About the green line at Video playback on HTML by using WebView on AndroidKK4.4.2
4,619 次查看
yuuki
Senior Contributor I
Dear all
Our customer plays a video on HTML by using WebView of AndroidKK4.4.2.
However, they have the following problem.
When a Video is switched to next Video, a green line may show in the end of a screen.
This phenomenon occurs very rarely.
Please see an attached video file.
- Issue_02.mp4
They investigate this problem.
Which cord should they refer to?
Could you teach the part they should correct?
May I have advice?
<Environment>
Baord: MX6Q-SABRE-SDB
Display: HDMI output
OS: AndroidKK4.4.2 FSL BSP
Package: AndroidKK4.4.2_Extended Feature Packages(android_kk4.4.2_1.0.0-ga_omxplayer_source)
Patchs: 0001-Fix-the-video-only-stream-can-t-play-issue.patch
             html5_video_issue.patch
Best Regards
Yuuki
标记 (5)
7 回复数
4,348 次查看
yuuki
Daer all,
Can anyone answer this question?
Please help me.
Yuuki
4,348 次查看
yuuki
Daer all,
Our customer has to settle a problem by the end of February.
Does anyone have any information?
Please help me.
Yuuki
4,348 次查看
SergioSolis
Yuuki,
I cannot reproduce this issue, can you send me the video you are showing and exactly how you reproduce it?
4,348 次查看
yuuki
Dear Sergio-san,
I'm sorry to delay.
I requested Video contents from our customer.
They are using application of a subcontracting company.
And they use the contents with which a picture and a video were combined.
Therefore they consider a way.
I consult with them.
Please wait a moment.
Yuuki
4,348 次查看
yuuki
Dear Sergio-san,
Thank you very much for your support.
About this problem, local FSL FAE has been contacted to R&D team internally.
Therefore I close this thread.
Yuuki
4,348 次查看
SergioSolis
Very well then, I will set this thread as 'assume answered'
best regards,
Sergio
Sergio
4,348 次查看
SergioSolis
Hello Yuuki,
Our team of experts is reviewing your case and I will update you as soon as I get a response from them.
