About freescale v4l2 framework be applied to adv7282m.
guanliangding
     In ours item, We used a adv7282m chip. But, we just have a standard v4l2 interface driver offer by official. It means that, we need found a driver for freescale framework.
     If you ever do that, please give me some advice or resource. Please contact me with email - 343399208@qq.com. Thanks.
- John.ding
weidong_sun
Hello ding,
     I checked and compared ADV7282's datasheet with that of ADV7280, both chips are almost same, so you can design it's linux driver based on adv7280, even I think you can directly use adv7280 to driver adv7282 on your board .
     In path linux/drivers/media/video/mxc/capture, you can find adv7280 driver, on our Sabre AI board, we used the chip for automotive applications.
Good Luck!
Weidong
guanliangding
Hi, weidong:
    Thanks! In ours source code tree, we didn't found name of adv7280.* release in the path drivers/media/platform/mxc/capture/. Ours kernel version is 3.10.17. Could you give me a web link to get it.
     Others, adv7280 data channel is RGB interface. but, the adv7282m is mipi-csi2 interface. So we need porting mxc_v4l2_capture.c of camera driver.
     Final, if you are a china, we can communication use Chinese. Thanks.
B.R
- John.ding
