ADC with DMA in imx91
2,082 次查看
sbmd_1234
Hi NXP Team,
I am new to working with ADC and I wanted to implement the DMA with ADC please tell me how to implement it on the imx91 processor.
Thanks.
7 回复数
2,043 次查看
Zhiming_Liu
Default driver doesn't support DMA feature, please refer RM to configure DMA registers, DMAE, and DMARn, for different channel groups.
Best Regards
Zhiming
1,964 次查看
sbmd_1234
Do you have any reference code, or document that would be helpful for the DMA implementation with ADC.
Thanks for your help!
1,952 次查看
Zhiming_Liu
I don't find such reference code in doucument.
Zhiming
1,942 次查看
sbmd_1234
How can we know the sample rate used in ADC and also if we want to configure for 200k samples per second then how could we do that?
Thanks.
1,909 次查看
Zhiming_Liu
Checked with SW team , they don't have plan to add DMA feature for ADC.
The adc driver has integrated with iio sensor framework, you can refer below link to access this device to get/set data you want with /sys/bus/iio/iio:deviceX/.
https://developer.toradex.com/linux-bsp/application-development/peripheral-access/adc-linux/
Zhiming
1,897 次查看
sbmd_1234
Hi @Zhiming_Liu ,
Actually my concern is that I can read the ADC value as /sys/bus/iio/devices/iio:device0/in_voltage0_raw, but how can we read the desired samples per second for example I need 200k samples per second how can I read or implement.
Please help with this.
Thanks.
1,860 次查看
Zhiming_Liu
The driver doesn't support iio buffer and iio scan feature, you may need refer other adc driver like drivers/iio/adc/ad7768-1.c to add them.
Zhiming
