ARMv7-A requires separate exception vector handler
ramesharise
ARMv7-A is Dual core, with Core0 and Core1. I am Implementing the exception handling in my application, configured the main stack and exception stack for both cores.
The vector address are same for both cores, so I would like to know, both core0 & core1 requires same Exception Vector handler or separate?
