Android7.1.1 Mount Cmd
2,480 次查看
baozhuliu
Hi   all
          I am   useing  the platform of imx6qp which is base of android7.1.1 os   .Now execut  the cmd "mount -o remount,rw /system"  ,but the result  is "mount: '/dev/block/mmcblk3p5'->'/system': Device or resource busy".
         Please  teach me  how to have done it.  Thanks!
标记 (1)
5 回复数
2,199 次查看
mpc5676r
Hi All,
We are also facing the same issue. Can any one got succeeded please provide the answer for the issue.
Anji
2,199 次查看
gary_bisson
Senior Contributor III
Please connect your platform to your machine via USB cable and use the following ADB command:
$ adb remount
Gary
2,199 次查看
baozhuliu
Thank for your answer!  I  have executed  the cmd " adb remount"  ,but  the result is the same .It  have no work.
2,199 次查看
gary_bisson
It is most likely due to SELinux enforcing that remount. Can you add the following arguments to the bootargs:
androidboot.selinux=permissive
Gary
2,199 次查看
baozhuliu
Hi  Gary Bisson
      The cmd is added,and the result  is:
      But  the result is  :
