About EIM (Parallel NOR) boot in i.MX6DQ.
992 次查看
keitanagashima
Senior Contributor I
Dear All,
Hello.
I have questions about Parallel NOR boot in i.MX6DQ.
We will use Parallel NOR Flash for boot with 16 bit muxed mode.
[Q1]
At the boot time, what timing waveform does it become with EIM muxed mode?
Do you have timing waveform?
(At the time of the boot, I consider that the timing can not be set by user.)
[Q2]
At the boot time, what is the frequency of NOR (EIM)?
132MHz?
Keita
标签 (3)
855 次查看
BiyongSUN
A1:  You can use the EIM default value to calculate the boot timing. And it is listed in the reference manual and datasheet as well.
A2:
856 次查看
BiyongSUN
A2:
