8MPLUSLPD4-CPU LPDDR4 CKE Connection
shimpei_sonoda
I designed the new product with reference to the i.MX 8M Plus evaluation board "8MPLUSLPD4-CPU".  The file name is SPF-46368_A3.pdf.
In "8MPLUSLPD4-CPU", the Data signals of the LPDDR4 Ch.A output by the SoC are byte-swapped and connected to the DRAM. However, the CKE signals are not swapped. Should the CKEs be swapped?
Thank you for your reply.
Yuri
@shimpei_sonoda
DRAM_CKE0_A corresponds DRAM_nCS0_A;
DRAM_CKE1_A corresponds DRAM_nCS1_A.
  Data lanes swapping are not affected here.
Yuri.
Yuri
@shimpei_sonoda
Yuri.
