8MMINILPD4-EVK rtsp stream slow processing
ashish_m
Development platform: 8MMINILPD4-EVK board
Application as follows:
  • Capture IP camera video stream.
  • Store video stream to Hard Disk (Time based / event driven storage)
  • Perform Object detection logic.
Setup Information:
  • 8MMINILPD4-EVK development board
  • Linux kernal LF5.15.5_1.0.0
  • Yocto Project Setup : build type :imx-image-full
  • IP camera and development board connected to local LAN network.
IP camera protocol          : RTSP
Frame Setting                    : 1080P @ 30 pfs, Mainstream: video H264, bitrate 2048 kbps
During IP camera RTSP stream integration with development board we face following problem –
When ffmpeg library transcodes the input video from rtsp stream using default /specific options, cpu utilization is very high and resulting video stream has lag and missing frames.
The performance is optimum when no video transcoding happens and input stream is copied as is from the input.
The above conclusion can be inferred from following results -
[following commands were executed on the target board to record 15s of video from the IP camera using FFMPEG library (binaries)]
Case 1
Ip cam settings:
Res - 1080p
Compression - h.264
Command 1 - time ffmpeg -i rtsp://admin:[email protected]:554/videoMain -t 15s out11.mp4
Execution time - 47.43s
CPU Utilisation - ~60-70%
Command 2 - time ffmpeg -c:v h264 -i rtsp://admin:[email protected]/videoMain -c:v copy -t 15s out12.mp4
Execution time - 15.516s
CPU Utilisation - ~5-10%
Case 2
Ip cam settings:
Res - 1080p
Compression - h.265
Command 1 - time ffmpeg -i rtsp://admin:[email protected]:554/videoMain -t 15s out21.mp4
Execution time - 46.58s
Command 2 - time ffmpeg -c:v hevc -i rtsp://admin:[email protected]/videoMain -c:v copy -t 15s ~/sample_ipcam_vid/out22.mp4
Execution time - 15.483s
Case 3
Ip cam settings:
Res - 720p
Compression - h.264
Command 1 - time ffmpeg -i rtsp://admin:[email protected]:554/videoMain -t 15s out31.mp4
Execution time - 24.516s
[Missed Frames]
Command 2 - time ffmpeg -c:v h264 -i rtsp://admin:[email protected]/videoMain -c:v copy -t 15s ~/sample_ipcam_vid/out32.mp4
Execution time - 15.494s
Similar performance is observed when using pre-saved local video file as input - thus ruling out bottlenecks caused due to network infrastructure
also, similar performance/lag is observed when reading video frames from opencv-python (both when input is ip camera url or saved local video file)
Python line -
video = cv2.VideoCapture(camUrl)
The performance doesn’t much vary when resolution/compression settings are changed in th eIP camera settings.
Desired performance – (to achieve live streaming, recording and ComputerVision applications)
CPU utilisation – as low as possible
Execution time –  around 1x (i.e. approx 15s for 15s Stream)
Kindly suggest how we can optimized same.
