BLE113 UART5 Check
BLE113 UART5 Check
3,080件の閲覧回数
deepanrajanbara
Ours is a custom board based on imx6 and we are faceing  a problem in which the UART5 is connected to BLE113 Bluetooth module and we are able to program the BT module but what we are able to check
Is that the module is it communicating with the board ?
Is there any way to check the debug print in the BT module ?
Thankyou,
Deepanraj.A
ラベル(2)
6 返答(返信)
2,920件の閲覧回数
saurabh206
Senior Contributor III
Ok
In this case just verify the Reset configuration of BLE113.
GPIO or power sequence is followed or not.
Saurabh
2,920件の閲覧回数
deepanrajanbara
Hi Saurabh
Yes Sir Reset configuration & Power Sequence everything has been followed.
Thankyou,
Deepanraj
2,920件の閲覧回数
saurabh206
Hi Deepanraj
Did you able to fixed this issue?
If yes than can you please mention what was the root cause?
Saurabh
2,920件の閲覧回数
deepanrajanbara
Hi Saurabh,
I am still facing that issue
Deepanraj
2,920件の閲覧回数
saurabh206
Deeanraj
First verify the RTS, CTS connection is configured properly or not.
You can used the scope for the signal verification.
These are the basic steps.
Saurabh
2,920件の閲覧回数
deepanrajanbara
Hi Saurabh
All the connections are correct and checked every signal all is fine but i dont know how to check the debug print using our BLE113.
Thankyou,
Deepanraj
