Building the image
Building the image
unaigonzalez
I am working with i.mx28. I am trying to build a kernel with a new
configuration, so, following your step by step guide I saw that the resulting
file is not complete.
The point is, that after I build with ./ltib command, I expect to have a big
rootfs.ext2 as image, but I only have a 11Mbit file. When I use CF Imager
to set up my SD and I use it on the i.mx28, the error: Kernel panic appear.
Yuri
  Please look at my comments below.
1.
  Default build configuration is minimal, so the rootfs is not big.
Please select  LTIB configuration as FSL_gnome, for example.
2.
Please try the mfg tool to deploy the image to Your board.
3.
  If Your board and i.MX28 EVK differ - it may cause kernel panic.
Yuri
