Building libsocketcan
2,580件の閲覧回数
UVicEcoCar2
When we were trying to build the libsocketcan using the method "./litb -p 'pkg_name' ". the following error occurred:
lucid@ubuntu:~/Desktop/imx53_ard_11.05/ltib$ ./ltib -p libsocketcan
Processing platform: Freescale iMX5x Based Boards
using config/platform/imx/.config
Cannot find spec file that contains the package name libsocketcan.
If necessary please give the whole spec file name (with the .spec extension).
traceback:
main::mk_buildlist:1917
main::f_buildrpms:974
main:560
Started: Tue Mar 13 15:54:58 2012
Ended: Tue Mar 13 15:54:59 2012
Elapsed: 1 seconds
Build Failed
Exiting on error or interrupt
Could you tell us what to look for to fix this error?
Thank you
UVic
タグ(2)
1,932件の閲覧回数
Frias
Please follow the instructions on the page 45 of the presentation, you need to copy the spec files and sources to the appropriate folder, see:
