About a Audio error and application abnormal termination for AndroidKK4.4.2 on i.MX6-SABRE-SDB.
6,423 次查看
yuuki
Senior Contributor II
Our customer is using the following development environment.
<Environment>
Baord: MX6Q-SABRE-SDB
Display: HDMI output
OS: AndroidKK4.4.2 FSL BSP
Package: AndroidKK4.4.2_Extended Feature Packages(android_kk4.4.2_1.0.0-ga_omxplayer_source)
Patchs: 0001-Fix-the-video-only-stream-can-t-play-issue.patch
             html5_video_issue.patch
When a Video playback is repeated, the following error occurs.
And It seems that a Video application is finished forcibly(abnormal termination).
=====Error log=====
I/OMXPlayer( 2291): failed to open file: /data/system/audio_pass_through_pref.
W/linker  ( 2291): lib_aac_dec_v2_arm12_elinux.so has text relocations. This is wasting memory and is a security risk. Please fix.
W/linker  ( 2291): lib_aacplus_dec_v2_arm11_elinux.so has text relocations. This is wasting memory and is a security risk. Please fix.
Are these errors related to abnormal termination?
May I have advice?
Yuuki
14 回复数
6,014 次查看
yuuki
Daer all,
Can anyone answer this question?
Please help me.
Yuuki
6,014 次查看
SergioSolis
Hello Yuuki,
One question, where did you get the patches you are mentioning?, who provided them to you?
6,014 次查看
yuuki
Dear Sergio Solis-san,
Thank you for your reply.
I got these patches from FSL.
Best Reagrds,
Yuuki
6,014 次查看
SergioSolis
Do you have the requested information Yuuki?
6,014 次查看
yuuki
Dear Sergio-san,
Thank you for your support.
I am sorry to delay.
Our customer uses the application of the partner.
Therefore I cannot provide the reproduction environment to you.
Would you teach the cause that you can suppose from contents of the error log?
Yuuki
6,014 次查看
yuuki
Dear Sergio-san,
May I have any advice for these error logs?
Yuuki
6,014 次查看
SergioSolis
Hello Yuuki,
Is your customer playing an httplive streaming media?  Playing through a web browser or from customer's own application?
thank you,
Sergio
6,014 次查看
yuuki
Dear Sergio-san,
We are playing the Video contents by using a Web browser based on Chromium.
Yuuki
6,013 次查看
SergioSolis
Can you ask your customer to test this patch?
6,013 次查看
yuuki
Dear Sergio-san,
We got a log by using this patch.
However, this log includes a confidential information.
Therefore we made a Service Request.
1-3768525447
Would you confirm this SR?
Yuuki
6,013 次查看
SergioSolis
Confirmed, we will continue through the SR.
6,013 次查看
yuuki
Dear Sergio-san,
Thank you very much for your support.
We confirm it now.
Please give me some time.
Yuuki
6,013 次查看
SergioSolis
Hello Yuuki,
Can you please share more information on how to apply the patches?:
1) baseline, commit hash id
2) whole patches with number 0001-*.patch, 0002-*.patch (i.e. 0001-Fix-* and html5_* which is the first?) . However, at this moment, I tried both sequence but failed to apply the two patches.
3) test files (media files)
4) the test steps.
5) run environment (i.e. boot from sd3 or mmc).
6,013 次查看
SergioSolis
Hello Yuuki,
Our Apps team is reviewing your question and I should update you as soon as I get a response from them.
