb6%5Cxfb%5Cx37%5Cx8c%5Cx8e%5Cxf1%E3%80%8D%3C%2FP%3E%0A%3CP%3E%E3%80%8C%5Cx46%5Cxbe%E3%80%8D%E3%80%81%3C%2FP%3E%0A%3CP%3E...%3C%2FP%3E%0A%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%80%8Cf1%2046%20be%E3%80%8D%E3%81%8C%E6%9C%9F%E5%BE%85%E5%80%A4%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E5%A4%B1%E6%95%97%E3%81%97%E3%81%9F%E5%90%84%E3%83%86%E3%82%B9%E3%83%88%E3%81%AE%E6%9C%80%E5%88%9D%E3%81%AE%2016%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%8C%E3%82%BC%E3%83%AD%E3%81%A8%E3%81%97%E3%81%A6%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%82%82%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-307490%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20and%20kernel%20crypto%20tests%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-307490%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B8%E3%82%A7%E3%82%A4%E3%83%9F%E3%83%BC%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3.0.35_4.1.0%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E3%81%A5%E3%81%8B%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%823.10.17-1.0.0-ga%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%203.10.31_1.0.0-alpha%E3%80%82%20%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AB%E3%80%81%E4%BB%96%E3%81%AE%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%8B%E3%82%89%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%8C%E3%81%99%E3%81%A7%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Edma_map_sg_chained%20%E3%81%B8%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%3A%3C%2FP%3E%3CP%3E%3CA%20class%3D%22loading%22%20href%3D%22http%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2Fcommit%2F%3Fh%3Dimx_3.0.35_4.0.0%26amp%3Bid%3Db30237c79003223c6e8035d5be183cd4f0b469f9%22%20title%3D%22http%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2Fcommit%2F%3Fh%3Dimx_3.0.35_4.0.0%26amp%3Bid%3Db30237c79003223c6e8035d5be183cd4f0b469f9%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2Fcommit%2F%3Fh%3Dimx_3.0.35_4.0.0%26amp%3Bid%3Db30237c79003223c6e8035d5be183cd4f0b469f9%3C%2FA%3E%3C%2FP%3E%3CP%3E3.10.17%20%E3%82%BD%E3%83%BC%E3%82%B9%3A%3C%2FP%3E%3CP%3E%3CA%20class%3D%22loading%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fboundarydevices%2Flinux-imx6%2Fblob%2Fboundary-imx_3.10.17_1.0.0_ga%2Fdrivers%2Fcrypto%2Fcaam%2Fsg_sw_sec4.h%23L96%22%20title%3D%22https%3A%2F%2Fgithub.com%2Fboundarydevices%2Flinux-imx6%2Fblob%2Fboundary-imx_3.10.17_1.0.0_ga%2Fdrivers%2Fcrypto%2Fcaam%2Fsg_sw_sec4.h%23L96%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2Fboundarydevices%2Flinux-imx6%2Fblob%2Fboundary-imx_3.10.17_1.0.0_ga%2Fdrivers%2Fcrypto%2Fcaam%2Fsg_sw_sec4.h%23L96%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Edriver_algs%20%E3%81%B8%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%3A%3C%2FP%3E%3CP%3E%3CA%20class%3D%22loading%22%20href%3D%22http%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2Fcommit%2F%3Fh%3Dimx_3.0.35_4.0.0%26amp%3Bid%3D6068d7a77b2101c172fc2f003f90b1febbf99505%22%20title%3D%22http%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2Fcommit%2F%3Fh%3Dimx_3.0.35_4.0.0%26amp%3Bid%3D6068d7a77b2101c172fc2f003f90b1febbf99505%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fgit.freescale.com%2Fgit%2Fcgit.cgi%2Fimx%2Flinux-2.6-imx.git%2Fcommit%2F%3Fh%3Dimx_3.0.35_4.0.0%26amp%3Bid%3D6068d7a77b2101c172fc2f003f90b1febbf99505%3C%2FA%3E%3C%2FP%3E%3CP%3E3.10.17%20%E3%82%BD%E3%83%BC%E3%82%B9%3A%3C%2FP%3E%3CP%3E%3CA%20class%3D%22loading%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fboundarydevices%2Flinux-imx6%2Fblob%2Fboundary-imx_3.10.17_1.0.0_ga%2Fdrivers%2Fcrypto%2Fcaam%2Fcaamalg.c%23L2083%22%20title%3D%22https%3A%2F%2Fgithub.com%2Fboundarydevices%2Flinux-imx6%2Fblob%2Fboundary-imx_3.10.17_1.0.0_ga%2Fdrivers%2Fcrypto%2Fcaam%2Fcaamalg.c%23L2083%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2Fboundarydevices%2Flinux-imx6%2Fblob%2Fboundary-imx_3.10.17_1.0.0_ga%2Fdrivers%2Fcrypto%2Fcaam%2Fcaamalg.c%23L2083%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%8C%E7%9B%AE%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%AF%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%AB%E3%81%AE%E3%81%BF%E9%96%A2%E4%BF%82%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%98%8E%E7%A2%BA%E3%81%AB%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%AA%E3%83%83%E3%82%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-307489%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20and%20kernel%20crypto%20tests%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-307489%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8B%E3%82%A8%E3%83%AA%E3%83%83%E3%82%AF%E3%81%B8%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELinux%203.0.35%E3%81%AE%E5%A0%B4%E5%90%88CAAM%E3%81%AE%E9%81%A9%E5%88%87%E3%81%AA%E6%A9%9F%E8%83%BD%E3%82%92%E5%BE%97%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95700%22%20target%3D%22_blank%22%3EQ%26amp%3BA%3A%20iMX6%20%E3%81%AE%20Linux%20%E3%81%A7%20CAAM%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%84%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E3%81%99%E3%81%A6%E3%81%8D%E3%81%AA%E4%B8%80%E6%97%A5%E3%82%92%E3%80%81%3CBR%20%2F%3E%E3%83%8F%E3%82%A4%E3%83%A1%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-----------------------------------------------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%3A%20%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%A7%E8%B3%AA%E5%95%8F%E3%81%8C%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3CBR%20%2F%3E%20-----------------------------------------------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E
