Android ADB
Android ADB
Purdbull
Hello everyone!
I am running android on the imx8m plus evk. I want to use adb over ethernet. The issue i am running into is that android uses adb over usb. In order to switch that to ethernet, i need access to some kind of a local terminal. The terminal from the developer options is only showing in the search bar, but not in the actual settings. Sadly there is no appstore where i could get some kind of emulator.
please help^^
Moritz
