About Mfgtool v2
About Mfgtool v2
yibhan
I am using to place some of images(uboot, kernel, rootfs) with Mfgtool v2 and kernel versioin is 4.1.15.
when I am using to Mfgtool v2, processing is stuck in "UTP: Waiting for device to appear), So, I realized linux_mfgtool kernel image should be used and then changed to linux_mfgtool and try again, downloading is complete.
But I have found Normal linux kernel image and linux_mfgtool image are different.
My question is that:
If I am right above my results, If only images for only mfgtool should be used when flashing to device with mfgtool,
the device with linux_mfgtool may operate differently on normal linux kernel image.
If so, how should i place normal uboot and kernel image to device after downloading uboot and linux image for mfgtool?
I have reviewed some of guides for mfgtool, but I can't be understood.
Labels (3)
yibhan
Hi guys,
I got my problems and now is okay, but I think some guide for mfgtool is lack of the explanation so that make someone misunderstand.
yibhan
Hi guys,
Rita_Wang
Glad it works on you side. For the newer version BSP, we supply the uuu tool.
yibhan
For your information, I am using imx6qp evaluation board.
