Add v4l2loopback.ko to yocto imx8 yocto image
2,321 次查看
lchen
I have built the v4l2looback.ko (source:https://github.com/umlaeute/v4l2loopback) on the imx8 target. My goal is to add it to the yocto image. Has anybody done this? Create a kernel module recipe for v4l2loopback and include it in the yocto building?
Lijun
2,310 次查看
joanxie
how do you build it? could you find the v4l2loopback when you use the command like "bitbake -c menuconfig linux-imx" ? if yes, try to enable it in the menuconfig list
