About scaling function of Surface in android of i.MX6DQ.
1,507 次查看
keitanagashima
Senior Contributor I
Dear All,
Hello.
android has s concept of "Surface" on the screen-display.
OpenGL(GPU) is used for the scaling of Surface.
Please, tell me the algorithm which does scaling using OpenGL(GPU).
(Nearest neighbor? or Bilinear? or Bicubic?)
BSP:android jb4.2.2_1.1.0
Keita
标签 (3)
1,041 次查看
Bio_TICFSL
Hi Keita,
jb4.2.2 take bilinear and Trilinear algorithms, please check on Android Graphic UI with GPU:
Android Graphic UI with GPU Hardware Acceleration
Hope this helps
1,042 次查看
Bio_TICFSL
Hi Keita,
Hope this helps
