AXI iRAM usage in IMX6 VPU
1,673 次查看
jparrish88
How was the AXI iram used for vpu? What are the A9 support routines for the VPU.  (e.g. me/mv/dbk)
Also,  Does a9 core share the AXI iram with vpu? can a9 reuse this piece of iram when vpu isn't needed?
标签 (3)
标记 (3)
1,320 次查看
Hi jparrish88
what do you mean by "AXI iram" ?
VPU does not specially use OCRAM (though you can use it in software).
OCRAM can be used as any other memory region (for example DDR3).
chip
