How do I make a build from UI_v2?
1,986 次查看
IdanRegev
When trying to run or build UI_v2.pro from Qt I get 2 build issues that prevent the build:
1. cannot find -lgsl
2. collect2L Id returned 1 exit status
Any ideas how I solve these issues?
标记 (2)
1 回复
1,908 次查看
Frias
Hello Idan,
Are you still having this issue?
Are you building on the the provided VM disk or you are doing it on your own environment?
Let me know and I'll try to help.
Thanks!
