hello,Community
In order to transition to the ON state, when (debounce time) + (ON_TIME) has elapsed, the PMIC_ON_REQ signal will be output high.
If the ONOFFpin low level signal exceeds the debounce time, will it transition to the ON state?
Or do you have to keep ONOFFpin low during the ON_TIME period?
(See attachment)
best regards
Goto
Solved! Go to Solution.
		Hi Goto
necessary to keep ONOFFpin low during the ON_TIME period.
		Hi Goto
