iMX6QD How to Add 24-bit LVDS Support in Android
Introduction
LVDS display panel driving data flow:
Display quality:
To get the best display quality for 24bit LVDS display panel in Android, we should use 32bit framebuffer, make IPUv3 display Engine and LDB output 24bit pixels, since RGB component information is aligned from source to destination.
2 stages to enable display:
Uboot splash screen and Kernel framebuffer
Guidelines
Uboot splash screen:
   Change should be done in board file, like board/freescale/mx6q_sabresd/mx6q_sabresd.c:
   1. Set video mode in struct fb_videomode according to the new 24bit LVDS display panel’s spec(please, refer to the example at the end of this doc).
   2. Set up pwm, iomux/display related clock trees in lcd_enable(). Note that these should be aligned with Kernel settings to support smooth UI transition
       from Uboot splash screen to Kernel framebuffer.
   3. Set the output pixel format of IPUv3 display engine and LDB to IPU_PIX_FMT_RGB24 when calling ipuv3_fb_init().
   4. Set pixel clock according to the new 24bit LVDS display panel’s spec when calling ipuv3_fb_init().
   5. If dual LDB channels are needed to support tough display video mode(high resolution or high pixel clock frequency), we need to enable both of the two LDB
       channels and set LDB to work at split mode. LDB_CTRL register should be set accordingly in lcd_enable().
Kernel framebuffer:
   As we may add ‘video=‘  and ‘ldb=’ options in kernel bootup command line, Kernel code is more flexible to handle different LVDS display panels with various display color depth than Uboot code. For detail description of ‘video=’ and ‘ldb=’ option, please refer to MXC Linux BSP release notes and Android User Guide. Some known points are:
   1. Add a video mode in struct fb_videomode in drivers/video/mxc/ldb.c according to the new 24bit LVDS display panel’s spec(please, refer to the example at
   2. Set up pwm backlight/display related iomux in platform code.
  3. Set appropriate ‘video=‘ option in kernel bootup command line, for example:
       video=mxcfb0:dev=ldb,LDB-NEW,if=RGB24,fbpix=RGB32
    4. Set appropriate ‘ldb=‘ option in kernel bootup command line if dual LDB channels are needed to support tough display video mode, for example:
       ldb=spl0 (IPUv3 DI0 is used)  or  ldb=spl1 (IPUv3 DI1 is used)
   5. Set appropriate ‘fbmem=‘ option in kernel bootup command line to reserve enough memory for framebuffer. For example, if we use 1280x800 LVDS panel
       for fb0 and fb0 is in RGB32 pixel format, then ‘fbmem=12M’ should be used, since the formula is:
       fbmem= width*height*3(triple buf)*Bytes_per_pixel= 1280*800*3*4B=12MB
An Example to Set struct fb_videomode:
   Let’s take a look at the timing description quoted from a real 1280x800@60 24bit LVDS panel spec:
And, standard linux struct fb_videomode definition in include/linux/fb.h:
struct fb_videomode {
        const char *name;       /* optional */
        u32 refresh;            /* optional */
        u32 xres;
        u32 yres;
        u32 pixclock;
        u32 left_margin;
        u32 right_margin;
        u32 upper_margin;
        u32 lower_margin;
        u32 hsync_len;
        u32 vsync_len;
        u32 sync;
        u32 vmode;
        u32 flag;
   What we need to do is to set every field of struct fb_videomode correctly according to the timing description of LVDS display panel’s spec:
    1. name: we can set it to ‘LDB-WXGA’.
   2. refresh: though it’s optional, we can set it to typical value, that is, 60(60Hz refresh rate).
   3. xres: the active width, that is, 1280.
   4. yres: the active height, that is, 800.
   5. pixclock: calculate with this formula – pixclock=(10^12)/clk_freq. Here, typically, for this example, pixclock=(10^12)/71100000=14065.
   6. left_margin/right_margin/hsync_len:
       They are the same to HS Back Porch(HBP)/HS Front Porch(HFP)/HS Width(HW) in the spec. Since the spec only tells us that typically
       HBP+HFP+HW=160. We may set left_margin=40, right_margin=40, hsync_len=80.
   7. upper_margin/lower_margin/vsync_len:
       Similar to horizontal timing, the vertical ones can be set to upper_margin=10, lower_margin=3, vsync_len=10.
   8. sync: Since the timing chart tells us that hsync/vsync are active low, so we don’t need to set FB_SYNC_HOR_HIGH_ACT or
       FB_SYNC_VERT_HIGH_ACT. Moreover, clock polarity and data polarity are invalid, so we set sync to be zero here.
   9. vmode: this is a progressive video mode, so set vmode to FB_VMODE_NONINTERLACED.
   10. flag: the video mode is provided by driver, so set flag to FB_MODE_IS_DETAILED.
ラベル(3)
コメント
Hi There,
Thanks for this detailed guide, very helpful!
However I can't seem to see any changes to my pixel clock, can you please elaborate on your u-boot step #4 "  4. Set pixel clock according to the new 24bit LVDS display panel’s spec when calling ipuv3_fb_init()."
How is this actually done?  Which file should we be modifying in u-boot.  Anything we change it always seems to output 75MHz.   We are using the mainline u-boot 2014-10 source.
Patrick
Thank you for the tutorial. But as i see, it is not applicable in Android Lollipop release, because the "ldb.c" is different.
In my case the timings are fine. I have a LVDS panel that does not support EDID. I just want to change the default resolution from 1024x768 to 1024x600. My lvds panel works fine but the bottom stays outside of the panel. How can i fix this in Android Lollipop?
LCD:CHIMEI G070Y2-L01
MCU:IMX6D
{“LBD-CHIMEI”,60,800,480,33898,
190,0,
14,14,
2,2,
0,
FB_VMODE_NONINTERLACED,
BF_MODE_IS_DETAILED,
LCD AA084BX01 works fine
please help
I have found the problem,it seems pixclock can only be set to up 40MHz,lower then 40MHz it's always output 40MHz,and my lcd can only works in 27MHz to 32Mhz
%3CLINGO-SUB%20id%3D%22lingo-sub-1104108%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX6QD%20Android%E3%81%A724%E3%83%93%E3%83%83%E3%83%88LVDS%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104108%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20id%3D%22toc-hId-380605108%22%20id%3D%22toc-hId-1304187640%22%3E%E3%81%AF%E3%81%98%E3%82%81%E3%81%AB%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%83%95%E3%83%AD%E3%83%BC%E3%82%92%E9%A7%86%E5%8B%95%E3%81%99%E3%82%8BLVDS%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%91%E3%83%8D%E3%83%AB%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Picture2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Picture2.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F38257i3412AADD37D3D9C4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Picture2.png%22%20alt%3D%22Picture2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPicture2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E5%93%81%E8%B3%AA%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3EAndroid%E3%81%AE24%E3%83%93%E3%83%83%E3%83%88LVDS%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%91%E3%83%8D%E3%83%AB%E3%81%A7%E6%9C%80%E9%AB%98%E3%81%AE%E8%A1%A8%E7%A4%BA%E5%93%81%E8%B3%AA%E3%82%92%E5%BE%97%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E32%E3%83%93%E3%83%83%E3%83%88%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81IPUv3%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%E3%81%A8LDB%E3%81%8C24%E3%83%93%E3%83%83%E3%83%88%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E8%A1%A8%E7%A4%BA%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE2%E3%81%A4%E3%81%AE%E3%82%B9%E3%83%86%E3%83%BC%E3%82%B8%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3EUboot%E3%82%B9%E3%83%97%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%81%A8%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1426849355%22%20id%3D%22toc-hId--503266823%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%82%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%237f7f7f%3B%20font-family%3A%20Arial%3B%20font-size%3A%2037px%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--736287881%22%20id%3D%22toc-hId-187294651%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3EUboot%3C%2FSPAN%3E%E3%82%B9%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E3%83%97%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E7%94%BB%E9%9D%A2%3A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FH2%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E5%A4%89%E6%9B%B4%E3%81%AF%E3%80%81board%2F%20freescale%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%2Fmx6q_sabresd%2Fmx6q_sabresd.c%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E3%81%AA%E3%81%A9%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E8%A1%8C%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%20%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E1.%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E6%96%B0%E3%81%97%E3%81%84%2024bit%20LVDS%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%20%E3%83%91%E3%83%8D%E3%83%AB%E3%81%AE%E4%BB%95%E6%A7%98%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E3%80%81struct%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%22%3E%20fb_videomode%20%E3%81%A7%E3%83%93%E3%83%87%E3%82%AA%20%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99(%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AB%E3%81%82%E3%82%8B%E4%BE%8B%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84)%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E2.%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20lcd_enable()%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E3%81%A7%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20pwm%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20iomux%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%2Fdisplay%20%E9%96%A2%E9%80%A3%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%83%84%E3%83%AA%E3%83%BC%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%22%3E%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%E3%81%93%E3%82%8C%E3%82%89%E3%81%AF%E3%80%81%E3%82%B9%E3%83%A0%E3%83%BC%E3%82%BA%E3%81%AAUI%E7%A7%BB%E8%A1%8C%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E8%A8%AD%E5%AE%9A%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3EUboot%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E3%81%AE%E3%82%B9%E3%83%97%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E7%94%BB%E9%9D%A2%E3%81%8B%E3%82%89%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%3C%2FSPAN%3E%E3%81%B8%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E3.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%22%3E%20ipuv3_fb_init()%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E9%9A%9B%E3%81%AB%20%E3%80%81IPUv3%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%E3%81%A8LDB%E3%81%AE%E5%87%BA%E5%8A%9B%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%82%92IPU_PIX_FMT_RGB24%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%20%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%204.%20ipuv3_fb_init()%20%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E3%81%A8%E3%81%8D%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%2024bit%20LVDS%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%20%E3%83%91%E3%83%8D%E3%83%AB%E3%81%AE%E4%BB%95%E6%A7%98%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%22%3E%205.%E3%82%BF%E3%83%95%E3%81%AA%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%93%E3%83%87%E3%82%AA%E3%83%A2%E3%83%BC%E3%83%89(%E9%AB%98%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%81%BE%E3%81%9F%E3%81%AF%E9%AB%98%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0)%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%83%87%E3%83%A5%E3%82%A2%E3%83%ABLDB%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%22%3E%E3%80%812%E3%81%A4%E3%81%AELDB%E3%81%AE%E4%B8%A1%E6%96%B9%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%22%3E%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81LDB%20%E3%82%92%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E5%88%86%E5%89%B2%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BFLDB_CTRL%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Elcd_enable%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E()%3C%2FSPAN%3E%E3%81%A7%E3%81%9D%E3%82%8C%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId-1751224952%22%20id%3D%22toc-hId--1620159812%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3EKernel%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Eframebuffer%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3A%3C%2FSPAN%3E%3C%2FH2%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20%E3%83%96%E3%83%BC%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AB%20'video%3D'%20%E3%81%A8%20'%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20ldb%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%3D'%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20Uboot%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E3%82%B3%E3%83%BC%E3%83%89%20%E3%82%88%E3%82%8A%E3%82%82%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E8%A1%A8%E7%A4%BA%E8%89%B2%E6%B7%B1%E5%BA%A6%E3%82%92%E6%8C%81%E3%81%A4%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%20LVDS%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%91%E3%83%8D%E3%83%AB%E3%82%92%E6%9F%94%E8%BB%9F%E3%81%AB%E5%87%A6%E7%90%86%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E3%80%82'video%3D'%20%E3%81%A8%20'%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20ldb%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%3D'%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81MXC%20Linux%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%22%3E%20BSP%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%88%E3%81%A8%20Android%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E6%97%A2%E7%9F%A5%E3%81%AE%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E1.%20%E6%96%B0%E3%81%97%E3%81%84%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%22%3E%2024bit%20LVDS%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%20%E3%83%91%E3%83%8D%E3%83%AB%E3%81%AE%E4%BB%95%E6%A7%98%20%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81%20drivers%2Fvideo%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20mxc%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20ldb.c%20%E3%81%AE%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20struct%20fb_videomode%20%E3%81%AB%20%E3%83%93%E3%83%87%E3%82%AA%20%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%20(%E6%AC%A1%E3%81%AE%E4%BE%8B%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84)%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%3B%22%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E7%B5%82%E3%82%8F%E3%82%8A)%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E2.%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20pwm%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E3%83%90%E3%83%83%E3%82%AF%E3%83%A9%E3%82%A4%E3%83%88%2F%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E9%96%A2%E9%80%A3%E3%81%AE%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20iomux%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%20%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E3.%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E3%83%96%E3%83%BC%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%20%E3%81%A7%E9%81%A9%E5%88%87%E3%81%AA%E3%80%8Cvideo%3D%E3%80%8D%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%20%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20video%3Dmxcfb0%3Adev%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Eldb%2CLDB-NEW%2Cif%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3DRGB24%2Cfbpix%3DRGB32%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E4.%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%96%E3%83%BC%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7%E3%80%81%E3%82%BF%E3%83%95%E3%81%AA%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%93%E3%83%87%E3%82%AA%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E3%83%87%E3%83%A5%E3%82%A2%E3%83%ABLDB%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%20font-size%3A%2010pt%3B%22%3E%20%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%E3%80%81%20%E9%81%A9%E5%88%87%E3%81%AA%E3%80%8C%20ldb%20%3D%E3%80%8D%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%20%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Eldb%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3Dspl0%20(IPUv3%20DI0%E3%82%92%E4%BD%BF%E7%94%A8)%20%E3%81%BE%E3%81%9F%E3%81%AF%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Eldb%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3Dspl1%20(IPUv3%20DI1%E3%82%92%E4%BD%BF%E7%94%A8)%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E5.%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Arial%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20%E3%83%96%E3%83%BC%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%20%E3%81%A7%E9%81%A9%E5%88%87%E3%81%AA%E3%80%8Cfbmem%3D%E3%80%8D%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E7%94%A8%E3%81%AB%E5%8D%81%E5%88%86%E3%81%AA%20%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%82%92%E7%A2%BA%E4%BF%9D%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E3%80%82%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%811280x800%20LVDS%20%E3%83%91%E3%83%8D%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Efb0%20%E3%81%A7%20fb0%20%E3%81%8C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20RGB32%20%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E5%BD%A2%E5%BC%8F%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E5%BC%8F%E3%81%8C%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81'fbmem%3D12M'%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Efbmem%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3D%20%E5%B9%85*%E9%AB%98%E3%81%95*3(%E3%83%88%E3%83%AA%E3%83%97%E3%83%AB%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3EBUF%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E)*%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3EBytes_per_pixel%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3D%201280*800*3*4B%3D12MB%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--56229511%22%20id%3D%22toc-hId-867353021%22%3E%3CSPAN%20style%3D%22color%3A%20%237f7f7f%3B%20font-size%3A%2014pt%3B%20font-family%3A%20Arial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E6%A7%8B%E9%80%A0%E4%BD%93%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20fb_videomode%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E4%BE%8B%3A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FH2%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%22%3E%20%E5%AE%9F%E9%9A%9B%E3%81%AE1280x800%4060%2024%E3%83%93%E3%83%83%E3%83%88LVDS%E3%83%91%E3%83%8D%E3%83%AB%E4%BB%95%E6%A7%98%E3%81%8B%E3%82%89%E5%BC%95%E7%94%A8%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AE%E8%AA%AC%E6%98%8E%E3%82%92%E8%A6%8B%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%82%87%E3%81%86%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%20font-size%3A%2012pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Picture3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Picture3.png%22%20style%3D%22width%3A%20735px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F38259i2340E2097AE2E05E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Picture3.png%22%20alt%3D%22Picture3.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPicture3.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Picture4.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Picture4.png%22%20style%3D%22width%3A%20693px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F38305i5F14991D91287EE7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Picture4.png%22%20alt%3D%22Picture4.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPicture4.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E3%81%BE%E3%81%9F%E3%80%81%E6%A8%99%E6%BA%96%E3%81%AE%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Elinux%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Estruct%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Efb_videomode%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20include%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Elinux%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Efb.h%3C%2FSPAN%3E%20%E3%81%A7%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%E6%A7%8B%E9%80%A0%E4%BD%93%20fb_videomode%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3Econst%20char%20*%E5%90%8D%E5%89%8D%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%E9%9A%8F%E6%84%8F*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3EU32%E3%83%AA%E3%83%95%E3%83%AC%E3%83%83%E3%82%B7%E3%83%A5%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%E9%9A%8F%E6%84%8F*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20u32%20xres%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20u32%20yres%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3EU32%20pixclock%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20u32%20left_margin%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3EU32%20right_margin%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20u32%20upper_margin%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3EU32%20lower_margin%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20u32%20hsync_len%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20u32%20vsync_len%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3EU32%E5%90%8C%E6%9C%9F%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20u32%20vmode%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20u32%20flag%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%22%3E%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%93%E3%81%A8%E3%81%AF%E3%80%81%20LVDS%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%20%E3%83%91%E3%83%8D%E3%83%AB%E3%81%AE%E4%BB%95%E6%A7%98%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E8%A8%98%E8%BF%B0%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E3%80%81struct%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20fb_videomode%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E8%A8%AD%E5%AE%9A%20%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%20font-size%3A%2010pt%3B%22%3E1.%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Ename%3A%20'LDB-WXGA'%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Arial%3B%20font-size%3A%2010pt%3B%22%3E2.%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E6%9B%B4%E6%96%B0%3A%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E5%80%A4%E3%80%81%E3%81%A4%E3%81%BE%E3%82%8A60(60Hz%E3%81%AE%E3%83%AA%E3%83%95%E3%83%AC%E3%83%83%E3%82%B7%E3%83%A5%E3%83%AC%E3%83%BC%E3%83%88)%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%3B%22%3E3.%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Exres%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3A%20%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AA%E5%B9%85%E3%80%81%E3%81%A4%E3%81%BE%E3%82%8A%201280%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%3B%22%3E4.%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Eyres%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3A%20%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AA%E9%AB%98%E3%81%95%E3%80%81%E3%81%A4%E3%81%BE%E3%82%8A%20800%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%3B%22%3E5.%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Epixclock%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3A%E6%AC%A1%E3%81%AE%E5%BC%8F%E3%81%A7%E8%A8%88%E7%AE%97%E3%81%97%E3%81%BE%E3%81%99%E2%80%93%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Epixclock%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3D(10%20%5E%2012)%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Eclk_freq%3C%2FSPAN%3E%E3%80%82%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%80%81%E9%80%9A%E5%B8%B8%E3%80%81%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E3%80%81pixclock%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3D(10%5E12)%2F71100000%3D14065%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%3B%22%3E%26nbsp%3B%26nbsp%3B%206.%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Eleft_margin%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Eright_margin%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Ehsync_len%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E4%BB%95%E6%A7%98%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E3%81%A7%E3%81%AFHS%E3%83%90%E3%83%83%E3%82%AF%E3%83%9D%E3%83%BC%E3%83%81(HBP)%2F%20HS%E3%83%95%E3%83%AD%E3%83%B3%E3%83%88%E3%83%9D%E3%83%BC%E3%83%81(HFP)%2F%20HS%E5%B9%85(HW)%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E3%80%82%E4%BB%95%E6%A7%98%E3%81%AF%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AB%E3%81%9D%E3%82%8C%E3%82%92%E6%95%99%E3%81%88%E3%82%8B%E3%81%A0%E3%81%91%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81%E9%80%9A%E5%B8%B8%E3%81%AF%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20HBP%2BHFP%2BHW%3D160%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Eleft_margin%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3D40%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Eright_margin%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3D40%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Ehsync_len%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3D80%3C%2FSPAN%3E%20%E3%81%A8%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%3B%22%3E%26nbsp%3B%26nbsp%3B%207.%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Eupper_margin%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Elower_margin%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Evsync_len%3C%2FSPAN%3E%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%E6%B0%B4%E5%B9%B3%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AB%E3%80%81%E5%9E%82%E7%9B%B4%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AF%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Eupper_margin%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3D10%3C%2FSPAN%3E%E3%80%81%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Elower_margin%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3D3%E3%80%81%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Evsync_len%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3D10%3C%2FSPAN%3E%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%3B%22%3E8.%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Esync%3A%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%83%81%E3%83%A3%E3%83%BC%E3%83%88%E3%81%AF%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Ehsync%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Evsync%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E3%81%8C%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%83%AD%E3%83%BC%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3EFB_SYNC_HOR_HIGH_ACT%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20FB_SYNC_VERT_HIGH_ACT%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%20%3C%2FSPAN%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E6%A5%B5%E6%80%A7%E3%81%A8%E3%83%87%E3%83%BC%E3%82%BF%E6%A5%B5%E6%80%A7%E3%81%AF%E7%84%A1%E5%8A%B9%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E5%90%8C%E6%9C%9F%E3%82%92%E3%82%BC%E3%83%AD%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%3B%22%3E9.%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Evmode%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3A%E3%81%93%E3%82%8C%E3%81%AF%E3%83%97%E3%83%AD%E3%82%B0%E3%83%AC%E3%83%83%E3%82%B7%E3%83%96%E3%83%93%E3%83%87%E3%82%AA%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Evmode%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E3%82%92FB_VMODE_NONINTERLACED%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%E3%80%82%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2016.0pt%3B%20font-family%3A%20Arial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E10.%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E3%83%95%E3%83%A9%E3%82%B0%3A%E3%83%93%E3%83%87%E3%82%AA%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%83%95%E3%83%A9%E3%82%B0%E3%82%92FB_MODE_IS_DETAILED%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%E3%80%82%20%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1104108%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E3%81%A8%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Dual%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Quad%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104113%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6QD%E3%81%AEAndroid%E3%81%A724%E3%83%93%E3%83%83%E3%83%88LVDS%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104113%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AF%E5%95%8F%E9%A1%8C%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AFpixclock%E3%81%8C40MHz%E3%81%BE%E3%81%A7%E3%81%97%E3%81%8B%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%8140MHz%E3%82%88%E3%82%8A%E4%BD%8E%E3%81%8F%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E5%B8%B8%E3%81%AB40MHz%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E7%A7%81%E3%81%AE%E6%B6%B2%E6%99%B6%E3%81%AF27MHz%E3%81%8B%E3%82%8932Mhz%E3%81%A7%E3%81%97%E3%81%8B%E5%8B%95%E4%BD%9C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104112%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6QD%E3%81%AEAndroid%E3%81%A724%E3%83%93%E3%83%83%E3%83%88LVDS%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104112%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220160624143341.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220160624143341.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F60343iA24647D399F51CC7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2220160624143341.png%22%20alt%3D%2220160624143341.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20160624143341.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22QQ%E5%9B%BE%E7%89%8720160624143437.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22QQ%E5%9B%BE%E7%89%8720160624143437.png%22%20style%3D%22width%3A%20831px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F60373iDD56DB8663F1E476%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22QQ%E5%9B%BE%E7%89%8720160624143437.png%22%20alt%3D%22QQ%E5%9B%BE%E7%89%8720160624143437.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EQQ%E5%9B%BE%E7%89%8720160624143437.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104110%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6QD%E3%81%AEAndroid%E3%81%A724%E3%83%93%E3%83%83%E3%83%88LVDS%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104110%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%8C%E8%A6%8B%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%20%22ldb.c%22%E3%81%AE%E3%81%A7%E3%80%81%3CSTRONG%3EAndroid%20Lollipop%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%AF%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSTRONG%3E%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%20%3CSTRONG%3E%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSTRONG%3E%E3%80%82%3CSTRONG%3EEDID%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84LVDS%E3%83%91%E3%83%8D%E3%83%AB%3C%2FSTRONG%3E%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CSTRONG%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%82%921024x768%E3%81%8B%E3%82%891024x600%E3%81%AB%E5%A4%89%E6%9B%B4%3C%2FSTRONG%3E%E3%81%97%E3%81%9F%E3%81%84%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82lvds%E3%83%91%E3%83%8D%E3%83%AB%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%BA%95%E9%83%A8%E3%81%AF%E3%83%91%E3%83%8D%E3%83%AB%E3%81%AE%E5%A4%96%E5%81%B4%E3%81%AB%E3%81%A8%E3%81%A9%E3%81%BE%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CSTRONG%3EAndroid%20Lollipop%3C%2FSTRONG%3E%E3%81%A7%E3%81%93%E3%82%8C%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104109%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AiMX6QD%E3%81%AEAndroid%E3%81%A724%E3%83%93%E3%83%83%E3%83%88LVDS%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104109%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AA%E3%82%AC%E3%82%A4%E3%83%89%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%97%E3%81%9F!%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%AF%E7%A7%81%E3%81%AE%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AB%E4%BB%BB%E6%84%8F%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AEu-boot%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%234%20%224%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%A9%B3%E3%81%97%E3%81%8F%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CSPAN%20style%3D%22font-size%3A%2013.63636302948px%3B%20font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E3%80%82ipuv3_fb_init()%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E3%81%A8%E3%81%8D%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%8424bit%20LVDS%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%91%E3%83%8D%E3%83%AB%E3%81%AE%E4%BB%95%E6%A7%98%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013.63636302948px%3B%20font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A1%8C%E3%82%8F%E3%82%8C%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3Fu-boot%E3%81%A7%E3%81%A9%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E4%BD%95%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E5%B8%B8%E3%81%AB75MHz%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AEu-boot%202014-10%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%88%E3%83%AA%E3%83%83%E3%82%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎10-14-2012 11:52 PM
更新者:
