About Asynchronous Write access of EIM of i.MX6
1,771件の閲覧回数
yuuki
Senior Contributor II
Dear all,
Our customer connects external device to EIM_CS0 of i.MX6.
They would like to access external device by asynchronous access.
They try to write 0xFFFF value into 0x80000000 address.
However, the value isn't output on a data bus(DATA[31:16]).
I'm checking their register setting.
However, I can't find a problem.
May I have some advice?
They set registers as follows.
[setting]
Non-Multiplex Mode/16bit_bus(DATA[31:16])
EIM_CS0GCR1=0x0002_0001
(MUM=0 / DSZ=010 / SRD=0 / SWR=0)
CCM_CCGR6   : 0x20C_4080 : 0xFFFF_0C03
EIM_CS0GCR1 : 0x21B_8000 : 0x0002_0001
EIM_CS0GCR2 : 0x21B_8004 : 0x0000_0000
EIM_CS0RCR1 : 0x21B_8008 : 0x2800_0203
EIM_CS0RCR2 : 0x21B_800C : 0x0000_0002
EIM_CS0WCR1 : 0x21B_8010 : 0x2800_2083
EIM_CS0WCR2 : 0x21B_8014 : 0x0000_0000
EIM_WCR     : 0x21B_8090 : 0x0000_0020
EIM_WIAR    : 0x21B_8094 : 0x0000_0010
Yuuki
1,499件の閲覧回数
yuuki
Dear Yuri-san,
Thank you for your support.
We checked IOMUX of EIM_D16-EIM_D31.
These defaults were GPIO mode.
When we set these in EIM_Dxx, our problem was settled.
Yuuki
3 返答(返信)
1,499件の閲覧回数
Yuri
   You wrote : “write 0xFFFF value into 0x80000000” ;
perhaps the problem concerns with the fact, that EIM CS0 address range
starts from 0x0800_0000.
~Yuri.
1,499件の閲覧回数
yuuki
Dear Yuri-san,
Thank you very much for your support.
I'm sorry, 0x8000_0000 is a mistake.
0x0800_0000 is right.
Anything else I should consider?
May I have advice?
Yuuki
1,500件の閲覧回数
yuuki
Dear Yuri-san,
Yuuki
