unable to connect to git.freescale.com
Recently many customers faced the issue about connecting the git.freesacle .com failed when they built old bsp version like 4.1.15 or 3.14.52,  when the customer repo init according to the yocto user guide, they get the error message like :
repo init -u git://git.freescale.com/imx/fsl-arm-yocto-bsp.git -b imx-4.1-krogoth
manifests:
 escale.com[0: 192.88.156.202]: errno=Connection refused
 fatal: cannot obtain manifest git://git.freescale.com/imx/fsl-arm-yocto-bsp.git
git clone git://git.freescale.com:9418/imx/fsl-arm-yocto-bsp.git -b imx-4.1.15-1.0.0_ga
Cloning into 'fsl-arm-yocto-bsp'...
fatal: unable to connect to git.freescale.com:
git.freescale.com[0: 192.88.156.202]: errno=Connection refused
the reason is that the old bsp source code was moved to "https://source.codeaurora.org/external/imx", customer needs to change "git://git.freescale.com/imx"  to "https://source.codeaurora.org/external/imx", for new repo init commands, try to use the commands like “repo init -u https://source.codeaurora.org/external/imx/fsl-arm-yocto-bsp -b <branch> [-m <manifest>]”
for example:
4.1.15_1.0.0:
repo init -u https://source.codeaurora.org/external/imx/fsl-arm-yocto-bsp -b imx-4.1.15-1.0.0_ga
4.1.15_2.0.0:
repo init -u https://source.codeaurora.org/external/imx/fsl-arm-yocto-bsp -b imx-4.1-krogoth -m imx-4.1.15-2.0.0.xml
4.1.15_2.1.1:
repo init -u https://source.codeaurora.org/external/imx/fsl-arm-yocto-bsp -b imx-4.1-krogoth -m imx-4.1.15-2.1.1.xml
then you can "repo sync" and "bitbake", but some customers still has the connection error on building firmware-imx package, the error message like :
ERROR: firmware-imx-1_5.4-r0 do_fetch: Fetcher failure: Fetch command failed with exit code 128, output:
Cloning into bare repository '/opt/yocto/fsl-release-bsp/downloads//git2/git.freescale.com.imx.imx-firmware.git'...
ERROR: firmware-imx-1_5.4-r0 do_fetch: Function failed: Fetcher failure for URL: 'git://git.freescale.com/imx/imx-firmware.git;branch=master;destsuffix=/opt/yocto/fsl-release-bsp/fsl_build...'. Unable to fetch URL from any source.
this reason is that 4.1.15 needs to download git2 package from git.freescale.com, then I uploaded the firmwar-imx git2 package, try to unzip first, then put packages under downloads/git2, then "bitbake firmware-imx" again
添付
コメント
我按上面的方法出现两个问题。
问题1:我已经把firmware-imx-5.4.bin和firmware-imx-5.4.bin.done拷贝到downloads,然后不管我bitbake firmware-imx还是bitbake fsl-image-qt5都出现:
WARNING: firmware-imx-1_5.4-r0 do_fetch: Failed to fetch URL git://git.freescale.com/imx/imx-firmware.git;branch=master;destsuffix=/home/longbin/Downloads/fsl-release-bsp/build_qt5/tmp/work/cortexa7hf-neon-mx6ul-poky-linux-gnueabi/firmware-imx/1_5.4-r0/firmware-imx-5.4/git, attempting MIRRORS if available
Cloning into bare repository '/home/longbin/Downloads/fsl-release-bsp/downloads//git2/git.freescale.com.imx.imx-firmware.git'...
ERROR: firmware-imx-1_5.4-r0 do_fetch: Function failed: Fetcher failure for URL: 'git://git.freescale.com/imx/imx-firmware.git;branch=master;destsuffix=/home/longbin/Downloads/fsl-release-bsp/build_qt5/tmp/work/cortexa7hf-neon-mx6ul-poky-linux-gnueabi/firmware-imx/1_5.4-r0/firmware-imx-5.4/git'. Unable to fetch URL from any source.
ERROR: Logfile of failure stored in: /home/longbin/Downloads/fsl-release-bsp/build_qt5/tmp/work/cortexa7hf-neon-mx6ul-poky-linux-gnueabi/firmware-imx/1_5.4-r0/temp/log.do_fetch.4135
ERROR: Task 4 (/home/longbin/Downloads/fsl-release-bsp/sources/meta-fsl-bsp-release/imx/meta-bsp/recipes-bsp/firmware-imx/firmware-imx_5.4.bb, do_fetch) failed with exit code '1'
问题二:linux-imx一直都下载不了。不管是bitbake -c fetchall linux-imx还是bitbake fsl-image-qt5。一直在
0: linux-imx-4.1.15-r0 do_fetch (pid 4449)
try to use "bitbake firmware-imx -c cleanall", then check if your downloads folder includes the two packages or not, if not, copy the packages there, then use bitbake firmware-imx again
longbin@longbin-virtual-machine:~/Downloads/fsl-release-bsp/build_qt5$ bitbake firmware-imx -c cleanall
Loading cache: 100% |###########################################| ETA:  00:00:00
Loaded 2792 entries from dependency cache.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION        = "1.30.0"
BUILD_SYS         = "x86_64-linux"
NATIVELSBSTRING   = "Ubuntu-14.04"
TARGET_SYS        = "arm-poky-linux-gnueabi"
MACHINE           = "imx6ull14x14evk"
DISTRO            = "fsl-imx-fb"
DISTRO_VERSION    = "4.1.15-2.1.0"
TUNE_FEATURES     = "arm armv7ve vfp  neon        callconvention-hard        cortexa7"
TARGET_FPU        = "hard"
meta
meta-poky         = "HEAD:f5da2a5913319ad6ac2141438ba1aa17576326ab"
meta-oe
meta-multimedia   = "HEAD:247b1267bbe95719cd4877d2d3cfbaf2a2f4865a"
meta-fsl-arm      = "HEAD:be78894e4682f111575470fb23e51e6ba523508d"
meta-fsl-arm-extra = "HEAD:3dfb82fc7e703eae9891b3ffda0e9393701f2396"
meta-fsl-demos    = "HEAD:a165068f8a0d1cf29aabe4b4053f28be1c2aa492"
meta-bsp
meta-sdk          = "HEAD:f0e54cdf7a1c6d35976b0be80ded28a7f019b567"
meta-browser      = "HEAD:77736988073a5d90fcff9d0005c8477332ede387"
meta-gnome
meta-networking
meta-python
meta-filesystems  = "HEAD:247b1267bbe95719cd4877d2d3cfbaf2a2f4865a"
meta-qt5          = "HEAD:ccae79be69c5268df3b47e4e14cea0591c39a531"
NOTE: Preparing RunQueue
NOTE: Executing RunQueue Tasks
NOTE: Tasks Summary: Attempted 3 tasks of which 0 didn't need to be rerun and all succeeded.
TARGET_FPU        = "hard"
meta
meta-oe
meta-bsp
meta-gnome
meta-networking
meta-python
NOTE: Executing SetScene Tasks
ERROR: Logfile of failure stored in: /home/longbin/Downloads/fsl-release-bsp/build_qt5/tmp/work/cortexa7hf-neon-mx6ul-poky-linux-gnueabi/firmware-imx/1_5.4-r0/temp/log.do_fetch.4056
NOTE: Tasks Summary: Attempted 346 tasks of which 345 didn't need to be rerun and 1 failed.
No currently running tasks (325 of 358)
Summary: 1 task failed:
Summary: There was 1 WARNING message shown.
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
从图可以看到我downloads是有firmware-imx5.4.bin和firmware-imx-5.4.bin.done
linux-imx-4.1.15错误:
ERROR: linux-imx-4.1.15-r0 do_fetch: Fetcher failure: Fetch command failed with exit code 128, output:
Cloning into bare repository '/home/longbin/Downloads/fsl-release-bsp/downloads//git2/source.codeaurora.org.external.imx.linux-imx.git'...
error: RPC failed; curl 56 GnuTLS recv error (-9): A TLS packet with unexpected length was received.
fatal: the remote end hung up unexpectedly
fatal: early EOF
fatal: index-pack failed
ERROR: linux-imx-4.1.15-r0 do_fetch: Function failed: Fetcher failure for URL: 'git://source.codeaurora.org/external/imx/linux-imx.git;protocol=https;branch=imx_4.1.15_2.0.0_ga'. Unable to fetch URL from any source.
ERROR: Logfile of failure stored in: /home/longbin/Downloads/fsl-release-bsp/build_qt5/tmp/work/imx6ull14x14evk-poky-linux-gnueabi/linux-imx/4.1.15-r0/temp/log.do_fetch.3591
ERROR: Task 0 (/home/longbin/Downloads/fsl-release-bsp/sources/meta-fsl-bsp-release/imx/meta-bsp/recipes-kernel/linux/linux-imx_4.1.15.bb, do_fetch) failed with exit code '1'
what's your mail address? let me figure out how to send the firmware-imx package to you, I tested on my ubuntu successfully, it's too big to upload here
我的邮箱是[email protected],非常感谢。
for firmware-imx, I have uploaded git package, you can download it then put to the downloads/git2, then "bitbake firmware-imx" again, for the linux-imx, I will try to send to you by mail
I have a similar issue building Yocto for i.MX6UL EVK using:
$ repo init -u https://source.codeaurora.org/external/imx/fsl-arm-yocto-bsp -b imx-4.1.15-1.0.0_ga
I'm building on Ubuntu 15.10 64-bit.  The build proceeds for several hours and then fails with:
ERROR: Function failed: Fetcher failure for URL: 'git://git.freescale.com/imx/linux-2.6-imx.git;protocol=git;branch=imx_4.1.15_1.0.0_ga'. Unable to fetch URL from any source.
Hi. Joan Xie.
I encountered same issue exactly.
Could you let me get firmware-imx package? ([email protected])
I already spent a few days because of this issue, pls send me file as soon as possible.
Thanks.
I couldn't find your mail address in our system, so you need to submit a case for me, then I can try to send the package to you, it's too big to upload here
https://community.nxp.com/docs/DOC-329745
after you submit the case, tell me the case number
you should the same issue, if you need the linux-imx package, you can create a case in salesforce too
then tell me your case number
Hi ,
I have the same issue...
changing to repo init -u https://source.codeaurora.org/external/imx/fsl-arm-yocto-bsp -b imx-4.1.15-1.0.0_ga
did not work also...
joanxie can you mail this to me as well please? [email protected]
I have already attached it, pls read my document again, I uploaded the firmwar-imx git2 package, try to unzip first, then put packages under downloads/git2, then "bitbake firmware-imx" again
Hi joanxie‌
Thanks for repsonse, however, see below, after using bitbake fimware-imx -c clean all, then again bitbake firmware-imx works but after I try bitbake core-image-v2x-refbsp then it gives out the same error...even after bitbake core-image-v2x-refbsp -c cleanall and again bitbake core-image-v2x-refbsp...
it seems that you have already built firmare-imx successfully, but couldn't download linux-imx-4.1.15 package, this is too large to upload here, if you need it, pls create a case to get it, try to add my name on the title, then I can get it and send the pacakge to you
Hi Need quick help
I havecopied ffirmware bin in download folder and firmware.gut in git2 folder when i an trying to compiler still bitbake is trying to download
| ERROR: Function failed: do_configure (log file is located at /home/msabnam/w117/build/tmp/work/x86_64-linux/qemu-native/2.5.0-r1/temp/log.do_configure.23854)
ERROR: Task 1187 (virtual:native:/home/msabnam/w117/Eagle-Distribution/oe-core/meta/recipes-devtools/qemu/qemu_2.5.0.bb, do_configure) failed with exit code '1'
WARNING: firmware-imx-1_5.4-r0 do_fetch: Failed to fetch URL git://github.com/NXP/imx-firmware.git;protocol=https;branch=master;destsuffix=imx-firmware;name=imx-firmware, attempting MIRRORS if available
ERROR: firmware-imx-1_5.4-r0 do_fetch: Fetcher failure: Unable to find revision 951c1363abe95dd75ab3e9447f640d7807240236 in branch master even from upstream
ERROR: firmware-imx-1_5.4-r0 do_fetch: Function failed: Fetcher failure for URL: 'git://github.com/NXP/imx-firmware.git;protocol=https;branch=master;destsuffix=imx-firmware;name=imx-firmware'. Unable to fetch URL from any source.
ERROR: Logfile of failure stored in: /home/msabnam/w117/build/tmp/work/cortexa9hf-neon-mx6qdl-oe-linux-gnueabi/firmware-imx/1_5.4-r0/temp/log.do_fetch.23884
ERROR: Task 226 (/home/msabnam/w117/Eagle-Distribution/oe-core/../meta-fsl-arm/recipes-bsp/firmware-imx/firmware-imx_5.4.bb, do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 952 tasks of which 926 didn't need to be rerun and 3 failed.
/downloads$ ll firmware-imx-5.4.bin*
-rw-rw-r-- 1 msabnam msabnam 429744 Aug 11 10:39 firmware-imx-5.4.bin
-rw-rw-r-- 1 msabnam msabnam 125 Aug 11 15:00 firmware-imx-5.4.bin.done
downloads$ ll git2/git.freescale.com.imx.imx-firmware.git
total 44
drwxrwxrwx 7 msabnam msabnam 4096 Aug 10 20:19 ./
drwxrwxr-x 30 msabnam msabnam 4096 Aug 11 15:01 ../
drwxrwxrwx 2 msabnam msabnam 4096 Aug 10 20:17 branches/
-rw-rw-r-- 1 msabnam msabnam 175 Aug 10 20:17 config
-rw-rw-r-- 1 msabnam msabnam 73 Aug 10 20:17 description
-rw-rw-r-- 1 msabnam msabnam 23 Aug 10 20:17 HEAD
drwxrwxrwx 2 msabnam msabnam 4096 Aug 10 20:19 hooks/
drwxrwxrwx 2 msabnam msabnam 4096 Aug 10 20:17 info/
drwxrwxrwx 4 msabnam msabnam 4096 Aug 10 20:19 objects/
-rw-rw-r-- 1 msabnam msabnam 718 Aug 10 20:17 packed-refs
drwxrwxrwx 4 msabnam msabnam 4096 Aug 10 20:17 refs/
%3CLINGO-SUB%20id%3D%22lingo-sub-1104028%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Egit.freescale.com%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104028%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%9C%80%E8%BF%91%E3%80%81%E5%A4%9A%E3%81%8F%E3%81%AE%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%8Cgit.freesacle.com%E3%81%B8%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%824.1.15%E3%82%843.14.52%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%8F%A4%E3%81%84BSP%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%26nbsp%3BYocto%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%8C%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%23ff0000%3B%22%3Erepo%20init%20-u%20git%3A%2F%2F%3CA%20href%3D%22http%3A%2F%2Fgit.freescale.com%2Fimx%2Ffsl-arm-yocto-bsp.git%22%20style%3D%22color%3A%20%23ff0000%3B%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Egit.freescale.com%2Fimx%2Ffsl-arm-yocto-bsp.git%3C%2FA%3E%20-b%20imx-4.1-krogoth%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%23ff0000%3B%22%3Emanifests%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CA%20href%3D%22http%3A%2F%2Fgit.freescale.com%22%20style%3D%22color%3A%20%23ff0000%3B%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Eescale.com%3C%2FA%3E%5B0%3A%20192.88.156.202%5D%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%E7%95%AA%E5%8F%B7%3D%E6%8E%A5%E7%B6%9A%E6%8B%92%E5%90%A6%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%23ff0000%3B%22%3E%26nbsp%3B%E8%87%B4%E5%91%BD%E7%9A%84%3A%20%E3%83%9E%E3%83%8B%E3%83%95%E3%82%A7%E3%82%B9%E3%83%88git%3A%2F%2F%3CA%20href%3D%22http%3A%2F%2Fgit.freescale.com%2Fimx%2Ffsl-arm-yocto-bsp.git%22%20style%3D%22color%3A%20%23ff0000%3B%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Egit.freescale.com%2Fimx%2Ffsl-arm-yocto-bsp.git%3C%2FA%3E%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%23ff0000%3B%22%3E%2F%2F%2F%2F%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%23ff0000%3B%22%3Egit%20clone%20git%3A%2F%2F%3CA%20href%3D%22http%3A%2F%2Fgit.freescale.com%22%20style%3D%22color%3A%20%23ff0000%3B%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Egit.freescale.com%3C%2FA%3E%3A9418%2Fimx%2Ffsl-arm-yocto-bsp.git%20-b%20imx-4.1.15-1.0.0_ga%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%23ff0000%3B%22%3E%E3%80%8Cfsl-arm-yocto-bsp%E3%80%8D%E3%81%AB%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E2%80%A6%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%23ff0000%3B%22%3E%E8%87%B4%E5%91%BD%E7%9A%84%EF%BC%9A%3CA%20href%3D%22http%3A%2F%2Fgit.freescale.com%22%20style%3D%22color%3A%20%23ff0000%3B%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Egit.freescale.com%3C%2FA%3E%E3%81%AB%E6%8E%A5%E7%B6%9A%E4%B8%8D%E5%8F%AF%E8%83%BD%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%23ff0000%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fgit.freescale.com%22%20style%3D%22color%3A%20%23ff0000%3B%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Egit.freescale.com%3C%2FA%3E%5B0%3A%20192.88.156.202%5D%3A%20errno%3D%E6%8E%A5%E7%B6%9A%E6%8B%92%E5%90%A6%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E5%8F%A4%E3%81%84BSP%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%3CA%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fsource.codeaurora.org%252Fexternal%252Fimx%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%22%3E%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%22%3C%2FSPAN%3E%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%95%E3%82%8C%E3%81%9F%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FA%3E%E3%80%8Cgit%3A%2F%2Fgit.freescale.com%2Fimx%E3%80%8D%E3%82%92%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%22%3E%20%3CA%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fsource.codeaurora.org%252Fexternal%252Fimx%22%20style%3D%22color%3A%20%233366ff%3B%22%20target%3D%22_blank%22%3E%E3%80%8Chttps%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%E3%80%8D%3C%2FA%3E%3C%2FSPAN%3E%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E6%96%B0%E3%81%97%E3%81%84%20repo%20init%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%22%3E%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%22%3Erepo%20init%20-u%20%3CA%20href%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Ffsl-arm-yocto-bsp%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Ffsl-arm-yocto-bsp%3C%2FA%3E%20-b%20%3CBRANCH%3E%20%5B-m%20%3CMANIFEST%3E%5D%22%3C%2FMANIFEST%3E%3C%2FBRANCH%3E%3C%2FSPAN%3E%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3E%E4%BB%A5%E4%B8%8B%E3%81%AB%E3%81%9D%E3%81%AE%E4%BE%8B%E3%82%92%E3%81%94%E7%B4%B9%E4%BB%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23ff0000%3B%22%3E4.1.15_1.0.0%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23000000%3B%22%3Erepo%20init%20-u%20%3CA%20href%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Ffsl-arm-yocto-bsp%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Ffsl-arm-yocto-bsp%3C%2FA%3E-b%20imx-4.1.15-1.0.0_ga%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23ff0000%3B%22%3E4.1.15_2.0.0%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3Erepo%20init%20-u%20%3CA%20href%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Ffsl-arm-yocto-bsp%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Ffsl-arm-yocto-bsp%3C%2FA%3E%20-b%20imx-4.1-krogoth%20-m%20imx-4.1.15-2.0.0.xml%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%20font-size%3A%2012pt%3B%22%3E4.1.15_2.1.1%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2012pt%3B%22%3Erepo%20init%20-u%20%3CA%20href%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Ffsl-arm-yocto-bsp%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Ffsl-arm-yocto-bsp%3C%2FA%3E%20-b%20imx-4.1-krogoth%20-m%20imx-4.1.15-2.1.1.xml%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%80%8Crepo%20sync%E3%80%8D%E3%81%A8%E3%80%8Cbitbake%E3%80%8D%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E4%B8%80%E9%83%A8%E3%81%AE%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%A7%E3%81%AF%E3%80%81firmware-imx%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E6%99%82%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20firmware-imx-1_5.4-r0%20do_fetch%EF%BC%9A%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%81%AB%E5%A4%B1%E6%95%97%EF%BC%9A%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89128%E3%81%A7%E5%A4%B1%E6%95%97%E3%80%81%E5%87%BA%E5%8A%9B%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%E3%83%99%E3%82%A2%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%20'%2Fopt%2Fyocto%2Ffsl-release-bsp%2Fdownloads%2F%2Fgit2%2F%3CA%20href%3D%22https%3A%2F%2Fgit.freescale.com%22%20style%3D%22color%3A%20%23ff0000%3B%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Egit.freescale.com%3C%2FA%3E.imx.imx-firmware.git'%20%E3%81%AB%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E4%B8%AD...%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%E8%87%B4%E5%91%BD%E7%9A%84%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fgit.freescale.com%22%20style%3D%22color%3A%20%23ff0000%3B%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Egit.freescale.com%3C%2FA%3E%E3%81%AB%E6%8E%A5%E7%B6%9A%E4%B8%8D%E5%8F%AF%E8%83%BD%EF%BC%9A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fgit.freescale.com%22%20style%3D%22color%3A%20%23ff0000%3B%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Egit.freescale.com%3C%2FA%3E%5B0%3A%20192.88.156.202%5D%3A%20errno%3D%E6%8E%A5%E7%B6%9A%E3%81%8C%E6%8B%92%E5%90%A6%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20%3C%2FSPAN%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%9Afirmware-imx-1_5.4-r0%20do_fetch%EF%BC%9A%E9%96%A2%E6%95%B0%E3%81%AE%E5%A4%B1%E6%95%97%EF%BC%9AURL%E3%81%AE%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%81%AE%E5%A4%B1%E6%95%97%EF%BC%9A%20'%3CA%20href%3D%22https%3A%2F%2Fgit.freescale.com%2Fimx%2Fimx-firmware.git%3Bbranch%3Dmaster%3Bdestsuffix%3D%2Fopt%2Fyocto%2Ffsl-release-bsp%2Ffsl_build_x11%2Ftmp%2Fwork%2Fcortexa9hf-neon-mx6qdl-poky-linux-gnueabi%2Ffirmware-imx%2F1_5.4-r0%2Ffirmware-imx-5.4%2Fgit%22%20style%3D%22color%3A%20%23ff0000%3B%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Egit%3A%2F%2Fgit.freescale.com%2Fimx%2Fimx-firmware.git%3Bbranch%3Dmaster%3Bdestsuffix%3D%2Fopt%2Fyocto%2Ffsl-release-bsp%2Ffsl_build_x11%2Ftmp%2Fwork%2Fcortexa9hf-neon-mx6qdl-poky-linux-gnueabi%2Ffirmware-imx%2F1_5.4-r0%2Ffirmware-imx-5.4%2Fgit%3C%2FA%3E'%E3%80%82%E3%81%A9%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8B%E3%82%89%E3%82%82URL%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%80%814.1.15%E3%81%8Cgit.freescale.com%E3%81%8B%E3%82%89git2%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81firmware-imx%20git2%20%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%80%81%E3%81%BE%E3%81%9A%E8%A7%A3%E5%87%8D%E3%81%97%E3%81%A6%E3%81%8B%E3%82%89%E3%80%81%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%20downloads%2Fgit2%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%97%E3%80%81%E3%80%8Cbitbake%20firmware-imx%E3%80%8D%E3%82%92%E5%86%8D%E5%BA%A6%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1104028%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6_All%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1703467%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20git.freescale.com%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1703467%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E6%80%A5%E3%81%8E%E3%81%A7%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2bin%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%80%81firmware.gut%E3%82%92git2%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81bitbake%E3%81%8C%E3%81%BE%E3%81%A0%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%7C%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%9A%E9%96%A2%E6%95%B0%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9Ado_configure%20(%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%2Fhome%2Fmsabnam%2Fw117%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Fqemu-native%2F2.5.0-r1%2Ftemp%2Flog.do_configure.23854%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99)%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%9A%E3%82%BF%E3%82%B9%E3%82%AF1187%20(virtual%3Anative%3A%2Fhome%2Fmsabnam%2Fw117%2FEagle-Distribution%2Foe-core%2Fmeta%2Frecipes-devtools%2Fqemu%2Fqemu_2.5.0.bb%2C%20do_configure)%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%80%8C1%E3%80%8D%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%EF%BC%9Afirmware-imx-1_5.4-r0do_fetch%EF%BC%9AURL%20git%3A%2F%2Fgithub.com%2FNXP%2Fimx-firmware.git%3Bprotocol%3Dhttps%3Bbranch%3Dmaster%3Bdestsuffix%3Dimx-firmware%3Bname%3Dimx-firmware%E3%81%AE%E5%8F%96%E5%BE%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%83%9F%E3%83%A9%E3%83%BC%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%E5%8F%96%E5%BE%97%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%9Afirmware-imx-1_5.4-r0do_fetch%EF%BC%9A%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%81%AE%E5%A4%B1%E6%95%97%EF%BC%9A%E3%82%A2%E3%83%83%E3%83%97%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%81%8B%E3%82%89%E3%81%A7%E3%81%82%E3%81%A3%E3%81%A6%E3%82%82master%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E5%86%85%E3%81%A7%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3951c1363abe95dd75ab3e9447f640d7807240236%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%9Afirmware-imx-1_5.4-r0do_fetch%EF%BC%9A%E9%96%A2%E6%95%B0%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9AURL%EF%BC%9A'git%3A%2F%2Fgithub.com%2FNXP%2Fimx-firmware.git%3Bprotocol%3Dhttps%3Bbranch%3Dmaster%3Bdestsuffix%3Dimx-firmware%3Bname%3Dimx-firmware'%E3%81%AE%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%A9%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8B%E3%82%89%E3%82%82URL%E3%82%92%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%9A%E5%A4%B1%E6%95%97%E3%81%AE%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%EF%BC%9A%2Fhome%2Fmsabnam%2Fw117%2Fbuild%2Ftmp%2Fwork%2Fcortexa9hf-neon-mx6qdl-oe-linux-gnueabi%2Ffirmware-imx%2F1_5.4-r0%2Ftemp%2Flog.do_fetch.23884%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%9A%E3%82%BF%E3%82%B9%E3%82%AF226%20(%2Fhome%2Fmsabnam%2Fw117%2FEagle-Distribution%2Foe-core%2F..%2Fmeta-fsl-arm%2Frecipes-bsp%2Ffirmware-imx%2Ffirmware-imx_5.4.bb%2C%20do_fetch)%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%80%8C1%E3%80%8D%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E6%A6%82%E8%A6%81%EF%BC%9A952%E5%80%8B%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%92%E8%A9%A6%E8%A1%8C%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A1926%E5%80%8B%E3%81%AF%E5%86%8D%E5%AE%9F%E8%A1%8C%E4%B8%8D%E8%A6%81%E3%81%A7%E3%80%813%E5%80%8B%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104044%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20git.freescale.com%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104044%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%99%E3%81%A7%E3%81%ABfirmare-imx%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81linux-imx-4.1.15%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%93%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%8C%E5%A4%A7%E3%81%8D%E3%81%99%E3%81%8E%E3%81%BE%E3%81%99%E3%80%82%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E3%82%B1%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E5%85%A5%E6%89%8B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%82%BF%E3%82%A4%E3%83%88%E3%83%AB%E3%81%AB%E7%A7%81%E3%81%AE%E5%90%8D%E5%89%8D%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E3%80%81%E7%A7%81%E3%81%8C%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E5%85%A5%E6%89%8B%E3%81%97%E3%81%A6%E3%81%8A%E9%80%81%E3%82%8A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-329745%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-329745%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104043%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20git.freescale.com%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104043%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fjoanxie%22%20target%3D%22_blank%22%3Ejoanxie%3C%2FA%3E%E2%80%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82bitbake%20fimware-imx%20-c%20clean%20all%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E5%86%8D%E3%81%B3bitbake%20firmware-imx%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81bitbake%20core-image-v2x-refbsp%E3%82%92%E8%A9%A6%E3%81%99%E3%81%A8%E5%90%8C%E3%81%98%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82bitbake%20core-image-v2x-refbsp%20-c%20cleanall%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E5%86%8D%E3%81%B3bitbake%20core-image-v2x-refbsp%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%82%82%E5%90%8C%E3%81%98%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F99646iB4BF702D3AA86BDF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104042%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20git.freescale.com%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104042%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%99%E3%81%A7%E3%81%AB%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E3%81%8A%E8%AA%AD%E3%81%BF%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82firmwar-imx%20git2%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AB%E8%A7%A3%E5%87%8D%E3%81%97%E3%81%A6%E3%81%8B%E3%82%89%E3%80%81%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92downloads%2Fgit2%E3%81%AB%E5%85%A5%E3%82%8C%E3%81%A6%E3%80%81%E6%AC%A1%E3%81%AB%E3%80%8Cbitbake%20firmware-imx%E3%80%8D%E3%82%92%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104041%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20git.freescale.com%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104041%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fjoanxie%22%20target%3D%22_blank%22%3Ejoanxie%3C%2FA%3E%3CSPAN%3E%E6%A7%98%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E3%83%A1%E3%83%BC%E3%83%AB%E3%81%A7%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Abseptember%40sedna.net%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ebseptember%40sedna.net%3C%2FA%3E%E3%81%BE%E3%81%A7%E9%80%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104040%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%20translate%3D%22no%22%3ERe%3A%20unable%20to%20connect%20to%20git.freescale.com%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104040%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A7%81%E3%82%82%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%82%92%E6%8A%B1%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Erepo%20init%20-u%E3%81%AB%E5%A4%89%E6%9B%B4%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CA%20style%3D%22color%3A%20%233d9ce7%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20text-decoration%3A%20underline%3B%20font-size%3A%2016px%3B%20padding%3A%200px%20calc(12px%20%2B%200.35ex)%200px%200px%3B%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fsource.codeaurora.org%252Fexternal%252Fimx%252Ffsl-arm-yocto-bsp%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Ffsl-arm-yocto-bsp%3C%2FA%3E%3CSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E-b%20imx-4.1.15-1.0.0_ga%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%81%BE%E3%81%9F%E3%80%81%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3Efirmware-imx-1_5.4-r0%E3%81%AF%E3%81%A9%E3%81%93%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F93563iED7A5BC7114AD414%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20git.freescale.com%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81linux-imx%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81Salesforce%E3%81%A7%E3%82%B1%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-329745%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-329745%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%BE%8C%E3%80%81%E3%82%B1%E3%83%BC%E3%82%B9%E7%95%AA%E5%8F%B7%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104038%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20git.freescale.com%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104038%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E4%B8%8A%E3%81%A7%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AE%E3%83%A1%E3%83%BC%E3%83%AB%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81%E3%82%B1%E3%83%BC%E3%82%B9%E3%82%92%E6%8F%90%E5%87%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8F%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%81%8A%E9%80%81%E3%82%8A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%93%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E5%A4%A7%E3%81%8D%E3%81%99%E3%81%8E%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-329745%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-329745%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%82%B1%E3%83%BC%E3%82%B9%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%82%B1%E3%83%BC%E3%82%B9%E7%95%AA%E5%8F%B7%E3%82%92%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20git.freescale.com%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi.%20Joan%20Xie.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%8F%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3Efirmware-imx%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E5%85%A5%E6%89%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%88%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Ajahong.ku%40geoplan.kr%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ejahong.ku%40geoplan.kr%3C%2FA%3E%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%81%99%E3%81%A7%E3%81%AB%E6%95%B0%E6%97%A5%E3%82%92%E8%B2%BB%E3%82%84%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A0%E3%81%91%E6%97%A9%E3%81%8F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E9%80%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104036%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20git.freescale.com%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104036%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ei.MX6UL%20EVK%E3%81%A7Yocto%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E3%80%81%E4%BB%A5%E4%B8%8B%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%90%8C%E6%A7%98%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9A%3CBR%20%2F%3E%3CSPAN%3E%24%20repo%20init%20-u%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fsource.codeaurora.org%252Fexternal%252Fimx%252Ffsl-arm-yocto-bsp%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Ffsl-arm-yocto-bsp%3C%2FA%3E%3CSPAN%3E%20-b%20imx-4.1.15-1.0.0_ga%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFUbuntu%2015.10%2064%E3%83%93%E3%83%83%E3%83%88%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%E3%81%AF%E6%95%B0%E6%99%82%E9%96%93%E9%80%B2%E8%A1%8C%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%EF%BC%9A%3C%2FP%3E%3CP%3Egit.freescale.com%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E...%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%9A%E9%96%A2%E6%95%B0%E3%81%AE%E5%A4%B1%E6%95%97%EF%BC%9AURL%EF%BC%9A'git%3A%20%2F%2Fgit.freescale.com%2Fimx%2Flinux-2.6-imx.git%3B%20protocol%3Dgit%3B%20branch%3Dimx_4.1.15_1.0.0_ga'%20%E3%81%AE%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%81%AB%E5%A4%B1%E6%95%97%E3%80%82%E3%81%A9%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8B%E3%82%89%E3%82%82URL%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20git.freescale.com%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Efirmware-imx%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81git%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Edownloads%2Fgit2%E3%81%AB%E5%85%A5%E3%82%8C%E3%80%81%E5%86%8D%E5%BA%A6%E3%80%8Cbitbake%20firmware-imx%E3%80%8D%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3Elinux-imx%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%A1%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%8A%E9%80%81%E3%82%8A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104034%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20unable%20to%20connect%20to%20git.freescale.com%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104034%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AE%E3%83%A1%E3%83%BC%E3%83%AB%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AF%3CA%20href%3D%22mailto%3Alongbin%40yada.com.cn%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Elongbin%40yada.com.cn%3C%2FA%3E%E3%81%A7%E3%81%99%E3%80%82%E3%81%A9%E3%81%86%E3%81%9E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104033%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20git.freescale.com%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104033%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%A1%E3%83%BC%E3%83%AB%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82firmware-imx%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%81%8A%E9%80%81%E3%82%8A%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E8%80%83%E3%81%88%E3%81%95%E3%81%9B%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82Ubuntu%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%A4%A7%E3%81%8D%E3%81%99%E3%81%8E%E3%81%A6%E3%81%93%E3%81%93%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104031%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20git.freescale.com%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104031%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20href%3D%22mailto%3Alongbin%40longbin-virtual-machine%3A~%2FDownloads%2Ffsl-release-bsp%2Fbuild_qt5%24%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Elongbin%40longbin-virtual-machine%3A~%2FDownloads%2Ffsl-release-bsp%2Fbuild_qt5%24%3C%2FA%3E%20bitbake%20firmware-imx%20-c%20cleanall%3CBR%20%2F%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%EF%BC%9A100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20ETA%EF%BC%9A%20%26nbsp%3B00%3A00%3A00%3CBR%20%2F%3E%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8B%E3%82%892792%E4%BB%B6%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E6%A7%8B%E6%88%90%EF%BC%9A%3CBR%20%2F%3EBB_VERSION%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%221.30.0%22%3CBR%20%2F%3EBUILD_SYS%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%22x86_64-linux%22%3CBR%20%2F%3ENATIVELSBSTRING%26nbsp%3B%26nbsp%3B%20%3D%20%22Ubuntu-14.04%22%3CBR%20%2F%3ETARGET_SYS%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%22arm-poky-linux-gnueabi%22%3CBR%20%2F%3EMACHINE%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%22imx6ull14x14evk%22%3CBR%20%2F%3EDISTRO%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%22fsl-imx-fb%22%3CBR%20%2F%3EDISTRO_VERSION%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%224.1.15-2.1.0%22%3CBR%20%2F%3ETUNE_FEATURES%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%22arm%20armv7ve%20vfp%26nbsp%3B%20neon%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20callconvention-hard%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20cortexa7%22%3CBR%20%2F%3ETARGET_FPU%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%22hard%22%3CBR%20%2F%3E%E3%83%A1%E3%82%BF%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3Emeta-poky%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%22HEAD%3Af5da2a5913319ad6ac2141438ba1aa17576326ab%22%3CBR%20%2F%3Emeta-oe%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3Emeta-multimedia%26nbsp%3B%26nbsp%3B%20%3D%20%22HEAD%3A247b1267bbe95719cd4877d2d3cfbaf2a2f4865a%22%3CBR%20%2F%3Emeta-fsl-arm%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%22HEAD%3Abe78894e4682f111575470fb23e51e6ba523508d%22%3CBR%20%2F%3Emeta-fsl-arm-extra%20%3D%20%22HEAD%3A3dfb82fc7e703eae9891b3ffda0e9393701f2396%22%3CBR%20%2F%3Emeta-fsl-demos%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%22HEAD%3Aa165068f8a0d1cf29aabe4b4053f28be1c2aa492%22%3CBR%20%2F%3Emeta-bsp%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3Emeta-sdk%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%22HEAD%3Af0e54cdf7a1c6d35976b0be80ded28a7f019b567%22%3CBR%20%2F%3Emeta-browser%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%22HEAD%3A77736988073a5d90fcff9d0005c8477332ede387%22%3CBR%20%2F%3Emeta-gnome%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3Emeta-networking%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3Emeta-python%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3Emeta-filesystems%26nbsp%3B%20%3D%20%22HEAD%3A247b1267bbe95719cd4877d2d3cfbaf2a2f4865a%22%3CBR%20%2F%3Emeta-qt5%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%22HEAD%3Accae79be69c5268df3b47e4e14cea0591c39a531%22%3C%2FP%3E%3CP%3E%E6%B3%A8%EF%BC%9ARunQueue%E3%81%AE%E6%BA%96%E5%82%99%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9ARunQueue%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%AE%9F%E8%A1%8C%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E6%A6%82%E8%A6%81%EF%BC%9A3%E3%81%A4%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%92%E8%A9%A6%E8%A1%8C%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A10%E3%81%AF%E5%86%8D%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CA%20href%3D%22mailto%3Alongbin%40longbin-virtual-machine%3A~%2FDownloads%2Ffsl-release-bsp%2Fbuild_qt5%24%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Elongbin%40longbin-virtual-machine%3A~%2FDownloads%2Ffsl-release-bsp%2Fbuild_qt5%24%3C%2FA%3E%20bitbake%20firmware-imx%3CBR%20%2F%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%3A%20100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20ETA%3A%2000%3A00%3A00%3CBR%20%2F%3E%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8B%E3%82%892792%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%AD%E3%83%A5%E3%83%BC%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E6%A7%8B%E6%88%90%EF%BC%9A%3CBR%20%2F%3EBB_VERSION%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%221.30.0%22%3CBR%20%2F%3EBUILD_SYS%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%22x86_64-linux%22%3CBR%20%2F%3ENATIVELSBSTRING%26nbsp%3B%26nbsp%3B%20%3D%20%22Ubuntu-14.04%22%3CBR%20%2F%3ETARGET_SYS%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%22arm-poky-linux-gnueabi%22%3CBR%20%2F%3EMACHINE%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%22imx6ull14x14evk%22%3CBR%20%2F%3EDISTRO%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%22fsl-imx-fb%22%3CBR%20%2F%3EDISTRO_VERSION%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%224.1.15-2.1.0%22%3CBR%20%2F%3ETUNE_FEATURES%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%22arm%20armv7ve%20vfp%26nbsp%3B%20neon%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20callconvention-hard%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20cortexa7%22%3CBR%20%2F%3ETARGET_FPU%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%22hard%22%3CBR%20%2F%3E%E3%83%A1%E3%82%BF%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3Emeta-poky%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%22HEAD%3Af5da2a5913319ad6ac2141438ba1aa17576326ab%22%3CBR%20%2F%3Emeta-oe%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3Emeta-multimedia%26nbsp%3B%26nbsp%3B%20%3D%20%22HEAD%3A247b1267bbe95719cd4877d2d3cfbaf2a2f4865a%22%3CBR%20%2F%3Emeta-fsl-arm%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%22HEAD%3Abe78894e4682f111575470fb23e51e6ba523508d%22%3CBR%20%2F%3Emeta-fsl-arm-extra%20%3D%20%22HEAD%3A3dfb82fc7e703eae9891b3ffda0e9393701f2396%22%3CBR%20%2F%3Emeta-fsl-demos%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%22HEAD%3Aa165068f8a0d1cf29aabe4b4053f28be1c2aa492%22%3CBR%20%2F%3Emeta-bsp%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3Emeta-sdk%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%22HEAD%3Af0e54cdf7a1c6d35976b0be80ded28a7f019b567%22%3CBR%20%2F%3Emeta-browser%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%22HEAD%3A77736988073a5d90fcff9d0005c8477332ede387%22%3CBR%20%2F%3Emeta-gnome%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3Emeta-networking%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3Emeta-python%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3Emeta-filesystems%26nbsp%3B%20%3D%20%22HEAD%3A247b1267bbe95719cd4877d2d3cfbaf2a2f4865a%22%3CBR%20%2F%3Emeta-qt5%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20%22HEAD%3Accae79be69c5268df3b47e4e14cea0591c39a531%22%3C%2FP%3E%3CP%3E%E6%B3%A8%EF%BC%9ARunQueue%E3%81%AE%E6%BA%96%E5%82%99%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9ASetScene%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%AE%9F%E8%A1%8C%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9ARunQueue%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E5%AE%9F%E8%A1%8C%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%EF%BC%9Afirmware-imx-1_5.4-r0do_fetch%3A%20URL%20git%3A%2F%2Fgit.freescale.com%2Fimx%2Fimx-firmware.git%3Bbranch%3Dmaster%3Bdestsuffix%3D%2Fhome%2Flongbin%2FDownloads%2Ffsl-release-bsp%2Fbuild_qt5%2Ftmp%2Fwork%2Fcortexa7hf-neon-mx6ul-poky-linux-gnueabi%2Ffirmware-imx%2F1_5.4-r0%2Ffirmware-imx-5.4%2Fgit%20%E3%81%AE%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%81%AB%E5%A4%B1%E6%95%97%E3%80%81%E5%8F%AF%E8%83%BD%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AFMIRRORS%E3%82%92%E8%A9%A6%E8%A1%8C%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%9Afirmware-imx-1_5.4-r0do_fetch%3A%20%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%81%AE%E5%A4%B1%E6%95%97%EF%BC%9A%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89128%E3%81%A7%E5%A4%B1%E6%95%97%E3%80%81%E5%87%BA%E5%8A%9B%EF%BC%9A%3CBR%20%2F%3E%E3%83%99%E3%82%A2%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%20'%2Fhome%2Flongbin%2FDownloads%2Ffsl-release-bsp%2Fdownloads%2F%2Fgit2%2Fgit.freescale.com.imx.imx-firmware.git'%20%E3%81%AB%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E4%B8%AD...%3CBR%20%2F%3E%E8%87%B4%E5%91%BD%E7%9A%84%EF%BC%9Agit.freescale.com%E3%81%AB%E6%8E%A5%E7%B6%9A%E4%B8%8D%E5%8F%AF%E8%83%BD%EF%BC%9A%3CBR%20%2F%3Egit.freescale.com%5B0%3A%20192.88.156.202%5D%3A%20errno%3D%E6%8E%A5%E7%B6%9A%E6%8B%92%E5%90%A6%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%9Afirmware-imx-1_5.4-r0do_fetch%EF%BC%9A%E9%96%A2%E6%95%B0%E3%81%AE%E5%A4%B1%E6%95%97%EF%BC%9AURL%E3%81%AE%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%81%AB%E5%A4%B1%E6%95%97%EF%BC%9A%20'git%3A%2F%2Fgit.freescale.com%2Fimx%2Fimx-firmware.git%3B%20branch%3Dmaster%3B%20destsuffix%3D%2Fhome%2Flongbin%2FDownloads%2Ffsl-release-bsp%2Fbuild_qt5%2Ftmp%2Fwork%2Fcortexa7hf-neon-mx6ul-poky-linux-gnueabi%2Ffirmware-imx%2F1_5.4-r0%2Ffirmware-imx-5.4%2Fgit'%E3%80%82%E3%81%A9%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8B%E3%82%89%E3%82%82URL%E3%82%92%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%9A%E9%9A%9C%E5%AE%B3%E3%81%AE%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E4%BB%A5%E4%B8%8B%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%EF%BC%9A%2Fhome%2Flongbin%2FDownloads%2Ffsl-release-bsp%2Fbuild_qt5%2Ftmp%2Fwork%2Fcortexa7hf-neon-mx6ul-poky-linux-gnueabi%2Ffirmware-imx%2F1_5.4-r0%2Ftemp%2Flog.do_fetch.4056%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%9A%E3%82%BF%E3%82%B9%E3%82%AF4%EF%BC%88%2Fhome%2Flongbin%2FDownloads%2Ffsl-release-bsp%2Fsources%2Fmeta-fsl-bsp-release%2Fimx%2Fmeta-bsp%2Frecipes-bsp%2Ffirmware-imx%2Ffirmware-imx_5.4.bb%2C%20do_fetch%EF%BC%89%E3%81%AB%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%80%8C1%E3%80%8D%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E6%A6%82%E8%A6%81%EF%BC%9A346%E4%BB%B6%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%92%E8%A9%A6%E3%81%BF%E3%80%81%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A1345%E4%BB%B6%E3%81%AF%E5%86%8D%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%811%E4%BB%B6%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E7%8F%BE%E5%9C%A8%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%88358%E4%BB%B6%E4%B8%AD325%E4%BB%B6%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E6%A6%82%E8%A6%81%EF%BC%9A1%E4%BB%B6%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%9A%3CBR%20%2F%3E%2Fhome%2Flongbin%2FDownloads%2Ffsl-release-bsp%2Fsources%2Fmeta-fsl-bsp-release%2Fimx%2Fmeta-bsp%2Frecipes-bsp%2Ffirmware-imx%2Ffirmware-imx_5.4.bb%E3%80%81do_fetch%3CBR%20%2F%3E%E6%A6%82%E8%A6%81%EF%BC%9A1%E4%BB%B6%E3%81%AE%E8%AD%A6%E5%91%8A%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E6%A6%82%E8%A6%81%EF%BC%9A2%E3%81%A4%E3%81%AEERROR%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%80%81%E9%9D%9E%E3%82%BC%E3%83%AD%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FF013C32-40ED-46c2-B9FE-CCD3FC90476C.png%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FF013C32-40ED-46c2-B9FE-CCD3FC90476C.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FF013C32-40ED-46c2-B9FE-CCD3FC90476C.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F105660iBFBF34A38F161A51%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FF013C32-40ED-46c2-B9FE-CCD3FC90476C.png%22%20alt%3D%22FF013C32-40ED-46c2-B9FE-CCD3FC90476C.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BB%8E%E5%9B%BE%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%E6%88%91downloads%E6%98%AF%E6%9C%89firmware-imx5.4.bin%E5%92%8Cfirmware-imx-5.4.bin.done%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104030%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20git.freescale.com%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104030%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%80%8Cbitbake%20firmware-imx%20-c%20cleanall%E3%80%8D%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%80%81%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB2%E3%81%A4%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%9D%E3%81%93%E3%81%AB%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%A6%E3%81%8B%E3%82%89%E3%80%81%E5%86%8D%E5%BA%A6bitbake%20firmware-imx%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104029%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20unable%20to%20connect%20to%20git.freescale.com%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104029%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%812%E3%81%A4%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E8%B3%AA%E5%95%8F1%3Afirmware-imx-5.4.bin%E3%81%A8firmware-imx-5.4.bin.done%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8Cbitbake%E3%81%A7%E4%BD%95%E3%82%92%E3%81%97%E3%81%A6%E3%82%82firmware-imx%20%E3%81%A8%20bitbake%20fsl-image-qt5%20%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%A7%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EWARNING%3A%20firmware-imx-1_5.4-r0%20do_fetch%3A%20Failed%20to%20fetch%20URL%20git%3A%2F%2Fgit.freescale.com%2Fimx%2Fimx-firmware.git%3Bbranch%3Dmaster%3Bdestsuffix%3D%2Fhome%2Flongbin%2FDownloads%2Ffsl-release-bsp%2Fbuild_qt5%2Ftmp%2Fwork%2Fcortexa7hf-neon-mx6ul-poky-linux-gnueabi%2Ffirmware-imx%2F1_5.4-r0%2Ffirmware-imx-5.4%2Fgit%2C%20attempting%20MIRRORS%20if%20available%3CBR%20%2F%3EERROR%3A%20firmware-imx-1_5.4-r0%20do_fetch%3A%20Fetcher%20failure%3A%20Fetch%20command%20failed%20with%20exit%20code%20128%2C%20output%3A%3CBR%20%2F%3ECloning%20into%20bare%20repository%20'%2Fhome%2Flongbin%2FDownloads%2Ffsl-release-bsp%2Fdownloads%2F%2Fgit2%2Fgit.freescale.com.imx.imx-firmware.git'...%3CBR%20%2F%3Efatal%3A%20unable%20to%20connect%20to%20git.freescale.com%3A%3CBR%20%2F%3Egit.freescale.com%5B0%3A%20192.88.156.202%5D%3A%20errno%3DConnection%20refused%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EERROR%3A%20firmware-imx-1_5.4-r0%20do_fetch%3A%20Function%20failed%3A%20Fetcher%20failure%20for%20URL%3A%20'git%3A%2F%2Fgit.freescale.com%2Fimx%2Fimx-firmware.git%3Bbranch%3Dmaster%3Bdestsuffix%3D%2Fhome%2Flongbin%2FDownloads%2Ffsl-release-bsp%2Fbuild_qt5%2Ftmp%2Fwork%2Fcortexa7hf-neon-mx6ul-poky-linux-gnueabi%2Ffirmware-imx%2F1_5.4-r0%2Ffirmware-imx-5.4%2Fgit'.%20Unable%20to%20fetch%20URL%20from%20any%20source.%3CBR%20%2F%3EERROR%3A%20Logfile%20of%20failure%20stored%20in%3A%20%2Fhome%2Flongbin%2FDownloads%2Ffsl-release-bsp%2Fbuild_qt5%2Ftmp%2Fwork%2Fcortexa7hf-neon-mx6ul-poky-linux-gnueabi%2Ffirmware-imx%2F1_5.4-r0%2Ftemp%2Flog.do_fetch.4135%3CBR%20%2F%3EERROR%3A%20Task%204%20(%2Fhome%2Flongbin%2FDownloads%2Ffsl-release-bsp%2Fsources%2Fmeta-fsl-bsp-release%2Fimx%2Fmeta-bsp%2Frecipes-bsp%2Ffirmware-imx%2Ffirmware-imx_5.4.bb%2C%20do_fetch)%20failed%20with%20exit%20code%20'1'%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22896090E0-69EE-45b7-AA14-05F85C020A81.png%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22896090E0-69EE-45b7-AA14-05F85C020A81.png%22%20style%3D%22width%3A%20946px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22896090E0-69EE-45b7-AA14-05F85C020A81.png%22%20style%3D%22width%3A%20946px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F104997iB595B46503A36E38%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22896090E0-69EE-45b7-AA14-05F85C020A81.png%22%20alt%3D%22896090E0-69EE-45b7-AA14-05F85C020A81.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C2%3A%20Linux-imx%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82bitbake%20-c%20fetchall%20linux-imx%E3%81%A7%E3%82%82bitbake%20fsl-image-qt5%E3%81%A7%E3%82%82%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E0%3A%20linux-imx-4.1.15-r0%20do_fetch%20(pid%204449)%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎04-03-2020 08:31 PM
更新者:
