Ar0521 ISP image processing
1,589 次查看
Creative
good day
Our task is to connect the AR0521 sensor via ISP to imx8plus
The vvcam driver is taken as a basis: ov2775.c (kernel-module-isp-vvcam / 4.2.2.13.0-r0)
and ISP driver: OV2775.c (isp-imx / 4.2.2.13.0-r0)
The driver is running in 10 bit mode
As a result, we got an image of this kind (see below)
What we are doing wrong, any help will be helpful. Thanks to.Image from iOS.jpg
1,572 次查看
joanxie
I have mailed to you, pls check
