About ON_TIME
About ON_TIME
2,076 次查看
goto11
hello,Community
About ON_TIME (00: 500msec off-> on transition time)
Is the time from when BTN is asserted to when the SOC power is turned on including the time when power is supplied to the iMX and the reset release time?
Browse attachments
best regards
Goto
标签 (1)
1 回复
2,003 次查看
gusarambula
Hello Goto,
The function of the ON_TIME is slightly different. You can see a simplified diagram on the following Community Document. The BTN must be asserted ON_TIME miliseconds so that the PMIC is asserted to power on the SoC power.
https://community.nxp.com/docs/DOC-97660
I hope this information helps!
