I have a question about MPII unused terminations of I.MX8M Plus.
IMX8MPHDG.pdf does not describe unused terminations under the following conditions.
MIPI-DSI: unused
MIPI-CSI1: used
MIPI-CSI2: unused
Is it okay to handle the following in this case?
VDD_MIPI_1P8, VDD_MIPI_0P8: Supply
MIPI_VREG1_CAP: Floating
VDD_MIPI_1P2_CAP: Connect to outside cap
VDD_TEST_DNU: Floating
MIPI_CSI1_CLK_P / N, MIPI_CSI1_Dx_P / N: Function
MIPI_CSI2_CLK_P / N, MIPI_CSI2_Dx_P / N: Tied to ground
MIPI_DSI_CLK_P / N, MIPI_DSI_Dx_P / N: Floating
Thank you for your reply.
解決済! 解決策の投稿を見る。
@shimpei_sonoda
Your considerations look reasonable, assuming VDD_TEST_DNU is MIPI_TEST_DNU.
Yuri.
@shimpei_sonoda
Yuri.
