i.MX6Q PCIe EP/RC Validation System
i.MX6Q PCIe EP/RC Validation and Throughput
Hardware setup
    * Two i.MX6Q SD boards, one is used as PCIe RC; the other one is used as PCIe EP. Connected by 2*mini_PCIe to standard_PCIe  adaptors, 2*PEX cable adaptors,  and one PCIe cable.
Software configurations
    * When building RC image, make sure that
        CONFIG_IMX_PCIE=y
        # CONFIG_IMX_PCIE_EP_MODE_IN_EP_RC_SYS is not set
        CONFIG_IMX_PCIE_RC_MODE_IN_EP_RC_SYS=y
    * When build EP image, make sure that
        CONFIG_IMX_PCIE=y
        CONFIG_IMX_PCIE_EP_MODE_IN_EP_RC_SYS=y
        # CONFIG_IMX_PCIE_RC_MODE_IN_EP_RC_SYS is not set
Features
    * Set-up link between RC and EP by their stand-alone 125MHz running internally.
* In EP's system, EP can access the reserved ddr memory    (default address:0x40000000) of PCIe RC's system, by the   interconnection between PCIe EP and PCIe RC.
NOTE: The layout of the 1G DDR memory on SD boards is 0x1000_0000 ~ 0x4FFF_FFFF)
Use mem=768M in the kernel command line to reserve the 0x4000_0000 ~ 0x4FFF_FFFF DDR memory  space used to do the EP access tests.
(The example of the RC’s cmd-line: Kernel command line: noinitrd console=ttymxc0,115200 mem=768M root=/dev/nfs nfsroot=10.192.225.216:/home/r65037/nfs/rootfs_mx5x_10.11,v3,tcp ip=dhcp rw)
Throughput results
ARM core used as the bus master, and cache is disabledARM core used as the bus master, and cache is enabledIPU used as the bus master(DMA)
Data size in one write tlp8 bytes32 bytes64 bytes
Write speed~109MB/s~298MB/s~344MB/s
Data size in one read tlp32 bytes64 bytes64 bytes
Read speed~29MB/s~100MB/s~211MB/s
Here is the summary of the PCIe throughput results tested by IPU.
Write speed is about 344 MB/s.
Read speed is about 211MB/s
ARM core used as the bus master (define EP_SELF_IO_TEST in pcie.c driver)
write speed ~300MB/s.
read speed ~100MB/s.
Cache is enabled.
PCIe EP: Starting data transfer...
PCIe EP: Data transfer is successful, tv_count1 54840us, tv_count2 162814us.
PCIe EP: Data write speed is 298MB/s.
PCIe EP: Data read speed is 100MB/s.
Regarding to the log, the data size of each TLP when cache is enabled, is about 4 times of the data size in write, and 2 times of the data size in read, when the cache is not enabled.
Cache is disabledCache is enabled
Cache is not enabled
PCIe EP: Data transfer is successful, tv_count1 149616us, tv_count2 552099us.
PCIe EP: Data write speed is 109MB/s.
PCIe EP: Data read speed is 29MB/s.
One simple method used to connect the imx6 pcie ep and rc
View of the whole solution:
HW materials:
2* iMX6Q SD boards,  2* Mini PCIe to STD PCIe adaptors, one SATA2 data cable.
the mini-pcie to standard pcie exchange adaptor.
Here is the URL:
http://www.bplus.com.tw/Adapter/PM2C.html
How to make it.
signals connections
Two adaptors, one is named as A, the other one is named as B.
A                  B
TXM <----> RXM
TXN <----> RXN
RXM <----> TXM
RXN <----> TXN
A1 connected to B3
A2 connected to B4
A3 connected to B1
A4 connected to B2
Connect the cable to the adaptor.
Connect the SATA2 data cable to Mini PCIe to STD PCIe adaptor (A)
Connect the SATA2 data cable to Mini PCIe to STD PCIe adaptor (B)
NOTE:
* Please keep length of Cable as short as possible.  Our cable is about 12cm.
* Please connect shield wire in SATA2 Cable to GND at both board.
* Please boot up PCIe EP system before booting PCIe RC system.
Base one imx_3.0.35 mainline, the patch, and the IPU test tools had been attached.
NOTE:
* IPU tests usage howto.
Unzip the xxx.zip, and run xxx_r.sh to do read tests, run xxx_w.sh to do the write tests.
Tests log:
EP:
root@freescale ~/pcie_ep_io_test$ ./pcie-r.sh
pass cmdline 14, ./pcie_ipudev_test.out
new option : c
frame count set 1
new option : l
loop count set 1
new option : i
input w=1024,h=1024,fucc=RGB4,cpx=0,cpy=0,cpw=0,cph=0,de=0,dm=0
new option : O
640,480,RGB4,0,0,0,0,0
new option : s
show to fb 0
new option : f
output file name ipu1-1st-ovfb
new option : ÿ
show_to_buf:0, input_paddr:0x1000000, output.paddr0x18800000
====== ipu task ======
input:
        foramt: 0x34424752
        width: 1024
        height: 1024
        crop.w = 1024
        crop.h = 1024
        crop.pos.x = 0
        crop.pos.y = 0
output:
        foramt: 0x34424752
        width: 640
        height: 480
        roate: 0
        crop.w = 640
        crop.h = 480
        crop.pos.x = 0
        crop.pos.y = 0
total frame count 1 avg frame time 19019 us, fps 52.579000
root@freescale ~/pcie_ep_io_test$ ./pcie-w.sh
new option : c
frame count set 1
new option : l
loop count set 1
new option : i
input w=640,h=480,fucc=RGB4,cpx=0,cpy=0,cpw=0,cph=0,de=0,dm=0
new option : O
1024,1024,RGB4,0,0,0,0,0
new option : s
show to fb 1
new option : f
new option : ÿ
show_to_buf:1, input_paddr:0x18a00000, output.paddr0x1000000
input:
        foramt: 0x34424752
        width: 640
        height: 480
        crop.w = 640
        crop.h = 480
        crop.pos.x = 0
        crop.pos.y = 0
output:
        foramt: 0x34424752
        width: 1024
        height: 1024
        roate: 0
        crop.w = 1024
        crop.h = 1024
        crop.pos.x = 0
        crop.pos.y = 0
total frame count 1 avg frame time 11751 us, fps 85.099140
root@freescale ~$ ./memtool -32 01000000=deadbeaf
Writing 32-bit value 0xDEADBEAF to address 0x01000000
RC:
Before run "./memtool -32 01000000=deadbeaf" at EP.
root@freescale ~$ ./memtool -32 40000000 10
Reading 0x10 count starting at address 0x40000000
0x40000000:  00000000 00000000 00000000 00000000
0x40000010:  00000000 00000000 00000000 00000000
0x40000020:  00000000 00000000 00000000 00000000
0x40000030:  00000000 00000000 00000000 00000000
After run "./memtool -32 01000000=deadbeaf" at EP.
0x40000000:  DEADBEAF 00000000 00000000 00000000
Labels parameters
ラベル(2)
添付
コメント
Thank You richard.zhu, for this great answer.
Was vers helpful to find an entry to this issue.
Regards, Dirk
Welcome.
Best Regards
Richard Zhu
hi
richard.zhu
I got problem about pcie mode for rc.here is my log
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 3.0.35 (root@ubuntu) (gcc version 4.6.2 20110630 (prerelease) (Freescale MAD -- Linaro 2011.07 -- Built at 2011/08/10 09:20) ) #3 SMP PREEMPT Wed Sep 4 14:20:01 CST 2013
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Freescale i.MX 6Quad/DualLite/Solo Sabre-SD Board
Ignoring unrecognised tag 0x54410008
Memory policy: ECC disabled, Data cache writealloc
CPU identified as i.MX6Q, silicon rev 1.2
PERCPU: Embedded 7 pages/cpu @8c008000 s5440 r8192 d15040 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 227328
Kernel command line: console=ttymxc0,115200 root=/dev/mmcblk0p1 rootwait video=mxcfb0:dev=ldb,1024x600M@60,if=RGB666 ldb=sin0
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 640MB 256MB = 896MB total
Memory: 896372k/896372k available, 152204k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xf4600000 - 0xffe00000   ( 184 MB)
    vmalloc : 0xc0800000 - 0xf2000000   ( 792 MB)
    lowmem  : 0x80000000 - 0xc0000000   (1024 MB)
    pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
    modules : 0x7f000000 - 0x7fe00000   (  14 MB)
      .init : 0x80008000 - 0x8003d000   ( 212 kB)
      .text : 0x8003d000 - 0x80b01d14   (11028 kB)
      .data : 0x80b02000 - 0x80b67420   ( 406 kB)
       .bss : 0x80b67444 - 0x80bb58ec   ( 314 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Preemptible hierarchical RCU implementation.
NR_IRQS:624
MXC GPIO hardware
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
arm_max_freq=1GHz
MXC_Early serial console at MMIO 0x2020000 (options '115200')
bootconsole [ttymxc0] enabled
Console: colour dummy device 80x30
Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
CPU1: Booted secondary processor
CPU2: Booted secondary processor
CPU3: Booted secondary processor
Brought up 4 CPUs
SMP: Total of 4 processors activated (6324.22 BogoMIPS).
print_constraints: dummy:
NET: Registered protocol family 16
print_constraints: vddpu: 725 <--> 1300 mV at 700 mV fast normal
print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal
print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal
print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal
print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal
print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast normal
hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
hw-breakpoint: maximum watchpoint size is 4 bytes.
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x02070000, Cache size: 1048576 B
bio: create slab <bio-0> at 0
mxs-dma mxs-dma-apbh: initialized
print_constraints: SPKVDD: 4200 mV
print_constraints: vmmc: 3300 mV
vgaarb: loaded
SCSI subsystem initialized
spi_imx imx6q-ecspi.0: probed
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Freescale USB OTG Driver loaded, $Revision: 1.55 $
mc_pfuze 1-0008: ID: 0,Full lay: 1 ,Metal lay: 1
mc_pfuze 1-0008: FAB: 0 ,FIN: 0
print_constraints: PFUZE100_SW1A: 300 <--> 1875 mV at 1300 mV
print_constraints: PFUZE100_SW1B: 300 <--> 1875 mV at 300 mV
print_constraints: PFUZE100_SW1C: 300 <--> 1875 mV at 1300 mV
print_constraints: PFUZE100_SW2: 800 <--> 3950 mV at 3300 mV
print_constraints: PFUZE100_SW3A: 400 <--> 1975 mV at 1500 mV
print_constraints: PFUZE100_SW3B: 400 <--> 1975 mV at 1500 mV
print_constraints: PFUZE100_SW4: 800 <--> 3950 mV at 3150 mV
print_constraints: PFUZE100_SWBST: 5000 <--> 5150 mV at 5000 mV
print_constraints: PFUZE100_VSNVS: 1200 <--> 3000 mV at 1800 mV
print_constraints: PFUZE100_VREFDDR: at 750 mV
print_constraints: PFUZE100_VGEN1: 800 <--> 1550 mV at 1500 mV
print_constraints: PFUZE100_VGEN2: 800 <--> 1550 mV at 1500 mV
print_constraints: PFUZE100_VGEN3: 1800 <--> 3300 mV at 2800 mV
print_constraints: PFUZE100_VGEN4: 1800 <--> 3300 mV at 1800 mV
print_constraints: PFUZE100_VGEN5: 1800 <--> 3300 mV at 3000 mV
print_constraints: PFUZE100_VGEN6: 1800 <--> 3300 mV at 3300 mV
imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
imx-ipuv3 imx-ipuv3.1: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 driver probed
mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 dphy version is 0x3130302a
MIPI CSI2 driver module loaded
Advanced Linux Sound Architecture Driver Version 1.0.24.
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
cfg80211: Calling CRDA to update world regulatory domain
max17135 2-0048: PMIC MAX17135 for eInk display
i2c-core: driver [max17135] using legacy suspend method
i2c-core: driver [max17135] using legacy resume method
Switching to clocksource mxc_timer1
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
PMU: registered new PMU device of type 0
Static Power Management for Freescale i.MX6
wait mode is enabled for i.MX6
cpaddr = c0880000 suspend_iram_base=c091c000
PM driver module loaded
iMX6 PCIe PCIe RC mode imx_pcie_pltfm_probe entering.
PCIE: imx_pcie_pltfm_probe start link up.
link up failed, DB_R0:0x009d9700, DB_R1:0x08200000!
IMX PCIe port: link down!
IMX usb wakeup probe
add wake up source irq 75
cpu regulator mode:ldo_bypass
_regulator_get: get() with no identifier
mx6_cpu_regulator_init: failed to get pu regulator
i.MXC CPU frequency driver
JFFS2 version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
msgmni has been set to 1750
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
mxc_mipi_dsi mxc_mipi_dsi: i.MX MIPI DSI driver probed
MIPI DSI driver module loaded
mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver ldb
mxc_ldb mxc_ldb: change IPU DI1 to IPU DI0 for LDB channel0.
fbcvt: Aspect ratio not CVT standard
fbcvt: 1024x600@60: CVT Name - Not a CVT standard - 0.614 Mega Pixel Image
imx-ipuv3 imx-ipuv3.1: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
Console: switching to colour frame buffer device 128x37
mxc_sdc_fb mxc_sdc_fb.1: register mxc display driver ldb
mxc_ldb mxc_ldb: for second ldb displdb mode should in separate mode
mxc_sdc_fb mxc_sdc_fb.1: NO mxc display driver found!
mxc_sdc_fb mxc_sdc_fb.2: register mxc display driver lcd
mxc_sdc_fb mxc_sdc_fb.3: register mxc display driver ldb
mxc_sdc_fb mxc_sdc_fb.3: NO mxc display driver found!
imx-sdma imx-sdma: loaded firmware 1.1
imx-sdma imx-sdma: initialized
Serial: IMX driver
imx-uart.2: ttymxc2 at MMIO 0x21ec000 (irq = 60) is a IMX
imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
console [ttymxc0] enabled, bootconsole disabled
loop: module loaded
ahci: SSS flag set, parallel bus scan disabled
ahci ahci.0: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
ahci ahci.0: flags: ncq sntf stag pm led clo only pmp pio slum part ccc apst
scsi0 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x02200000-0x02200fff] port 0x100 irq 71
m25p80 spi0.0: unrecognized JEDEC id ffffff
GPMI NAND driver registered. (IMX)
e1000e: Intel(R) PRO/1000 Network Driver - 1.3.10-k2
e1000e: Copyright(c) 1999 - 2011 Intel Corporation.
vcan: Virtual CAN interface driver
CAN device driver interface
flexcan netdevice driver
FEC Ethernet Driver
fec_enet_mii_bus: probed
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000
fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
add wake up source irq 72
fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200
fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
ARC USBOTG Device Controller driver (1 August 2005)
mousedev: PS/2 mouse device common for all mice
input: gpio-keys as /devices/platform/gpio-keys/input/input0
input: max11801_ts as /devices/platform/imx-i2c.1/i2c-1/1-0048/input/input1
egalax_ts 1-0004: egalax_ts: failed to read firmware version
egalax_ts: probe of 1-0004 failed with error -5
egalax_ts 2-0004: egalax_ts: failed to read firmware version
egalax_ts: probe of 2-0004 failed with error -5
usb 2-1: new full speed USB device number 2 using fsl-ehci
elan - Read Hello Packet Failed
elan-touch: probe of 2-0010 failed with error -22
i2c-core: driver [isl29023] using legacy suspend method
i2c-core: driver [isl29023] using legacy resume method
snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0
i2c /dev entries driver
Linux video capture interface: v2.00
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video18
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video19
hub 2-1:1.0: USB hub found
hub 2-1:1.0: 4 ports detected
mag3110 2-000e: check mag3110 chip ID
mag3110 2-000e: read chip ID 0xfffffffb is not equal to 0xc4!
mag3110: probe of 2-000e failed with error -22
i2c-core: driver [mag3110] using legacy suspend method
i2c-core: driver [mag3110] using legacy resume method
mma8451 0-001c: read chip ID 0x1 is not equal to 0x1a or 0x2a!
mma8451: probe of 0-001c failed with error -22
imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1)
Bluetooth: Virtual HCI driver ver 1.3
Bluetooth: HCI UART driver ver 2.2
Bluetooth: HCIATH3K protocol initialized
Bluetooth: Generic Bluetooth USB driver ver 0.6
usbcore: registered new interface driver btusb
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
mmc0: SDHCI controller on platform [sdhci-esdhc-imx.3] using DMA
mmc1: SDHCI controller on platform [sdhci-esdhc-imx.1] using DMA
mmc2: SDHCI controller on platform [sdhci-esdhc-imx.2] using DMA
mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
VPU initialized
mxc_asrc registered
Thermal calibration data is 0x5894f069
Thermal sensor with ratio = 183
Anatop Thermal registered as thermal_zone0
anatop_thermal_probe: default cooling device is cpufreq!
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
usbcore: registered new interface driver snd-usb-audio
mxc_hdmi_soc mxc_hdmi_soc.0: MXC HDMI Audio
Cirrus Logic CS42888 ALSA SoC Codec Driver
i2c-core: driver [cs42888] using legacy suspend method
i2c-core: driver [cs42888] using legacy resume method
imx-hdmi-soc-dai imx-hdmi-soc-dai.0: Failed: Load HDMI-video first.
mmc0: new high speed DDR MMC card at address 0001
mmcblk0: mmc0:0001 SEM04G 3.68 GiB
mmcblk0boot0: mmc0:0001 SEM04G partition 1 2.00 MiB
mmcblk0boot1: mmc0:0001 SEM04G partition 2 2.00 MiB
mmcblk0: p1
mmcblk0boot1: unknown partition table
mmcblk0boot0: unknown partition table
usb 2-1.3: new low speed USB device number 3 using fsl-ehci
wm8962 0-001a: Device is not a WM8962, ID 0 != 6243
wm8962 0-001a: asoc: failed to probe CODEC wm8962.0-001a: -22
asoc: failed to instantiate card wm8962-audio: -22
imx_3stack asoc driver
Initialize HDMI-audio failed. Load HDMI-video first!
ALSA device list:
  No soundcards found.
NET: Registered protocol family 26
TCP cubic registered
NET: Registered protocol family 17
can: controller area network core (rev 20090105 abi 8)
NET: Registered protocol family 29
can: raw protocol (rev 20090105)
can: broadcast manager protocol (rev 20090105 t)
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
lib80211: common routines for IEEE802.11 drivers
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
input: HID 04b3:310d as /devices/platform/fsl-ehci.1/usb2/2-1/2-1.3/2-1.3:1.0/input/input2
Bus freq driver module loaded
generic-usb 0003:04B3:310D.0001: input,hidraw0: USB HID v1.11 Mouse [HID 04b3:310d] on usb-fsl-ehci.1-1.3/input0
Bus freq driver Enabled
mxc_dvfs_core_probe
DVFS driver module loaded
regulator_init_complete: PFUZE100_VGEN6: incomplete constraints, leaving on
regulator_init_complete: PFUZE100_VGEN3: incomplete constraints, leaving on
regulator_init_complete: PFUZE100_VGEN2: incomplete constraints, leaving on
regulator_init_complete: PFUZE100_VGEN1: incomplete constraints, leaving on
snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:00:00 UTC (0)
usb 2-1.4: new low speed USB device number 4 using fsl-ehci
input:   USB Keyboard as /devices/platform/fsl-ehci.1/usb2/2-1/2-1.4/2-1.4:1.0/input/input3
generic-usb 0003:04D9:1702.0002: input,hidraw1: USB HID v1.10 Keyboard [  USB Keyboard] on usb-fsl-ehci.1-1.4/input0
input:   USB Keyboard as /devices/platform/fsl-ehci.1/usb2/2-1/2-1.4/2-1.4:1.1/input/input4
generic-usb 0003:04D9:1702.0003: input,hidraw2: USB HID v1.10 Device [  USB Keyboard] on usb-fsl-ehci.1-1.4/input1
ata1: SATA link down (SStatus 1 SControl 300)
EXT3-fs: barriers not enabled
kjournald starting.  Commit interval 5 seconds
EXT3-fs (mmcblk0p1): using internal journal
EXT3-fs (mmcblk0p1): recovery complete
EXT3-fs (mmcblk0p1): mounted filesystem with writeback data mode
VFS: Mounted root (ext3 filesystem) on device 179:1.
Freeing init memory: 212K
I follow you hit a patch to the kernel (0001-ENGR00257661-pcie-imx-pcie-ep-rc-validation.patch).
and
   CONFIG_IMX_PCIE=y
I want to turn a PCIE Gigabit Ethernet ports.
help please.
Hi:
Regarding to the log, the PCIe link is not setup at your side at all.
This validation system I pasted here is mainly used to verify the i.MX6 PCIe EP mode, and test the i.MX6 PCIe throught-put.
But I don‘t know the scenario of what you said ”I want to turn a PCIE Gigabit Ethernet ports.
Can you describe the details of your PCIe implementation ?
Best Regard
Richard Zhu
Hi:
I want to connect a PCIE card Gigabit Ethernet Controller such as  RTL8111E through PCIE on IMX6.
but my imx6 pcie does not work .
Ok, got that.
You shouldn‘t enable
In the kernel configuration.
The following is the correct configuration. Just FYI.
CONFIG_IMX_PCIE=y
# CONFIG_IMX_PCIE_RC_MODE_IN_EP_RC_SYS=y
BS
Richard Zhu
I followed your configureatin,but always the same log:
link up failed, DB_R0:0x00ff5100, DB_R1:0x08200000!
│                     *** MX6 Options: ***        │ │
  │ │                 [*] PCI Express support        │ │
  │ │                 [ ]   PCI Express EP mode in the IMX6 RC/EP interconnection system                      │ │
  │ │                 [ ]   PCI Express RC mode in the IMX6 RC/EP interconnection system                      │ │
  │ │                 <*> USB Host 1 support
  │ │                 [*] Message Signaled Interrupts (MSI and MSI-X)                                         │ │
  │ │                 < > PCI Stub driver        │ │
  │ │                 [ ] PCI IOV support        │ │
  │ │                 [*]   Root Port Advanced Error Reporting support                                        │ │
  │ │                 [ ]     PCI Express ECRC settings control                                               │ │
  │ │                 < >     PCIe AER error injector support                                                 │ │
  │ │                 [*]   PCI Express ASPM control                                                          │ │
  │ │                 [*]     Debug PCI Express ASPM
are there any other need to modify?
Starting kernel ...
Linux version 3.0.35-2508-g54750ff (root@ubuntu) (gcc version 4.6.2 20110630 (prerelease) (Freescale MAD -- Linaro 2011.07 -- Built at 2011/08/10 09:20) ) #1 SMP PREEMPT Thu Sep 5 12:46:34 CST 2013
Memory: 896688k/896688k available, 151888k reserved, 0K highmem
      .text : 0x8003d000 - 0x80ab36f8   (10714 kB)
      .data : 0x80ab4000 - 0x80b18300   ( 401 kB)
       .bss : 0x80b18324 - 0x80b6678c   ( 314 kB)
NR_IRQS:624
MXC GPIO hardware
arm_max_freq=1GHz
Brought up 4 CPUs
vgaarb: loaded
TCP reno registered
link up failed, DB_R0:0x00b4f900, DB_R1:0x08200000!
msgmni has been set to 1751
Serial: IMX driver
loop: module loaded
FEC Ethernet Driver
ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
ata1.00: ATA-8: WDC WD3200BPVT-00JJ5T0, 01.01A01, max UDMA/133
ata1.00: 625142448 sectors, multi 0: LBA48 NCQ (depth 31/32)
ata1.00: configured for UDMA/133
scsi 0:0:0:0: Direct-Access     ATA      WDC WD3200BPVT-0 01.0 PQ: 0 ANSI: 5
sd 0:0:0:0: [sda] 625142448 512-byte logical blocks: (320 GB/298 GiB)
sd 0:0:0:0: [sda] 4096-byte physical blocks
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sda: sda1 sda2 sda3
sd 0:0:0:0: [sda] Attached SCSI disk
VPU initialized
mxc_asrc registered
mmcblk0: p1
ALSA device list:
mxc_dvfs_core_probe
EXT3-fs (mmcblk0p1): warning: maximal mount count reached, running e2fsck is recommended
This is a new uImage.It does not make any patch.And just followed the following configuration
CONFIG_IMX_PCIE=y
but pcie does not work.
there is nothing output followed the commend lspci.
Regarding to the your logs:
The PCIe link is still failed to be setup properly.
Do you provide the mandatory requirements required by your PCIe EP device, such as external power supply and so on ?
Or, can you ship one PCIe EP used by you to me?
Then I can try to re-produce this problem at my side.
Best Regards
Richard Zhu.
hi
Thanks for your reply.
I have several pcie nic inside.such as BCM5751.I will be mailed to you, please give me your address.
For pcie nic use,I've realized on TI's DM8168.However, the power consumption is too high.So I intend to replace IMX6.
O, I see.
Do you use the standard PCIe EP device?
The mini-PCIe to STD-PCIe convertor is required if the STD-PCIe EP is used by you, right?
The convertor would impact the quality of the PCIe deeply, please pay attention to it.
Here is one recommended convertor.
Best Regards
Richard Zhu
yes,I use the standard PCIE EP device.
But the board of imx6 is our own design.so i does not need to convert.
Now I think the pcie bus not up yet.No relationship with the PCIE NIC device.
Here is my address:
Shanghai PuDong new district LiangJing Road 192# building A 2F
Postcode 201203.
Best Regards
Richard Zhu
Can you  send a business card to my e-mail? Mailing BCM5751 need to fill in your telephone number.My e-mail luhao89@me.com.
hi
I have solved the problem.My power supply capacity is insufficient,Therefore, the device is not detected.
now here is the log
CLK setup,by OpenEmbed---
IMX PCIe pcie_rst, 0.
IMX PCIe pcie_rst, 1.
IMX PCIe port: link up.
PCI: bus0: Fast back to back transfers disabled
PCI: bus1: Fast back to back transfers disabled
pci 0000:00:00.0: BAR 0: assigned [mem 0x01100000-0x011fffff 64bit pref]
pci 0000:00:00.0: BAR 0: set to [mem 0x01100000-0x011fffff 64bit pref] (PCI address [0x1100000-0x11fffff])
pci 0000:00:00.0: BAR 9: assigned [mem 0x01200000-0x012fffff pref]
pci 0000:00:00.0: BAR 6: assigned [mem 0x01300000-0x0130ffff pref]
pci 0000:00:00.0: BAR 7: assigned [io  0x1000000-0x1000fff]
pci 0000:01:00.0: BAR 4: assigned [mem 0x01200000-0x0120ffff 64bit pref]
pci 0000:01:00.0: BAR 4: set to [mem 0x01200000-0x0120ffff 64bit pref] (PCI address [0x1200000-0x120ffff])
pci 0000:01:00.0: BAR 6: assigned [mem 0x01210000-0x0121ffff pref]
pci 0000:01:00.0: BAR 2: assigned [mem 0x01220000-0x01220fff 64bit pref]
pci 0000:01:00.0: BAR 2: set to [mem 0x01220000-0x01220fff 64bit pref] (PCI address [0x1220000-0x1220fff])
pci 0000:01:00.0: BAR 0: assigned [io  0x1000000-0x10000ff]
pci 0000:01:00.0: BAR 0: set to [io  0x1000000-0x10000ff] (PCI address [0x1000000-0x10000ff])
pci 0000:00:00.0: PCI bridge to [bus 01-01]
pci 0000:00:00.0:   bridge window [io  0x1000000-0x1000fff]
pci 0000:00:00.0:   bridge window [mem disabled]
pci 0000:00:00.0:   bridge window [mem 0x01200000-0x012fffff pref]
r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
PCI: enabling device 0000:01:00.0 (0140 -> 0143)
IMX-PCIe: MSI 0x3f01 @0x0:0x1ff8000, irq = 497
r8169 0000:01:00.0: eth1: RTL8168c/8111c at 0xc09e4000, ff:ff:ff:ff:ff:ff, XID 1c4000c0 IRQ 497
root@imx6-luhao:~# lspci -v
00:00.0 Class 0604: Device 16c3:abcd (rev 01)
        Flags: bus master, fast devsel, latency 0
        Memory at 01100000 (64-bit, prefetchable) [size=1M]
        Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
        I/O behind bridge: 00000000-00000fff
        Prefetchable memory behind bridge: 01200000-012fffff
        [virtual] Expansion ROM at 01300000 [disabled] [size=64K]
        Capabilities: [40] Power Management version 3
        Capabilities: [50] MSI: Enable+ Count=1/1 Maskable+ 64bit+
        Capabilities: [70] Express Root Port (Slot-), MSI 00
        Capabilities: [100] Advanced Error Reporting
        Capabilities: [140] Virtual Channel <?>
        Kernel driver in use: pcieport
01:00.0 Class 0200: Device 10ec:8168 (rev 02)
        Subsystem: Device 10ec:8168
        Flags: bus master, fast devsel, latency 0, IRQ 497
        I/O ports at 1000000 [size=256]
        Memory at 01220000 (64-bit, prefetchable) [size=4K]
        Memory at 01200000 (64-bit, prefetchable) [size=64K]
        [virtual] Expansion ROM at 01210000 [disabled] [size=64K]
        Capabilities: [50] MSI: Enable+ Count=1/2 Maskable- 64bit+
        Capabilities: [70] Express Endpoint, MSI 01
        Capabilities: [b0] MSI-X: Enable- Count=2 Masked-
        Capabilities: [d0] Vital Product Data
        Capabilities: [160] Device Serial Number 00-00-00-00-00-00-00-00
        Kernel driver in use: r8169
root@imx6-luhao:~#
Thank you for your long-term support,Now I wont to use pcie switch pex8608,Have you done similar tests ?
Great.
One Pericom PCIe switch(PI7C9X2G303EL) had been verified on imx_3.0.35.4.0 and 4.1.0 releases.
Good luck.
Best Regadrs
Richard Zhu
Thank you very mach.I'll do some test about pcie switch on imx6.
Hi, we want to extend the usb via pcie with chip (mcs9990). There is a strange thing, if the pcie setup up good, then the system stop after about 10s and then restart with "pcie link up failed". Here is the log if pcie setups ok.
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Linux version 3.0.35-2666-gbdde708 (oser@macbook) (gcc version 4.6.2 20110630 (prerelease) (Freescale MAD -- Linaro 2011.07 -- Built at 2011/08
/10 09:20) ) #6 SMP Tue Sep 17 09:04:37 CEST 2013
[    0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c5387d
[    0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: Dynsense DS7109 Board
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] CPU identified as i.MX6Q, silicon rev 1.2
[    0.000000] PERCPU: Embedded 7 pages/cpu @cc006000 s5728 r8192 d14752 u32768
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260096
[    0.000000] Kernel command line: console=ttymxc3,115200 root=/dev/mmcblk0p3 rootwait rw
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 1024MB = 1024MB total
[    0.000000] Memory: 1033972k/1033972k available, 14604k reserved, 360448K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     DMA     : 0xf4600000 - 0xffe00000   ( 184 MB)
[    0.000000]     vmalloc : 0xea800000 - 0xf2000000   ( 120 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xea000000   ( 672 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .init : 0xc0008000 - 0xc0033000   ( 172 kB)
[    0.000000]       .text : 0xc0033000 - 0xc04ce188   (4717 kB)
[    0.000000]       .data : 0xc04d0000 - 0xc05149e0   ( 275 kB)
[    0.000000]        .bss : 0xc0514a04 - 0xc05570a8   ( 266 kB)
[    0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] NR_IRQS:624
[    0.000000] MXC GPIO hardware
[    0.000000] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
[    0.000000] arm_max_freq=1GHz
[    0.000000] MXC_Early serial console at MMIO 0x21f0000 (options '115200')
[    0.000000] bootconsole [ttymxc3] enabled
[    0.000000] Console: colour dummy device 80x30
[    0.217079] Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
[    0.305391] pid_max: default: 32768 minimum: 301
[    0.310317] Mount-cache hash table entries: 512
[    0.315667] CPU: Testing write buffer coherency: ok
[    0.320824] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
[    0.330207] CPU1: Booted secondary processor
[    0.361619] CPU2: Booted secondary processor
[    0.401646] CPU3: Booted secondary processor
[    0.440862] Brought up 4 CPUs
[    0.456684] SMP: Total of 4 processors activated (6324.22 BogoMIPS).
[    0.463648] devtmpfs: initialized
[    0.485974] print_constraints: dummy:
[    0.489947] NET: Registered protocol family 16
[    0.498839] print_constraints: vddpu: 725 <--> 1300 mV at 1150 mV fast normal
[    0.506463] print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal
[    0.514251] print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal
[    0.521978] print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal
[    0.529772] print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal
[    0.537479] print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast normal
[    0.549656] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.556488] hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
[    0.563843] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.569727] L310 cache controller enabled
[    0.573764] l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x02070000, Cache size: 1048576 B
[    0.583862] IMX usb wakeup probe
[    0.587238] IMX usb wakeup probe
[    0.599086] bio: create slab <bio-0> at 0
[    0.606129] mxs-dma mxs-dma-apbh: initialized
[    0.610956] print_constraints: vmmc: 3300 mV
[    0.616092] SCSI subsystem initialized
[    0.620426] usbcore: registered new interface driver usbfs
[    0.626188] usbcore: registered new interface driver hub
[    0.631680] usbcore: registered new device driver usb
[    0.638581] Switching to clocksource mxc_timer1
[    0.643177] cfg80211: Calling CRDA to update world regulatory domain
[    0.657854] NET: Registered protocol family 2
[    0.662438] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.670374] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.679660] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[    0.687383] TCP: Hash tables configured (established 131072 bind 65536)
[    0.694025] TCP reno registered
[    0.697184] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.703180] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.710009] NET: Registered protocol family 1
[    0.714674] RPC: Registered named UNIX socket transport module.
[    0.720613] RPC: Registered udp transport module.
[    0.725342] RPC: Registered tcp transport module.
[    0.730061] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.737627] PMU: registered new PMU device of type 0
[    0.742741] Static Power Management for Freescale i.MX6
[    0.747994] wait mode is enabled for i.MX6
[    0.752315] cpaddr = ea880000 suspend_iram_base=ea828000
[    0.757735] PM driver module loaded
[    0.761300] iMX6 PCIe PCIe RC mode imx_pcie_pltfm_probe entering.
[    0.873230] PCIE: imx_pcie_pltfm_probe start link up.
[    0.896452] IMX PCIe port: link up.
[    0.900472] PCI: bus0: Fast back to back transfers disabled
[    0.923438] PCI: bus1: Fast back to back transfers disabled
[    0.931153] pci 0000:00:00.0: BAR 0: assigned [mem 0x01000000-0x010fffff 64bit pref]
[    0.938948] pci 0000:00:00.0: BAR 0: set to [mem 0x01000000-0x010fffff 64bit pref] (PCI address [0x1000000-0x10fffff])
[    0.949687] pci 0000:00:00.0: BAR 8: assigned [mem 0x01100000-0x011fffff]
[    0.956506] pci 0000:00:00.0: BAR 6: assigned [mem 0x01200000-0x0120ffff pref]
[    0.963769] pci 0000:01:00.0: BAR 0: assigned [mem 0x01100000-0x01100fff]
[    0.970587] pci 0000:01:00.0: BAR 0: set to [mem 0x01100000-0x01100fff] (PCI address [0x1100000-0x1100fff])
[    0.980365] pci 0000:01:00.1: BAR 0: assigned [mem 0x01101000-0x01101fff]
[    0.987190] pci 0000:01:00.1: BAR 0: set to [mem 0x01101000-0x01101fff] (PCI address [0x1101000-0x1101fff])
[    0.996968] pci 0000:01:00.2: BAR 0: assigned [mem 0x01102000-0x01102fff]
[    1.003804] pci 0000:01:00.2: BAR 0: set to [mem 0x01102000-0x01102fff] (PCI address [0x1102000-0x1102fff])
[    1.013582] pci 0000:01:00.3: BAR 0: assigned [mem 0x01103000-0x01103fff]
[    1.020399] pci 0000:01:00.3: BAR 0: set to [mem 0x01103000-0x01103fff] (PCI address [0x1103000-0x1103fff])
[    1.030177] pci 0000:01:00.4: BAR 0: assigned [mem 0x01104000-0x01104fff]
[    1.037001] pci 0000:01:00.4: BAR 0: set to [mem 0x01104000-0x01104fff] (PCI address [0x1104000-0x1104fff])
[    1.046779] pci 0000:01:00.5: BAR 0: assigned [mem 0x01105000-0x01105fff]
[    1.053603] pci 0000:01:00.5: BAR 0: set to [mem 0x01105000-0x01105fff] (PCI address [0x1105000-0x1105fff])
[    1.063380] pci 0000:01:00.6: BAR 0: assigned [mem 0x01106000-0x01106fff]
[    1.070198] pci 0000:01:00.6: BAR 0: set to [mem 0x01106000-0x01106fff] (PCI address [0x1106000-0x1106fff])
[    1.079976] pci 0000:01:00.7: BAR 0: assigned [mem 0x01107000-0x01107fff]
[    1.086799] pci 0000:01:00.7: BAR 0: set to [mem 0x01107000-0x01107fff] (PCI address [0x1107000-0x1107fff])
[    1.096577] pci 0000:00:00.0: PCI bridge to [bus 01-01]
[    1.101819] pci 0000:00:00.0:   bridge window [io  disabled]
[    1.107509] pci 0000:00:00.0:   bridge window [mem 0x01100000-0x011fffff]
[    1.114327] pci 0000:00:00.0:   bridge window [mem pref disabled]
[    1.120837] IMX usb wakeup probe
[    1.124593] IMX usb wakeup probe
[    1.128126] cpu regulator mode:ldo_enable
[    1.132342] i.MXC CPU frequency driver
[    1.151254] highmem bounce pool size: 64 pages
[    1.169381] msgmni has been set to 1315
[    1.174837] alg: No test for stdrng (krng)
[    1.179101] io scheduler noop registered
[    1.183040] io scheduler deadline registered
[    1.187408] io scheduler cfq registered (default)
[    1.192486] IMX-PCIe: MSI 0x3f00 @0x0:0x1ff8000, irq = 496
[    1.199230] imx-sdma imx-sdma: loaded firmware 1.1
[    1.208696] imx-sdma imx-sdma: initialized
[    1.350226] Serial: IMX driver
[    1.353438] imx-uart.3: ttymxc3 at MMIO 0x21f0000 (irq = 61) is a IMX
[    1.359919] console [ttymxc3] enabled, bootconsole disabled
[    1.376725] loop: module loaded
[    1.381551] usbcore: registered new interface driver asix
[    1.387076] usbcore: registered new interface driver cdc_ether
[    1.393037] usbcore: registered new interface driver smsc75xx
[    1.398920] usbcore: registered new interface driver smsc95xx
[    1.404788] usbcore: registered new interface driver net1080
[    1.410575] usbcore: registered new interface driver rndis_host
[    1.416620] usbcore: registered new interface driver cdc_subset
[    1.422669] usbcore: registered new interface driver zaurus
[    1.428266] cdc_ncm: 04-Aug-2011
[    1.431611] usbcore: registered new interface driver cdc_ncm
[    1.437410] usbcore: registered new interface driver rndis_wlan
[    1.443872] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.450527] add wake up source irq 73
[    1.454227] fsl-ehci fsl-ehci.2: Freescale On-Chip EHCI Host Controller
[    1.461279] fsl-ehci fsl-ehci.2: new USB bus registered, assigned bus number 1
[    1.493211] fsl-ehci fsl-ehci.2: irq 73, io base 0x02184400
[    1.513186] fsl-ehci fsl-ehci.2: USB 2.0 started, EHCI 1.00
[    1.518851] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.525654] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.532881] usb usb1: Product: Freescale On-Chip EHCI Host Controller
[    1.539331] usb usb1: Manufacturer: Linux 3.0.35-2666-gbdde708 ehci_hcd
[    1.545955] usb usb1: SerialNumber: fsl-ehci.2
[    1.551056] hub 1-0:1.0: USB hub found
[    1.554824] hub 1-0:1.0: 1 port detected
[    1.559261] add wake up source irq 74
[    1.562943] fsl-ehci fsl-ehci.3: Freescale On-Chip EHCI Host Controller
[    1.569893] fsl-ehci fsl-ehci.3: new USB bus registered, assigned bus number 2
[    1.603198] fsl-ehci fsl-ehci.3: irq 74, io base 0x02184600
[    1.623181] fsl-ehci fsl-ehci.3: USB 2.0 started, EHCI 1.00
[    1.628832] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    1.635632] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.642858] usb usb2: Product: Freescale On-Chip EHCI Host Controller
[    1.649306] usb usb2: Manufacturer: Linux 3.0.35-2666-gbdde708 ehci_hcd
[    1.655934] usb usb2: SerialNumber: fsl-ehci.3
[    1.660988] hub 2-0:1.0: USB hub found
[    1.664755] hub 2-0:1.0: 1 port detected
[    1.669192] add wake up source irq 75
[    1.677670] fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
[    1.684575] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 3
[    1.713200] fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000
[    1.733180] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
[    1.738830] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    1.745631] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.752859] usb usb3: Product: Freescale On-Chip EHCI Host Controller
[    1.759307] usb usb3: Manufacturer: Linux 3.0.35-2666-gbdde708 ehci_hcd
[    1.765934] usb usb3: SerialNumber: fsl-ehci.0
[    1.770988] hub 3-0:1.0: USB hub found
[    1.774755] hub 3-0:1.0: 1 port detected
[    1.779164] add wake up source irq 72
[    1.782865] fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
[    1.789777] fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 4
[    1.823201] fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200
[    1.843185] fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
[    1.848835] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    1.855637] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.862863] usb usb4: Product: Freescale On-Chip EHCI Host Controller
[    1.869312] usb usb4: Manufacturer: Linux 3.0.35-2666-gbdde708 ehci_hcd
[    1.875940] usb usb4: SerialNumber: fsl-ehci.1
[    1.880997] hub 4-0:1.0: USB hub found
[    1.884765] hub 4-0:1.0: 1 port detected
[    1.889282] PCI: enabling device 0000:01:00.1 (0140 -> 0142)
[    1.894989] ehci_hcd 0000:01:00.1: EHCI Host Controller
[    1.900490] ehci_hcd 0000:01:00.1: new USB bus registered, assigned bus number 5
[    1.908034] ehci_hcd 0000:01:00.1: applying MosChip frame-index workaround
[    1.943222] ehci_hcd 0000:01:00.1: irq 155, io mem 0x01101000
[    1.963182] ehci_hcd 0000:01:00.1: USB 2.0 started, EHCI 1.00
[    1.969010] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[    1.975816] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.983043] usb usb5: Product: EHCI Host Controller
[    1.987930] usb usb5: Manufacturer: Linux 3.0.35-2666-gbdde708 ehci_hcd
[    1.994553] usb usb5: SerialNumber: 0000:01:00.1
[    1.999488] +++ hub_port_connect_change:udev->level :1
[    1.999747] hub 5-0:1.0: USB hub found
[    1.999759] hub 5-0:1.0: 1 port detected
[    2.000187] PCI: enabling device 0000:01:00.3 (0140 -> 0142)
[    2.000214] ehci_hcd 0000:01:00.3: EHCI Host Controller
[    2.000509] ehci_hcd 0000:01:00.3: new USB bus registered, assigned bus number 6
[    2.000737] ehci_hcd 0000:01:00.3: applying MosChip frame-index workaround
[    2.023241] ehci_hcd 0000:01:00.3: irq 154, io mem 0x01103000
[    2.043189] ehci_hcd 0000:01:00.3: USB 2.0 started, EHCI 1.00
[    2.043272] usb usb6: New USB device found, idVendor=1d6b, idProduct=0002
[    2.043280] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.043287] usb usb6: Product: EHCI Host Controller
[    2.043293] usb usb6: Manufacturer: Linux 3.0.35-2666-gbdde708 ehci_hcd
[    2.043300] usb usb6: SerialNumber: 0000:01:00.3
[    2.043862] hub 6-0:1.0: USB hub found
[    2.043875] hub 6-0:1.0: 1 port detected
[    2.044307] PCI: enabling device 0000:01:00.5 (0140 -> 0142)
[    2.044334] ehci_hcd 0000:01:00.5: EHCI Host Controller
[    2.044597] ehci_hcd 0000:01:00.5: new USB bus registered, assigned bus number 7
[    2.044811] ehci_hcd 0000:01:00.5: applying MosChip frame-index workaround
[    2.113240] ehci_hcd 0000:01:00.5: irq 153, io mem 0x01105000
[    2.223212] usb 3-1: new high speed USB device number 2 using fsl-ehci
[    2.243203] ehci_hcd 0000:01:00.5: USB 2.0 started, EHCI 1.00
[    2.249029] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002
[    2.255832] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.263059] usb usb7: Product: EHCI Host Controller
[    2.267946] usb usb7: Manufacturer: Linux 3.0.35-2666-gbdde708 ehci_hcd
[    2.274570] usb usb7: SerialNumber: 0000:01:00.5
[    2.279804] hub 7-0:1.0: USB hub found
[    2.283572] hub 7-0:1.0: 1 port detected
[    2.287948] PCI: enabling device 0000:01:00.7 (0140 -> 0142)
[    2.293641] ehci_hcd 0000:01:00.7: EHCI Host Controller
[    2.299165] ehci_hcd 0000:01:00.7: new USB bus registered, assigned bus number 8
[    2.306717] ehci_hcd 0000:01:00.7: applying MosChip frame-index workaround
[    2.343213] ehci_hcd 0000:01:00.7: request interrupt 152 failed
[    2.349138] ehci_hcd 0000:01:00.7: USB bus 8 deregistered
[    2.354820] ehci_hcd 0000:01:00.7: init 0000:01:00.7 fail, -22
[    2.360665] ehci_hcd: probe of 0000:01:00.7 failed with error -22
[    2.366899] usb register error with 0
[    2.370703] usbcore: registered new interface driver arc hset
[    2.376462] usb hset init succeed
[    2.380273] imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1)
[    2.388450] cpuidle: using governor ladder
[    2.392551] cpuidle: using governor menu
[    2.394974] unsupported device: not in white list
[    2.395019] +++ hub_port_connect_change:udev->level :1
[    2.406435] sdhci: Secure Digital Host Controller Interface driver
[    2.412619] sdhci: Copyright(c) Pierre Ossman
[    2.417084] sdhci sdhci-esdhc-imx.1: no write-protect pin available!
[    2.423491] mmc0: no vmmc regulator found
[    2.427681] mmc0: SDHCI controller on platform [sdhci-esdhc-imx.1] using DMA
[    2.434999] Thermal calibration data is 0x59c50d69
[    2.439791] Thermal sensor with ratio = 186
[    2.463188] Anatop Thermal registered as thermal_zone0
[    2.468495] anatop_thermal_probe: default cooling device is cpufreq!
[    2.475415] NET: Registered protocol family 26
[    2.480355] TCP cubic registered
[    2.483599] NET: Registered protocol family 17
[    2.488055] lib80211: common routines for IEEE802.11 drivers
[    2.494497] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[    2.502176] ThumbEE CPU extension supported.
[    2.506470] Registering SWP/SWPB emulation handler
[    2.511407] Bus freq driver module loaded
[    2.513199] usb 4-1: new high speed USB device number 2 using fsl-ehci
[    2.521949] Bus freq driver Enabled
[    2.527136] DVFS driver module loaded
[    2.532045] regulator_init_complete: vmmc: incomplete constraints, leaving on
After hang and reboot, pci linkup failed
[    0.761407] iMX6 PCIe PCIe RC mode imx_pcie_pltfm_probe entering.
[    0.873253] PCIE: imx_pcie_pltfm_probe start link up.
[    1.483143] link up failed, DB_R0:0xdc998200, DB_R1:0x0820f700!
[    1.489108] IMX PCIe port: link down!
But now the system works ok.
What do you think it's the problem?
Thanks a lot.
Hello, guys.
I have some issue.
Is it possible to create Route Complex Integrated End Point on RC board?
Or can you explain how did you get acces to RC board memory?
Hope for you help.
Regards.
hi , we want to stdpci and use theMini PCIe to STD PCIe adaptors,, i use Linux 3.0.35_1.1.0_121218 download from freescale
the log:
U-Boot 2009.08 (Sep 17 2013 - 20:02:02)
CPU: Freescale i.MX6 family TO1.2 at 792 MHz
Temperature:   29 C, calibration data 0x5784c37d
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
ipg clock     : 66000000Hz
ipg per clock : 66000000Hz
uart clock    : 80000000Hz
cspi clock    : 60000000Hz
ahb clock     : 132000000Hz
axi clock   : 264000000Hz
emi_slow clock: 132000000Hz
ddr clock     : 528000000Hz
usdhc1 clock  : 198000000Hz
usdhc2 clock  : 198000000Hz
usdhc3 clock  : 198000000Hz
usdhc4 clock  : 198000000Hz
nfc clock     : 24000000Hz
Board: i.MX6Q-SABRESD: unknown-board Board: 0x63012 [POR ]
Boot Device: MMC
I2C:   ready
DRAM:   1 GB
MMC:   FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3
### Inside lcd_enable
In:    serial
Out:   serial
Err:   serial
Found PFUZE100! deviceid=10,revid=11
Net:   got MAC address from IIM: 00:00:00:00:00:00
FEC0 [PRIME]
Hit any key to stop autoboot:  0
mmc3(part 0) is current device
MMC read: dev # 3, block # 2048, count 8192 ... 8192 blocks read: OK
## Booting kernel from Legacy Image at 10800000 ...
   Image Name:   Linux-3.0.35-2310-gc27cb38
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    4147924 Bytes =  4 MB
   Load Address: 10008000
   Entry Point:  10008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 3.0.35-2310-gc27cb38 (lyc@ubuntu) (gcc version 4.6.2 20110630 (prerelease) (Freescale MAD -- Linaro 2011.07 -- Built at 2011/08/10 09:20) ) #22 SMP PREEMPT Wed Nov 13 00:56:32 PST 2013
Kernel command line: console=ttymxc2,115200 root=/dev/mmcblk0p1 rootwait rw ldb=sin0 video=mxcfb0:dev=ldb,LDB-WXGA,if=RGB666
Memory: 896280k/896280k available, 152296k reserved, 0K highmem
      .text : 0x8003d000 - 0x80b1309c   (11097 kB)
      .data : 0x80b14000 - 0x80b7e0c0   ( 425 kB)
       .bss : 0x80b7e0e4 - 0x80bccfec   ( 316 kB)
NR_IRQS:496
MXC GPIO hardware
arm_max_freq=2
MXC_Early serial console at MMIO 0x21ec000 (options '115200')
bootconsole [ttymxc2] enabled
Brought up 4 CPUs
Inside mx6_sabresd_board_init line:1809
Inside mx6_sabresd_board_init line:1832
vgaarb: loaded
imx-i2c imx-i2c.1: <i2c_imx_probe>
imx-i2c imx-i2c.1: <i2c_imx_probe> bitrate:100000
i2c i2c-1: claimed irq 69
i2c i2c-1: device resources from 0x21a4000 to 0x21a4fff
i2c i2c-1: allocated 4096 bytes at 0x21a4000
i2c i2c-1: adapter name: "imx-i2c"
i2c i2c-1: IMX I2C adapter registered
imx-i2c imx-i2c.2: <i2c_imx_probe>
imx-i2c imx-i2c.2: <i2c_imx_probe> bitrate:100000
i2c i2c-2: claimed irq 70
i2c i2c-2: device resources from 0x21a8000 to 0x21a8fff
i2c i2c-2: allocated 4096 bytes at 0x21a8000
i2c i2c-2: adapter name: "imx-i2c"
i2c i2c-2: IMX I2C adapter registered
TCP reno registered
pci 0000:00:00.0: BAR 14: assigned [mem 0x01200000-0x013fffff]
pci 0000:00:00.0: BAR 6: assigned [mem 0x01400000-0x0140ffff pref]
pci 0000:01:00.0: BAR 0: assigned [mem 0x01200000-0x013fffff 64bit]
pci 0000:01:00.0: BAR 0: set to [mem 0x01200000-0x013fffff 64bit] (PCI address [0x1200000-0x13fffff])
pci 0000:00:00.0:   bridge window [mem 0x01200000-0x013fffff]
cpu regulator init ldo=1
valid mode RGB666
mxc_ldb mxc_ldb: ldb_clk to di clk: ldb_di0_clk -> ipu1_di0_clk
mxc_ldb mxc_ldb: Single mode channel 0 route to IPU0-DI0
Inside ldb_disp_setup pixel_clk:64998000 rounded_pixel_clk:64653061
imx-ipuv3 imx-ipuv3.0: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
mxc_sdc_fb mxc_sdc_fb.0:  ### fb_blank line:1039
mxc_sdc_fb mxc_sdc_fb.0: blank = 0
Console: switching to colour frame buffer device 170x48
mxc_sdc_fb mxc_sdc_fb.0:  mxcfb_pan_display line:1399
### Called fb_pan_display err:-22
valid mode RGB666
mxc_sdc_fb mxc_sdc_fb.2: ipu0-di0 already in use
mxc_sdc_fb: probe of mxc_sdc_fb.2 failed with error -16
valid mode RGB666
Serial: IMX driver
console [ttymxc2] enabled, bootconsole disabled
loop: module loaded
Can't recover from RESET HBA!
No sata disk.
m25p80 spi0.0: unrecognized JEDEC id 206a56
FEC Ethernet Driver
wait otg vbus change timeout!
lirc_dev: IR Remote Control driver registered, major 252
IR NEC protocol handler initialized
IR RC5(x) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR RC5 (streamzap) protocol handler initialized
IR LIRC bridge handler initialized
In MVC: init_camera_struct
###### Inside prp_enc_init line:584
###### Inside csi_enc_init line:423
In adv7180_init
DBG sensor data is at 80b9f718
In adv7180_probe
Inside mx6q_csi0_io_init_adv7441 line:564
Inside mx6q_csi0_io_init_adv7441 line:577 init high
Inside mx6q_csi0_io_init_adv7441 line:581 set low
Inside mx6q_csi0_io_init_adv7441 line:588 set high
Inside mx6q_csi0_cam_powerdown_adv7441 line:559
adv7441a 1-0021: adv7180_probe:adv7180 probe i2c address is 0x21
adv7441a 1-0021: adv7180_probe:Analog Device adv7 00 detected!
adv7441a 1-0021: In adv7180:adv7180_hard_reset
###### adv7180_write_reg reg:0x0 val:0xe
###### adv7180_write_reg reg:0x3 val:0x0
###### adv7180_write_reg reg:0x4 val:0x47
###### adv7180_write_reg reg:0x5 val:0x0
###### adv7180_write_reg reg:0x3c val:0xad
###### adv7180_write_reg reg:0x17 val:0x41
###### adv7180_write_reg reg:0x67 val:0x2
###### adv7180_write_reg reg:0x68 val:0xf0
###### adv7180_write_reg reg:0x1d val:0x40
###### adv7180_write_reg reg:0x31 val:0x1a
###### adv7180_write_reg reg:0x32 val:0x81
###### adv7180_write_reg reg:0x33 val:0x84
###### adv7180_write_reg reg:0x34 val:0x0
###### adv7180_write_reg reg:0x35 val:0x0
###### adv7180_write_reg reg:0x36 val:0x7d
###### adv7180_write_reg reg:0x37 val:0xa1
###### adv7180_write_reg reg:0x3a val:0x7
###### adv7180_write_reg reg:0x3c val:0xa8
###### adv7180_write_reg reg:0x47 val:0xa
###### adv7180_write_reg reg:0xba val:0xa0
###### adv7180_write_reg reg:0xf3 val:0x7
###### adv7180_write_reg reg:0x69 val:0x0
###### adv7180_write_reg reg:0xe8 val:0x41
###### adv7180_write_reg reg:0xe9 val:0x84
###### adv7180_write_reg reg:0xea val:0x6
   type is 2 (expect 2)
   num ioctls is 11
adv7441a 1-0021: adv7180:ioctl_s_power
adv7441a 1-0021: adv7180:ioctl_g_fmt_cap
   Returning size of 720x625
End of mxc_v4l2_master_attach: device_type 1
End of mxc_v4l2_master_attach: v2f pix widthxheight 288 x 352
End of mxc_v4l2_master_attach: crop_bounds widthxheight 720 x 625
End of mxc_v4l2_master_attach: crop_defrect widthxheight 720 x 625
End of mxc_v4l2_master_attach: crop_current widthxheight 720 x 625
gspca: v2.13.0 registered
cx25858 driver version 2.0.111 loaded
cx25858 driver unsuccess
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v1.1.0)
sdhci sdhci-esdhc-imx.3: support_8bit:1
sdhci sdhci-esdhc-imx.1: support_8bit:1
sdhci sdhci-esdhc-imx.2: support_8bit:1
VPU initialized
mxc_asrc registered
Thermal calibration data is 0x5784c37d
imx-hdmi-soc-dai: probe of imx-hdmi-soc-dai.0 failed with error -12
ALSA device list:
mmcblk0: mmc0:0001 SEM08G 7.39 GiB
mmcblk0boot0: mmc0:0001 SEM08G partition 1 2.00 MiB
mmcblk0boot1: mmc0:0001 SEM08G partition 2 2.00 MiB
mmcblk0: p1
mxc_dvfs_core_probe
regulator_init_complete: SPKVDD: incomplete constraints, leaving on
snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 08:04:21 UTC (29061)
EXT2-fs (mmcblk0p1): warning: mounting unchecked fs, running e2fsck is recommended
VFS: Mounted root (ext2 filesystem) on device 179:1.
starting pid 1440, tty '': '/etc/rc.d/rcS'
Mounting /proc and /sys
Starting the hotplug events dispatcher udevd
udevd (1449): /proc/1449/oom_adj is deprecated, please use /proc/1449/oom_score_adj instead.
Synthesizing initial hotplug events
mmc2: new high speed SDHC card at address 1234
mmcblk1: mmc2:1234 SA08G 7.28 GiB
mmcblk1: p1
Setting the hostname to freescale
Mounting filesystems
cp: write error: No space left on device
cp: write error: EXT2-fs (mmcblk0p1): error: ext2_lookup: deleted inode referenced: 234449
cp: write error: No space left on deviceEXT2-fs (mmcblk0p1): error: ext2_lookup: deleted inode referenced: 234449
cp: write error: No space left EXT2-fs (mmcblk0p1): error: ext2_lookup: deleted inode referenced: 234449
on device
ln: /etc/mtab: Input/output error
mount: mounting usbfs on /proc/bus/usb failed: No such file or directory
Starting the port mapper:
Starting the boa webserver:
rebuilding rpm database
rpmdb: write: 0x7e977654, 8192: No space left on device
error: db4 error(28) from dbenv->open: No space left on device
error: cannot open Packages index
starting pid 2772, tty '': '/etc/rc.d/rc_gpu.S'
EXT2-fs (mmcblk0p1): error: ext2_lookup: deleted inode referenced: 363702
ln: /usr/lib/libOpenVG.so: Input/output error
starting pid 2779, tty '': '/etc/rc.d/rc_mxc.S'
arm-none-linux-gnueabi-gcc (Freescale MAD -- Linaro 2011.07 -- Built at 2011/08/10 09:20) 4.6.2 20110630 (prerelease)
root filesystem built on Sun, 28 Jul 2013 02:45:43 +0800
Freescale Semiconductor, Inc.
freescale login:
is pcie right?
It seems that the PCIe is right, the memory space required by EP device had been allocated by PCIe RC.
You can get the detailed info by the "lspci -v” command, after you login the console.
Best Regards
Richard
root@freescale ~$ lspci
00:00.0 Class 0604: 16c3:abcd
01:00.0 Class 0400: 14f1:8580
root@freescale ~$ lspci -v
root@freescale ~$   my device is
static struct pci_device_id cx25858_pci_tbl[] = {
        /* CX25858 Atlas Plus */
        .vendor       = 0x14f1,
        .device       = 0x8580,
        .subvendor    = 0x14f1,
        .subdevice    = 0x0950,
it  seem id is right,but you can see from log:
I print the message in the driver :
  if (!pci_register_driver(&cx25858_pci_driver)) {
        pci_unregister_driver(&cx25858_pci_driver);
       printk(KERN_INFO "cx25858 driver unsuccess\n");
        return -ENODEV;
  printk(KERN_INFO "cx25858 driver success\n");
    return 0;
  why register wrong,can you give any suggest?
   /* return pci_register_driver(&cx25858_pci_driver);*/
[ ] Message Signaled Interrupts (MSI and MSI-X)       in make menuconfig    need select ?
when I select ,there is wrong .i
drivers/built-in.o: In function `default_setup_msi_irqs':
clkdev.c:(.text+0x10ca4): undefined reference to `arch_setup_msi_irq'
drivers/built-in.o: In function `default_teardown_msi_irqs':
clkdev.c:(.text+0x10d18): undefined reference to `arch_teardown_msi_irq'
make: *** [.tmp_vmlinux1] Error 1
Hi:
Can you please issue one new topic to discuss your problem?
I think that your problem is not related to PCIe EP/RC validation at all.
Please make sure that the release version used by you support PCIe MSI or not.
As I remember that the 1.1.0 release doesn't support PCIe MSI yet.
Best Regards
Richard
Hello Richard
I'm trying to use a Sabrelite board with IMX6Q as a PCIe EP.
I Created a PCIe Cable that goes from the PCIe Port (j23) to a little board where I have a molex connector, and that gets rooted to a FPC Flex connector all the way to the PCIe Goldfinger using one of those Raiser: http://www.bplustech.com/KZ/KZ-B21.html The schematic of this raiser can be found here: http://www.bplus.com.tw/PDF/KZ-B21_VER1_0_20130118A.pdf
Basically I Connect on the PCIe Goldfinger part the  PRSNT1#  --  PRSNT2# to tell the HOST PC that it's a x1 pcie:
then my setup could be resumed as:
GND --  GND
TXP -- RXP
TXM -- RXM
RXP -- TXP
RXM -- TXM
(http://whatsphere.com/pcie.jpeg)
Here is a view to the BOOT
Starting kernel ...
[    0.000000] Linux version 3.0.35-2508-g54750ff (xavier@ubuntu) (gcc version 4.6.2 20110630 (prerelease) (Freescale MAD -- Linaro 2011.07 -- Built at 2011/08/10 09:20) ) #24 SMP PREEMPT Sun Nov 3
[    0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
[    0.000000] Machine: Freescale i.MX 6Quad Sabre-Lite Board
[    0.000000] PERCPU: Embedded 7 pages/cpu @8c008000 s5440 r8192 d15040 u32768
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 227328
[    0.000000] Kernel command line: enable_wait_mode=off video=mxcfb0:off video=mxcfb1:off video=mxcfb2:off console=ttymxc1,115200 vmalloc=400M consoleblank=0 rootwait root=/dev/mmcblk0p1
[    0.000000] Memory: 640MB 256MB = 896MB total
[    0.000000] Memory: 896756k/896756k available, 151820k reserved, 0K highmem
[    0.000000]     vmalloc : 0xc0800000 - 0xf2000000   ( 792 MB)
[    0.000000]     lowmem  : 0x80000000 - 0xc0000000   (1024 MB)
[    0.000000]     pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
[    0.000000]     modules : 0x7f000000 - 0x7fe00000   (  14 MB)
[    0.000000]       .init : 0x80008000 - 0x8003b000   ( 204 kB)
[    0.000000]       .text : 0x8003b000 - 0x80aa62cc   (10669 kB)
[    0.000000]       .data : 0x80aa8000 - 0x80b072c0   ( 381 kB)
[    0.000000]        .bss : 0x80b072e4 - 0x80b556ac   ( 313 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] MXC_Early serial console at MMIO 0x21e8000 (options '115200')
[    0.000000] bootconsole [ttymxc1] enabled
[    0.224540] Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
[    0.312867] pid_max: default: 32768 minimum: 301
[    0.317802] Mount-cache hash table entries: 512
[    0.323097] CPU: Testing write buffer coherency: ok
[    0.328254] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
[    0.428774] CPU1: Booted secondary processor
[    0.508778] CPU2: Booted secondary processor
[    0.588792] CPU3: Booted secondary processor
[    0.628290] Brought up 4 CPUs
[    0.644115] SMP: Total of 4 processors activated (6324.22 BogoMIPS).
[    0.667822] print_constraints: dummy:
[    0.671823] NET: Registered protocol family 16
[    0.680477] print_constraints: vddpu: 725 <--> 1300 mV at 1150 mV fast normal
[    0.688013] print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal
[    0.695751] print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal
[    0.703438] print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal
[    0.711197] print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal
[    0.718839] print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast normal
[    0.727742] **DEBUG mx6_sabrelite_board_init
[    0.790388] **DEBUG imx_add_pcie
[    0.793966] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.800798] hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
[    0.808143] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.814042] L310 cache controller enabled
[    0.818071] l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x02070000, Cache size: 1048576 B
[    0.849718] bio: create slab <bio-0> at 0
[    0.857066] mxs-dma mxs-dma-apbh: initialized
[    0.861759] print_constraints: vmmc: 3300 mV
[    0.866817] vgaarb: loaded
[    0.870369] SCSI subsystem initialized
[    0.874931] spi_imx imx6q-ecspi.0: probed
[    0.879688] usbcore: registered new interface driver usbfs
[    0.885314] usbcore: registered new interface driver hub
[    0.890798] usbcore: registered new device driver usb
[    0.895867] Freescale USB OTG Driver loaded, $Revision: 1.55 $
[    0.918287] imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
[    0.938282] imx-ipuv3 imx-ipuv3.1: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
[    0.946109] mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 driver probed
[    0.952586] mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 dphy version is 0x3130302a
[    0.960308] MIPI CSI2 driver module loaded
[    0.964632] Advanced Linux Sound Architecture Driver Version 1.0.24.
[    0.971833] Bluetooth: Core ver 2.16
[    0.975533] NET: Registered protocol family 31
[    0.980001] Bluetooth: HCI device and connection manager initialized
[    0.986377] Bluetooth: HCI socket layer initialized
[    0.991277] Bluetooth: L2CAP socket layer initialized
[    0.996429] Bluetooth: SCO socket layer initialized
[    1.001760] cfg80211: Calling CRDA to update world regulatory domain
[    1.008652] i2c-core: driver [max17135] using legacy suspend method
[    1.014941] i2c-core: driver [max17135] using legacy resume method
[    1.021168] Switching to clocksource mxc_timer1
[    1.037670] NET: Registered protocol family 2
[    1.042238] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    1.050180] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    1.059505] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[    1.067234] TCP: Hash tables configured (established 131072 bind 65536)
[    1.073869] TCP reno registered
[    1.077034] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    1.082999] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    1.089789] NET: Registered protocol family 1
[    1.094454] RPC: Registered named UNIX socket transport module.
[    1.100408] RPC: Registered udp transport module.
[    1.105126] RPC: Registered tcp transport module.
[    1.109852] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.117195] Static Power Management for Freescale i.MX6
[    1.122438] wait mode is disabled for i.MX6
[    1.126812] cpaddr = c0880000 suspend_iram_base=c091c000
[    1.132223] PM driver module loaded
[    1.135722] **DEBUG imx_pcie_drv_init
[    1.174919] **DEBUG imx_pcie_pltfm_probe
[    1.178171] iMX6 PCIe PCIe EP mode imx_pcie_pltfm_probe entering.
[    1.184380] PCIE: imx_pcie_pltfm_probe start link up.
[    1.189459] PCIe EP: waiting for link up...
[   15.540166] PCIe EP: link up.
[   15.543512] IMX usb wakeup probe
[   15.547195] add wake up source irq 75
[   15.554446] IMX usb wakeup probe
[   15.557952] cpu regulator mode:ldo_enable
[   15.562170] i.MXC CPU frequency driver
[   15.590899] JFFS2 version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
[   15.597527] msgmni has been set to 1751
[   15.602766] alg: No test for stdrng (krng)
[   15.607030] io scheduler noop registered
[   15.610966] io scheduler deadline registered
[   15.615331] io scheduler cfq registered (default)
[   15.621043] MIPI DSI driver module loaded
[   15.625229] mxc_sdc_fb mxc_sdc_fb.0: Can't get fb option for mxcfb0!
[   15.631641] mxc_sdc_fb mxc_sdc_fb.1: Can't get fb option for mxcfb1!
[   15.638041] mxc_sdc_fb mxc_sdc_fb.2: Can't get fb option for mxcfb2!
[   15.644430] mxc_sdc_fb mxc_sdc_fb.3: register mxc display driver ldb
[   15.650830] _regulator_get: get() with no identifier
[   15.667087] Console: switching to colour frame buffer device 160x50
[   15.682241] imx-sdma imx-sdma: loaded firmware 1.1
[   15.690972] imx-sdma imx-sdma: initialized
[   15.814091] Serial: IMX driver
[   15.817281] imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
[   15.824129] imx-uart.1: ttymxc1 at MMIO 0x21e8000 (irq = 59) is a IMX
[   15.830620] console [ttymxc1] enabled, bootconsole disabled
[   15.846998] loop: module loaded
[   15.884600] No sata disk.
[   15.888429] m25p80 spi0.0: sst25vf016b (2048 Kbytes)
[   15.893400] Creating 2 MTD partitions on "m25p80":
[   15.898209] 0x000000000000-0x000000100000 : "bootloader"
[   15.904579] 0x000000100000-0x000000200000 : "kernel"
[   15.910711] GPMI NAND driver registered. (IMX)
[   15.916014] vcan: Virtual CAN interface driver
[   15.920464] CAN device driver interface
[   15.924304] flexcan netdevice driver
[   15.928752] flexcan imx6q-flexcan.0: device registered (reg_base=c09e8000, irq=142)
[   15.936542] FEC Ethernet Driver
[   15.941717] fec_enet_mii_bus: probed
[   15.946292] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   15.952944] fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
[   15.959594] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
[   15.995767] fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000
[   16.015757] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
[   16.022008] hub 1-0:1.0: USB hub found
[   16.025780] hub 1-0:1.0: 1 port detected
[   16.029901] add wake up source irq 72
[   16.033602] fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
[   16.040243] fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
[   16.075767] fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200
[   16.095755] fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
[   16.101938] hub 2-0:1.0: USB hub found
[   16.105702] hub 2-0:1.0: 1 port detected
[   16.109947] Initializing USB Mass Storage driver...
[   16.114988] usbcore: registered new interface driver usb-storage
[   16.121010] USB Mass Storage support registered.
[   16.125632] ARC USBOTG Device Controller driver (1 August 2005)
[   16.132344] mousedev: PS/2 mouse device common for all mice
[   16.138373] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[   16.145762] egalax_ts 2-0004: egalax_ts: failed to read firmware version
[   16.152477] egalax_ts: probe of 2-0004 failed with error -5
[   16.158557] i2c-core: driver [isl29023] using legacy suspend method
[   16.164830] i2c-core: driver [isl29023] using legacy resume method
[   16.171586] snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0
[   16.178258] i2c /dev entries driver
[   16.182461] Linux video capture interface: v2.00
[   16.187446] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16
[   16.195068] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17
[   16.202918] i2c-core: driver [mag3110] using legacy suspend method
[   16.209139] i2c-core: driver [mag3110] using legacy resume method
[   16.215645] imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1)
[   16.223761] Bluetooth: Virtual HCI driver ver 1.3
[   16.228680] Bluetooth: HCI UART driver ver 2.2
[   16.233128] Bluetooth: HCIATH3K protocol initialized
[   16.238105] Bluetooth: Generic Bluetooth USB driver ver 0.6
[   16.243804] usbcore: registered new interface driver btusb
[   16.249437] sdhci: Secure Digital Host Controller Interface driver
[   16.255623] sdhci: Copyright(c) Pierre Ossman
[   16.260386] mmc0: SDHCI controller on platform [sdhci-esdhc-imx.3] using DMA
[   16.267756] mmc1: SDHCI controller on platform [sdhci-esdhc-imx.2] using DMA
[   16.275002] mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
[   16.286210] VPU initialized
[   16.289955] mxc_asrc registered
[   16.317073] Thermal calibration data is 0x5874c87d
[   16.321870] Thermal sensor with ratio = 183
[   16.345881] Anatop Thermal registered as thermal_zone0
[   16.351169] anatop_thermal_probe: default cooling device is cpufreq!
[   16.358317] usbcore: registered new interface driver usbhid
[   16.363893] usbhid: USB HID core driver
[   16.368144] usbcore: registered new interface driver snd-usb-audio
[   16.374848] mxc_hdmi_soc mxc_hdmi_soc.0: MXC HDMI Audio
[   16.380296] Cirrus Logic CS42888 ALSA SoC Codec Driver
[   16.385539] i2c-core: driver [cs42888] using legacy suspend method
[   16.387149] mmc0: new high speed SDHC card at address 0001
[   16.397244] i2c-core: driver [cs42888] using legacy resume method
[   16.403550] mmcblk0: mmc0:0001 00000 7.44 GiB
[   16.404126] imx-hdmi-soc-dai imx-hdmi-soc-dai.0: Failed: Load HDMI-video first.
[   16.404881] imx_3stack asoc driver
[   16.405497] Initialize HDMI-audio failed. Load HDMI-video first!
[   16.405505] ALSA device list:
[   16.405510]   No soundcards found.
[   16.405716] NET: Registered protocol family 26
[   16.406295] TCP cubic registered
[   16.406303] NET: Registered protocol family 17
[   16.406320] can: controller area network core (rev 20090105 abi 8)
[   16.406391] NET: Registered protocol family 29
[   16.406407] can: raw protocol (rev 20090105)
[   16.406413] can: broadcast manager protocol (rev 20090105 t)
[   16.425829] usb 2-1: new high speed USB device number 2 using fsl-ehci
[   16.470303] Bluetooth: RFCOMM TTY layer initialized
[   16.471595]  mmcblk0: p1
[   16.477735] Bluetooth: RFCOMM socket layer initialized
[   16.482876] Bluetooth: RFCOMM ver 1.11
[   16.486635] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   16.491949] Bluetooth: BNEP filters: protocol multicast
[   16.497189] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[   16.503241] lib80211: common routines for IEEE802.11 drivers
[   16.508958] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[   16.516994] Bus freq driver module loaded
[   16.521011] Bus freq driver Enabled
[   16.526514] mxc_dvfs_core_probe
[   16.529846] DVFS driver module loaded
[   16.535886] snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 05:59:54 UTC (21594)
[   16.549411] EXT3-fs: barriers not enabled
[   16.554225] kjournald starting.  Commit interval 5 seconds
[   16.558984] EXT3-fs (mmcblk0p1): using internal journal
[   16.558996] EXT3-fs (mmcblk0p1): mounted filesystem with writeback data mode
[   16.559027] VFS: Mounted root (ext3 filesystem) on device 179:1.
[   16.559086] Freeing init memory: 204K
[   16.648921] hub 2-1:1.0: USB hub found
[   16.652848] hub 2-1:1.0: 3 ports detected
starting pid 1354, tty '': '/etc/rc.d/rcS'
[   16.886688] udevd (1372): /proc/1372/oom_adj is deprecated, please use /proc/1372/oom_score_adj instead.
Setting the hostname to boundary
Running sysctl
Setting up networking on loopback device:
Setting up networking on eth0:
udhcpc (v1.20.2) started
[   19.039687] eth0: Freescale FEC PHY driver [Micrel KSZ9021 Gigabit PHY] (mii_bus:phy_addr=1:06, irq=-1)
Sending discover...
Sending discover...
Sending discover...
No lease, forking to background
Starting the dropbear ssh server:
starting pid 3060, tty '': '/etc/rc.d/rc_gpu.S'
starting pid 3068, tty '': '/etc/rc.d/rc_mxc.S'
root filesystem built on Tue, 18 Jun 2013 12:28:53 -0700
boundary login:
U-Boot 2013.01-rc1-00120-g7c28db0 (Nov 12 2012 - 09:15:04)
CPU:   Freescale i.MX6Q rev1.2 at 792 MHz
So the behaviour is that the board boots, and blocks at: "PCIe EP: waiting for link up..." and as soon as I switch on the PC, it goes on all the way to the login prompt.
At that stage, knowing that by default the IMX6q is at 125Mhz and that the CLK signal are not connected on the PCIe connector of the board, so it uses internal PLL, and that the standard for PCIe is 100Mhz. Is it sure that the link isr really UP ?
Obviously on the PC side, if I issue a "lspci" I don't see anything. :smileysad:
The thing is that according to the patch, it's supposed to set the VID/PID to "DEADBEAF" but when I look at the memory, I see the default VID/PID:
$ ./memtool -32 01FFC000 20
Reading 0x20 count starting at address 0x01FFC000
0x01FFC000:  ABCD16C3 00100000 00000001 00000000
0x01FFC010:  0000000C 00000000 00000008 00000001
0x01FFC020:  00000000 00000000 00000000 00000000
0x01FFC030:  00000000 00000040 00000000 000001FF
0x01FFC040:  DBC35001 00000000 00000000 00000000
0x01FFC050:  01807005 00000000 00000000 00000000
0x01FFC060:  00000000 00000000 00000000 00000000
0x01FFC070:  00020010 00008700 00102010 0001CC12
So I must be doing something wrong. any help would be welcome.
just for info, i even patched my sabrelite files like that:
arch/arm/mach-mx6/board-mx6q_sabrelite.c
+#define SABREAUTO_MAX7310_1_BASE_ADDR   IMX_GPIO_NR(8, 0)
+#define SABREAUTO_PCIE_RST_B_REVB       (SABREAUTO_MAX7310_1_BASE_ADDR + 2)
+static const struct imx_pcie_platform_data mx6_sabrelite_pcie_data __initconst = {
+        .pcie_pwr_en    = -EINVAL,
+        .pcie_rst       = SABREAUTO_PCIE_RST_B_REVB,
+        .pcie_wake_up   = -EINVAL,
+        .pcie_dis       = -EINVAL,
+#ifdef CONFIG_IMX_PCIE_EP_MODE_IN_EP_RC_SYS
+        .type_ep        = 1,
+#else
+        .type_ep        = 0,
+#endif
static void __init mx6_sabrelite_board_init(void)
+        /* Add PCIe RC interface support */
+        imx6q_add_pcie(&mx6_sabrelite_pcie_data);
        imx6q_add_perfmon(0);
        imx6q_add_perfmon(1);
        imx6q_add_perfmon(2);
regards
Hi:
Wow, It's amazing, pcie link is still up, cable of the connector is a little long of your HW.
About link is up or not, you can make a double check on the bit4 of Debug Register 1(0x01ff_c72c), link is up if this bit is set.
Best Regards
Richard.
Hi, thx for your answer. My question was more: If it says link is UP, is it really UP ? or is it just because there is some electrical activity on the RX path ?
Right now, I believe the board is at 125Mhz and not 100Mhz (how can I check that?) and since it's inserted inside a PC, the freq of the bus in a PC should be 100Mhz, no ? in this case how would the link be up ?
Also, on the PC side, I don't see any PCI interface corresponding to the board as a memory device when I issue a "lspci". So does your patch for EP and "emulating a memory device" work for beeing seen as a memory device on the other side ?
regards
Hello.
I have same issue as "keytwo.
Short cable help me avoid the problem when kernel hang up after message "PCIE: Waiting for link up..." (or something like this).
Now kernel booting right, but i have no "dead_beaf" device on root complex.
I use PC on root complex side. My question is "Is it possible to make the board working as EP with usual PC with usual linux 3.11?" I have no more freescale boards.
Regards.
I just checked my register with memtool. "while(true) ; do sleep 1 ; ./memtool -32 01ffc72c 1 | grep -v add | grep 0x; done"
in fact the 4th bit switches from 1 to 0 then 1 again.. randomly.
so maybe something is wrong with my cable. or, it's the fact that my device might be sync at 125Mhz while the normal PCI bus is sync at 100Mhz therefor it desync and link goes down.
richard.zhu How do I know if I'm in 125Mhz or 100Mhz ?
Too bad there is no demonstration of how to turn the device into EP with a normal PC instead of 2 Sabre boards.
aleksandrmuraviov Could you post a pic of your setup ?
On the board i'm using, the TX+/TX- signals get separated for a couple of centimeters because i was doing single face PCB, so that might be the reason it doesnt work.
keytwothat is - https://community.freescale.com/docs/DOC-98614
Sorry, but i cannot paste image right here.
The situation that i am writing about were without pink and orange plug on the adapter.
I added it in hope to it will provide clock to the board. But now i have no any signals from root complex. Kernel load hang up on the message "PCIe EP: waiting for link up...".
Regards.
After checking the uplink register on a while loop, i realized that my device was in fact loosing the link up.
So i decided to make a new cable, where I respect the proximity of the TX/RX lines by putting the track right next to eachother, with a new type of connector
so on one side I come from the SABRE Lite J23 connector, to my little adapter, and that goes to a KZ-B21 ( http://www.bplus.com.tw/ExtenderBoard/KZ-B21.html )
I tested this one on several PC, and on one of them (just one) when I do a "lspci" i see my dead:beaf device as a RAM pcie card.
On the Sabrelite, the link stays UP (0x00000310) It looks like the cable was really an issue here.
I still can not read the PC's memmory.
I still don't know if the device is working on 100Mhz or 125Mhz and if I don't have a clock problem. What I know for sure is that on another PC, the link gets UP and Down non stop. So I still wonder if I don't have a clock issue.
maybe richard.zhu could tell us more about it ? What i know is that on some EP implementation, it activates the CLK1 of LVDS port in input. is it switching into external clock ?
As of aleksandrmuraviov could you tell me more about the board you are using ? (btw, to post a picture here, just drag and drop)
Hi key two:
It's great that you can look at imx ep at one of your pc.
Sorry, I'm busy on one internal critical release in these days, don't have much time here.
Imx6q pcie uses 125mhz as internal ref clk.
Actually, it's doesn't matter when the standalone ref clk is used by ep and rc.
Another ref clk solution, imx6q pcie ep can use the 100m clk provided by pc pcie rc in theory.
But some configurations are required,you can make a reference to the topic when the 100m external OSC is implemented in this community.
Richard
在 2013-11-28,下午6:38,"key two" <admin@community.freescale.com<mailto:admin@community.freescale.com>> 写道:
<https://community.freescale.com/>
i.MX6Q PCIe EP/RC Validation System
new comment by key two<https://community.freescale.com/people/keytwo?et=watches.email.document_comment> View all comments on this document<https://community.freescale.com/docs/DOC-95014?et=watches.email.document_comment#comment-8508>
Hi richard.zhu,
it's true it doesn't matter if EP and RC use each of them an internal clock, but in the case of a PC, the PC acting as a RC is providing the CLK to the EP (here the imx) and I believe this clock is 100Mhz as it's standard. (unless i'm wrong?)
So here the problem is that if the IMX is set at 125Mhz, that it only uses TX/RX but NOT the CLK coming from the RC which is at 100Mhz. what happens ?
Could it be the reason it works only in 1 PC ?
Hello, Hongxing Zhu.
Do you mean that PC not provide LVDS differencial clock that required by freescale?
Is it possible to make PC provide this signal? I can not find anything relation option in kernel menuconfig of PC.
The PCIe from the PC always sends the CLK signal, it's not an option, it's mandatory !
The EP can use this CLK signal, or can use it's internal clock, and relay on the 8b10b clock recovery.
In the case of the MX6Q, the way it is implemented currently in the kernel, it uses it's internal clock.
It is also possible to give the MX6 an external clock (coming from the PC) but in this case you need to patch the kernel in order to use the external clock !
I suggest you to run "while(true) ; do sleep 1 ; ./memtool -32 01ffc72c 1 | grep -v add | grep 0x; done" and see the value you get. if it's something like "xxxxxx1x" then the link is up, if it's something like "xxxxxx0x" then the link is down !
Hi:
Imx pcie can use external 100m ref clk, after the responding sw modifications.
The modifications can be made reference to the external OSC usage topic in this community.
Best Regards
Richard
Sent from Huawei Mobile
aleksandr Muraviov <admin@community.freescale.com>编写:
new comment by aleksandr Muraviov<https://community.freescale.com/people/aleksandrmuraviov?et=watches.email.document_comment> View all comments on this document<https://community.freescale.com/docs/DOC-95014?et=watches.email.document_comment#comment-8518>
Thanks for this post, works perfectly.
Little question : if i create some 4K IO in BAR0, they are seen at 0x1E00000 on RC. Thats' fine. But how to read/write the IO space from the endpoint itself ? Where is it allocated ?
Another question : any example on how to sent PCIe interrupt from the EP to the RC ? I have tested various settings with the iATU, but no result up to now. Any ideas ?
We currently try to archive high bandwidth data transfers from a Xilinx Artix7 FPGA to the DDR of the iMX6. We finally got something running but unfortunately the data transfer bandwidth was not as good as we would have expected on the i.MX6. We generate a data stream within the FPGA using a clock counter and send it using the FPGA as a bus master to the iMX6 RC. By subtracting the last transferred data word from the first we calculated the data transfer speed, so calculation should not depend on any CPU latencies. Some precision might get lost, as we currently sending the generated clock values to the PCIe core of the FPGA that buffers them. As we could see in chipscope the iMX6 always has some stalls on the PCIe bus after 128bytes (probably the payload size limitation), but we can only see gaps in the received data words on the iMX6' DDR after about 2048 bytes so there seem to be a buffer in the Xilinx PCIe core, that makes the timing values not synchronous to the real PCIe data packages. But it shouldn't have a big impact on the overall calculation of bandwidth speed.
Nevertheless when transferring a 512KByte buffer from the FPGA to the i.MX6 we got 270MB/s while we got ~400MB/s on an x86 system with one PCIe 2.0 lane.
Is there any obvious reason (apart from the maximum payload size of 128byte on the i.MX6) that the transfer rate is only that low? As the maximum payload size on the FPGA is currently limited to 256 bytes anyway it shouldn't have a very big effect in comparison to the x86 system.
I'm also wondering why in your case you only reach 344MB/s as a maximum. Shouldn't the PCIe interface allow a bit higher bandwidth?
Hi richard.zhu
I've been trying to repeat this validation on an i.MX6DL setup but failed so far. Can you see any reason why such setup fails? It looks like it fails on hardware access after link training has been started. A lot of code is "labeled" iMX6Q but used for iMX6DL, I've reviewed it and can't find anything obvious wrong, most differences are handled by if iMX6Q or iMX6DL
My community post on the matter. Have anyone successfully reproduced i.MX6Q PCIe EP/RC Validation System on an i.MX6DL setup
Any feedback is appreciated.
Andreas
I am using the same setup to validate PCIe througput from imx6 end point to root complex. I want to know how can we change TLP size when arm core is used as bus master. More importantly, how tlp paload size can have any impact on read throughput when arm core can only read 4 bytes at a time. Why are we setting TLP size to 32 bytes when arm core is used as bus master? Does it have any affect on read performance? or we just get same numbers irrespective of TLP size?
Hi:
As I know that the MAX_PAY_LOAD_SIZE of imx6 pcie is 128bytes.
The actual data size on one tlp is decided by the cache-burst capability of the pcie master.
That's why the data size in the imx6 pcie ep/rc validation is 32 when arm core is used as the bus master.
And the data size is 64 when IPU(DMA) used as the bus master.
Best Regards.
Richard.
Hi richard.zhu keytwo
I have successfully run the validation system with the two Sabre_Lite boards.
Now I am trying to run PCIe endpoint (Sabre_Lite) with other Root Complexes (like PC). My link is not up when I connect my EP to other RC than the Sabre_Lite. Is using internal ref 125Mhz clock be the issue.
Since Sabre_Lite PCIe connector does not have input CLK signal, will I be a needing hardware modification If I have to pass RC reference clock to EP?.
If yes, can hardware modification be prevented.
Haider
HW modifications is mandatory required, since the REF CLK is sourced from pll in the original imx6 pcie hw design.
Best Regards.
Richard
One customer uses RTL8111e and reported kernel panic issue,
eth1      Link encap:Ethernet  HWaddr 00:E0:4C:68:A2:04
          inet addr:192.168.0.2  Bcast:192.168.0.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:12 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:1002 (1002.0 B)  TX bytes:0 (0.0 B)
          Interrupt:155 Base address:0xe000
<5-2666-gbdde708/kernel/drivers/net/r8168-8.039.00$ ping 192.168.0.1
PING 192.168.0.1 (192.168.0.1): 56 data bytes
kernel BUG at arch/arm/mm/dma-mapping.c:478!
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = 80004000
[00000000] *pgd=00000000
Internal error: Oops: 817 [#1] PREEMPT SMP
Modules linked in: r8168
CPU: 2    Not tainted  (3.0.35-2666-gbdde708 #20)
PC is at __bug+0x1c/0x28
LR is at __bug+0x18/0x28
pc : [<800462c8>]    lr : [<800462c4>]    psr: 60000193
sp : bffb5dc8  ip : c097a000  fp : ba074000
r10: 0000021c  r9 : 7f03d544  r8 : ff9f2000
r7 : ff9f8000  r6 : 00000001  r5 : 00000012  r4 : ff9f2000
r3 : 00000000  r2 : 80ad329c  r1 : 60000193  r0 : 00000033
Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
Control: 10c53c7d  Table: 4a2b404a  DAC: 00000015
Process swapper (pid: 0, stack limit = 0xbffb42f0)
Stack: (0xbffb5dc8 to 0xbffb6000)
5dc0:                   80b16930 8004cb08 00000012 00400000 0000002a 7f0019f8
5de0: 00000000 80000000 00000000 bfd92480 ba0744b4 ff9f8000 ff9f8000 80000113
5e00: c0b7e000 bfc938a0 00000000 60004980 bfd92480 ba074000 00000000 80abc11c
5e20: 7f03d544 bfd82480 80439354 8042f11c 00000006 ba07418c bfc1ec08 bfd3dd02
5e40: ba074000 bfd3df00 ba074000 bfd3df5c bfd92480 bfd82480 00000000 00000002
5e60: 80439354 8044a694 bfd82480 bfd3df00 bfd92480 ba074000 bfd82480 bfd3df5c
5e80: 00000000 8042f5a0 bfd3df5c bfd3de00 00000000 00000000 00000000 bfd92240
5ea0: ba074000 0100a8c0 0200a8c0 00000000 bfd3de00 8047d8fc 0200a8c0 00000000
5ec0: bfc1ec08 00000000 00000010 bfd92240 bfd9225c bfd92254 bfd923c0 00000000
5ee0: 00000103 80439558 bffb5f08 bffcc000 80aa8080 bffb4000 00200200 80082f84
5f00: 000000fa 8436ae00 bffb5f08 bffb5f08 00000000 00000141 80aa8044 bffb4000
5f20: 00000103 80b102e0 00000002 80aa8040 00000001 8007d078 839e72da 000000fa
5f40: 839e72da 0000000a 839e72da bffb4000 bffb4000 8003bc00 00000000 00000002
5f60: bffb4000 00000000 00000000 8007d5b4 80abbcc0 8003d2e0 ffffffff f2a00100
5f80: 00000002 00000002 00000001 80042a0c 80b11c40 80000093 00000001 00000000
5fa0: bffb4000 80b0a744 80abba70 8051d870 80abef0c 412fc09a 00000000 00000000
5fc0: 00000000 bffb5fd8 80051e2c 80043b04 40000013 ffffffff 80043ae0 80043d20
5fe0: 4ffb806a 00000015 10c03c7d 80b0a8f8 1000406a 10511694 8102080c 22705244
[<800462c8>] (__bug+0x1c/0x28) from [<8004cb08>] (___dma_single_cpu_to_dev+0x94/0xa4)
[<8004cb08>] (___dma_single_cpu_to_dev+0x94/0xa4) from [<7f0019f8>] (rtl8168_start_xmit+0x514/0x6c4 [r8168])
[<7f0019f8>] (rtl8168_start_xmit+0x514/0x6c4 [r8168]) from [<8042f11c>] (dev_hard_start_xmit+0x2f4/0x59c)
[<8042f11c>] (dev_hard_start_xmit+0x2f4/0x59c) from [<8044a694>] (sch_direct_xmit+0xb0/0x1dc)
[<8044a694>] (sch_direct_xmit+0xb0/0x1dc) from [<8042f5a0>] (dev_queue_xmit+0x1dc/0x60c)
[<8042f5a0>] (dev_queue_xmit+0x1dc/0x60c) from [<8047d8fc>] (arp_solicit+0xd4/0x1b0)
[<8047d8fc>] (arp_solicit+0xd4/0x1b0) from [<80439558>] (neigh_timer_handler+0x204/0x38c)
[<80439558>] (neigh_timer_handler+0x204/0x38c) from [<80082f84>] (run_timer_softirq+0xec/0x214)
[<80082f84>] (run_timer_softirq+0xec/0x214) from [<8007d078>] (__do_softirq+0xac/0x140)
[<8007d078>] (__do_softirq+0xac/0x140) from [<8007d5b4>] (irq_exit+0x94/0x9c)
[<8007d5b4>] (irq_exit+0x94/0x9c) from [<8003d2e0>] (do_IPI+0x10c/0x17c)
[<8003d2e0>] (do_IPI+0x10c/0x17c) from [<80042a0c>] (__irq_svc+0x4c/0xe8)
Exception stack(0xbffb5f90 to 0xbffb5fd8)
5f80:                                     80b11c40 80000093 00000001 00000000
[<80042a0c>] (__irq_svc+0x4c/0xe8) from [<80043b04>] (default_idle+0x24/0x28)
[<80043b04>] (default_idle+0x24/0x28) from [<80043d20>] (cpu_idle+0xe0/0x124)
[<80043d20>] (cpu_idle+0xe0/0x124) from [<10511694>] (0x10511694)
Code: e59f0010 e1a01003 eb133c07 e3a03000 (e5833000)
clk_enable cannot be called in an interrupt context
[<80049e34>] (unwind_backtrace+0x0/0xf8) from [<8006563c>] (clk_enable+0x88/0xa0)
[<8006563c>] (clk_enable+0x88/0xa0) from [<8039b608>] (_ipu_get+0xc/0x24)
[<8039b608>] (_ipu_get+0xc/0x24) from [<8039c4bc>] (ipu_clear_irq+0x18/0x8c)
[<8039c4bc>] (ipu_clear_irq+0x18/0x8c) from [<802714bc>] (mxcfb_set_par+0xb8/0x6d0)
[<802714bc>] (mxcfb_set_par+0xb8/0x6d0) from [<80271b78>] (mxcfb_blank+0xa4/0xb8)
[<80271b78>] (mxcfb_blank+0xa4/0xb8) from [<80259d24>] (fb_blank+0x3c/0x68)
[<80259d24>] (fb_blank+0x3c/0x68) from [<80263b18>] (fbcon_blank+0x1c4/0x258)
[<80263b18>] (fbcon_blank+0x1c4/0x258) from [<80297fa0>] (do_unblank_screen+0x94/0x194)
[<80297fa0>] (do_unblank_screen+0x94/0x194) from [<8023c004>] (bust_spinlocks+0x24/0x4c)
[<8023c004>] (bust_spinlocks+0x24/0x4c) from [<800465c0>] (die+0xa8/0x284)
[<800465c0>] (die+0xa8/0x284) from [<8051464c>] (__do_kernel_fault.part.4+0x54/0x74)
[<8051464c>] (__do_kernel_fault.part.4+0x54/0x74) from [<8004da68>] (do_page_fault+0x2b4/0x31c)
[<8004da68>] (do_page_fault+0x2b4/0x31c) from [<8003d384>] (do_DataAbort+0x34/0x9c)
[<8003d384>] (do_DataAbort+0x34/0x9c) from [<80042990>] (__dabt_svc+0x70/0xa0)
Exception stack(0xbffb5d80 to 0xbffb5dc8)
5d80: 00000033 60000193 80ad329c 00000000 ff9f2000 00000012 00000001 ff9f8000
5da0: ff9f2000 7f03d544 0000021c ba074000 c097a000 bffb5dc8 800462c4 800462c8
5dc0: 60000193 ffffffff
[<80042990>] (__dabt_svc+0x70/0xa0) from [<800462c8>] (__bug+0x1c/0x28)
kernel BUG at arch/arm/plat-mxc/clock.c:101!
pgd = 80004000
What's kernel version used by customer and what's the activities of the RTL8111e when it report the kernel panic?
Richard
Richard
       kernel version is :Linux version 3.0.35-2666-gbdde708
     kernel boot log :
Uncompressing Linux... done, booting the kernel.
Linux version 3.0.35-2666-gbdde708 (user@ubuntu) (gcc version 4.6.2 20110630 (prerelease) (Freescale MAD -- Linaro 2011.07 -- Built at 2011/08/10 09:20) ) #20 SMP PREEMPT Sun Jan 11 02:32:04 PST 2015
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Freescale i.MX 6Quad/DualLite/Solo Sabre-SD Board
Ignoring unrecognised tag 0x54410008
Memory policy: ECC disabled, Data cache writealloc
CPU identified as i.MX6Q, silicon rev 1.2
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 194560
Kernel command line: console=ttymxc0,115200 root=/dev/mmcblk1p1 rootwait rw video=mxcfb1:dev=ldb,LDB-XGA,if=RGB666 video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 512MB 256MB = 768MB total
Memory: 765672k/765672k available, 282904k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xf4600000 - 0xffe00000   ( 184 MB)
      .init : 0x80008000 - 0x8003d000   ( 212 kB)
      .text : 0x8003d000 - 0x80aa54f0   (10658 kB)
      .data : 0x80aa6000 - 0x80b0a660   ( 402 kB)
       .bss : 0x80b0a684 - 0x80b58b8c   ( 314 kB)
NR_IRQS:624
MXC GPIO hardware
arm_max_freq=1GHz
MXC_Early serial console at MMIO 0x2020000 (options '115200')
bootconsole [ttymxc0] enabled
Brought up 4 CPUs
print_constraints: vddpu: 725 <--> 1300 mV at 700 mV fast normal
print_constraints: SPKVDD: 4200 mV
vgaarb: loaded
mc_pfuze 1-0008: ID: 0,Full lay: 1 ,Metal lay: 1
mc_pfuze 1-0008: FAB: 0 ,FIN: 0
print_constraints: PFUZE100_SW1A: 300 <--> 1875 mV at 1300 mV
print_constraints: PFUZE100_SW1B: 300 <--> 1875 mV at 300 mV
print_constraints: PFUZE100_SW1C: 300 <--> 1875 mV at 1300 mV
print_constraints: PFUZE100_SW2: 800 <--> 3950 mV at 3300 mV
print_constraints: PFUZE100_SW3A: 400 <--> 1975 mV at 1500 mV
print_constraints: PFUZE100_SW3B: 400 <--> 1975 mV at 1500 mV
print_constraints: PFUZE100_SW4: 800 <--> 3950 mV at 3150 mV
print_constraints: PFUZE100_SWBST: 5000 <--> 5150 mV at 5000 mV
print_constraints: PFUZE100_VSNVS: 1200 <--> 3000 mV at 1800 mV
print_constraints: PFUZE100_VREFDDR: at 750 mV
print_constraints: PFUZE100_VGEN1: 800 <--> 1550 mV at 1500 mV
print_constraints: PFUZE100_VGEN2: 800 <--> 1550 mV at 1500 mV
print_constraints: PFUZE100_VGEN3: 1800 <--> 3300 mV at 2800 mV
print_constraints: PFUZE100_VGEN4: 1800 <--> 3300 mV at 1800 mV
print_constraints: PFUZE100_VGEN5: 1800 <--> 3300 mV at 3000 mV
print_constraints: PFUZE100_VGEN6: 1800 <--> 3300 mV at 3300 mV
max17135 2-0048: PMIC MAX17135 for eInk display
TCP reno registered
pci 0000:00:00.0: BAR 9: assigned [mem 0x01100000-0x011fffff pref]
pci 0000:00:00.0: BAR 7: assigned [io  0x1e00000-0x1e00fff]
pci 0000:01:00.0: BAR 4: assigned [mem 0x01100000-0x01103fff 64bit pref]
pci 0000:01:00.0: BAR 4: set to [mem 0x01100000-0x01103fff 64bit pref] (PCI address [0x1100000-0x1103fff])
pci 0000:01:00.0: BAR 2: assigned [mem 0x01104000-0x01104fff 64bit pref]
pci 0000:01:00.0: BAR 2: set to [mem 0x01104000-0x01104fff 64bit pref] (PCI address [0x1104000-0x1104fff])
pci 0000:01:00.0: BAR 0: assigned [io  0x1e00000-0x1e000ff]
pci 0000:01:00.0: BAR 0: set to [io  0x1e00000-0x1e000ff] (PCI address [0x1e00000-0x1e000ff])
pci 0000:00:00.0:   bridge window [io  0x1e00000-0x1e00fff]
pci 0000:00:00.0:   bridge window [mem disabled]
pci 0000:00:00.0:   bridge window [mem 0x01100000-0x011fffff pref]
cpu regulator mode:ldo_bypass
mx6_cpu_regulator_init: failed to get pu regulator
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 1495
mxc_mipi_dsi mxc_mipi_dsi: i.MX MIPI DSI driver probed
mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver hdmi
mxc_hdmi mxc_hdmi: Detected HDMI controller 0x13:0xa:0xa0:0xc1
fbcvt: 1920x1080@60: CVT Name - 2.073M9
Console: switching to colour frame buffer device 240x67
mxc_sdc_fb mxc_sdc_fb.1: register mxc display driver ldb
mxc_sdc_fb mxc_sdc_fb.2: register mxc display driver lcd
Serial: IMX driver
imx-uart.2: ttymxc2 at MMIO 0x21ec000 (irq = 60) is a IMX
console [ttymxc0] enabled, bootconsole disabled
loop: module loaded
No sata disk.
m25p80 spi0.0: found m25p32, expected sst25vf016b
m25p80 spi0.0: m25p32 (4096 Kbytes)
0x000000100000-0x000000400000 : "kernel"
FEC Ethernet Driver
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
input: max11801_ts as /devices/platform/imx-i2c.1/i2c-1/1-0048/input/input1
egalax_ts 1-0004: egalax_ts: failed to read firmware version
egalax_ts: probe of 1-0004 failed with error -5
input: eGalax Touch Screen as /devices/platform/imx-i2c.2/i2c-2/2-0004/input/input2
elan - Read Hello Packet Failed
elan-touch: probe of 2-0010 failed with error -22
input: isl29023 light sensor as /devices/virtual/input/input3
isl29023 2-0044: driver version 1.0 enabled
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video18
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video19
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video20
mag3110 2-000e: check mag3110 chip ID
input: mag3110 as /devices/virtual/input/input4
mag3110 2-000e: mag3110 is probed
input: mma845x as /devices/virtual/input/input5
mmc1: SDHCI controller on platform [sdhci-esdhc-imx.1] using DMA
mmc2: SDHCI controller on platform [sdhci-esdhc-imx.2] using DMA
VPU initialized
mxc_asrc registered
Galcore version 4.6.9.6622
Thermal calibration data is 0x55c4af7d
Thermal sensor with ratio = 176
wm8962 0-001a: customer id 0 revision D
input: WM8962 Beep Generator as /devices/platform/imx-i2c.0/i2c-0/0-001a/input/input6
asoc: wm8962 <-> imx-ssi.1 mapping ok
input: wm8962-audio DMIC as /devices/platform/soc-audio.5/sound/card0/input7
input: wm8962-audio Ext Spk as /devices/platform/soc-audio.5/sound/card0/input8
asoc: mxc-hdmi-soc <-> imx-hdmi-soc-dai.0 mapping ok
ALSA device list:
  #0: wm8962-audio
  #1: imx-hdmi-soc
mmc0: new high speed DDR MMC card at address 0001
mmcblk0: p1
mmcblk0boot1: unknown partition table
mmcblk0boot0: unknown partition table
mxc_dvfs_core_probe
regulator_init_complete: PFUZE100_VGEN6: incomplete constraints, leaving on
regulator_init_complete: PFUZE100_VGEN3: incomplete constraints, leaving on
regulator_init_complete: PFUZE100_VGEN2: incomplete constraints, leaving on
regulator_init_complete: PFUZE100_VGEN1: incomplete constraints, leaving on
snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:00:01 UTC (1)
Waiting for root device /dev/mmcblk1p1...
mmcblk1: mmc2:1234 SA04G 3.63 GiB
mmcblk1: p1
EXT3-fs (mmcblk1p1): using internal journal
EXT3-fs (mmcblk1p1): recovery complete
EXT3-fs (mmcblk1p1): mounted filesystem with writeback data mode
VFS: Mounted root (ext3 filesystem) on device 179:25.
Freeing init memory: 212K
starting pid 1468, tty '': '/etc/rc.d/rcS'
udevd (1477): /proc/1477/oom_adj is deprecated, please use /proc/1477/oom_score_adj instead.
starting pid 3292, tty '': '/etc/rc.d/rc_gpu.S'
starting pid 3298, tty '': '/etc/rc.d/rc_mxc.S'
root filesystem built on Wed, 31 Dec 2014 21:03:35 -0800
    command lspci output :
<5-2666-gbdde708/kernel/drivers/net/r8168-8.039.00$ lspci
01:00.0 Class 0200: 10ec:8168
    Then I load the RTL8111E driver, and config the interface eth1:
<5-2666-gbdde708/kernel/drivers/net/r8168-8.039.00$ insmod r8168.ko
r8168 Gigabit Ethernet driver 8.039.00-NAPI loaded
r8168 0000:01:00.0: no MSI. Back to INTx.
r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
r8168  Copyright (C) 2014  Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
<vers/net/r8168-8.039.00$ ifconfig eth1 192.168.0.2 up
eth1: 0xc0b86000, 00:e0:4c:68:a2:04, IRQ 155
<5-2666-gbdde708/kernel/drivers/net/r8168-8.039.00$ r8168: eth1: link up
<5-2666-gbdde708/kernel/drivers/net/r8168-8.039.00$ ifconfig
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Interrupt:155 Base address:0x6000
The kernel coredump when I run the command "PING 192.168.0.1"
PING 192.168.0.1 (192.168.0.1): 5kernel BUG at arch/arm/mm/dma-mapping.c:478!
6 data bytes
pgd = 80004000
Modules linked in: r8168 [last unloaded: r8168]
sp : bffb5dc8  ip : c097a000  fp : bfb80000
r10: 0000021c  r9 : 7f084544  r8 : ff9f2000
Control: 10c53c7d  Table: 4a70404a  DAC: 00000015
5dc0:                   80b16930 8004cb08 00000012 00400000 0000002a 7f0489f8
5de0: 00000000 80000000 00000000 bfcbfd80 bfb804b4 ff9f8000 ff9f8000 80000113
5e00: c0b86000 ba14f090 00000000 60004980 bfcbfd80 bfb80000 00000000 80abc11c
5e20: 7f084544 bfdb8a20 80439354 8042f11c 00000006 bfb8018c bfcd0608 bfe7ed02
5e40: bfb80000 bfe7ef00 bfb80000 bfe7ef5c bfcbfd80 bfdb8a20 00000000 00000002
5e60: 80439354 8044a694 bfdb8a20 bfe7ef00 bfcbfd80 bfb80000 bfdb8a20 bfe7ef5c
5e80: 00000000 8042f5a0 bfe7ef5c bfe7ee00 00000000 00000000 00000000 bfcbfb40
5ea0: bfb80000 0100a8c0 0200a8c0 00000000 bfe7ee00 8047d8fc 0200a8c0 00000000
5ec0: bfcd0608 00000000 00000010 bfcbfb40 bfcbfb5c bfcbfb54 bfcbfcc0 00000000
5f00: 0000024e 7abe5a80 bffb5f08 bffb5f08 00000000 00000141 80aa8044 bffb4000
5f20: 00000103 80b102e0 00000002 80aa8040 00000001 8007d078 7a264549 0000024e
5f40: 7a264549 0000000a 7a264549 bffb4000 bffb4000 8003bc00 00000000 00000002
5fe0: 4ffb806a 00000015 10c03c7d 80b0a8f8 1000406a 10511694 81022cce 22705254
[<8004cb08>] (___dma_single_cpu_to_dev+0x94/0xa4) from [<7f0489f8>] (rtl8168_start_xmit+0x514/0x6c4 [r8168])
[<7f0489f8>] (rtl8168_start_xmit+0x514/0x6c4 [r8168]) from [<8042f11c>] (dev_hard_start_xmit+0x2f4/0x59c)
5da0: ff9f2000 7f084544 0000021c bfb80000 c097a000 bffb5dc8 800462c4 800462c8
pgd = 80004000
add kernel's configure:
  x x     <*> PCI Stub driver                                                        x x
  x x     [ ] PCI IOV support                                                        x x
  x x     [*] PCI Express support                                                    x x
  x x     [*]   Root Port Advanced Error Reporting support                           x x
  x x     [ ] PCI Express ECRC settings control                                  x x
  x x     < > PCIe AER error injector support                                    x x
  x x     [*]   PCI Express ASPM control                                             x x
  x x     [ ] Debug PCI Express ASPM                                             x x
%3CLINGO-SUB%20id%3D%22lingo-sub-1126624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX6Q%20PCIe%20EP%2FRC%E6%A4%9C%E8%A8%BC%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20id%3D%22toc-hId-382516595%22%20id%3D%22toc-hId-1304073311%22%3Ei.MX6Q%20PCIe%20EP%2FRC%E6%A4%9C%E8%A8%BC%E3%81%A8%E3%82%B9%E3%83%AB%E3%83%BC%E3%83%97%E3%83%83%E3%83%88%3C%2FH1%3E%3CH2%20id%3D%22toc-hId-1073078069%22%20id%3D%22toc-hId-1994634785%22%3E%3CBR%20%2F%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId--734376394%22%20id%3D%22toc-hId-187180322%22%3E%3CBR%20%2F%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId-1753136439%22%20id%3D%22toc-hId--1620274141%22%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3C%2FH2%3E%3CP%3E*%202%E3%81%A4%E3%81%AEi.MX6Q%20SD%E3%83%9C%E3%83%BC%E3%83%89%E3%80%811%E3%81%A4%E3%81%AFPCIe%20RC%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%82%82%E3%81%861%E3%81%A4%E3%81%AFPCIe%20EP%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%822%20*%20mini_PCIe%20%E3%81%A7%20standard_PCIe%20%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%83%BC%E3%80%812%20%20PEX%20%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%83%BC%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%201%20%E6%9C%AC%E3%81%AE%20PCIe%20%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-03-21_10-24-40_704.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-03-21_10-24-40_704.jpg%22%20style%3D%22width%3A%20907px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110864i0A900558E63E8936%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222013-03-21_10-24-40_704.jpg%22%20alt%3D%222013-03-21_10-24-40_704.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--54318024%22%20id%3D%22toc-hId-867238692%22%3E%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E6%A7%8B%E6%88%90%3C%2FH2%3E%3CP%3E*%20RC%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20CONFIG_IMX_PCIE%3Dy%3C%2FP%3E%3CP%3E%23%20CONFIG_IMX_PCIE_EP_MODE_IN_EP_RC_SYS%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20CONFIG_IMX_PCIE_RC_MODE_IN_EP_RC_SYS%3Dy%3C%2FP%3E%3CP%3E*%20EP%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20CONFIG_IMX_PCIE%3Dy%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20CONFIG_IMX_PCIE_EP_MODE_IN_EP_RC_SYS%3Dy%3C%2FP%3E%3CP%3E%23%20CONFIG_IMX_PCIE_RC_MODE_IN_EP_RC_SYS%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%3C%2FP%3E%3CH2%20id%3D%22toc-hId--1861772487%22%20id%3D%22toc-hId--940215771%22%3E%3CBR%20%2F%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId-625740346%22%20id%3D%22toc-hId-1547297062%22%3E%E7%89%B9%E9%95%B7%3C%2FH2%3E%3CP%3E*%20RC%E3%81%A8EP%E3%81%AE%E9%96%93%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AF%E3%80%81%E5%86%85%E9%83%A8%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%A2%E3%83%AD%E3%83%B3%E3%81%AE125MHz%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E2%80%BBEP%E3%81%AE%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E3%81%AF%E3%80%81PCIe%20EP%E3%81%A8PCIe%20RC%E3%81%AE%E7%9B%B8%E4%BA%92%E6%8E%A5%E7%B6%9A%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81PCIe%20RC%E3%81%AE%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BFDDR%E3%83%A1%E3%83%A2%E3%83%AA(%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A0x40000000)%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%B3%A8%3ASD%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE1G%20DDR%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%81%AF0x1000_0000~0x4FFF_FFFF)%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7%20mem%3D768M%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81EP%20%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%83%86%E3%82%B9%E3%83%88%E3%81%AE%E5%AE%9F%E8%A1%8C%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%200x4000_0000%20~%200x4FFF_FFFF%20DDR%20%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%82%92%E4%BA%88%E7%B4%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E(RC%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E4%BE%8B%3A%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%3A%20noinitrd%20console%3Dttymxc0%2C115200%20%3CSTRONG%3Emem%3D768M%3C%2FSTRONG%3E%20root%3D%2Fdev%2Fnfs%20nfsroot%3D10.192.225.216%3A%2Fhome%2Fr65037%2Fnfs%2Frootfs_mx5x_10.11%2Cv3%2Ctcpip%3Ddhcp%20rw)%3C%2FP%3E%3CH2%20id%3D%22toc-hId--1181714117%22%20id%3D%22toc-hId--260157401%22%3E%3CA%20id%3D%22PCIeEP_RCvalidationandthroughput-Throughputresults%5C%5C%22%20name%3D%22PCIeEP_RCvalidationandthroughput-Throughputresults%5C%5C%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId-1305798716%22%20id%3D%22toc-hId--2067611864%22%3E%3CBR%20%2F%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId--501655747%22%20id%3D%22toc-hId-419900969%22%3E%3CBR%20%2F%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId--635340471%22%20id%3D%22toc-hId-286216245%22%3E%E3%82%B9%E3%83%AB%E3%83%BC%E3%83%97%E3%83%83%E3%83%88%E3%81%AE%E7%B5%90%E6%9E%9C%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CDIV%20class%3D%22table-wrap%22%3E%3CTABLE%20class%3D%22confluenceTable%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3E%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3EARM%20%E3%82%B3%E3%82%A2%E3%82%92%E3%83%90%E3%82%B9%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AF%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3EARM%20%E3%82%B3%E3%82%A2%E3%82%92%E3%83%90%E3%82%B9%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E%E3%83%90%E3%82%B9%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC(DMA)%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8BIPU%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3E1%20%E5%9B%9E%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%20tlp%20%E3%81%A7%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%B5%E3%82%A4%E3%82%BA%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E8%E3%83%90%E3%82%A4%E3%83%88%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E32%E3%83%90%E3%82%A4%E3%83%88%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E64%20%E3%83%90%E3%82%A4%E3%83%88%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3E%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E9%80%9F%E5%BA%A6%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E~109MB%2F%E7%A7%92%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E~298MB%2F%E7%A7%92%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E~%3CSTRONG%3E344MB%3C%2FSTRONG%3E%2F%E7%A7%92%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3E1%20%E5%9B%9E%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%20tlp%20%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%B5%E3%82%A4%E3%82%BA%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E32%E3%83%90%E3%82%A4%E3%83%88%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E64%20%E3%83%90%E3%82%A4%E3%83%88%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E64%20%E3%83%90%E3%82%A4%E3%83%88%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3E%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E9%80%9F%E5%BA%A6%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E~29MB%2F%E7%A7%92%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E~100MB%2F%E7%A7%92%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E~%3CSTRONG%3E211%E3%83%A1%E3%82%AC%E3%83%90%E3%82%A4%E3%83%88%3C%2FSTRONG%3E%2F%E7%A7%92%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1981255081%22%20id%3D%22toc-hId--1392155499%22%3E%E3%83%90%E3%82%B9%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC(DMA)%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8BIPU%3C%2FH3%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%80%81IPU%E3%81%8C%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%9FPCIe%E3%82%B9%E3%83%AB%E3%83%BC%E3%83%97%E3%83%83%E3%83%88%E7%B5%90%E6%9E%9C%E3%81%AE%E6%A6%82%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E9%80%9F%E5%BA%A6%E3%81%AF%E7%B4%84344%20MB%20%2F%20s%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E9%80%9F%E5%BA%A6%E3%81%AF%E7%B4%84211MB%2F%E7%A7%92%3C%2FP%3E%3CH3%20id%3D%22toc-hId-173800618%22%20id%3D%22toc-hId-1095357334%22%3E%3CBR%20%2F%3E%3C%2FH3%3E%3CH3%20id%3D%22toc-hId--1633653845%22%20id%3D%22toc-hId--712097129%22%3E%E3%83%90%E3%82%B9%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8BARM%E3%82%B3%E3%82%A2(pcie.c%E3%81%A7EP_SELF_IO_TEST%E3%82%92%E5%AE%9A%E7%BE%A9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC)%3C%2FH3%3E%3CP%3E%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E9%80%9F%E5%BA%A6%20~300MB%2F%E7%A7%92%3C%2FP%3E%3CP%3E%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E9%80%9F%E5%BA%A6%20~100MB%2F%E7%A7%92%3C%2FP%3E%3CH4%20id%3D%22toc-hId-982941707%22%20id%3D%22toc-hId-1904498423%22%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AF%E3%82%A4%E3%83%8D%E3%83%BC%E3%83%96%E3%83%AB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FH4%3E%3CP%3EPCIe%20EP%3A%E3%83%87%E3%83%BC%E3%82%BF%E8%BB%A2%E9%80%81%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FP%3E%3CP%3EPCIe%20EP%3A%E3%83%87%E3%83%BC%E3%82%BF%E8%BB%A2%E9%80%81%E3%81%AF%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81tv_count1%2054840us%E3%80%81tv_count2%20162814us%E3%80%82%3C%2FP%3E%3CP%3EPCIe%20EP%3A%E3%83%87%E3%83%BC%E3%82%BF%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E9%80%9F%E5%BA%A6%E3%81%AF298MB%2Fs%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EPCIe%20EP%3A%E3%83%87%E3%83%BC%E3%82%BF%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E9%80%9F%E5%BA%A6%E3%81%AF100MB%2Fs%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%AD%E3%82%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AE%E5%90%84TLP%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF%E3%80%81%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E6%99%82%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AE%E7%B4%844%E5%80%8D%E3%80%81%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%A8%E3%81%8D%E3%81%AF%E3%83%AA%E3%83%BC%E3%83%89%E6%99%82%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AE%E7%B4%842%E5%80%8D%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20class%3D%22table-wrap%22%3E%3C%2FP%3E%3CTABLE%20class%3D%22confluenceTable%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3E%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3E1%20%E5%9B%9E%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%20tlp%20%E3%81%A7%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%B5%E3%82%A4%E3%82%BA%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E8%E3%83%90%E3%82%A4%E3%83%88%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E32%E3%83%90%E3%82%A4%E3%83%88%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3E%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E9%80%9F%E5%BA%A6%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E~109MB%2F%E7%A7%92%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E~298MB%2F%E7%A7%92%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3E1%20%E5%9B%9E%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%20tlp%20%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%B5%E3%82%A4%E3%82%BA%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E32%E3%83%90%E3%82%A4%E3%83%88%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E64%20%E3%83%90%E3%82%A4%E3%83%88%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20class%3D%22confluenceTd%22%3E%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E9%80%9F%E5%BA%A6%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E~29MB%2F%E7%A7%92%3C%2FTD%3E%3CTD%20class%3D%22confluenceTd%22%3E~100MB%2F%E7%A7%92%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CH4%20id%3D%22toc-hId--824512756%22%20id%3D%22toc-hId-97043960%22%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%3C%2FH4%3E%3CP%3EPCIe%20EP%3A%E3%83%87%E3%83%BC%E3%82%BF%E8%BB%A2%E9%80%81%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FP%3E%3CP%3EPCIe%20EP%3A%E3%83%87%E3%83%BC%E3%82%BF%E8%BB%A2%E9%80%81%E3%81%AF%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82tv_count1%20149616us%E3%80%81tv_count2%20552099us%E3%80%82%3C%2FP%3E%3CP%3EPCIe%20EP%3A%E3%83%87%E3%83%BC%E3%82%BF%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E9%80%9F%E5%BA%A6%E3%81%AF109MB%2Fs%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EPCIe%20EP%3A%E3%83%87%E3%83%BC%E3%82%BF%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E9%80%9F%E5%BA%A6%E3%81%AF29MB%2Fs%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1275751920%22%20id%3D%22toc-hId--2097658660%22%3E%3CBR%20%2F%3E%3C%2FH1%3E%3CH1%20id%3D%22toc-hId--531702543%22%20id%3D%22toc-hId-389854173%22%3E%3CBR%20%2F%3E%3C%2FH1%3E%3CH1%20id%3D%22toc-hId-1955810290%22%20id%3D%22toc-hId--1417600290%22%3Eimx6%20pcie%20ep%20%E3%81%A8%20rc%20%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E7%B0%A1%E5%8D%98%E3%81%AA%E6%96%B9%E6%B3%95%E3%81%AE%201%20%E3%81%A4%3C%2FH1%3E%3CH2%20id%3D%22toc-hId-277438546%22%20id%3D%22toc-hId-1198995262%22%3E%3CBR%20%2F%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId--831853976%22%20id%3D%22toc-hId-89702740%22%3E%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E5%85%A8%E4%BD%93%E3%81%AE%E3%83%93%E3%83%A5%E3%83%BC%3A%3C%2FH2%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-04-07_15-43-46_818_small.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-04-07_15-43-46_818_small.jpg%22%20style%3D%22width%3A%20907px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110861i2984C2608B437C9D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222013-04-07_15-43-46_818_small.jpg%22%20alt%3D%222013-04-07_15-43-46_818_small.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId-1655658857%22%20id%3D%22toc-hId--1717751723%22%3EHW%E6%9D%90%E6%96%99%3A%3C%2FH2%3E%3CP%3E2%20*%20iMX6Q%20SD%E3%83%9C%E3%83%BC%E3%83%89%E3%80%812%20*%20Mini%20PCIe%20to%20STD%20PCIe%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%83%BC%E3%80%811%E6%9C%AC%E3%81%AESATA2%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3EMini-PCIe%20%E3%81%8B%E3%82%89%E6%A8%99%E6%BA%96%E3%81%AE%20PCIe%20%E4%BA%A4%E6%8F%9B%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%83%BC%E3%80%82%3C%2FP%3E%3CP%3EHere%20is%20the%20URL%3A%3CBR%20%2F%3E%3CA%20class%3D%22external-link%22%20href%3D%22http%3A%2F%2Fwww.bplus.com.tw%2FAdapter%2FPM2C.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.bplus.com.tw%2FAdapter%2FPM2C.html%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PM2C.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PM2C.png%22%20style%3D%22width%3A%20350px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110857i1C40DD0BB637386E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22PM2C.png%22%20alt%3D%22PM2C.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--151795606%22%20id%3D%22toc-hId-769761110%22%3E%E4%BD%9C%E3%82%8A%E6%96%B9%E3%80%82%3C%2FH2%3E%3CH3%20id%3D%22toc-hId--1830167350%22%20id%3D%22toc-hId--908610634%22%3E%3CBR%20%2F%3E%3C%2FH3%3E%3CH3%20id%3D%22toc-hId-657345483%22%20id%3D%22toc-hId-1578902199%22%3E%E4%BF%A1%E5%8F%B7%E6%8E%A5%E7%B6%9A%3C%2FH3%3E%3CP%3E2%20%E3%81%A4%E3%81%AE%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%83%BC%20(1%20%E3%81%A4%E3%81%AF%20A%E3%80%81%E3%82%82%E3%81%86%201%20%E3%81%A4%E3%81%AF%20B%20%E3%81%A8%E5%91%BC%E3%81%B0%E3%82%8C%E3%81%BE%E3%81%99)%3C%2FP%3E%3CP%3EA%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20B%3C%2FP%3E%3CP%3ETXM%20%26lt%3B----%26gt%3B%20RXM%3C%2FP%3E%3CP%3ETXN%20%26lt%3B----%26gt%3B%20RXN%3C%2FP%3E%3CP%3ERXM%20%26lt%3B----%26gt%3B%20TXM%3C%2FP%3E%3CP%3ERXN%20%26lt%3B----%26gt%3B%20TXN%3C%2FP%3E%3CP%3EA1%20%E3%82%92%20B3%20%E3%81%AB%E6%8E%A5%E7%B6%9A%3C%2FP%3E%3CP%3EA2%20%E3%82%92%20B4%20%E3%81%AB%E6%8E%A5%E7%B6%9A%3C%2FP%3E%3CP%3EA3%20%E3%82%92%20B1%20%E3%81%AB%E6%8E%A5%E7%B6%9A%3C%2FP%3E%3CP%3EA4%20%E3%82%92%20B2%20%E3%81%AB%E6%8E%A5%E7%B6%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-04-07_16-02-59_594_small.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-04-07_16-02-59_594_small.jpg%22%20style%3D%22width%3A%20907px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110851i98266B769FE82A21%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222013-04-07_16-02-59_594_small.jpg%22%20alt%3D%222013-04-07_16-02-59_594_small.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId--1150108980%22%20id%3D%22toc-hId--228552264%22%3E%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%83%BC%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FH3%3E%3CP%3ESATA2%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92MiniPCIe-STDPCIe%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%83%BC(A)%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-04-07_16-02-17_913_small.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-04-07_16-02-17_913_small.jpg%22%20style%3D%22width%3A%20907px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110849iE1ED638DC4B6F47A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222013-04-07_16-02-17_913_small.jpg%22%20alt%3D%222013-04-07_16-02-17_913_small.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3ESATA2%20%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%20Mini%20PCIe%20to%20STD%20PCIe%20%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%83%BC%20(B)%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-04-07_16-01-36_658_small.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222013-04-07_16-01-36_658_small.jpg%22%20style%3D%22width%3A%20907px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110848iAB15F6405BE2880B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222013-04-07_16-01-36_658_small.jpg%22%20alt%3D%222013-04-07_16-01-36_658_small.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%89%8B%E8%A8%98%EF%BC%9A%3C%2FSTRONG%3E%3CBR%20%2F%3E%E2%80%BB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AE%E9%95%B7%E3%81%95%E3%81%AF%E3%81%AA%E3%82%8B%E3%81%B9%E3%81%8F%E7%9F%AD%E3%81%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%BC%8A%E7%A4%BE%E3%81%AE%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AF%E7%B4%8412cm%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E2%80%BBSATA2%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AE%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%E7%B7%9A%E3%81%AF%E3%80%81%E4%B8%A1%E5%9F%BA%E6%9D%BF%E3%81%AEGND%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%E2%80%BBPCIe%20RC%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E3%80%81PCIe%20EP%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%99%E3%83%BC%E3%82%B91%E3%81%AEimx_3.0.35%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%E3%80%81%E3%83%91%E3%83%83%E3%83%81%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3IPU%E3%83%86%E3%82%B9%E3%83%88%E3%83%84%E3%83%BC%E3%83%AB%E3%81%8C%E5%8F%96%E3%82%8A%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%B3%A8%EF%BC%9A%3C%2FP%3E%3CP%3E*%20IPU%E3%83%86%E3%82%B9%E3%83%88%E4%BD%BF%E7%94%A8%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3Exxx.zip%E3%82%92%E8%A7%A3%E5%87%8D%E3%81%97%E3%80%81xxx_r.sh%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81xxx_w.sh%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E3%83%86%E3%82%B9%E3%83%88%E3%83%AD%E3%82%B0%3A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3EEP%E3%81%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20class%3D%22external-link%22%20href%3D%22mailto%3Aroot%40freescale%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eroot%40freescale%3C%2FA%3E%20~%2Fpcie_ep_io_test%24%20.%2Fpcie-r.sh%3CBR%20%2F%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%2014%2C%20.%2Fpcie_ipudev_test.out%20%E3%82%92%E6%B8%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3Ac%3CBR%20%2F%3E%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%82%BB%E3%83%83%E3%83%88%201%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3AL%3CBR%20%2F%3E%E3%83%AB%E3%83%BC%E3%83%97%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%82%BB%E3%83%83%E3%83%88%201%3C%2FP%3E%3CP%3Enew%20option%20%3A%20i%3CBR%20%2F%3Einput%20w%3D1024%2Ch%3D1024%2Cfucc%3DRGB4%2Ccpx%3D0%2Ccpy%3D0%2Ccpw%3D0%2Ccph%3D0%2Cde%3D0%2Cdm%3D0%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3AO%3CBR%20%2F%3E640%2C480%2CRGB4%2C0%2C0%2C0%2C0%2C0%3CBR%20%2F%3E%E6%96%B0%E3%81%97%E3%81%84%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3As%3CBR%20%2F%3EFB%200%E3%81%AB%E8%A1%A8%E7%A4%BA%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3AF%3CBR%20%2F%3E%E5%87%BA%E5%8A%9B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%90%8D%20IPU1-1ST-OVFB%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3A%C3%BF%3CBR%20%2F%3Eshow_to_buf%3A0%E3%80%81input_paddr%3A0x1000000%E3%80%81output.paddr0x18800000%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%20IPU%E3%82%BF%E3%82%B9%E3%82%AF%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%97%E3%83%83%E3%83%88%EF%BC%9A%3CBR%20%2F%3E%E3%83%95%E3%82%A9%E3%83%A9%E3%83%A0%E3%83%88%3A0x34424752%3CBR%20%2F%3E%E5%B9%85%3A1024%3CBR%20%2F%3E%E9%AB%98%E3%81%95%3A1024%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%83%97.w%3D%201024%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%83%97.h%3D%201024%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%83%97.pos.x%3D%200%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%83%97.pos.y%3D%200%3CBR%20%2F%3E%E3%82%A2%E3%82%A6%E3%83%88%E3%83%97%E3%83%83%E3%83%88%EF%BC%9A%3CBR%20%2F%3E%E3%83%95%E3%82%A9%E3%83%A9%E3%83%A0%E3%83%88%3A0x34424752%3CBR%20%2F%3E%E5%B9%85%3A640%3CBR%20%2F%3E%E8%BA%AB%E9%95%B7%3A480%3CBR%20%2F%3E%E3%83%AD%E3%83%BC%E3%82%A2%E3%83%86%3A0%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%83%97.w%3D%20640%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%83%97.h%3D%20480%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%83%97.pos.x%3D%200%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%83%97.pos.y%3D%200%3CBR%20%2F%3E%E5%90%88%E8%A8%88%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E6%95%B0%201%20%E5%B9%B3%E5%9D%87%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E6%99%82%E9%96%93%2019019%20US%E3%80%81FPS%2052.579000%3CBR%20%2F%3E%3CA%20class%3D%22external-link%22%20href%3D%22mailto%3Aroot%40freescale%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eroot%40freescale%3C%2FA%3E%20~%2Fpcie_ep_io_test%24%20.%2Fpcie-w.sh%3CBR%20%2F%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%2014%2C%20.%2Fpcie_ipudev_test.out%20%E3%82%92%E6%B8%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3Ac%3CBR%20%2F%3E%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%82%BB%E3%83%83%E3%83%88%201%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3AL%3CBR%20%2F%3E%E3%83%AB%E3%83%BC%E3%83%97%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%82%BB%E3%83%83%E3%83%88%201%3C%2FP%3E%3CP%3Enew%20option%20%3A%20i%3CBR%20%2F%3Einput%20w%3D640%2Ch%3D480%2Cfucc%3DRGB4%2Ccpx%3D0%2Ccpy%3D0%2Ccpw%3D0%2Ccph%3D0%2Cde%3D0%2Cdm%3D0%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3AO%3CBR%20%2F%3E1024%2C1024%2CRGB4%2C0%2C0%2C0%2C0%2C0%3CBR%20%2F%3E%E6%96%B0%E3%81%97%E3%81%84%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3As%3CBR%20%2F%3EFB%201%E3%81%AB%E8%A1%A8%E7%A4%BA%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3AF%3CBR%20%2F%3E%E5%87%BA%E5%8A%9B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%90%8D%20IPU1-1ST-OVFB%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3A%C3%BF%3CBR%20%2F%3Eshow_to_buf%3A1%E3%80%81input_paddr%3A0x18a00000%E3%80%81output.paddr0x1000000%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%20IPU%E3%82%BF%E3%82%B9%E3%82%AF%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%E3%82%A4%E3%83%B3%E3%83%97%E3%83%83%E3%83%88%EF%BC%9A%3CBR%20%2F%3E%E3%83%95%E3%82%A9%E3%83%A9%E3%83%A0%E3%83%88%3A0x34424752%3CBR%20%2F%3E%E5%B9%85%3A640%3CBR%20%2F%3E%E8%BA%AB%E9%95%B7%3A480%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%83%97.w%3D%20640%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%83%97.h%3D%20480%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%83%97.pos.x%3D%200%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%83%97.pos.y%3D%200%3CBR%20%2F%3E%E3%82%A2%E3%82%A6%E3%83%88%E3%83%97%E3%83%83%E3%83%88%EF%BC%9A%3CBR%20%2F%3E%E3%83%95%E3%82%A9%E3%83%A9%E3%83%A0%E3%83%88%3A0x34424752%3CBR%20%2F%3E%E5%B9%85%3A1024%3CBR%20%2F%3E%E9%AB%98%E3%81%95%3A1024%3CBR%20%2F%3E%E3%83%AD%E3%83%BC%E3%82%A2%E3%83%86%3A0%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%83%97.w%3D%201024%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%83%97.h%3D%201024%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%83%97.pos.x%3D%200%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%83%97.pos.y%3D%200%3CBR%20%2F%3E%E5%90%88%E8%A8%88%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E6%95%B0%201%20%E5%B9%B3%E5%9D%87%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E6%99%82%E9%96%93%2011751%20US%E3%80%81FPS%2085.099140%3C%2FP%3E%3CP%3E%3CA%20class%3D%22external-link%22%20href%3D%22mailto%3Aroot%40freescale%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eroot%40freescale%3C%2FA%3E%20~%24%20.%2Fmemtool-32%2001000000%3D%E3%83%87%E3%83%83%E3%83%89%E3%83%93%E3%83%BC%E3%83%95%3CBR%20%2F%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%2032%20%E3%83%93%E3%83%83%E3%83%88%E5%80%A4%200xDEADBEAF%20%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x01000000%20%E3%81%B8%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%3C%2FP%3E%3CP%3ERC%3A%3C%2FP%3E%3CP%3E%22.%2Fmemtool%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB-32%2001000000%3Ddeadbeaf%22%20%E3%82%92%20EP%20%E3%81%A7%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20class%3D%22external-link%22%20href%3D%22mailto%3Aroot%40freescale%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eroot%40freescale%3C%2FA%3E%20~%24%20.%2Fmemtool-32%2040000000%2010%3CBR%20%2F%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x40000000%20%E3%81%8B%E3%82%89%E5%A7%8B%E3%81%BE%E3%82%8B0x10%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3C%2FP%3E%3CP%3E0x40000000%3A%20%3CSTRONG%3E00000000%3C%2FSTRONG%3E%2000000000%2000000000%2000000000%3CBR%20%2F%3E0x40000010%3A%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E0x40000020%3A%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E0x40000030%3A%2000000000%2000000000%2000000000%2000000000%3C%2FP%3E%3CP%3E%22.%2Fmemtool%22%E3%81%AE%E5%AE%9F%E8%A1%8C%E5%BE%8C-32%2001000000%3Ddeadbeaf%22%20%E3%82%92%20EP%20%E3%81%A7%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20class%3D%22external-link%22%20href%3D%22mailto%3Aroot%40freescale%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eroot%40freescale%3C%2FA%3E%20~%24%20.%2Fmemtool-32%2040000000%2010%3CBR%20%2F%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x40000000%20%E3%81%8B%E3%82%89%E5%A7%8B%E3%81%BE%E3%82%8B0x10%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3C%2FP%3E%3CP%3E0x40000000%3A%20%3CSTRONG%3EDEADBEAF%3C%2FSTRONG%3E%2000000000%2000000000%2000000000%3CBR%20%2F%3E0x40000010%3A%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E0x40000020%3A%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E0x40000030%3A%2000000000%2000000000%2000000000%2000000000%3C%2FP%3E%3C%2FDIV%3E%3CSPAN%3ELabels%20parameters%3C%2FSPAN%3E%3CFORM%3E%3CINPUT%20type%3D%22hidden%22%20%2F%3E%20%3CINPUT%20type%3D%22hidden%22%20%2F%3E%20%3CINPUT%20type%3D%22hidden%22%20%2F%3E%20%3CINPUT%20type%3D%22hidden%22%20%2F%3E%20%3CINPUT%20type%3D%22hidden%22%20%2F%3E%3C%2FFORM%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1126624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6_All%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126690%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126690%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20958px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F107519i084603FDBC0E3527%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%90%8C%E3%81%98%E3%82%82%E3%81%AE%E3%81%B8%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E8%A8%98%E4%BA%8B%E3%82%92%E8%AA%AD%E3%82%93%E3%81%A7%E7%90%86%E8%A7%A3%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%AF%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AB1%E3%81%A4%E3%81%AEtlp%E3%81%A7%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0%2F%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EChristoph%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126688%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126688%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Eduardo%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AA%E3%81%93%E3%81%A8%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBrian%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frichard.zhu%22%20target%3D%22_blank%22%3E%E3%83%AA%E3%83%81%E3%83%A3%E3%83%BC%E3%83%89%E3%83%BB%E3%83%81%E3%83%A5%E3%83%BC%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ei.MAX6%20Quad%20Sabre%20Lite%20Development%20%E3%83%9C%E3%83%BC%E3%83%89%20(%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fboundarydevices.com%2Fproduct%2Fsabre-lite-imx6-sbc%2F%22%20title%3D%22https%3A%2F%2Fboundarydevices.com%2Fproduct%2Fsabre-lite-imx6-sbc%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fboundarydevices.com%2Fproduct%2Fsabre-lite-imx6-sbc%2F%3C%2FA%3E)%20%E3%81%A7%20PCIE%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81TW6865%20Intersil%20%E3%83%93%E3%83%87%E3%82%AA%20%E3%83%81%E3%83%83%E3%83%97%E3%81%A8%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81TW6865%20%E3%81%AE%20REFCLK-%20%E3%81%8A%E3%82%88%E3%81%B3%20REFCLK%2B%20%E3%82%92%20i.MAX6Q%20Sabre%20Lite%20%E3%81%AE%20PCIE%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AE%E5%8D%81%E5%88%86%E3%81%AA%E8%A9%B3%E7%B4%B0%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_504.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_504.png%22%20style%3D%22width%3A%20249px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F1894i97B4911B492CCAA1%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_504.png%22%20alt%3D%22pastedImage_504.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3ETW6865%E3%82%92Sabre%20Lite%E3%81%AEPCIE%E3%81%A8%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E6%A1%88%E5%86%85%E3%81%97%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F(%E7%8F%BE%E5%9C%A8%E3%80%81%E7%A7%81%E3%81%AF3.14.52%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%E3%80%82%3C%2FP%3E%3CP%3Ei.max%E2%80%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Ftag%2Fi.mx6q%20pcie%2Ftg-p%22%20target%3D%22_blank%22%3E%23i.mx6q%20pcie%3C%2FA%3E%E2%80%8C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126686%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126686%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8B%E3%83%AA%E3%83%81%E3%83%A3%E3%83%BC%E3%83%89%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%80%81iMX6%E3%81%AEPCIe%20RC%E3%81%ABDMA%E3%81%8C%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E8%80%83%E3%81%88%E3%82%8B%E3%81%A8%E3%80%81IPU%20DMA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6PCIe%20Link%20x1%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6iMX6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89Xilinx%20FPGA%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%92%E3%81%82%E3%81%82%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%87%E3%83%A2%E3%82%92%E7%A7%81%E3%81%AE%E7%89%B9%E5%AE%9A%E3%81%AE%E3%82%B7%E3%83%8A%E3%83%AA%E3%82%AA%E3%81%AB%E9%81%A9%E5%BF%9C%E3%81%95%E3%81%9B%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E9%81%A9%E5%BF%9C%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%A7%E5%A4%A7%E3%81%8D%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82iMX6%E3%81%8B%E3%82%89FPGA%E3%81%B8%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E6%93%8D%E4%BD%9C%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81Yann%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AB(%E3%82%B7%E3%83%8A%E3%83%AA%E3%82%AA%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C)%E3%80%81%E3%83%87%E3%83%A2%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B344%20MB%20%2F%20s%E3%81%AB%E9%81%94%E3%81%99%E3%82%8B%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E3%80%81TLP%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C64%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81FPGA%E5%81%B4%E3%81%A7%E5%8F%97%E4%BF%A1%E3%81%99%E3%82%8BTLP%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C16%E3%83%90%E3%82%A4%E3%83%88%E3%81%97%E3%81%8B%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E7%B4%8454MB%20%2F%20s%E3%81%97%E3%81%8B%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%822%E3%81%A4%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E9%96%93%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%81%AF%E3%80%81%E3%83%9F%E3%83%8BPCIe%E3%81%8B%E3%82%89PCIe%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CIMG%20alt%3D%22Resultado%20de%20imagen%20de%20mini%20pcie%20to%20pcie%20connector%22%20height%3D%22194%22%20src%3D%22http%3A%2F%2Fi.ebayimg.com%2Fimages%2Fi%2F221160508053-0-1%2Fs-l1000.jpg%22%20width%3D%22281%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%82%8BTLP%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E5%A2%97%E3%82%84%E3%81%99%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81iMX6%E5%81%B4%E3%81%A7%E3%81%A9%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AB%E8%A7%A6%E3%82%8C%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E8%AA%A0%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EEduardo.%3C%2FP%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126685%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126685%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%2C%20Richard%3A%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%BF%94%E4%BF%A1%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E3%81%9D%E3%82%8C%E3%81%AF%E5%A4%A7%E4%B8%88%E5%A4%AB%E3%81%AA%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E5%AE%9F%E9%A8%93%E3%82%92%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81r8169%E3%81%A7nic%E3%82%92%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81r8168-8.039.00%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81linux%20bsp%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AEfsl%E3%81%AE%E5%85%83%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E---------------------------------------------------------------%3C%2FP%3E%3CP%3Ex%20x%20%26lt%3B%20%26gt%3B%20%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%20Hamachi%20GNIC-II%20%E5%AF%BE%E5%BF%9C%20x%20x%3C%2FP%3E%3CP%3Ex%20x%20%26lt%3B%20%26gt%3B%20%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%20%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%20Yellowfin%20%E3%82%AE%E3%82%AC%E3%83%93%E3%83%83%E3%83%88%20NIC%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20(%E5%AE%9F%E9%A8%93%E7%9A%84)%20x%20x%3C%2FP%3E%3CP%3Ex%20x%20%26lt%3B*%26gt%3B%20Realtek%208169%20%E3%82%AE%E3%82%AC%E3%83%93%E3%83%83%E3%83%88%20%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20x%20x%3C%2FP%3E%3CP%3Ex%20x%20%26lt%3B%20%26gt%3B%20Realtek%208111E%E3%82%AE%E3%82%AC%E3%83%93%E3%83%83%E3%83%88%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20%3C%2FP%3E%3CP%3E-------------------------------------------------------------------%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%BE%E3%81%A0%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126684%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126684%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E4%BB%A5%E5%89%8D%E3%80%81INTEL%20e1000e%20NIC%E3%82%AB%E3%83%BC%E3%83%89%E3%81%A71000%E3%83%90%E3%82%A4%E3%83%88%E4%BB%A5%E4%B8%8A%E3%81%AE%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E9%80%81%E4%BF%A1%E3%81%8C%E7%A2%BA%E8%AA%8D%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E8%A6%9A%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3ENIC%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E5%86%8D%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E5%8D%98%E3%81%AA%E3%82%8B%E5%8F%82%E7%85%A7%E3%83%AD%E3%82%B0%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3Eroot%40imx6sxsabresd%3A~%23%20%E3%83%94%E3%83%B3%20192.168.1.253-S%20469%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%83%94%E3%83%B3192.168.1.253(192.168.1.253)%3A469%E3%83%87%E3%83%BC%E3%82%BF%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E192.168.1.253%20%E3%81%8B%E3%82%89%20477%20%E3%83%90%E3%82%A4%E3%83%88%3A%3CSPAN%20class%3D%22SpellE%22%3Eseq%3C%2FSPAN%3E%3D0%20%3CSPAN%20class%3D%22SpellE%22%3Ettl%3C%2FSPAN%3E%3D64%20time%3D0.595%E3%81%95%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E192.168.1.253%20%E3%81%8B%E3%82%89%20477%20%E3%83%90%E3%82%A4%E3%83%88%3A%3CSPAN%20class%3D%22SpellE%22%3Eseq%3C%2FSPAN%3E%3D1%20%3CSPAN%20class%3D%22SpellE%22%3Ettl%3C%2FSPAN%3E%3D64%20time%3D0.482%E3%81%95%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E192.168.1.253%20%E3%81%8B%E3%82%89%20477%20%E3%83%90%E3%82%A4%E3%83%88%3A%3CSPAN%20class%3D%22SpellE%22%3Eseq%3C%2FSPAN%3E%3D2%20%3CSPAN%20class%3D%22SpellE%22%3Ettl%3C%2FSPAN%3E%3D64%20time%3D0.457%E3%81%95%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E192.168.1.253%20%E3%81%8B%E3%82%89%20477%20%E3%83%90%E3%82%A4%E3%83%88%3A%3CSPAN%20class%3D%22SpellE%22%3Eseq%3C%2FSPAN%3E%3D3%20%3CSPAN%20class%3D%22SpellE%22%3Ettl%3C%2FSPAN%3E%3D64%20%E6%99%82%E9%96%93%3D0.450%E3%81%95%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%5EC%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E---%20192.168.1.253PING%E7%B5%B1%E8%A8%88---%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E9%80%81%E4%BF%A1%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%204%20%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%80%81%E5%8F%97%E4%BF%A1%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%204%20%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%80%81%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E6%90%8D%E5%A4%B1%200%25%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E5%BE%80%E5%BE%A9%E6%9C%80%E5%B0%8F%2F%3CSPAN%20class%3D%22SpellE%22%3E%E5%B9%B3%E5%9D%87%3C%2FSPAN%3E%2F%E6%9C%80%E5%A4%A7%20%3D%200.450%2F0.496%2F0.595%E3%81%95%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3Eroot%40imx6sxsabresd%3A~%23%20%3CSPAN%20class%3D%22SpellE%22%3Elspci%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E00%3A00.0%20PCI%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B916c3%3Aabcd(%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B301)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E01%3A00.0%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%3AIntel%20Corporation%2082574L%E3%82%AE%E3%82%AC%E3%83%93%E3%83%83%E3%83%88%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E6%8E%A5%E7%B6%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3Eroot%40imx6sxsabresd%3A~%23%20%E3%83%94%E3%83%B3%20192.168.1.253-S1000%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%83%94%E3%83%B3192.168.1.253(192.168.1.253)%3A1000%E3%83%87%E3%83%BC%E3%82%BF%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E192.168.1.253%20%E3%81%8B%E3%82%89%201008%20%E3%83%90%E3%82%A4%E3%83%88%3A%3CSPAN%20class%3D%22SpellE%22%3Eseq%3C%2FSPAN%3E%3D0%20%3CSPAN%20class%3D%22SpellE%22%3Ettl%3C%2FSPAN%3E%3D64%20time%3D0.559%E3%81%95%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E192.168.1.253%20%E3%81%8B%E3%82%89%201008%20%E3%83%90%E3%82%A4%E3%83%88%3A%3CSPAN%20class%3D%22SpellE%22%3Eseq%3C%2FSPAN%3E%3D1%20%3CSPAN%20class%3D%22SpellE%22%3Ettl%3C%2FSPAN%3E%3D64%20time%3D0.485%E3%81%95%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E192.168.1.253%20%E3%81%8B%E3%82%89%201008%20%E3%83%90%E3%82%A4%E3%83%88%3A%3CSPAN%20class%3D%22SpellE%22%3Eseq%3C%2FSPAN%3E%3D2%20%3CSPAN%20class%3D%22SpellE%22%3Ettl%3C%2FSPAN%3E%3D64%20%E6%99%82%E9%96%93%3D0.472%E3%81%95%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%5EC%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E---%20192.168.1.253PING%E7%B5%B1%E8%A8%88---%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E9%80%81%E4%BF%A1%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E6%95%B0%203%E3%80%81%E5%8F%97%E4%BF%A1%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E6%95%B0%203%E3%80%81%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E6%90%8D%E5%A4%B1%200%25%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E5%BE%80%E5%BE%A9%E6%9C%80%E5%B0%8F%2F%3CSPAN%20class%3D%22SpellE%22%3E%E5%B9%B3%E5%9D%87%3C%2FSPAN%3E%2F%E6%9C%80%E5%A4%A7%20%3D%200.472%2F0.505%2F0.559%E3%81%95%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3Eroot%40imx6sxsabresd%3A~%23%20%3CSPAN%20class%3D%22SpellE%22%3Elspci%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E00%3A00.0%20PCI%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B916c3%3Aabcd(%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B301)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E01%3A00.0%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%3AIntel%20Corporation%2082574L%E3%82%AE%E3%82%AC%E3%83%93%E3%83%83%E3%83%88%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E6%8E%A5%E7%B6%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3Eroot%40imx6sxsabresd%3A~%23%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%20Richard%3A%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%8C%E9%81%AD%E9%81%87%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E6%96%B0%E3%81%97%E3%81%84%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%81%E7%A7%81%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81rtl8111e%20nic%E3%81%AFping%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%26gt%3B%3D%20469bytes%E3%81%AE%E3%81%A8%E3%81%8D%E3%81%ABping%E6%93%8D%E4%BD%9C%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%81%95%E3%82%89%E3%81%AB%E3%80%81ubuntu%E3%81%AErootfs%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81ssh%E3%81%A7%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%81%93%E3%81%AE%E6%93%8D%E4%BD%9C%E3%82%82rtl8111e%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AB%E7%95%B0%E5%B8%B8%E3%82%92%E5%BC%95%E3%81%8D%E8%B5%B7%E3%81%93%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%E4%BB%96%E3%81%AE%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F393520%22%20target%3D%22_blank%22%3Emx6%20%2B%20rtl8111e%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCCarmili%3C%2FA%3E%20Li%E3%81%A8Pavel%E3%81%8C%E7%A7%81%E3%81%A8%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82Alexander%20%E3%81%AF%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-size%3A%2014px%3B%20background-color%3A%20%23fefefe%3B%20font-family%3A%20arial%3B%22%3E%3A%3CA%20class%3D%22jive-link-external-small%22%20data-content-finding%3D%22Community%22%20href%3D%22http%3A%2F%2Fwww.spinics.net%2Flists%2Flinux-pci%2Fmsg34379.html%22%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%236a737b%3B%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%20%5BPATCH%20-%20v4%5D%20PCI%3A%20keystone%3A%20PCI%20%E7%99%96%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%20mrrs%20%E3%82%92%E5%88%B6%E9%99%90%E3%81%99%E3%82%8B%20--%20Linux%20PCI%3C%2FA%3E%3C%2FSPAN%3E%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E7%A7%81%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%22%2Fdrivers%2Fpci%2Fhost%2Fpci-keystone.c%22%20%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20kernel%20ver%3A%20Linux%20version%203.0.35-2666-gbdde708%3C%2FP%3E%3CP%3ERTL8111E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E6%83%85%E5%A0%B1%3A%3C%2FP%3E%3CP%3Er8168%3A%20Realtek%20PCIe%20GBE%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%20mcfg%20%3D%200014%3C%2FP%3E%3CP%3ER8168%200000%3A01%3A00.0%3AMSI%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82INTx%E3%81%AB%E6%88%BB%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Er8168%3A%E3%81%93%E3%81%AE%E8%A3%BD%E5%93%81%E3%81%AF%E3%80%81US6%2C570%2C884%E3%80%81US6%2C115%2C776%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3US6%2C327%2C625%E3%81%AE1%E3%81%A4%E4%BB%A5%E4%B8%8A%E3%81%AE%E7%89%B9%E8%A8%B1%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E4%BF%9D%E8%AD%B7%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%20r8168%20Copyright%20(C)%202014%20Realtek%20NIC%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%81%E3%83%BC%E3%83%A0%20%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Anicfae%40realtek.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Enicfae%40realtek.com%3C%2FA%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%20%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AB%E3%81%AF%E4%B8%80%E5%88%87%E3%81%AE%E4%BF%9D%E8%A8%BC%E3%81%8C%E4%BB%98%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.gnu.org%2Flicenses%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.gnu.org%2Flicenses%2F%3C%2FA%3E%3CSPAN%3E%26gt%3B%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%20%E3%81%93%E3%82%8C%E3%81%AF%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E7%89%B9%E5%AE%9A%E3%81%AE%E6%9D%A1%E4%BB%B6%E4%B8%8B%E3%81%A7%E5%86%8D%E9%85%8D%E5%B8%83%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E6%AD%93%E8%BF%8E%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.gnu.org%2Flicenses%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.gnu.org%2Flicenses%2F%3C%2FA%3E%3CSPAN%3E%26gt%3B%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eping%20%E6%93%8D%E4%BD%9C%3A%3C%2FP%3E%3CP%3Eroot%40freescale%20~%24%20ping%20192.168.1.5-S%20465%3C%2FP%3E%3CP%3E%E3%83%94%E3%83%B3192.168.1.5(192.168.1.5)%3A465%E3%83%87%E3%83%BC%E3%82%BF%E3%83%90%E3%82%A4%E3%83%88%3C%2FP%3E%3CP%3E192.168.1.5%20%E3%81%8B%E3%82%89%20473%20%E3%83%90%E3%82%A4%E3%83%88%3Aseq%3D0%20ttl%3D64%20time%3D0.435%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E192.168.1.5%20%E3%81%8B%E3%82%89%20473%20%E3%83%90%E3%82%A4%E3%83%88%3Aseq%3D1%20ttl%3D64%20time%3D0.518%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E---%20192.168.1.5PING%E7%B5%B1%E8%A8%88---%3C%2FP%3E%3CP%3E%E9%80%81%E4%BF%A1%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%202%20%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%80%81%E5%8F%97%E4%BF%A1%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%202%20%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%80%81%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E6%90%8D%E5%A4%B1%200%25%3C%2FP%3E%3CP%3E%E5%BE%80%E5%BE%A9%E6%9C%80%E5%B0%8F%2F%E5%B9%B3%E5%9D%87%2F%E6%9C%80%E5%A4%A7%20%3D%200.435%2F0.476%2F0.518%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3Eroot%40freescale%20~%24%20ping%20192.168.1.5-S%20468%3C%2FP%3E%3CP%3E%E3%83%94%E3%83%B3192.168.1.5(192.168.1.5)%3A468%E3%83%87%E3%83%BC%E3%82%BF%E3%83%90%E3%82%A4%E3%83%88%3C%2FP%3E%3CP%3E192.168.1.5%20%E3%81%8B%E3%82%89%20476%20%E3%83%90%E3%82%A4%E3%83%88%3Aseq%3D0%20ttl%3D64%20time%3D0.440%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E192.168.1.5%20%E3%81%8B%E3%82%89%20476%20%E3%83%90%E3%82%A4%E3%83%88%3Aseq%3D1%20ttl%3D64%20time%3D0.503%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E---%20192.168.1.5PING%E7%B5%B1%E8%A8%88---%3C%2FP%3E%3CP%3E%E9%80%81%E4%BF%A1%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%202%20%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%80%81%E5%8F%97%E4%BF%A1%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%202%20%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%80%81%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E6%90%8D%E5%A4%B1%200%25%3C%2FP%3E%3CP%3E%E5%BE%80%E5%BE%A9%E6%9C%80%E5%B0%8F%2F%E5%B9%B3%E5%9D%87%2F%E6%9C%80%E5%A4%A7%20%3D%200.440%2F0.471%2F0.503%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3Eroot%40freescale%20~%24%20ping%20192.168.1.5-S%20469%3C%2FP%3E%3CP%3E%E3%83%94%E3%83%B3192.168.1.5(192.168.1.5)%3A469%E3%83%87%E3%83%BC%E3%82%BF%E3%83%90%E3%82%A4%E3%83%88%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E---%20192.168.1.5PING%E7%B5%B1%E8%A8%88---%3C%2FP%3E%3CP%3E%E9%80%81%E4%BF%A1%E3%83%91%E3%82%B1%E3%83%83%E3%83%8834%E3%80%81%E5%8F%97%E4%BF%A1%E3%83%91%E3%82%B1%E3%83%83%E3%83%880%E3%80%81%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%83%AD%E3%82%B9100%25%3C%2FP%3E%3CP%3Eroot%40freescale%20~%24%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126682%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126682%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8B%E6%9C%B1%E3%81%95%E3%82%93%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%E3%81%AEIPU%E3%83%91%E3%83%83%E3%83%81%E3%81%8C%E4%BD%95%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%81%82%E3%82%8B%E3%81%AE%E3%81%8B%E3%80%81%E7%A7%81%E3%81%AB%E3%81%AF%E3%82%88%E3%81%8F%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%9FIPU%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%80%81IPU%E3%82%92%E5%86%8D%E6%A7%8B%E6%88%90%E3%81%97%E3%80%81%E7%94%BB%E5%83%8F%E5%87%A6%E7%90%86%E3%81%AA%E3%81%97%E3%81%A7IPU%20DMA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%9B%AE%E7%9A%84%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81IPU%E3%81%A7%E7%94%BB%E5%83%8F%E5%87%A6%E7%90%86%E3%82%92%E8%A1%8C%E3%81%86%E3%81%A8%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E3%81%A7IPU%20DMA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E7%A7%81%E3%81%AFIPU%E3%82%92%E3%80%81DMA%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%97%E3%80%81DDR%E3%81%AB%E9%AB%98%E9%80%9F(344MB%2Fs)%E3%81%A7%E7%94%BB%E5%83%8F%E3%82%92%E4%BF%9D%E5%AD%98%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E7%94%BB%E5%83%8F%E3%82%92%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%AA%E3%81%84%E5%B0%8F%E3%81%95%E3%81%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9(%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%811%E8%A1%8C%E3%81%AE%E3%83%88%E3%83%AA%E3%83%9F%E3%83%B3%E3%82%B0)%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EiMX6%E3%81%A8%E3%83%93%E3%83%87%E3%82%AA%E5%87%A6%E7%90%86%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E9%96%93%E3%81%ABPHYFLEX%E3%82%AD%E3%83%A3%E3%83%AA%E3%82%A2%E3%83%9C%E3%83%BC%E3%83%891364.3(%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89)%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%BC%E3%82%BF%E8%BB%A2%E9%80%81%E9%87%8F%E3%81%8C%E5%B0%91%E3%81%AA%E3%81%84%E3%81%AE%E3%81%AF%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93...%E6%8E%A5%E7%B6%9A%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81IPU%20DMA%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%E3%81%AFIPU%E5%B0%82%E7%94%A8%E8%A8%AD%E8%A8%88%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E6%B1%8E%E7%94%A8DMA%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E5%AE%9F%E8%A3%85%E3%81%A7IPU%20DMA%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%81%B4%E3%81%A7%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E8%BB%A2%E9%80%81%E3%81%AE%E3%82%B9%E3%83%AB%E3%83%BC%E3%83%97%E3%83%83%E3%83%88%E3%81%8C%E3%81%AA%E3%81%9C%E3%81%9D%E3%82%93%E3%81%AA%E3%81%AB%E6%82%AA%E3%81%84%E3%81%AE%E3%81%8B%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E6%8E%A5%E7%B6%9A%E3%81%AE%E5%93%81%E8%B3%AA%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AE%E3%81%8B%E8%88%88%E5%91%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EIMX6%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%A8%E3%83%93%E3%83%87%E3%82%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E9%96%93%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E5%8D%81%E5%88%86%E3%81%AA%E5%93%81%E8%B3%AA%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%81%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E5%A4%9A%E3%81%8F%E3%81%AECRC%E3%81%8A%E3%82%88%E3%81%B3%E5%86%8D%E8%A9%A6%E8%A1%8C%E6%93%8D%E4%BD%9C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E5%B9%B8%E9%81%8B%E3%82%92%E7%A5%88%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%83%AA%E3%83%81%E3%83%A3%E3%83%BC%E3%83%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126680%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126680%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%81%AF%E3%81%84%E3%80%81%20%3CSPAN%20class%3D%22SpellE%22%3Eep%3C%2FSPAN%3E%20%E3%83%A2%E3%83%BC%E3%83%89%E3%83%86%E3%82%B9%E3%83%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%81%20%3CSPAN%20class%3D%22SpellE%22%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AFfsl%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22SpellE%22%3Elinux%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22SpellE%22%3Ebsp%3C%2FSPAN%3E%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%92%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%83%AA%E3%83%81%E3%83%A3%E3%83%BC%E3%83%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126679%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126679%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8B%E6%9C%B1%E3%81%95%E3%82%93%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%E3%82%92%E6%B3%A8%E6%84%8F%E6%B7%B1%E3%81%8F%E8%AA%AD%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%8A%A9%E3%81%91%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9A%E3%80%81%E7%A7%81%E3%81%AE%E7%8A%B6%E6%B3%81%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%3CP%3EPCIe%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%81%AE%E3%81%8A%E3%81%8B%E3%81%92%E3%81%A7%E3%80%81iMX6%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%9F%E3%83%93%E3%83%87%E3%82%AA%E5%87%A6%E7%90%86%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%93%E3%83%87%E3%82%AA%E5%87%A6%E7%90%86%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81iMX6%E3%81%AEDDR%E3%81%AB%E7%94%BB%E5%83%8F%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%E3%81%9F%E3%82%81%E3%81%AB%E7%89%A9%E7%90%86%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%93%E3%81%AA%E7%A7%81%E3%82%82iMX6(MEM%3D768M)%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E6%B8%9B%E3%82%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AF0x4000_0000%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E7%94%BB%E5%83%8F%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E7%A7%81%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81%E6%9C%80%E5%A4%A7%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E9%80%9F%E5%BA%A6%E3%81%8C%E7%B4%8450MB%20%2F%20s%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82IPU%E3%82%92%E3%83%90%E3%82%B9%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81344MB%2Fs%E3%81%AE%E9%80%9F%E5%BA%A6%E3%81%AB%E5%88%B0%E9%81%94%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%E5%85%B7%E4%BD%93%E7%9A%84%E3%81%AB%E4%BD%95%E3%82%92%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EYann%20Tinauus%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126678%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126678%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%20%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E6%9C%B1%E9%B4%BB%E8%88%88%3A%3C%2FP%3E%3CP%3Eimx6%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0sdk%E3%80%8Cpcie_test%E3%80%8D%E3%82%92RC%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81imx6%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0sdk%E3%81%ABEP%E3%83%A2%E3%83%BC%E3%83%89%E3%83%86%E3%82%B9%E3%83%88%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126677%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126677%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%AA%E3%83%81%E3%83%A3%E3%83%BC%E3%83%89%EF%BC%9A%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E3%82%84%E3%82%8A%E7%9B%B4%E3%81%97%E3%80%81%E5%86%8D%E5%BA%A6%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%B5%90%E6%9E%9C%E3%81%AF%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EMX6%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3A***%20%3C%2FP%3E%3CP%3Ex%20x%20%5B*%5D%20PCI%20Express%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20%3C%2FP%3E%3CP%3EIMX6%20RC%2FEP%E7%9B%B8%E4%BA%92%E6%8E%A5%E7%B6%9A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AEPCI%20Express%20EP%E3%83%A2%E3%83%BC%E3%83%89%20%3C%2FP%3E%3CP%3EIMX6%20RC%2FEP%E7%9B%B8%E4%BA%92%E6%8E%A5%E7%B6%9A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AEPCI%20Express%20RC%E3%83%A2%E3%83%BC%E3%83%89%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2019px%3B%22%3E%E3%81%BE%E3%81%9F%E3%80%81IPU%E9%96%A2%E9%80%A3%E3%81%AE%3C%2FSPAN%3E%E5%88%A5%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%E4%BB%96%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%9B%E3%81%9A%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%80%81eth1%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%8B%E3%82%89%E3%80%81PING%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A1%E3%81%AA%E3%81%BF%E3%81%ABRTL8111E%E3%81%AFPCIE%20nic%E3%81%A7%E3%80%81mini-PCIE%20to%20PCIE%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81RTL8111E%20nic%E3%81%A8i.MX6-SebraSDP%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126676%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126676%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%80%E3%83%B3%E3%83%97%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A12.0pt%22%3E%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A9.0pt%3Bfont-family%3A%20inherit%20%2C%20serif%20%3Bmso-bidi-font-family%3AArial%22%3E%E3%82%B3%E3%83%BC%E3%83%89%3A%20e59f0010%20e1a01003%20eb133c07%20e3a03000%20(e5833000)%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%3Boutline%3A%200%3Bfont-weight%3Ainherit%3Bfont-style%3Ainherit%22%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20Arial%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20inherit%20%2C%20serif%3B%20%22%3E%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A9.0pt%3Bfont-family%3A%20inherit%20%2C%20serif%20%3Bmso-bidi-font-family%3AArial%22%3E%20%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%81%A7%E3%81%AFclk_enable%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%3Boutline%3A%200%3Bfont-weight%3Ainherit%3Bfont-style%3Ainherit%22%3E%3CSPAN%20style%3D%22font-size%3A9.0pt%3Bfont-family%3A%20inherit%20%2C%20serif%20%3Bmso-bidi-font-family%3AArial%22%3E%5B%26lt%3B80049e34%26gt%3B%5D(unwind_backtrace%2B0x0%2F0xf8)%20from%20%5B%26lt%3B8006563c%26gt%3B%5D%20(clk_enable%2B0x88%2F0xa0)%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3ERTL8111e%E3%81%AE%E6%93%8D%E4%BD%9C%E3%82%92%E8%A1%8C%E3%81%86%E3%81%A8%E3%81%8D%E3%81%ABIPU%E9%96%A2%E9%80%A3%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%80%E3%83%B3%E3%83%97%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%AF%E4%B8%8D%E6%80%9D%E8%AD%B0%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%83%AA%E3%83%81%E3%83%A3%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126675%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126675%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%80%8C%E5%89%8A%E9%99%A4%E3%80%8D%E5%BE%8C%E3%81%AB%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3C%2FSPAN%3E%3C%2FP%3E%3CTABLE%20border%3D%220%22%20cellpadding%3D%220%22%20cellspacing%3D%220%22%20style%3D%22border-collapse%3Acollapse%3Bmso-yfti-tbllook%3A1184%3Bmso-padding-alt%3A0in%200in%200in%200in%22%3E%3CTBODY%3E%3CTR%20style%3D%22mso-yfti-irow%3A0%3Bmso-yfti-firstrow%3Ayes%3Bmso-yfti-lastrow%3Ayes%22%3E%3CTD%20style%3D%22padding%3A1.5pt%203.0pt%201.5pt%203.0pt%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A12.0pt%3Bfont-family%3A%20inherit%20%2C%20serif%20%3Bmso-fareast-font-family%3A%20Times%20New%20Roman%20%3Bmso-bidi-font-family%3A%20Times%20New%20Roman%20%22%3EPCI%20Express%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A1.5pt%203.0pt%201.5pt%203.0pt%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A12.0pt%3Bfont-family%3A%20inherit%20%2C%20serif%20%3Bmso-fareast-font-family%3A%20Times%20New%20Roman%20%3Bmso-bidi-font-family%3A%20Times%20New%20Roman%20%22%3E%E3%82%A8%20%3CSPAN%20class%3D%22SpellE%22%3E%E3%83%83%E3%82%AF%E3%82%B9%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E6%A7%8B%E6%88%90%E3%81%AE%E3%80%8C%E3%80%8D%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%AA%E3%83%81%E3%83%A3%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126674%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126674%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CTABLE%20jive-data-cell%3D%22%7B%22%20color%3D%22%22%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%E3%82%A8%E3%83%83%E3%82%AF%E3%82%B9%20%3C%2FTD%3E%3CTD%3E%26lt%3B*%26gt%3B%20PCI%20%E3%82%B9%E3%82%BF%E3%83%96%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%3C%2FTD%3E%3CTD%3Exx%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%82%A8%E3%83%83%E3%82%AF%E3%82%B9%20%3C%2FTD%3E%3CTD%3E%5B%20%5D%20PCI%20IOV%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20%3C%2FTD%3E%3CTD%3Exx%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%82%A8%E3%83%83%E3%82%AF%E3%82%B9%20%3C%2FTD%3E%3CTD%3E%5B*%5DPCI%20Express%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20%3C%2FTD%3E%3CTD%3Exx%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%82%A8%E3%83%83%E3%82%AF%E3%82%B9%20%3C%2FTD%3E%3CTD%3E%5B*%5D%26nbsp%3B%20%E3%83%AB%E3%83%BC%E3%83%88%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E9%AB%98%E5%BA%A6%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E5%A0%B1%E5%91%8A%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20%3C%2FTD%3E%3CTD%3Exx%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%82%A8%E3%83%83%E3%82%AF%E3%82%B9%20%3C%2FTD%3E%3CTD%3E%5B%20%5D%20%3C%2FTD%3E%3CTD%3EPCI%20Express%20ECRC%20%E8%A8%AD%E5%AE%9A%E5%88%B6%E5%BE%A1%20%3C%2FTD%3E%3CTD%3Exx%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%82%A8%E3%83%83%E3%82%AF%E3%82%B9%20%3C%2FTD%3E%3CTD%3E%26lt%3B%20%26gt%3B%20%3C%2FTD%3E%3CTD%3EPCIe%20AER%20%E3%82%A8%E3%83%A9%E3%83%BC%20%E3%82%A4%E3%83%B3%E3%82%B8%E3%82%A7%E3%82%AF%E3%82%BF%E3%83%BC%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20%3C%2FTD%3E%3CTD%3Exx%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%82%A8%E3%83%83%E3%82%AF%E3%82%B9%20%3C%2FTD%3E%3CTD%3E%5B*%5D%26nbsp%3B%20PCI%20Express%20ASPM%20%E5%88%B6%E5%BE%A1%20%3C%2FTD%3E%3CTD%3Exx%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%82%A8%E3%83%83%E3%82%AF%E3%82%B9%20%3C%2FTD%3E%3CTD%3E%5B%20%5D%20%3C%2FTD%3E%3CTD%3EDebug%20PCI%20Express%20ASPM%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FTD%3E%3CTD%3Exx%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%AA%E3%83%81%E3%83%A3%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%3ALinux%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B33.0.35-2666-gbdde708%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%82%B0%3A%3C%2FP%3E%3CP%3ELinux%E3%81%AE%E8%A7%A3%E5%87%8D...%E5%AE%8C%E4%BA%86%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E3%83%96%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3ELinux%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B33.0.35-2666-gbdde708(user%40ubuntu)(GCC%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B34.6.220110630%20(%E3%83%97%E3%83%AC%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9)%20(Freescale%20MAD%20--%20Linaro%202011.07%20--%20Built%20at%202011%2F08%2F10%2009%3A20)%20)%20%2320%20SMP%20PREEMPT%20Sun%20Jan%2011%2002%3A32%3A04%20PST%202015%3CBR%20%2F%3ECPU%3A%20ARMv7%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20%5B412fc09a%5D%20%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%2010%20(ARMv7)%E3%80%81cr%3D10c53c7d%3CBR%20%2F%3ECPU%3A%20VIPT%20%E9%9D%9E%E3%82%A8%E3%82%A4%E3%83%AA%E3%82%A2%E3%82%B7%E3%83%B3%E3%82%B0%20%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%80%81VIPT%20%E3%82%A8%E3%82%A4%E3%83%AA%E3%82%A2%E3%82%B7%E3%83%B3%E3%82%B0%E5%91%BD%E4%BB%A4%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%3CBR%20%2F%3E%E3%83%9E%E3%82%B7%E3%83%B3%3AFreescale%20i.MX%206Quad%2FDualLite%2FSolo%20Sabre-SD%E3%83%9C%E3%83%BC%E3%83%89%3CBR%20%2F%3E%E8%AA%8D%E8%AD%98%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%82%BF%E3%82%B00x54410008%E3%82%92%E7%84%A1%E8%A6%96%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%9D%E3%83%AA%E3%82%B7%E3%83%BC%3A%20ECC%20%E3%81%8C%E7%84%A1%E5%8A%B9%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20writealloc%3CBR%20%2F%3ECPU%20%E3%81%AF%20i.MX6Q%E3%80%81%E3%82%B7%E3%83%AA%E3%82%B3%E3%83%B3%20rev%201.2%20%E3%81%A8%E8%AD%98%E5%88%A5%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EPERCPU%3A%E5%9F%8B%E3%82%81%E8%BE%BC%E3%81%BF7%E3%83%9A%E3%83%BC%E3%82%B8%2F%20CPU%20%408c008000%20s5440%20r8192%20d15040%20u32768%3CBR%20%2F%3E%E3%82%BE%E3%83%BC%E3%83%B3%E9%A0%86%E3%81%AB1%E3%81%A4%E3%81%AE%E3%82%BE%E3%83%BC%E3%83%B3%E3%83%AA%E3%82%B9%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%83%A2%E3%83%93%E3%83%AA%E3%83%86%E3%82%A3%E3%81%AE%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E5%8C%96%E3%82%92%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%B7%8F%E3%83%9A%E3%83%BC%E3%82%B8%E6%95%B0%3A194560%3CBR%20%2F%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%3A%20console%3Dttymxc0%2C115200%20root%3D%2Fdev%2Fmmcblk1p1%20rootwait%20rw%20video%3Dmxcfb1%3Adev%3Dldb%2CLDB-XGA%2Cif%3DRGB666%20video%3Dmxcfb0%3Adev%3Dhdmi%2C1920x1080M%4060%2Cif%3DRGB24%3CBR%20%2F%3EPID%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%204096%20(%E9%A0%86%E5%BA%8F%3A%202%E3%80%8116384%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3EDentry%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20131072%20(%E9%A0%86%E5%BA%8F%3A%207%E3%80%81524288%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3Einode-cache%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%2065536%20(%E9%A0%86%E5%BA%8F%3A%206%E3%80%81262144%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3E%E3%83%A1%E3%83%A2%E3%83%AA%3A512MB%20256MB%20%3D%20%E5%90%88%E8%A8%88768MB%3CBR%20%2F%3E%E3%83%A1%E3%83%A2%E3%83%AA%3A765672k%20%2F%20765672k%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%80%81282904k%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF%E3%80%810K%E9%AB%98%E3%83%A1%E3%83%A2%E3%83%AA%3CBR%20%2F%3E%E4%BB%AE%E6%83%B3%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%3A%3CBR%20%2F%3E%E3%83%99%E3%82%AF%E3%82%BF%E3%83%BC%20%3A%200xffff0000%20-%200xffff1000%20(%204%20kB)%3CBR%20%2F%3E%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E3%83%9E%E3%83%83%E3%83%97%20%3A%200xfff00000%20-%200xfffe0000%20(%20896%20kB)%3CBR%20%2F%3EDMA%20%3A%200xf4600000%20-%200xffe00000%20(%20184%20MB)%3CBR%20%2F%3Evmalloc%20%3A%200xc0800000%20-%200xf2000000%20(%20792%20%E3%83%A1%E3%82%AC%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3Elowmem%20%3A%200x80000000%20-%200xc0000000%20(1024%20MB)%3CBR%20%2F%3Epkmap%20%3A%200x7fe00000%20-%200x80000000%20(%202%E3%83%A1%E3%82%AC%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3E%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20%3A%200x7f000000%20-%200x7fe00000%20(%2014%20MB)%3CBR%20%2F%3E.init%3A%200x80008000%20-%200x8003d000%20(%20212%20kB)%3CBR%20%2F%3E%E3%80%82%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%3A%200x8003d000%20-%200x80aa54f0%20(10658%20kB)%3CBR%20%2F%3E%E3%80%82%E3%83%87%E3%83%BC%E3%82%BF%3A%200x80aa6000%20-%200x80b0a660%20(%20402%20kB)%3CBR%20%2F%3E.bss%E3%81%AE%3A%200x80b0a684%20-%200x80b58b8c%20(%20314%20kB)%3CBR%20%2F%3ESLUB%3A%20Genslabs%3D13%2C%20HWalign%3D32%2C%20Order%3D0-3%2C%20MinObjects%3D0%2C%20CPUs%3D4%2C%20Nodes%3D1%3CBR%20%2F%3E%E3%83%97%E3%83%AA%E3%82%A8%E3%83%B3%E3%83%97%E3%83%86%E3%82%A3%E3%83%96%E3%81%AA%E9%9A%8E%E5%B1%A4%E5%9E%8B%20RCU%20%E3%81%AE%E5%AE%9F%E8%A3%85%E3%80%82%3CBR%20%2F%3ENR_IRQS%3A624%3CBR%20%2F%3EMXC%20GPIO%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%3CBR%20%2F%3Esched_clock%3A3000kHz%E3%81%A732%E3%83%93%E3%83%83%E3%83%88%E3%80%81%E8%A7%A3%E5%83%8F%E5%BA%A6333ns%E3%80%811431655ms%E3%81%94%E3%81%A8%E3%81%AB%E3%83%A9%E3%83%83%E3%83%97%3CBR%20%2F%3Earm_max_freq%3D1GHz%E5%B8%AF%3CBR%20%2F%3EMMIO%200x2020000%20%E3%81%AE%20MXC_Early%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20(%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%20'115200')%3CBR%20%2F%3E%E3%83%96%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20%5Bttymxc0%5D%20%E6%9C%89%E5%8A%B9%3CBR%20%2F%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%3A%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%80%E3%83%9F%E3%83%BC%E3%83%87%E3%83%90%E3%82%A4%E3%82%B980x30%3CBR%20%2F%3E%E9%81%85%E5%BB%B6%E3%83%AB%E3%83%BC%E3%83%97%E3%82%92%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...1581.05%20BogoMIPS(lpj%20%3D%207905280)%3CBR%20%2F%3Epid_max%3A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%3A%2032768%20%E6%9C%80%E5%B0%8F%3A%20301%3CBR%20%2F%3E%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%83%BB%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%83%BC%E6%95%B0%3A%20512%3CBR%20%2F%3ECPU%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE%E3%82%B3%E3%83%92%E3%83%BC%E3%83%AC%E3%83%B3%E3%82%B7%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%3AOK%3CBR%20%2F%3Ehw%20perfevents%3A%20ARMv7%20Cortex-A9%20PMU%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%A7%E6%9C%89%E5%8A%B9%E3%80%817%20%E3%81%A4%E3%81%AE%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%3CBR%20%2F%3ECPU1%3A%E8%B5%B7%E5%8B%95%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3CBR%20%2F%3ECPU2%3A%E8%B5%B7%E5%8B%95%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3CBR%20%2F%3ECPU3%3A%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3CBR%20%2F%3E4%E3%81%A4%E3%81%AECPU%E3%82%92%E8%82%B2%E3%81%A6%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ESMP%3A%E5%90%88%E8%A8%884%E3%81%A4%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%8C%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F(6324.22%20BogoMIPS)%E3%80%82%3CBR%20%2F%3Eprint_constraints%3A%E3%83%80%E3%83%9F%E3%83%BC%3A%3CBR%20%2F%3E%20NET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2016%3CBR%20%2F%3E%20print_constraints%3Avddpu%3A725%26lt%3B--%26gt%3B%20700%20mV%E3%81%AE%E9%80%9F%E3%81%84%E6%AD%A3%E5%B8%B8%E3%81%AA700%E3%81%AEmV%E3%81%A7%3CBR%20%2F%3E%20print_constraints%3A%20vddcore%3A%20725%26lt%3B--%26gt%3B%201300%20mV%20at%201150%20mV%20fast%20normal%3CBR%20%2F%3E%20print_constraints%3Avddsoc%3A725%26lt%3B--%26gt%3B%201300%20mV%3CBR%20%2F%3E%20print_constraints%3A%20vdd2p5%3A%202000%26lt%3B--%26gt%3B%202400%20mV%20%E3%81%A7%202775%20mV%3CBR%20%2F%3E%26lt%3B--%26gt%3B%20%3CBR%20%2F%3E%26lt%3B--%26gt%3B%E9%AB%98%E9%80%9F%E3%83%8E%E3%83%BC%E3%83%9E%E3%83%AB%3CBR%20%2F%3E%20%3CBR%20%2F%3Eprint_constraints%3Avdd1p1%3A800%201400%20mV%20print_constraints%3Avdd3p0%3A2625%20hw-breakpoint%3A%206%20%E3%81%A4%E3%81%AE%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%A8%201%20%E3%81%A4%E3%81%AE%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82hw-breakpoint%3A%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E7%94%A8%E3%81%AB%E4%BA%88%E7%B4%84%E3%81%95%E3%82%8C%E3%81%9F%201%20%E3%81%A4%E3%81%AE%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%80%82%3CBR%20%2F%3Ehw-breakpoint%3A%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E6%9C%80%E5%A4%A7%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF%204%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3EL310%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%8C%E6%9C%89%E5%8A%B9%3CBR%20%2F%3El2x0%3A%2016%20%E9%80%9A%E3%82%8A%E3%80%81CACHE_ID%200x410000c7%E3%80%81AUX_CTRL%200x02070000%E3%80%81%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%E3%82%B5%E3%82%A4%E3%82%BA%3A%201048576%20B%3CBR%20%2F%3EBIO%3A0%E3%81%AB%E3%82%B9%E3%83%A9%E3%83%96%3CBIO-0%3E%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3EMXS-DMA%20MXS-DMA-APBH%3A%E5%88%9D%E6%9C%9F%E5%8C%96%E6%B8%88%E3%81%BF%3CBR%20%2F%3Eprint_constraints%3ASPKVDD%3A4200mV%3CBR%20%2F%3Eprint_constraints%3Avmmc%3A3300%20mV%3CBR%20%2F%3Evgaarb%3A%20%E3%83%AD%E3%83%BC%E3%83%89%E6%B8%88%E3%81%BF%3CBR%20%2F%3ESCSI%20%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Espi_imx%20imx6q-ecspi.0%3A%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%20usbcore%3A%3CBR%20%2F%3E%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20usbfs%20%E3%82%92%E7%99%BB%E9%8C%B2%3CBR%20%2F%3E%20usbcore%3A%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%83%8F%E3%83%96%E3%82%92%E7%99%BB%E9%8C%B2%20usbcore%3A%3CBR%20%2F%3E%20%E6%96%B0%E3%81%97%E3%81%84%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20USB%20%E3%82%92%E7%99%BB%E9%8C%B2%20%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%ABUSB%20OTG%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%80%81%24Revision%3A%201.55%20%24%3CBR%20%2F%3E%20mc_pfuze%201-0008%3A%20ID%3A%200%E3%80%81%E3%83%95%E3%83%AB%E3%83%AC%E3%82%A4%3A%201%E3%80%81%E3%83%A1%E3%82%BF%E3%83%AB%E3%83%AC%E3%82%A4%3A%201%3CBR%20%2F%3E%20mc_pfuze%201-0008%3A%20FAB%3A%200%20%E3%80%81%20FIN%20%3A%200%3CBR%20%2F%3E%20%26lt%3B--%26gt%3B%3CBR%20%2F%3Eprint_constraints%3APFUZE100_SW1A%3A300%20print_constraints%3APFUZE100_SW1B%3A300%26lt%3B--%26gt%3B%20print_constraints%3APFUZE100_SW1C%3A300%26lt%3B--%26gt%3B%20%3CBR%20%2F%3E%26lt%3B--%26gt%3B%3CBR%20%2F%3E%26lt%3B--%26gt%3B%3CBR%20%2F%3E%26lt%3B--%26gt%3B%3CBR%20%2F%3E%26lt%3B--%26gt%3B%3CBR%20%2F%3E%26lt%3B--%26gt%3B%3CBR%20%2F%3E%26lt%3B--%26gt%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%26lt%3B--%26gt%3B%3CBR%20%2F%3E%26lt%3B--%26gt%3B%3CBR%20%2F%3E%26lt%3B--%26gt%3B%3CBR%20%2F%3E%26lt%3B--%26gt%3B%3CBR%20%2F%3E%26lt%3B--%26gt%3B%3CBR%20%2F%3E1875%26lt%3B--%26gt%3B%20%3CBR%20%2F%3EmV%20print_constraints%3APFUZE100_SW2%3A800%20print_constraints%3APFUZE100_SW3A%3A400%201975%20mV%E3%80%811500%20mV%20print_constraints%3APFUZE100_SW3B%3A400%20print_constraints%3APFUZE100_SW4%3A800%20print_constraints%3APFUZE100_SWBST%3A5000%205150%20mV%20print_constraints%3APFUZE100_VSNVS%3A1200%20print_constraints%3APFUZE100_VREFDDR%3A750mV%E3%81%A7%20print_constraints%3APFUZE100_VGEN1%3A800%201550%20mV%20print_constraints%3APFUZE100_VGEN2%3A800%201550%20mV%20print_constraints%3APFUZE100_VGEN3%3A1800%20print_constraints%3APFUZE100_VGEN4%3A1800%20print_constraints%3APFUZE100_VGEN5%3A1800%20print_constraints%3APFUZE100_VGEN6%3A1800%203300%20mV%20IMX-IPUV3%20IMX-IPUV3.0%3A%3CBR%20%2F%3EIPU%20DMFC%20NORMAL%20%E3%83%A2%E3%83%BC%E3%83%89%3A%201(0~1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3CBR%20%2F%3EIMX-IPUV3%20IMX-IPUV3.1%3AIPU%20DMFC%20NORMAL%20%E3%83%A2%E3%83%BC%E3%83%89%3A%201(0~1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3CBR%20%2F%3Emxc_mipi_csi2%20mxc_mipi_csi2%3A%20i.MX%20MIPI%20CSI2%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Emxc_mipi_csi2%20mxc_mipi_csi2%3Ai.MX%20MIPI%20CSI2%20dphy%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8C0x3130302a%3CBR%20%2F%3EMIPI%20CSI2%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%83%BB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EAdvanced%20Linux%20Sound%20Architecture%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B31.0.24%E3%80%82%3CBR%20%2F%3EBluetooth%3A%E3%82%B3%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B32.16%3CBR%20%2F%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2031%3CBR%20%2F%3EBluetooth%3AHCI%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E6%8E%A5%E7%B6%9A%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3AHCI%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3AL2CAP%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3ASCO%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Ecfg80211%3A%20CRDA%20%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%A6%E4%B8%96%E7%95%8C%E3%81%AE%E8%A6%8F%E5%88%B6%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3EMAX17135%202-0048%3AeInk%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E7%94%A8PMIC%20MAX17135%3CBR%20%2F%3EI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BMAX17135%5D%3CBR%20%2F%3EI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E3%83%AC%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A0%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%5BMAX17135%5D%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9mxc_timer1%E3%81%B8%E3%81%AE%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3CBR%20%2F%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%202%3CBR%20%2F%3EIP%20%E3%83%AB%E3%83%BC%E3%83%88%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%2032768%20(%E9%A0%86%E5%BA%8F%3A%205%E3%80%81131072%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3ETCP%20%E7%A2%BA%E7%AB%8B%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20131072%20(%E9%A0%86%E5%BA%8F%3A%208%E3%80%811048576%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3ETCP%E3%83%90%E3%82%A4%E3%83%B3%E3%83%89%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A65536(%E9%A0%86%E5%BA%8F%3A7%E3%80%81786432%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3ETCP%3A%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99(%E3%83%90%E3%82%A4%E3%83%B3%E3%83%8965536%20131072%E7%A2%BA%E7%AB%8B)%3CBR%20%2F%3ETCP%20reno%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EUDP%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20512%20(%E9%A0%86%E5%BA%8F%3A%202%E3%80%8116384%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3EUDP-Lite%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20512%20(%E9%A0%86%E5%BA%8F%3A%202%E3%80%8116384%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%201%3CBR%20%2F%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%E5%90%8D%E5%89%8D%E3%81%AE%20UNIX%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E8%BB%A2%E9%80%81%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3CBR%20%2F%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%20UDP%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3CBR%20%2F%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%20tcp%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3CBR%20%2F%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%20tcp%20NFSv4.1%20%E3%83%90%E3%83%83%E3%82%AF%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3CBR%20%2F%3EPMU%3A%E3%82%BF%E3%82%A4%E3%83%970%E3%81%AE%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%E6%96%B0%E3%81%97%E3%81%84PMU%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3CBR%20%2F%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%ABi.MX6%E3%81%AE%E3%82%B9%E3%82%BF%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%83%BB%E3%83%91%E3%83%AF%E3%83%BC%E3%83%BB%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A1%E3%83%B3%E3%83%88%3CBR%20%2F%3Ei.MX6%20%E3%81%AE%E5%BE%85%E6%A9%9F%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%3CBR%20%2F%3Ecpaddr%20%3D%20c0880000%20suspend_iram_base%3Dc091c000%3CBR%20%2F%3EPM%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EiMX6%20PCIe%20PCIe%20RC%E3%83%A2%E3%83%BC%E3%83%89imx_pcie_pltfm_probe%E5%85%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EPCIE%3A%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E9%96%8B%E5%A7%8Bimx_pcie_pltfm_probe%E3%80%82%3CBR%20%2F%3EIMX%20PCIe%E3%83%9D%E3%83%BC%E3%83%88%3A%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%80%82%3CBR%20%2F%3E%3CSTRONG%3EPCI%3A%20bus0%3A%20%E9%AB%98%E9%80%9F%E3%83%90%E3%83%83%E3%82%AF%E3%83%84%E3%83%BC%E3%83%90%E3%83%83%E3%82%AF%E8%BB%A2%E9%80%81%E3%81%8C%E7%84%A1%E5%8A%B9%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EPCI%3Abus1%3A%E9%AB%98%E9%80%9F%E3%83%90%E3%83%83%E3%82%AF%E3%83%84%E3%83%BC%E3%83%90%E3%83%83%E3%82%AF%E8%BB%A2%E9%80%81%E3%81%AF%E7%84%A1%E5%8A%B9%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Epci%200000%3A00%3A00.0%3A%20BAR%200%3A%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E6%B8%88%E3%81%BF%20%5Bmem%200x01000000-0x010fffff%2064bit%20pref%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Epci%200000%3A00%3A00.0%3A%20BAR%200%3A%20%5Bmem%200x01000000-0x010fffff%2064bit%20pref%5D%20(PCI%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%5B0x1000000-0x10fffff%5D)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Epci%200000%3A00%3A00.0%3A%20BAR%209%3A%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E6%B8%88%E3%81%BF%20%5Bmem%200x01100000-0x011fffff%20pref%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Epci%200000%3A00%3A00.0%3A%20BAR%206%3A%20assigned%20%5Bmem%200x01200000-0x0120ffff%20pref%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Epci%200000%3A00%3A00.0%3A%20BAR%207%3A%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E6%B8%88%E3%81%BF%20%5Bio%200x1e00000-0x1e00fff%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Epci%200000%3A01%3A00.0%3A%20BAR%204%3A%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E6%B8%88%E3%81%BF%20%5Bmem%200x01100000-0x01103fff%2064bit%20pref%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Epci%200000%3A01%3A00.0%3A%20BAR%204%3A%20%5Bmem%200x01100000-0x01103fff%2064bit%20pref%5D%20(PCI%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%5B0x1100000-0x1103fff%5D)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Epci%200000%3A01%3A00.0%3A%20BAR%202%3A%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E6%B8%88%E3%81%BF%20%5Bmem%200x01104000-0x01104fff%2064bit%20pref%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Epci%200000%3A01%3A00.0%3A%20BAR%202%3A%20%5Bmem%200x01104000-0x01104fff%2064bit%20pref%5D%20(PCI%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%5B0x1104000-0x1104fff%5D)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Epci%200000%3A01%3A00.0%3A%20BAR%200%3A%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E6%B8%88%E3%81%BF%20%5Bio%200x1e00000-0x1e000ff%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Epci%200000%3A01%3A00.0%3A%20BAR%200%3A%20%5Bio%200x1e00000-0x1e000ff%5D%20(PCI%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%5B0x1e00000-0x1e000ff%5D)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Epci%200000%3A00%3A00.0%3A%20%5Bbus%2001-01%5D%20%E3%81%B8%E3%81%AE%20PCI%20%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EPCI%200000%3A00%3A00.0%3A%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%5BIO%200x1e00000-0x1e00fff%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EPCI%200000%3A00%3A00.0%3A%20%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%20%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%20%5BMEM%20%E7%84%A1%E5%8A%B9%5D%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EPCI%3C%2FSTRONG%3E%200000%3A00%3A00.0%3A%20%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%20%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%20%5Bmem%200x01100000-0x011fffff%20pref%5D%3CBR%20%2F%3E%3CSTRONG%3EIMX%20USB%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3C%2FSTRONG%3E%3CBR%20%2F%3E%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%BD%E3%83%BC%E3%82%B9IRQ%2075%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3EIMX%20USB%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3CBR%20%2F%3ECPU%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%A2%E3%83%BC%E3%83%89%3Aldo_bypass%3CBR%20%2F%3E_regulator_get%3A%20%E8%AD%98%E5%88%A5%E5%AD%90%E3%81%AA%E3%81%97%E3%81%AE%20get()%3CBR%20%2F%3Emx6_cpu_regulator_init%3APU%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AE%E5%85%A5%E6%89%8B%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Ei.MXC%20CPU%E5%91%A8%E6%B3%A2%E6%95%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3CBR%20%2F%3EJFFS2%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.2.(NAND)%20%C2%A9%202001-2006%20%E3%83%AC%E3%83%83%E3%83%89%E3%83%8F%E3%83%83%E3%83%88%E6%A0%AA%E5%BC%8F%E4%BC%9A%E7%A4%BE%3CBR%20%2F%3Emsgmni%20%E3%81%8C%201495%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%3CBR%20%2F%3Ealg%3A%20stdrng%20(krng)%20%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%AA%E3%81%97%3CBR%20%2F%3EIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9NOOP%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9%E3%81%AE%E7%B7%A0%E5%88%87%E6%97%A5%E7%99%BB%E9%8C%B2%3CBR%20%2F%3EIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9CFQ%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF(%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88)%3CBR%20%2F%3Emxc_mipi_dsi%20mxc_mipi_dsi%3A%20i.MX%20MIPI%20DSI%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EMIPI%20DSI%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Emxc_sdc_fb%20mxc_sdc_fb.0%3AMXC%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCHDMI%E3%81%AE%E7%99%BB%E9%8C%B2%3CBR%20%2F%3Emxc_hdmi%20mxc_hdmi%3A%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%9FHDMI%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%200x13%3A0xa%3A0xa0%3A0xc1%3CBR%20%2F%3Efbcvt%3A%201920x1080%4060%3A%20CVT%20%E5%90%8D%20-%202.073M9%3CBR%20%2F%3EIMX-IPUV3%20IMX-IPUV3.0%3AIPU%20DMFC%20DP%20%E9%AB%98%E5%88%86%E8%A7%A3%E8%83%BD%3A%201(0%2C1)%2C%205B(2~5)%2C%205F(6%2C7)%3CBR%20%2F%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%3A%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9240x67%E3%81%B8%E3%81%AE%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3CBR%20%2F%3Emxc_sdc_fb%20mxc_sdc_fb.1%3AMXC%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCLDB%E3%81%AE%E7%99%BB%E9%8C%B2%3CBR%20%2F%3E_regulator_get%3A%20%E8%AD%98%E5%88%A5%E5%AD%90%E3%81%AA%E3%81%97%E3%81%AE%20get()%3CBR%20%2F%3Emxc_sdc_fb%20mxc_sdc_fb.2%3AMXC%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCLCD%E3%81%AE%E7%99%BB%E9%8C%B2%3CBR%20%2F%3Emxc_sdc_fb%20mxc_sdc_fb.2%3AIPU0-DI0%20%E3%81%AF%E6%97%A2%E3%81%AB%E4%BD%BF%E7%94%A8%E6%B8%88%E3%81%BF%3CBR%20%2F%3Emxc_sdc_fb%3A%20mxc_sdc_fb.2%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-16%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Emxc_sdc_fb%20mxc_sdc_fb.3%3AMXC%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCLDB%E3%81%AE%E7%99%BB%E9%8C%B2%3CBR%20%2F%3EIMX-SDMA%3A%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%201.1%20%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%3CBR%20%2F%3Eimx-sdma%3A%20%E5%88%9D%E6%9C%9F%E5%8C%96%E6%B8%88%E3%81%BF%3CBR%20%2F%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3AIMX%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3CBR%20%2F%3Eimx-uart.2%3AMMIO%200x21ec000%20(irq%20%3D%2060)%20%E3%81%AE%20ttymxc2%20%E3%81%AF%20IMX%20%E3%81%A7%E3%81%99%3CBR%20%2F%3Eimx-uart.0%3AMMIO%200x2020000%20(irq%20%3D%2058)%20%E3%81%AE%20ttymxc0%20%E3%81%AF%20IMX%20%E3%81%A7%E3%81%99%3CBR%20%2F%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20%5Bttymxc0%5D%20%E3%81%8C%E6%9C%89%E5%8A%B9%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%8C%E7%84%A1%E5%8A%B9%3CBR%20%2F%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20%5Bttymxc0%5D%20%E3%81%8C%E6%9C%89%E5%8A%B9%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%8C%E7%84%A1%E5%8A%B9%3CBR%20%2F%3Eloop%3A%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ESATA%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3EM25P80%20SPI0.0%3AM25P32%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%80%81%E4%BA%88%E6%83%B3SST25VF016B%3CBR%20%2F%3EM25P80%20SPI0.0%3Am25p32%20(4096%20%E3%82%AD%E3%83%AD%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3E%22m25p80%22%20%E3%81%AB%202%20%E3%81%A4%E3%81%AE%20MTD%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E0x000000000000-0x000000100000%20%3A%20%E3%80%8C%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%80%8D%3CBR%20%2F%3E0x000000100000-0x000000400000%20%3A%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%3CBR%20%2F%3EGPMI%20NAND%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82(IMX%E3%81%AE)%3CBR%20%2F%3Evcan%3A%20%E4%BB%AE%E6%83%B3%20CAN%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3CBR%20%2F%3ECAN%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3CBR%20%2F%3EFlexcan%20NetDevice%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3EFEC%20%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3CBR%20%2F%3Efec_enet_mii_bus%3A%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3CBR%20%2F%3Eehci_hcd%3A%20USB%202.0%20%E3%80%8C%E6%8B%A1%E5%BC%B5%E3%80%8D%E3%83%9B%E3%82%B9%E3%83%88%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%20(EHCI)%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3CBR%20%2F%3EFSL-EHCI%20FSL-EHCI.0%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AE%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97EHCI%E3%83%9B%E3%82%B9%E3%83%88%E3%83%BB%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%3CBR%20%2F%3EFSL-EHCI%20FSL-EHCI.0%3A%E6%96%B0%E3%81%97%E3%81%84USB%E3%83%90%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%80%81%E3%83%90%E3%82%B9%E7%95%AA%E5%8F%B71%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3EFSL-EHCI%20FSL-EHCI.0%3AIRQ%2075%E3%80%81IO%E3%83%99%E3%83%BC%E3%82%B90x02184000%3CBR%20%2F%3EFSL-EHCI%20FSL-EHCI.0%3AUSB%202.0%20%E9%96%8B%E5%A7%8B%E3%80%81EHCI%201.00%3CBR%20%2F%3E%E3%83%8F%E3%83%96%201-0%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%83%8F%E3%83%96%201-0%3A1.0%3A%201%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%BD%E3%83%BC%E3%82%B9IRQ%2072%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3EFSL-EHCI%20FSL-EHCI.1%3A%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AE%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97EHCI%E3%83%9B%E3%82%B9%E3%83%88%E3%83%BB%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%3CBR%20%2F%3EFSL-EHCI%20FSL-EHCI.1%3A%E6%96%B0%E3%81%97%E3%81%84USB%E3%83%90%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%80%81%E3%83%90%E3%82%B9%E7%95%AA%E5%8F%B72%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EFSL-EHCI%20FSL-EHCI.1%3AIRQ%2072%E3%80%81IO%E3%83%99%E3%83%BC%E3%82%B90x02184200%3CBR%20%2F%3EFSL-EHCI%20FSL-EHCI.1%3AUSB%202.0%20%E9%96%8B%E5%A7%8B%E3%80%81EHCI%201.00%3CBR%20%2F%3E%E3%83%8F%E3%83%96%202-0%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%83%8F%E3%83%96%202-0%3A1.0%3A%201%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eusbcore%3A%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97cdc_acm%3CBR%20%2F%3Ecdc_acm%3A%20USB%20%E3%83%A2%E3%83%87%E3%83%A0%E3%81%A8%20ISDN%20%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E7%94%A8%E3%81%AE%20USB%20Abstract%20Control%20Model%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3CBR%20%2F%3EUSB%E5%A4%A7%E5%AE%B9%E9%87%8F%E8%A8%98%E6%86%B6%E8%A3%85%E7%BD%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3Eusbcore%3A%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AEusb-storage%E3%82%92%E7%99%BB%E9%8C%B2%3CBR%20%2F%3EUSB%E3%83%9E%E3%82%B9%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EARC%20USBOTG%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20(2005%20%E5%B9%B4%208%20%E6%9C%88%201%20%E6%97%A5)%3CBR%20%2F%3Emousedev%3A%20PS%2F2%20%E3%83%9E%E3%82%A6%E3%82%B9%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20(%E5%85%A8%E3%83%9E%E3%82%A6%E3%82%B9%E5%85%B1%E9%80%9A)%3CBR%20%2F%3E%E5%85%A5%E5%8A%9B%3A%20GPIO-keys%20as%20%2Fdevices%2Fplatform%2Fgpio-keys%2Finput%2Finput0%3CBR%20%2F%3E%E5%85%A5%E5%8A%9B%3A%2Fdevices%2Fplatform%2Fimx-i2c.1%2Fi2c-1%2F1-0048%2Finput%2Finput1%E3%81%A8%E3%81%97%E3%81%A6max11801_ts%3CBR%20%2F%3Eegalax_ts%201-0004%3Aegalax_ts%3A%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eegalax_ts%3A%201-0004%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-5%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E5%85%A5%E5%8A%9B%3AeGalax%E3%82%BF%E3%83%83%E3%83%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3(%2Fdevices%2Fplatform%2Fimx-i2c.2%2Fi2c-2%2F2-0004%2Finput%2Finput2)%3CBR%20%2F%3Eelan%20-%20Hello%20%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EELAN-TOUCH%3A2-0010%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC-22%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E5%85%A5%E5%8A%9B%3AISL29023%E5%85%89%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%82%92%2Fdevices%2Fvirtual%2Finput%2Finput3%E3%81%A8%E3%81%97%E3%81%A6%3CBR%20%2F%3EISL29023%202-0044%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%201.0%20%E3%81%8C%E6%9C%89%E5%8A%B9%3CBR%20%2F%3EI2C-Core%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%5BISL29023%5D%20%E3%81%8C%E5%BE%93%E6%9D%A5%E3%81%AE%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3EI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E3%83%AC%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A0%E6%96%B9%E6%B3%95%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BISL29023%5D%3CBR%20%2F%3Esnvs_rtc%20snvs_rtc.0%3ARTC%E3%82%B3%E3%82%A2%3ARTC0%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2snvs_rtc%3CBR%20%2F%3Ei2c%20%2Fdev%20entries%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3CBR%20%2F%3ELinux%E3%83%93%E3%83%87%E3%82%AA%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3Av2.00%3CBR%20%2F%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%E3%83%93%E3%83%87%E3%82%AA%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FV4L2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B916%3CBR%20%2F%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%E3%83%93%E3%83%87%E3%82%AA%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FV4L2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B917%3CBR%20%2F%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%E3%83%93%E3%83%87%E3%82%AA%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FV4L2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B918%3CBR%20%2F%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%E3%83%93%E3%83%87%E3%82%AA%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FV4L2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B919%3CBR%20%2F%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%E3%83%93%E3%83%87%E3%82%AA%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FV4L2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B920%3CBR%20%2F%3Emag3110%202-000e%3Amag3110%E3%83%81%E3%83%83%E3%83%97ID%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CBR%20%2F%3E%E5%85%A5%E5%8A%9B%3Amag3110%20as%20%2Fdevices%2Fvirtual%2Finput%2Finput4%3CBR%20%2F%3EMAG3110%202-000E%3AMAG3110%E3%82%92%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3CBR%20%2F%3EI2C-Core%3A%20%E5%BE%93%E6%9D%A5%E3%81%AE%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%5BMAG3110%5D%3CBR%20%2F%3EI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E3%83%AC%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A0%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BMAG3110%5D%3CBR%20%2F%3E%E5%85%A5%E5%8A%9B%3A%20MMA845x%20as%20%2Fdevices%2Fvirtual%2Finput%2Finput5%3CBR%20%2F%3EIMX2-WDT%20IMX2-WDT.0%3AIMX2%2B%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%3D60%E7%A7%92%20(nowayout%3D1)%3CBR%20%2F%3EBluetooth%3A%E4%BB%AE%E6%83%B3HCI%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCver%201.3%3CBR%20%2F%3EBluetooth%3AHCI%20UART%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCver%202.2%3CBR%20%2F%3EBluetooth%3A%20HCIATH3K%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3A%E6%B1%8E%E7%94%A8Bluetooth%20USB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCver%200.6%3CBR%20%2F%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20btusb%20%E3%82%92%E7%99%BB%E9%8C%B2%3CBR%20%2F%3Esdhci%3A%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%BB%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%83%BB%E3%83%9B%E3%82%B9%E3%83%88%E3%83%BB%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%83%BB%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3CBR%20%2F%3Esdhci%3A%20Copyright(c)%20Pierre%20Ossman%20(%E8%8B%B1%E8%AA%9E)%3CBR%20%2F%3Emmc0%3A%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20%5BSDHCI-ESDHC-IMX.3%5D%20%E4%B8%8A%E3%81%AE%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BCDMA%E3%81%AE%E4%BD%BF%E7%94%A8%3CBR%20%2F%3Emmc1%3A%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20%5BSDHCI-ESDHC-IMX.1%5D%20%E4%B8%8A%E3%81%AE%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BCDMA%E3%81%AE%E4%BD%BF%E7%94%A8%3CBR%20%2F%3Emmc2%3A%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20%5BSDHCI-ESDHC-IMX.2%5D%20%E4%B8%8A%E3%81%AE%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BCDMA%E3%81%AE%E4%BD%BF%E7%94%A8%3CBR%20%2F%3Emxc_vdoa%20mxc_vdoa%3A%20i.MX%20Video%20Data%20Order%20Adapter%20(VDOA)%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EVPU%20%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E7%99%BB%E9%8C%B2mxc_asrc%3CBR%20%2F%3EGalcore%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B34.6.9.6622%3CBR%20%2F%3E%E3%82%B5%E3%83%BC%E3%83%9E%E3%83%AB%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%87%E3%83%BC%E3%82%BF0x55c4af7d%3CBR%20%2F%3E%E3%83%AC%E3%82%B7%E3%82%AA%3D176%E3%81%AE%E3%82%B5%E3%83%BC%E3%83%9E%E3%83%AB%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%3CBR%20%2F%3EAnatop%20Thermal%20%E3%81%AF%20thermal_zone0%20%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3Eanatop_thermal_probe%3A%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E5%86%B7%E5%8D%B4%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AFCPUFreq%E3%81%A7%E3%81%99!%3CBR%20%2F%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20usbhid%20%E3%82%92%E7%99%BB%E9%8C%B2%3CBR%20%2F%3Eusbhid%3A%20USB%20HID%20%E3%82%B3%E3%82%A2%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3CBR%20%2F%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCsnd-usb-audio%E3%82%92%E7%99%BB%E9%8C%B2%3CBR%20%2F%3Emxc_hdmi_soc%20mxc_hdmi_soc.0%3AMXC%20HDMI%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%3CBR%20%2F%3ECirrus%20Logic%20CS42888%20ALSA%20SoC%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3CBR%20%2F%3EI2C-Core%3A%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BCS42888%5D%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3EI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E5%86%8D%E9%96%8B%E6%96%B9%E6%B3%95%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BCS42888%5D%3CBR%20%2F%3Ewm8962%200-001a%3A%20%E3%81%8A%E5%AE%A2%E6%A7%98%20ID%200%20%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%20D%3CBR%20%2F%3E%E5%85%A5%E5%8A%9B%3AWM8962%E3%83%93%E3%83%BC%E3%83%97%E9%9F%B3%E7%99%BA%E7%94%9F%E5%99%A8%E3%82%92%2Fdevices%2Fplatform%2Fimx-i2c.0%2Fi2c-0%2F0-001a%2Finput%2Finput6%E3%81%A8%E3%81%97%E3%81%A6%3CBR%20%2F%3EASOC%3A%20WM8962%20%26lt%3B-%26gt%3B%20IMX-SSI.1%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%20OK%3CBR%20%2F%3E%E5%85%A5%E5%8A%9B%3A%20wm8962-audio%20DMIC%20as%20%2Fdevices%2Fplatform%2Fsoc-audio.5%2Fsound%2Fcard0%2Finput7%3CBR%20%2F%3E%E5%85%A5%E5%8A%9B%3Awm8962-audio%20Ext%20Spk%20as%20%2Fdevices%2Fplatform%2Fsoc-audio.5%2Fsound%2Fcard0%2Finput8%3CBR%20%2F%3Eimx_3stack%20ASOC%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3CBR%20%2F%3EASOC%3A%20MXC-HDMI-SOC%20%26lt%3B-%26gt%3B%20IMX-HDMI-SOC-DAI.0%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0OK%3CBR%20%2F%3EALSA%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E4%B8%80%E8%A6%A7%3A%3CBR%20%2F%3E%230%3AWM8962-%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%3CBR%20%2F%3E%231%3AIMX-HDMI-SOC%E3%81%AE%3CBR%20%2F%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2026%3CBR%20%2F%3ETCP%E3%82%AD%E3%83%A5%E3%83%BC%E3%83%93%E3%83%83%E3%82%AF%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2017%3CBR%20%2F%3ECAN%3A%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%82%A8%E3%83%AA%E3%82%A2%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B3%E3%82%A2(REB%2020090105%20ABI%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%3CBR%20%2F%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2029%3CBR%20%2F%3ECAN%3ARAW%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB(Rev%2020090105)%3CBR%20%2F%3ECAN%3A%20%E3%83%96%E3%83%AD%E3%83%BC%E3%83%89%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%20%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20(%E6%94%B9%E8%A8%82%E7%89%88%2020090105%20T)%3CBR%20%2F%3EBluetooth%3ARFCOMM%20TTY%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3ARFCOMM%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EBluetooth%3ARFCOMM%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B31.11%3CBR%20%2F%3EBluetooth%3ABNEP(%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3)ver%201.3%3CBR%20%2F%3Emmc0%3A%20%E6%96%B0%E3%81%97%E3%81%84%E9%AB%98%E9%80%9F%20DDR%20MMC%20%E3%82%AB%E3%83%BC%E3%83%89%20(%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200001)%3CBR%20%2F%3Emmcblk0%3A%20mmc0%3A0001%20SEM08G%207.39%20GiB%3CBR%20%2F%3Emmcblk0boot0%3A%20mmc0%3A0001%20SEM08G%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%201%202.00%20MiB%3CBR%20%2F%3Emmcblk0boot1%3A%20mmc0%3A0001%20SEM08G%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%202%202.00%20MiB%3CBR%20%2F%3E%20mmcblk0%3A%20p1%3CBR%20%2F%3EBluetooth%3ABNEP%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%3A%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%9E%E3%83%AB%E3%83%81%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%3CBR%20%2F%3E%20mmcblk0boot1%3A%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E4%B8%8D%E6%98%8E%E3%81%A7%E3%81%99%3CBR%20%2F%3EBluetooth%3AHIDP(%E3%83%92%E3%83%A5%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3)ver%201.2%3CBR%20%2F%3E%20mmcblk0boot0%3A%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E4%B8%8D%E6%98%8E%E3%81%A7%E3%81%99%3CBR%20%2F%3Elib80211%3A%20IEEE802.11%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E5%85%B1%E9%80%9A%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%3CBR%20%2F%3EVFP%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20v0.3%3A%20implementor%2041%20architecture%203%20part%2030%20variant%209%20rev%204%3CBR%20%2F%3E%E3%83%90%E3%82%B9%E5%91%A8%E6%B3%A2%E6%95%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%83%90%E3%82%B9%E5%91%A8%E6%B3%A2%E6%95%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%E6%9C%89%E5%8A%B9%3CBR%20%2F%3Emxc_dvfs_core_probe%3CBR%20%2F%3EDVFS%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eregulator_init_complete%3A%20PFUZE100_VGEN6%3A%20%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%AA%E5%88%B6%E7%B4%84%E3%80%81%E3%82%AA%E3%83%B3%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3Eregulator_init_complete%3A%20PFUZE100_VGEN3%3A%20%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%AA%E5%88%B6%E7%B4%84%E3%80%81%E3%82%AA%E3%83%B3%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3Eregulator_init_complete%3A%20PFUZE100_VGEN2%3A%20%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%AA%E5%88%B6%E7%B4%84%E3%80%81%E3%82%AA%E3%83%B3%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3Eregulator_init_complete%3A%20PFUZE100_VGEN1%3A%20%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%AA%E5%88%B6%E7%B4%84%E3%80%81%E3%82%AA%E3%83%B3%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3Esnvs_rtc%20snvs_rtc.0%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%201970-01-01%2000%3A00%3A01%20UTC%20(1)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3E%E3%83%AB%E3%83%BC%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%2Fdev%2Fmmcblk1p1%20%E3%82%92%E5%BE%85%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3Emmc2%3A%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%201234%20%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E9%AB%98%E9%80%9F%20SDHC%20%E3%82%AB%E3%83%BC%E3%83%89%3CBR%20%2F%3Emmcblk1%3A%20mmc2%3A1234%20SA04G%203.63%20GiB%3CBR%20%2F%3E%20MMCBLK1%3AP1%3CBR%20%2F%3EEXT3-fs%3A%20%E3%83%90%E3%83%AA%E3%82%A2%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Ekjournald%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%E9%96%93%E9%9A%94%205%20%E7%A7%92%3CBR%20%2F%3EEXT3-fs%20(mmcblk1p1)%3A%20%E5%86%85%E9%83%A8%E3%82%B8%E3%83%A3%E3%83%BC%E3%83%8A%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3EEXT3-fs%20(mmcblk1p1)%3A%20%E3%83%AA%E3%82%AB%E3%83%90%E3%83%AA%E5%AE%8C%E4%BA%86%3CBR%20%2F%3EEXT3-fs%20(mmcblk1p1)%3A%20%E3%83%A9%E3%82%A4%E3%83%88%E3%83%90%E3%83%83%E3%82%AF%E3%83%BB%E3%83%87%E3%83%BC%E3%82%BF%E3%83%BB%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3CBR%20%2F%3EVFS%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20179%3A25%20%E3%81%AB%E3%83%AB%E3%83%BC%E3%83%88%20(ext3%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0)%20%E3%81%8C%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Einit%20%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E8%A7%A3%E6%94%BE%3A%20212K%3CBR%20%2F%3Epid%201468%20%E4%BB%A5%E9%99%8D%E3%80%81tty%20''%3A%20'%2Fetc%2Frc.d%2FrcS'%3CBR%20%2F%3E%2Fproc%20%E3%81%A8%20%2Fsys%20%E3%81%AE%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%3CBR%20%2F%3E%E3%83%9B%E3%83%83%E3%83%88%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%83%87%E3%82%A3%E3%82%B9%E3%83%91%E3%83%83%E3%83%81%E3%83%A3%E3%83%BCudevd%E3%81%AE%E8%B5%B7%E5%8B%95%3CBR%20%2F%3Eudevd(1477)%3A%2F%20proc%20%2F%201477%20%2F%20oom_adj%E3%81%AF%E9%9D%9E%E6%8E%A8%E5%A5%A8%E3%81%A7%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%2F%20proc%20%2F%201477%20%2F%20oom_score_adj%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%E5%88%9D%E6%9C%9F%E3%83%9B%E3%83%83%E3%83%88%E3%83%97%E3%83%A9%E3%82%B0%E3%83%BB%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%81%AE%E5%90%88%E6%88%90%3CBR%20%2F%3E%E3%83%9B%E3%82%B9%E3%83%88%E5%90%8D%E3%82%92%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%3CBR%20%2F%3Ecp%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%8C%E6%AE%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Ecp%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%8C%E6%AE%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Ecp%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%8C%E6%AE%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Ecp%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%8C%E6%AE%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Emount%3A%20%2Fproc%2Fbus%2Fusb%20%E3%81%B8%E3%81%AE%20usbfs%20%E3%81%AE%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%84%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Epid%203292%20%E4%BB%A5%E9%99%8D%E3%80%81tty%20''%3A%20'%2Fetc%2Frc.d%2Frc_gpu.S'%3CBR%20%2F%3Epid%203298%20%E4%BB%A5%E9%99%8D%E3%80%81tty%20''%3A%20'%2Fetc%2Frc.d%2Frc_mxc.S'%3C%2FBIO-0%3E%3C%2FP%3E%3CP%3Earm-none-linux-gnueabi-gcc%20(Freescale%20MAD%20--%20Linaro%202011.07%20--%202011%2F08%2F10%2009%3A20%20%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89)%204.6.220110630(%E3%83%97%E3%83%AC%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9)%3CBR%20%2F%3E%E3%83%AB%E3%83%BC%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20Wed%2C%2031%20Dec%202014%2021%3A03%3A35%20-0800%20%E3%81%AB%E6%A7%8B%E7%AF%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%BB%E3%83%9F%E3%82%B3%E3%83%B3%E3%83%80%E3%82%AF%E3%82%BF%E6%A0%AA%E5%BC%8F%E4%BC%9A%E7%A4%BE%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3CSTRONG%3E%20lspci%3C%2FSTRONG%3E%20%E5%87%BA%E5%8A%9B%20%3A%3C%2FP%3E%3CP%3E%26lt%3B5-2666-gbdde708%2Fkernel%2Fdrivers%2Fnet%2Fr8168-8.039.00%24%20lspci%3C%2FP%3E%3CP%3E00%3A00.0%20%E3%82%AF%E3%83%A9%E3%82%B9%200604%3A%2016c3%3Aabcd%3C%2FP%3E%3CP%3E01%3A00.0%20%E3%82%AF%E3%83%A9%E3%82%B9%200200%3A%2010ec%3A8168%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81RTL8111E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%80%81%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9eth1%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%26lt%3B5-2666-gbdde708%2Fkernel%2Fdrivers%2Fnet%2Fr8168-8.039.00%24%20insmod%20r8168.ko%3C%2FP%3E%3CP%3Er8168%E3%82%AE%E3%82%AC%E3%83%93%E3%83%83%E3%83%88%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%83%89%E3%83%A9%E3%82%A4%E3%83%908.039.00-NAPI%E3%83%AD%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3ER8168%200000%3A01%3A00.0%3AMSI%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82INTx%E3%81%AB%E6%88%BB%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Er8168%3A%E3%81%93%E3%81%AE%E8%A3%BD%E5%93%81%E3%81%AF%E3%80%81US6%2C570%2C884%E3%80%81US6%2C115%2C776%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3US6%2C327%2C625%E3%81%AE1%E3%81%A4%E4%BB%A5%E4%B8%8A%E3%81%AE%E7%89%B9%E8%A8%B1%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E4%BF%9D%E8%AD%B7%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3Er8168%20Copyright%20(C)%202014%20Realtek%20NIC%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%81%E3%83%BC%E3%83%A0%20%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Anicfae%40realtek.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Enicfae%40realtek.com%3C%2FA%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%20%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AB%E3%81%AF%E4%B8%80%E5%88%87%E3%81%AE%E4%BF%9D%E8%A8%BC%E3%81%8C%E4%BB%98%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.gnu.org%2Flicenses%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.gnu.org%2Flicenses%2F%3C%2FA%3E%3CSPAN%3E%26gt%3B%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%20%E3%81%93%E3%82%8C%E3%81%AF%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E7%89%B9%E5%AE%9A%E3%81%AE%E6%9D%A1%E4%BB%B6%E4%B8%8B%E3%81%A7%E5%86%8D%E9%85%8D%E5%B8%83%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E6%AD%93%E8%BF%8E%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.gnu.org%2Flicenses%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.gnu.org%2Flicenses%2F%3C%2FA%3E%3CSPAN%3E%26gt%3B%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CVERS%3E%3C%2FVERS%3Eeth1%3A%200xc0b86000%2C%2000%3Ae0%3A4c%3A68%3Aa2%3A04%2C%20IRQ%20155%3CBR%20%2F%3E%26lt%3B5-2666-gbdde708%2Fkernel%2Fdrivers%2Fnet%2Fr8168-8.039.00%24%20r8168%3A%20eth1%3A%20link%20up%3C%2FP%3E%3CP%3E%26lt%3B5-2666-gbdde708%2Fkernel%2Fdrivers%2Fnet%2Fr8168-8.039.00%24(%E8%8B%B1%E8%AA%9E)ifconfig%E3%81%AE%3CBR%20%2F%3Eeth1%20Link%20encap%3AEthernet%20HWaddr%2000%3AE0%3A4C%3A68%3AA2%3A04%3CBR%20%2F%3Einet%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A192.168.0.2B%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%3A192.168.0.255%E3%83%9E%E3%82%B9%E3%82%AF%3A255.255.255.0%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%E3%83%9E%E3%83%AB%E3%83%81%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8BUP%E3%83%96%E3%83%AD%E3%83%BC%E3%83%89%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88MTU%3A1500%E3%83%A1%E3%83%88%E3%83%AA%E3%83%83%E3%82%AF%3A1%3CBR%20%2F%3ERX%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E6%95%B0%3A0%20%E3%82%A8%E3%83%A9%E3%83%BC%E6%95%B0%3A0%20%E3%83%89%E3%83%AD%E3%83%83%E3%83%97%E6%95%B0%3A0%20%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%83%B3%E6%95%B0%3A0%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E6%95%B0%3A0%3CBR%20%2F%3ETX%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%3A0%20%E3%82%A8%E3%83%A9%E3%83%BC%3A0%20%E3%83%89%E3%83%AD%E3%83%83%E3%83%97%3A0%20%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%83%B3%3A0%20%E3%82%AD%E3%83%A3%E3%83%AA%E3%82%A2%3A0%3CBR%20%2F%3E%E8%A1%9D%E7%AA%81%E6%95%B0%3A0%20txqueuelen%3A1000%3CBR%20%2F%3ERX%E3%83%90%E3%82%A4%E3%83%88%3A0%20(0.0%20B)%20TX%E3%83%90%E3%82%A4%E3%83%88%3A0%20(0.0%20B)%3CBR%20%2F%3E%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%3A155%20%E3%83%99%E3%83%BC%E3%82%B9%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A0x6000%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%80%8CPING%20192.168.0.1%E3%80%8D%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%82%A2%E3%83%80%E3%83%B3%E3%83%97%3C%2FP%3E%3CP%3E%26lt%3B5-2666-gbdde708%2Fkernel%2Fdrivers%2Fnet%2Fr8168-8.039.00%24%20ping%20192.168.0.1%3C%2FP%3E%3CP%3EPING%20192.168.0.1(192.168.0.1)%3Aarch%20%2F%20arm%20%2F%20mm%20%2F%20dma-mapping.c%3A478%E3%81%AE5kernel%E3%83%90%E3%82%B0!%3C%2FP%3E%3CP%3E6%20%E3%83%87%E3%83%BC%E3%82%BF%20%E3%83%90%E3%82%A4%E3%83%88%3C%2FP%3E%3CP%3E%E4%BB%AE%E6%83%B3%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B900000000%E3%81%A7%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%ABNULL%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%E9%80%86%E5%8F%82%E7%85%A7%E3%82%92%E5%87%A6%E7%90%86%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Epgd%20%3D%2080004000%3C%2FP%3E%3CP%3E%5B00000000%5D%20*pgd%3D00000000%3C%2FP%3E%3CP%3E%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%3A%20Oops%3A%20817%20%5B%231%5D%20PREEMPT%20SMP%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%3Ar8168%20%5B%E6%9C%80%E5%BE%8C%E3%81%AB%E3%82%A2%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%3Ar8168%5D%3C%2FP%3E%3CP%3ECPU%3A2%E6%B1%9A%E6%9F%93%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84(3.0.35-2666-gbdde708%20%2320)%3C%2FP%3E%3CP%3EPC%E3%81%AF__bug%2B0x1c%2F0x28%3C%2FP%3E%3CP%3ELR%E3%81%AF__bug%2B0x18%2F0x28%3C%2FP%3E%3CP%3Epc%20%3A%20%5B%26lt%3B800462c8%26gt%3B%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%20lr%20%3A%20%5B%26lt%3B800462c4%26gt%3B%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%20psr%3A%2060000193%3C%2FP%3E%3CP%3Esp%20%3A%20bffb5dc8%26nbsp%3B%20ip%20%3A%20c097a000%26nbsp%3B%20fp%20%3A%20bfb80000%3C%2FP%3E%3CP%3ER10%3A%200000021C%20R9%20%3A%207F084544%20R8%20%3A%20FF9F2000%3C%2FP%3E%3CP%3ER7%20%3A%20FF9F8000%20R6%20%3A%2000000001%20R5%20%3A%2000000012%20R4%20%3A%20FF9F2000%3C%2FP%3E%3CP%3ER3%20%3A%2000000000%20R2%20%3A%2080AD329C%20R1%20%3A%2060000193%20R0%20%3A%2000000033%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%82%B0%3A%20nZCv%20IRQ%20%E3%81%AF%E3%83%A2%E3%83%BC%E3%83%89%20SVC_32%20ISA%20ARM%20%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A7%20FIQ%20%E3%82%92%E3%82%AA%E3%83%95%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%88%B6%E5%BE%A1%3A10c53c7d%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%3A4a70404a%20DAC%3A00000015%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%82%B9%E3%83%AF%E3%83%83%E3%83%91%E3%83%BC%20(pid%3A%200%2C%20stack%20limit%20%3D%200xbffb42f0)%3C%2FP%3E%3CP%3E%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%3A%20(0xbffb5dc8%20%E3%81%8B%E3%82%89%200xbffb6000)%3C%2FP%3E%3CP%3E5DC0%3A%2080B16930%208004CB08%2000000012%2000400000%200000002A%207F0489F8%3C%2FP%3E%3CP%3E5de0%3A%2000000000%2080000000%2000000000%20bfcbfd80%20bfb804b4%20ff9f8000%20ff9f8000%2080000113%3C%2FP%3E%3CP%3E5e00%3A%20c0b86000%20ba14f090%2000000000%2060004980%20bfcbfd80%20bfb80000%2000000000%2080abc11c%3C%2FP%3E%3CP%3E5e20%3A%207f084544%20bfdb8a20%2080439354%208042f11c%2000000006%20bfb8018c%20bfcd0608%20bfe7ed02%3C%2FP%3E%3CP%3E5e40%3A%20bfb80000%20bfe7ef00%20bfb80000%20bfe7ef5c%20bfcbfd80%20bfdb8a20%2000000000%2000000002%3C%2FP%3E%3CP%3E5e60%3A%2080439354%208044a694%20bfdb8a20%20bfe7ef00%20bfcbfd80%20bfb80000%20bfdb8a20%20bfe7ef5c%3C%2FP%3E%3CP%3E5e80%3A%2000000000%208042f5a0%20bfe7ef5c%20bfe7ee00%2000000000%2000000000%2000000000%20bfcbfb40%3C%2FP%3E%3CP%3E5ea0%3A%20bfb80000%200100a8c0%200200a8c0%2000000000%20bfe7ee00%208047d8fc%200200a8c0%2000000000%3C%2FP%3E%3CP%3E5ec0%3A%20bfcd0608%2000000000%2000000010%20bfcbfb40%20bfcbfb5c%20bfcbfb54%20bfcbfcc0%2000000000%3C%2FP%3E%3CP%3E5ee0%3A%2000000103%2080439558%20bffb5f08%20bffcc000%2080aa8080%20bffb4000%2000200200%2080082f84%3C%2FP%3E%3CP%3E5f00%3A%200000024e%207abe5a80%20bffb5f08%20bffb5f08%2000000000%2000000141%2080aa8044%20bffb4000%3C%2FP%3E%3CP%3E5f20%3A%2000000103%2080b102e0%2000000002%2080aa8040%2000000001%208007d078%207a264549%200000024e%3C%2FP%3E%3CP%3E5F40%3A%207A264549%200000000A%207A264549%20BFFB4000%20BFFB4000%208003BC00%2000000000%2000000002%3C%2FP%3E%3CP%3E5F60%3A%20bffb4000%2000000000%2000000000%208007D5B4%2080abbcc0%208003D2E0%20FFFFFFFF%20F2A00100%3C%2FP%3E%3CP%3E5F80%3A00000002%2000000002%2000000001%2080042A0C%2080B11C40%2080000093%2000000001%2000000000%3C%2FP%3E%3CP%3E5FA0%3ABFFB4000%2080B0A744%2080ABBA70%208051D870%2080ABEF0C%20412FC09A%2000000000%2000000000%3C%2FP%3E%3CP%3E5fc0%3A%2000000000%20bffb5fd8%2080051e2c%2080043b04%2040000013%20ffffffff%2080043ae0%2080043d20%3C%2FP%3E%3CP%3E5FE0%3A4FFB806A%2000000015%2010C03C7D80B0A8F8%201000406A%2010511694%2081022CCE%2022705254%3C%2FP%3E%3CP%3E%5B%26lt%3B800462c8%26gt%3B%5D%20(__bug%2B0x1c%2F0x28)%20from%20%5B%26lt%3B8004cb08%26gt%3B%5D%20(___dma_single_cpu_to_dev%2B0x94%2F0xa4)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B8004cb08%26gt%3B%E3%80%91(___dma_single_cpu_to_dev%2B0x94%2F0xa4)%20from%20%5B%26lt%3B7f0489f8%26gt%3B%5D%20(rtl8168_start_xmit%2B0x514%2F0x6c4%20%5BR8168%5D)%3C%2FP%3E%3CP%3E%5B%26lt%3B7f0489f8%26gt%3B%5D(rtl8168_start_xmit%2B0x514%2F0x6c4%20%5BR8168%5D)%20from%20%5B%26lt%3B8042f11c%26gt%3B%5D%20(dev_hard_start_xmit%2B0x2f4%2F0x59c)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B8042f11c%26gt%3B%E3%80%91(dev_hard_start_xmit%2B0x2f4%2F0x59c)%20from%20%5B%26lt%3B8044a694%26gt%3B%5D%20(sch_direct_xmit%2B0xb0%2F0x1dc)%3C%2FP%3E%3CP%3E%5B%26lt%3B8044a694%26gt%3B%5D(sch_direct_xmit%2B0xb0%2F0x1dc)%20from%20%5B%26lt%3B8042f5a0%26gt%3B%5D%20(dev_queue_xmit%2B0x1dc%2F0x60c)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B8042f5a0%26gt%3B%E3%80%91(dev_queue_xmit%2B0x1dc%2F0x60c)%20from%20%5B%26lt%3B8047d8fc%26gt%3B%5D%20(arp_solicit%2B0xd4%2F0x1b0)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B8047d8fc%26gt%3B%E3%80%91(arp_solicit%2B0xd4%2F0x1b0)%20from%20%5B%26lt%3B80439558%26gt%3B%5D%20(neigh_timer_handler%2B0x204%2F0x38c)%3C%2FP%3E%3CP%3E%5B%26lt%3B80439558%26gt%3B%5D(neigh_timer_handler%2B0x204%2F0x38c)%20from%20%5B%26lt%3B80082f84%26gt%3B%5D%20(run_timer_softirq%2B0xec%2F0x214)%3C%2FP%3E%3CP%3E%5B%26lt%3B80082f84%26gt%3B%5D(run_timer_softirq%2B0xec%2F0x214)%20from%20%5B%26lt%3B8007d078%26gt%3B%5D%20(__do_softirq%2B0xac%2F0x140)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B8007d078%26gt%3B%E3%80%91(__do_softirq%2B0xac%2F0x140)%20from%20%5B%26lt%3B8007d5b4%26gt%3B%5D%20(irq_exit%2B0x94%2F0x9c)%3C%2FP%3E%3CP%3E%5B%26lt%3B8007d5b4%26gt%3B%5D(irq_exit%2B0x94%2F0x9c)%20from%20%5B%26lt%3B8003d2e0%26gt%3B%5D%20(do_IPI%2B0x10c%2F0x17c)%3C%2FP%3E%3CP%3E%5B%26lt%3B8003d2e0%26gt%3B%5D%20(do_IPI%2B0x10c%2F0x17c)%20from%20%5B%26lt%3B80042a0c%26gt%3B%5D%20(__irq_svc%2B0x4c%2F0xe8)%3C%2FP%3E%3CP%3E%E4%BE%8B%E5%A4%96%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF(0xbffb5f90%20%E3%81%8B%E3%82%89%200xbffb5fd8)%3C%2FP%3E%3CP%3E5F80%3A%2080B11C40%2080000093%2000000001%2000000000%3C%2FP%3E%3CP%3E5FA0%3ABFFB4000%2080B0A744%2080ABBA70%208051D870%2080ABEF0C%20412FC09A%2000000000%2000000000%3C%2FP%3E%3CP%3E5fc0%3A%2000000000%20bffb5fd8%2080051e2c%2080043b04%2040000013%20ffffffff%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B80042a0c%26gt%3B%E3%80%91(__irq_svc%2B0x4c%2F0xe8)%20from%20%5B%26lt%3B80043b04%26gt%3B%5D%20(default_idle%2B0x24%2F0x28)%3C%2FP%3E%3CP%3E%5B%26lt%3B80043b04%26gt%3B%5D(default_idle%2B0x24%2F0x28)%20from%20%5B%26lt%3B80043d20%26gt%3B%5D%20(cpu_idle%2B0xe0%2F0x124)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B80043d20%26gt%3B%E3%80%91(cpu_idle%2B0xe0%2F0x124)%20from%20%5B%26lt%3B10511694%26gt%3B%5D%20(0x10511694)%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%BC%E3%83%89%3A%20e59f0010%20e1a01003%20eb133c07%20e3a03000%20(e5833000)%3C%2FP%3E%3CP%3E%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%81%A7%E3%81%AFclk_enable%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%5B%26lt%3B80049e34%26gt%3B%5D(unwind_backtrace%2B0x0%2F0xf8)%20from%20%5B%26lt%3B8006563c%26gt%3B%5D%20(clk_enable%2B0x88%2F0xa0)%3C%2FP%3E%3CP%3E%5B%26lt%3B8006563c%26gt%3B%5D(clk_enable%2B0x88%2F0xa0)%20from%20%5B%26lt%3B8039b608%26gt%3B%5D%20(_ipu_get%2B0xc%2F0x24)%3C%2FP%3E%3CP%3E%5B%26lt%3B8039b608%26gt%3B%5D(_ipu_get%2B0xc%2F0x24)%20from%20%5B%26lt%3B8039c4bc%26gt%3B%5D%20(ipu_clear_irq%2B0x18%2F0x8c)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B8039c4bc%26gt%3B%E3%80%91(ipu_clear_irq%2B0x18%2F0x8c)%20from%20%5B%26lt%3B802714bc%26gt%3B%5D%20(mxcfb_set_par%2B0xb8%2F0x6d0)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B802714bc%26gt%3B%E3%80%91(mxcfb_set_par%2B0xb8%2F0x6d0)%20from%20%5B%26lt%3B80271b78%26gt%3B%5D%20(mxcfb_blank%2B0xa4%2F0xb8)%3C%2FP%3E%3CP%3E%5B%26lt%3B80271b78%26gt%3B%5D(mxcfb_blank%2B0xa4%2F0xb8)%20from%20%5B%26lt%3B80259d24%26gt%3B%5D%20(fb_blank%2B0x3c%2F0x68)%3C%2FP%3E%3CP%3E%5B%26lt%3B80259d24%26gt%3B%5D(fb_blank%2B0x3c%2F0x68)%20from%20%5B%26lt%3B80263b18%26gt%3B%5D(fbcon_blank%2B0x1c4%2F0x258)%3C%2FP%3E%3CP%3E%5B%26lt%3B80263b18%26gt%3B%5D(fbcon_blank%2B0x1c4%2F0x258)%20from%20%5B%26lt%3B80297fa0%26gt%3B%5D%20(do_unblank_screen%2B0x94%2F0x194)%3C%2FP%3E%3CP%3E%5B%26lt%3B80297fa0%26gt%3B%5D(do_unblank_screen%2B0x94%2F0x194)%20from%20%5B%26lt%3B8023c004%26gt%3B%5D%20(bust_spinlocks%2B0x24%2F0x4c)%3C%2FP%3E%3CP%3E%5B%26lt%3B8023c004%26gt%3B%5D(bust_spinlocks%2B0x24%2F0x4c)%20from%20%5B%26lt%3B800465c0%26gt%3B%5D%20(%E3%83%80%E3%82%A4%2B0xa8%2F0x284)%3C%2FP%3E%3CP%3E%5B%26lt%3B800465c0%26gt%3B%5D(%E3%83%80%E3%82%A4%2B0xa8%2F0x284)%20from%20%5B%26lt%3B8051464c%26gt%3B%5D(__do_kernel_fault.part.4%2B0x54%2F0x74)%3C%2FP%3E%3CP%3E%5B%26lt%3B8051464c%26gt%3B%5D(__do_kernel_fault.part.4%2B0x54%2F0x74)%5B%26lt%3B8004da68%26gt%3B%5D%E3%81%8B%E3%82%89%20(do_page_fault%2B0x2b4%2F0x31c)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B8004da68%26gt%3B%E3%80%91(do_page_fault%2B0x2b4%2F0x31c)%20from%20%5B%26lt%3B8003d384%26gt%3B%5D(do_DataAbort%2B0x34%2F0x9c)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B8003d384%26gt%3B%E3%80%91(do_DataAbort%2B0x34%2F0x9c)%20from%20%5B%26lt%3B80042990%26gt%3B%5D%20(__dabt_svc%2B0x70%2F0xa0)%3C%2FP%3E%3CP%3E%E4%BE%8B%E5%A4%96%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF(0xbffb5d80%20%E3%81%8B%E3%82%89%200xbffb5dc8)%3C%2FP%3E%3CP%3E5D80%3A%2000000033%2060000193%2080AD329C%2000000000%20FF9F2000%2000000012%2000000001%20FF9F8000%3C%2FP%3E%3CP%3E5da0%3A%20ff9f2000%207f084544%200000021c%20bfb80000%20c097a000%20bffb5dc8%20800462c4%20800462c8%3C%2FP%3E%3CP%3E5dc0%3A%2060000193%20ffffffff%3C%2FP%3E%3CP%3E%5B%26lt%3B80042990%26gt%3B%5D(__dabt_svc%2B0x70%2F0xa0)%20from%20%5B%26lt%3B800462c8%26gt%3B%5D%20(__bug%2B0x1c%2F0x28)%3C%2FP%3E%3CP%3E%5B%26lt%3B800462c8%26gt%3B%5D%20(__bug%2B0x1c%2F0x28)%20from%20%5B%26lt%3B8004cb08%26gt%3B%5D%20(___dma_single_cpu_to_dev%2B0x94%2F0xa4)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B8004cb08%26gt%3B%E3%80%91(___dma_single_cpu_to_dev%2B0x94%2F0xa4)%20from%20%5B%26lt%3B7f0489f8%26gt%3B%5D%20(rtl8168_start_xmit%2B0x514%2F0x6c4%20%5BR8168%5D)%3C%2FP%3E%3CP%3E%5B%26lt%3B7f0489f8%26gt%3B%5D(rtl8168_start_xmit%2B0x514%2F0x6c4%20%5BR8168%5D)%20from%20%5B%26lt%3B8042f11c%26gt%3B%5D%20(dev_hard_start_xmit%2B0x2f4%2F0x59c)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B8042f11c%26gt%3B%E3%80%91(dev_hard_start_xmit%2B0x2f4%2F0x59c)%20from%20%5B%26lt%3B8044a694%26gt%3B%5D%20(sch_direct_xmit%2B0xb0%2F0x1dc)%3C%2FP%3E%3CP%3E%5B%26lt%3B8044a694%26gt%3B%5D(sch_direct_xmit%2B0xb0%2F0x1dc)%20from%20%5B%26lt%3B8042f5a0%26gt%3B%5D%20(dev_queue_xmit%2B0x1dc%2F0x60c)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B8042f5a0%26gt%3B%E3%80%91(dev_queue_xmit%2B0x1dc%2F0x60c)%20from%20%5B%26lt%3B8047d8fc%26gt%3B%5D%20(arp_solicit%2B0xd4%2F0x1b0)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B8047d8fc%26gt%3B%E3%80%91(arp_solicit%2B0xd4%2F0x1b0)%20from%20%5B%26lt%3B80439558%26gt%3B%5D%20(neigh_timer_handler%2B0x204%2F0x38c)%3C%2FP%3E%3CP%3E%5B%26lt%3B80439558%26gt%3B%5D(neigh_timer_handler%2B0x204%2F0x38c)%20from%20%5B%26lt%3B80082f84%26gt%3B%5D%20(run_timer_softirq%2B0xec%2F0x214)%3C%2FP%3E%3CP%3E%5B%26lt%3B80082f84%26gt%3B%5D(run_timer_softirq%2B0xec%2F0x214)%20from%20%5B%26lt%3B8007d078%26gt%3B%5D%20(__do_softirq%2B0xac%2F0x140)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B8007d078%26gt%3B%E3%80%91(__do_softirq%2B0xac%2F0x140)%20from%20%5B%26lt%3B8007d5b4%26gt%3B%5D%20(irq_exit%2B0x94%2F0x9c)%3C%2FP%3E%3CP%3E%5B%26lt%3B8007d5b4%26gt%3B%5D(irq_exit%2B0x94%2F0x9c)%20from%20%5B%26lt%3B8003d2e0%26gt%3B%5D%20(do_IPI%2B0x10c%2F0x17c)%3C%2FP%3E%3CP%3E%5B%26lt%3B8003d2e0%26gt%3B%5D%20(do_IPI%2B0x10c%2F0x17c)%20from%20%5B%26lt%3B80042a0c%26gt%3B%5D%20(__irq_svc%2B0x4c%2F0xe8)%3C%2FP%3E%3CP%3E%E4%BE%8B%E5%A4%96%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF(0xbffb5f90%20%E3%81%8B%E3%82%89%200xbffb5fd8)%3C%2FP%3E%3CP%3E5F80%3A%2080B11C40%2080000093%2000000001%2000000000%3C%2FP%3E%3CP%3E5FA0%3ABFFB4000%2080B0A744%2080ABBA70%208051D870%2080ABEF0C%20412FC09A%2000000000%2000000000%3C%2FP%3E%3CP%3E5fc0%3A%2000000000%20bffb5fd8%2080051e2c%2080043b04%2040000013%20ffffffff%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B80042a0c%26gt%3B%E3%80%91(__irq_svc%2B0x4c%2F0xe8)%20from%20%5B%26lt%3B80043b04%26gt%3B%5D%20(default_idle%2B0x24%2F0x28)%3C%2FP%3E%3CP%3E%5B%26lt%3B80043b04%26gt%3B%5D(default_idle%2B0x24%2F0x28)%20from%20%5B%26lt%3B80043d20%26gt%3B%5D%20(cpu_idle%2B0xe0%2F0x124)%3C%2FP%3E%3CP%3E%E3%80%90%26lt%3B80043d20%26gt%3B%E3%80%91(cpu_idle%2B0xe0%2F0x124)%20from%20%5B%26lt%3B10511694%26gt%3B%5D%20(0x10511694)%3C%2FP%3E%3CP%3Earch%2Farm%2Fplat-mxc%2Fclock.c%3A101%20%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%90%E3%82%B0!%3C%2FP%3E%3CP%3E%E4%BB%AE%E6%83%B3%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B900000000%E3%81%A7%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%ABNULL%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%E9%80%86%E5%8F%82%E7%85%A7%E3%82%92%E5%87%A6%E7%90%86%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Epgd%20%3D%2080004000%3C%2FP%3E%3CP%3E%5B00000000%5D%20*pgd%3D00000000%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126672%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126672%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A8%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%91%E3%83%8B%E3%83%83%E3%82%AF%E3%82%92%E5%A0%B1%E5%91%8A%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AERTL8111e%E3%81%AE%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%93%E3%83%86%E3%82%A3%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%83%AA%E3%83%81%E3%83%A3%E3%83%BC%E3%83%89%3CBR%20style%3D%22mso-special-character%3Aline-break%22%20%2F%3E%3CBR%20style%3D%22mso-special-character%3Aline-break%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126671%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126671%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%82%E3%82%8B%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%20RTL8111e%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%91%E3%83%8B%E3%83%83%E3%82%AF%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E5%A0%B1%E5%91%8A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3Eeth1%20Link%20encap%3AEthernet%20HWaddr%2000%3AE0%3A4C%3A68%3AA2%3A04%3CBR%20%2F%3Einet%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A192.168.0.2B%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%3A192.168.0.255%E3%83%9E%E3%82%B9%E3%82%AF%3A255.255.255.0%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%E3%83%9E%E3%83%AB%E3%83%81%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8BUP%E3%83%96%E3%83%AD%E3%83%BC%E3%83%89%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88MTU%3A1500%E3%83%A1%E3%83%88%E3%83%AA%E3%83%83%E3%82%AF%3A1%3CBR%20%2F%3ERX%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E6%95%B0%3A12%20%E3%82%A8%E3%83%A9%E3%83%BC%E6%95%B0%3A0%20%E3%83%89%E3%83%AD%E3%83%83%E3%83%97%E6%95%B0%3A0%20%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%83%B3%E6%95%B0%3A0%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E6%95%B0%3A0%3CBR%20%2F%3ETX%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%3A0%20%E3%82%A8%E3%83%A9%E3%83%BC%3A0%20%E3%83%89%E3%83%AD%E3%83%83%E3%83%97%3A0%20%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%83%B3%3A0%20%E3%82%AD%E3%83%A3%E3%83%AA%E3%82%A2%3A0%3CBR%20%2F%3E%E8%A1%9D%E7%AA%81%E6%95%B0%3A0%20txqueuelen%3A1000%3CBR%20%2F%3ERX%E3%83%90%E3%82%A4%E3%83%88%3A1002%20(1002.0B)%20TX%E3%83%90%E3%82%A4%E3%83%88%3A0%20(0.0%20B)%3CBR%20%2F%3E%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%3A155%20%E3%83%99%E3%83%BC%E3%82%B9%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A0xe000%3C%2FP%3E%3CP%3E%26lt%3B5-2666-gbdde708%2Fkernel%2Fdrivers%2Fnet%2Fr8168-8.039.00%24(%E8%8B%B1%E8%AA%9E)%E3%83%94%E3%83%B3%20192.168.0.1%3CBR%20%2F%3EPING%20192.168.0.1%20(192.168.0.1)%3A%2056%20%E3%83%87%E3%83%BC%E3%82%BF%20%E3%83%90%E3%82%A4%E3%83%88%3CBR%20%2F%3Earch%2Farm%2Fmm%2Fdma-mapping.c%3A478%20%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%90%E3%82%B0!%3CBR%20%2F%3E%E4%BB%AE%E6%83%B3%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B900000000%E3%81%A7%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%ABNULL%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%E9%80%86%E5%8F%82%E7%85%A7%E3%82%92%E5%87%A6%E7%90%86%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3EPGD%20%3D%2080004000%3CBR%20%2F%3E%5B00000000%5D%20*pgd%3D00000000%3CBR%20%2F%3E%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%3A%20Oops%3A%20817%20%5B%231%5D%20PREEMPT%20SMP%3CBR%20%2F%3E%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%3A%20r8168%3CBR%20%2F%3ECPU%3A2%E6%B1%9A%E6%9F%93%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84(3.0.35-2666-gbdde708%20%2320)%3CBR%20%2F%3EPC%E3%81%AF%E3%83%90%E3%82%B0%20__bug%2B0x1c%2F0x28%3CBR%20%2F%3ELR%20is%20at%20__%2B0x18%2F0x28%E3%81%A7%E3%81%99%3CBR%20%2F%3EPC%3A%5B%26lt%3B800462c8%26gt%3B%5D%20LR%3A%5B%26lt%3B800462c4%26gt%3B%5D%20PSR%3A60000193%3CBR%20%2F%3ESP%3ABFFB5DC8%20IP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3AC097A000%20FP%3ABA074000%3CBR%20%2F%3ER10%3A0000021C%20R9%3A7F03D544%20R8%3AFF9F2000%3CBR%20%2F%3ER7%20%3A%20FF9F8000%20R6%20%3A%2000000001%20R5%20%3A%2000000012%20R4%20%3A%20FF9F2000%3CBR%20%2F%3ER3%20%3A%2000000000%20R2%20%3A%2080AD329C%20R1%20%3A%2060000193%20R0%20%3A%2000000033%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%82%B0%3A%20nZCv%20IRQ%20%E3%81%AF%E3%83%A2%E3%83%BC%E3%83%89%20SVC_32%20ISA%20ARM%20%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A7%20FIQ%20%E3%82%92%E3%82%AA%E3%83%95%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%88%B6%E5%BE%A1%3A10c53c7d%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%3A4a2b404a%20DAC%3A00000015%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%82%B9%E3%83%AF%E3%83%83%E3%83%91%E3%83%BC%20(pid%3A%200%2C%20stack%20limit%20%3D%200xbffb42f0)%3CBR%20%2F%3E%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%3A%20(0xbffb5dc8%20%E3%81%8B%E3%82%89%200xbffb6000)%3CBR%20%2F%3E5DC0%3A%2080B16930%208004CB08%2000000012%2000400000%200000002A%207F0019F8%3CBR%20%2F%3E5DE0%3A%2000000000%2080000000%2000000000%20BFD92480%20BA0744B4%20FF9F8000%20FF9F8000%2080000113%3CBR%20%2F%3E5E00%3A%20C0B7E000%20BFC938A0%2000000000%2060004980%20BFD92480%20BA074000%200000000%2080ABC11C%3CBR%20%2F%3E5E20%3A7F03D544%20BFD82480%2080439354%208042F11C%2000000006%20BA07418C%20BFC1EC08%20BFD3DD02%3CBR%20%2F%3E5E40%3ABA074000%20BFD3DF00%20BA074000%20BFD3DF5C%20BFD92480%20BFD82480%2000000000%2000000002%3CBR%20%2F%3E5E60%3A%2080439354%208044A694%20BFD82480%20BFD3DF00%20BFD92480%20BA074000%20BFD82480%20BFD3DF5C%3CBR%20%2F%3E5E80%3A%2000000000%208042F5A0%20BFD3DF5C%20BFD3DE00%20000000000%2000000000%2000000000%20BFD92240%3CBR%20%2F%3E5EA0%3A%20BA074000%200100A8C0%200200A8C0%2000000000%20BFD3DE00%208047D8FC%200200A8C0%2000000000%3CBR%20%2F%3E5EC0%3A%20BFC1EC08%2000000000%2000000010%20BFD92240%20BFD9225C%20BFD92254%20BFD923C0%2000000000%3CBR%20%2F%3E5EE0%3A%2000000103%2080439558%20bffb5f08%20bffcc000%2080aa8080%20bffb4000%2000200200%2080082f84%3CBR%20%2F%3E5F00%3A%20000000FA%208436AE00%20BFFB5F08%20BFFB5F08%2000000000%2000000141%2080AA8044%20BFFB4000%3CBR%20%2F%3E5F20%3A00000103%2080B102E0%2000000002%2080AA8040%2000000001%208007D078%20839E72DA%20000000FA%3CBR%20%2F%3E5F40%3A%20839E72DA%200000000A%20839E72DA%20BFFB4000%20BFFB4000%208003BC00%2000000000%2000000002%3CBR%20%2F%3E5F60%3A%20bffb4000%2000000000%2000000000%208007D5B4%2080abbcc0%208003D2E0%20FFFFFFFF%20F2A00100%3CBR%20%2F%3E5F80%3A00000002%2000000002%2000000001%2080042A0C%2080B11C40%2080000093%2000000001%2000000000%3CBR%20%2F%3E5FA0%3ABFFB4000%2080B0A744%2080ABBA70%208051D870%2080ABEF0C%20412FC09A%2000000000%2000000000%3CBR%20%2F%3E5FC0%3A%2000000000%20bffb5fd8%2080051e2c%2080043b04%2040000013%20ffffffff%2080043ae0%2080043d20%3CBR%20%2F%3E5FE0%3A4FFB806A%2000000015%2010C03C7D80B0A8F8%201000406A%2010511694%208102080C%2022705244%3CBR%20%2F%3E%5B%26lt%3B800462c8%26gt%3B%5D(__bug%2B0x1c%2F0x28)%20from%20%5B%26lt%3B8004cb08%26gt%3B%5D%20(___dma_single_cpu_to_dev%2B0x94%2F0xa4)%3CBR%20%2F%3E%E3%80%90%26lt%3B8004cb08%26gt%3B%E3%80%91(___dma_single_cpu_to_dev%2B0x94%2F0xa4)%20from%20%5B%26lt%3B7f0019f8%26gt%3B%5D%20(rtl8168_start_xmit%2B0x514%2F0x6c4%20%5BR8168%5D)%3CBR%20%2F%3E%5B%26lt%3B7f0019f8%26gt%3B%5D(rtl8168_start_xmit%2B0x514%2F0x6c4%20%5BR8168%5D)%20from%20%5B%26lt%3B8042f11c%26gt%3B%5D%20(dev_hard_start_xmit%2B0x2f4%2F0x59c)%3CBR%20%2F%3E%E3%80%90%26lt%3B8042f11c%26gt%3B%E3%80%91(dev_hard_start_xmit%2B0x2f4%2F0x59c)%20from%20%5B%26lt%3B8044a694%26gt%3B%5D%20(sch_direct_xmit%2B0xb0%2F0x1dc)%3CBR%20%2F%3E%5B%26lt%3B8044a694%26gt%3B%5D(sch_direct_xmit%2B0xb0%2F0x1dc)%20from%20%5B%26lt%3B8042f5a0%26gt%3B%5D%20(dev_queue_xmit%2B0x1dc%2F0x60c)%3CBR%20%2F%3E%E3%80%90%26lt%3B8042f5a0%26gt%3B%E3%80%91(dev_queue_xmit%2B0x1dc%2F0x60c)%20from%20%5B%26lt%3B8047d8fc%26gt%3B%5D%20(arp_solicit%2B0xd4%2F0x1b0)%3CBR%20%2F%3E%E3%80%90%26lt%3B8047d8fc%26gt%3B%E3%80%91(arp_solicit%2B0xd4%2F0x1b0)%20from%20%5B%26lt%3B80439558%26gt%3B%5D%20(neigh_timer_handler%2B0x204%2F0x38c)%3CBR%20%2F%3E%5B%26lt%3B80439558%26gt%3B%5D(neigh_timer_handler%2B0x204%2F0x38c)%20from%20%5B%26lt%3B80082f84%26gt%3B%5D%20(run_timer_softirq%2B0xec%2F0x214)%3CBR%20%2F%3E%5B%26lt%3B80082f84%26gt%3B%5D(run_timer_softirq%2B0xec%2F0x214)%20from%20%5B%26lt%3B8007d078%26gt%3B%5D%20(__do_softirq%2B0xac%2F0x140)%3CBR%20%2F%3E%E3%80%90%26lt%3B8007d078%26gt%3B%E3%80%91(__do_softirq%2B0xac%2F0x140)%20from%20%5B%26lt%3B8007d5b4%26gt%3B%5D%20(irq_exit%2B0x94%2F0x9c)%3CBR%20%2F%3E%5B%26lt%3B8007d5b4%26gt%3B%5D(irq_exit%2B0x94%2F0x9c)%20from%20%5B%26lt%3B8003d2e0%26gt%3B%5D%20(do_IPI%2B0x10c%2F0x17c)%3CBR%20%2F%3E%E3%80%90%26lt%3B8003d2e0%26gt%3B%E3%80%91(do_IPI%2B0x10c%2F0x17c)%20from%20%5B%26lt%3B80042a0c%26gt%3B%5D%20(__irq_svc%2B0x4c%2F0xe8)%3CBR%20%2F%3E%E4%BE%8B%E5%A4%96%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF(0xbffb5f90%20%E3%81%8B%E3%82%89%200xbffb5fd8)%3CBR%20%2F%3E5F80%3A%2080B11C40%2080000093%2000000001%2000000000%3CBR%20%2F%3E5FA0%3ABFFB4000%2080B0A744%2080ABBA70%208051D870%2080ABEF0C%20412FC09A%2000000000%2000000000%3CBR%20%2F%3E5FC0%3A%2000000000%20bffb5fd8%2080051e2c%2080043b04%2040000013%20ffffffff%3CBR%20%2F%3E%E3%80%90%26lt%3B80042a0c%26gt%3B%E3%80%91(__irq_svc%2B0x4c%2F0xe8)%20from%20%5B%26lt%3B80043b04%26gt%3B%5D%20(default_idle%2B0x24%2F0x28)%3CBR%20%2F%3E%5B%26lt%3B80043b04%26gt%3B%5D(default_idle%2B0x24%2F0x28)%20from%20%5B%26lt%3B80043d20%26gt%3B%5D%20(cpu_idle%2B0xe0%2F0x124)%3CBR%20%2F%3E%E3%80%90%26lt%3B80043d20%26gt%3B%E3%80%91(cpu_idle%2B0xe0%2F0x124)%20from%20%5B%26lt%3B10511694%26gt%3B%5D%20(0x10511694)%3CBR%20%2F%3E%E3%82%B3%E3%83%BC%E3%83%89%3A%20e59f0010%20e1a01003%20eb133c07%20e3a03000%20(e5833000)%3CBR%20%2F%3E%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%81%A7%E3%81%AFclk_enable%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B%26lt%3B80049e34%26gt%3B%5D(unwind_backtrace%2B0x0%2F0xf8)%20from%20%5B%26lt%3B8006563c%26gt%3B%5D%20(clk_enable%2B0x88%2F0xa0)%3CBR%20%2F%3E%5B%26lt%3B8006563c%26gt%3B%5D(clk_enable%2B0x88%2F0xa0)%20from%20%5B%26lt%3B8039b608%26gt%3B%5D%20(_ipu_get%2B0xc%2F0x24)%3CBR%20%2F%3E%5B%26lt%3B8039b608%26gt%3B%5D(_ipu_get%2B0xc%2F0x24)%20%5B%26lt%3B8039c4bc%26gt%3B%5D%E3%81%8B%E3%82%89(ipu_clear_irq%2B0x18%2F0x8c)%3CBR%20%2F%3E%E3%80%90%26lt%3B8039c4bc%26gt%3B%E3%80%91(ipu_clear_irq%2B0x18%2F0x8c)%20from%20%5B%26lt%3B802714bc%26gt%3B%5D%20(mxcfb_set_par%2B0xb8%2F0x6d0)%3CBR%20%2F%3E%E3%80%90%26lt%3B802714bc%26gt%3B%E3%80%91(mxcfb_set_par%2B0xb8%2F0x6d0)%20from%20%5B%26lt%3B80271b78%26gt%3B%5D%20(mxcfb_blank%2B0xa4%2F0xb8)%3CBR%20%2F%3E%5B%26lt%3B80271b78%26gt%3B%5D(mxcfb_blank%2B0xa4%2F0xb8)%20from%20%5B%26lt%3B80259d24%26gt%3B%5D%20(fb_blank%2B0x3c%2F0x68)%3CBR%20%2F%3E%5B%26lt%3B80259d24%26gt%3B%5D(fb_blank%2B0x3c%2F0x68)%20from%20%5B%26lt%3B80263b18%26gt%3B%5D(fbcon_blank%2B0x1c4%2F0x258)%3CBR%20%2F%3E%5B%26lt%3B80263b18%26gt%3B%5D(fbcon_blank%2B0x1c4%2F0x258)%20from%20%5B%26lt%3B80297fa0%26gt%3B%5D%20(do_unblank_screen%2B0x94%2F0x194)%3CBR%20%2F%3E%5B%26lt%3B80297fa0%26gt%3B%5D(do_unblank_screen%2B0x94%2F0x194)%20from%20%5B%26lt%3B8023c004%26gt%3B%5D%20(bust_spinlocks%2B0x24%2F0x4c)%3CBR%20%2F%3E%5B%26lt%3B8023c004%26gt%3B%5D(bust_spinlocks%2B0x24%2F0x4c)%20from%20%5B%26lt%3B800465c0%26gt%3B%5D%20(%E3%83%80%E3%82%A4%2B0xa8%2F0x284)%3CBR%20%2F%3E%5B%26lt%3B800465c0%26gt%3B%5D(%E3%83%80%E3%82%A4%2B0xa8%2F0x284)%20from%20%5B%26lt%3B8051464c%26gt%3B%5D(__do_kernel_fault.part.4%2B0x54%2F0x74)%3CBR%20%2F%3E%5B%26lt%3B8051464c%26gt%3B%5D(__do_kernel_fault.part.4%2B0x54%2F0x74)%5B%26lt%3B8004da68%26gt%3B%5D%E3%81%8B%E3%82%89%20(do_page_fault%2B0x2b4%2F0x31c)%3CBR%20%2F%3E%E3%80%90%26lt%3B8004da68%26gt%3B%E3%80%91(do_page_fault%2B0x2b4%2F0x31c)%20from%20%5B%26lt%3B8003d384%26gt%3B%5D(do_DataAbort%2B0x34%2F0x9c)%3CBR%20%2F%3E%E3%80%90%26lt%3B8003d384%26gt%3B%E3%80%91(do_DataAbort%2B0x34%2F0x9c)%20from%20%5B%26lt%3B80042990%26gt%3B%5D%20(__dabt_svc%2B0x70%2F0xa0)%3CBR%20%2F%3E%E4%BE%8B%E5%A4%96%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF(0xbffb5d80%20%E3%81%8B%E3%82%89%200xbffb5dc8)%3CBR%20%2F%3E5D80%3A%2000000033%2060000193%2080AD329C%2000000000%20FF9F2000%2000000012%2000000001%20FF9F8000%3CBR%20%2F%3E5DA0%3A%20FF9F2000%207F03D544%200000021C%20BA074000%20C097A000%20BFFB5DC8%20800462C4%20800462C8%3CBR%20%2F%3E5DC0%3A%2060000193%20ffffffff%3CBR%20%2F%3E%5B%26lt%3B80042990%26gt%3B%5D(__dabt_svc%2B0x70%2F0xa0)%20from%20%5B%26lt%3B800462c8%26gt%3B%5D%20(__bug%2B0x1c%2F0x28)%3CBR%20%2F%3E%5B%26lt%3B800462c8%26gt%3B%5D%20(__%E3%83%90%E3%82%B0%2B0x1c%2F0x28)%20from%20%5B%26lt%3B8004cb08%26gt%3B%5D%20(___dma_single_cpu_to_dev%2B0x94%2F0xa4)%3CBR%20%2F%3E%E3%80%90%26lt%3B8004cb08%26gt%3B%E3%80%91(___dma_single_cpu_to_dev%2B0x94%2F0xa4)%20from%20%5B%26lt%3B7f0019f8%26gt%3B%5D%20(rtl8168_start_xmit%2B0x514%2F0x6c4%20%5BR8168%5D)%3CBR%20%2F%3E%5B%26lt%3B7f0019f8%26gt%3B%5D(rtl8168_start_xmit%2B0x514%2F0x6c4%20%5BR8168%5D)%20from%20%5B%26lt%3B8042f11c%26gt%3B%5D%20(dev_hard_start_xmit%2B0x2f4%2F0x59c)%3CBR%20%2F%3E%E3%80%90%26lt%3B8042f11c%26gt%3B%E3%80%91(dev_hard_start_xmit%2B0x2f4%2F0x59c)%20from%20%5B%26lt%3B8044a694%26gt%3B%5D%20(sch_direct_xmit%2B0xb0%2F0x1dc)%3CBR%20%2F%3E%5B%26lt%3B8044a694%26gt%3B%5D(sch_direct_xmit%2B0xb0%2F0x1dc)%20from%20%5B%26lt%3B8042f5a0%26gt%3B%5D%20(dev_queue_xmit%2B0x1dc%2F0x60c)%3CBR%20%2F%3E%E3%80%90%26lt%3B8042f5a0%26gt%3B%E3%80%91(dev_queue_xmit%2B0x1dc%2F0x60c)%20from%20%5B%26lt%3B8047d8fc%26gt%3B%5D%20(arp_solicit%2B0xd4%2F0x1b0)%3CBR%20%2F%3E%E3%80%90%26lt%3B8047d8fc%26gt%3B%E3%80%91(arp_solicit%2B0xd4%2F0x1b0)%20from%20%5B%26lt%3B80439558%26gt%3B%5D%20(neigh_timer_handler%2B0x204%2F0x38c)%3CBR%20%2F%3E%5B%26lt%3B80439558%26gt%3B%5D(neigh_timer_handler%2B0x204%2F0x38c)%20from%20%5B%26lt%3B80082f84%26gt%3B%5D%20(run_timer_softirq%2B0xec%2F0x214)%3CBR%20%2F%3E%5B%26lt%3B80082f84%26gt%3B%5D(run_timer_softirq%2B0xec%2F0x214)%20from%20%5B%26lt%3B8007d078%26gt%3B%5D%20(__do_softirq%2B0xac%2F0x140)%3CBR%20%2F%3E%E3%80%90%26lt%3B8007d078%26gt%3B%E3%80%91(__do_softirq%2B0xac%2F0x140)%20from%20%5B%26lt%3B8007d5b4%26gt%3B%5D%20(irq_exit%2B0x94%2F0x9c)%3CBR%20%2F%3E%5B%26lt%3B8007d5b4%26gt%3B%5D(irq_exit%2B0x94%2F0x9c)%20from%20%5B%26lt%3B8003d2e0%26gt%3B%5D%20(do_IPI%2B0x10c%2F0x17c)%3CBR%20%2F%3E%E3%80%90%26lt%3B8003d2e0%26gt%3B%E3%80%91(do_IPI%2B0x10c%2F0x17c)%20from%20%5B%26lt%3B80042a0c%26gt%3B%5D%20(__irq_svc%2B0x4c%2F0xe8)%3CBR%20%2F%3E%E4%BE%8B%E5%A4%96%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF(0xbffb5f90%20%E3%81%8B%E3%82%89%200xbffb5fd8)%3CBR%20%2F%3E5F80%3A%2080B11C40%2080000093%2000000001%2000000000%3CBR%20%2F%3E5FA0%3ABFFB4000%2080B0A744%2080ABBA70%208051D870%2080ABEF0C%20412FC09A%2000000000%2000000000%3CBR%20%2F%3E5FC0%3A%2000000000%20bffb5fd8%2080051e2c%2080043b04%2040000013%20ffffffff%3CBR%20%2F%3E%E3%80%90%26lt%3B80042a0c%26gt%3B%E3%80%91(__irq_svc%2B0x4c%2F0xe8)%20from%20%5B%26lt%3B80043b04%26gt%3B%5D%20(default_idle%2B0x24%2F0x28)%3CBR%20%2F%3E%5B%26lt%3B80043b04%26gt%3B%5D(default_idle%2B0x24%2F0x28)%20from%20%5B%26lt%3B80043d20%26gt%3B%5D%20(cpu_idle%2B0xe0%2F0x124)%3CBR%20%2F%3E%E3%80%90%26lt%3B80043d20%26gt%3B%E3%80%91(cpu_idle%2B0xe0%2F0x124)%20from%20%5B%26lt%3B10511694%26gt%3B%5D%20(0x10511694)%3CBR%20%2F%3Earch%2Farm%2Fplat-mxc%2Fclock.c%3A101%20%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%90%E3%82%B0!%3CBR%20%2F%3E%E4%BB%AE%E6%83%B3%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B900000000%E3%81%A7%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%ABNULL%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%E9%80%86%E5%8F%82%E7%85%A7%E3%82%92%E5%87%A6%E7%90%86%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3EPGD%20%3D%2080004000%3CBR%20%2F%3E%5B00000000%5D%20*pgd%3D00000000%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126670%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126670%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EREF%20CLK%20%E3%81%AF%E5%85%83%E3%81%AE%20imx6%3CSPAN%20class%3D%22SpellE%22%3E%20pcie%3C%2FSPAN%3E%20hw%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%AE%3CSPAN%20class%3D%22SpellE%22%3E%20pll%20%E3%81%8B%E3%82%89%E4%BE%9B%E7%B5%A6%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81HW%20%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AF%E5%BF%85%E9%A0%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%83%AA%E3%83%81%E3%83%A3%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126669%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126669%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frichard.zhu%22%20target%3D%22_blank%22%3Erichard.zhu%3C%2FA%3E%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fkeytwo%22%20target%3D%22_blank%22%3Ekeytwo%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF2%E3%81%A4%E3%81%AESabre_Lite%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E6%A4%9C%E8%A8%BC%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E6%88%90%E5%8A%9F%E8%A3%8F%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81PCIe%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88(Sabre_Lite)%E3%82%92%E4%BB%96%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%83%97%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9(PC%E3%81%AA%E3%81%A9)%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82EP%E3%82%92Sabre_Lite%E4%BB%A5%E5%A4%96%E3%81%AERC%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%8C%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%86%85%E9%83%A8ref%20125Mhz%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPCIe%20%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BFSabre_Lite%E5%85%A5%E5%8A%9B%20CLK%20%E4%BF%A1%E5%8F%B7%E3%81%8C%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81RC%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%20EP%20%E3%81%AB%E6%B8%A1%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%E3%80%8C%E3%81%AF%E3%81%84%E3%80%8D%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E9%98%B2%E3%81%90%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%8F%E3%82%A4%E3%83%80%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126668%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126668%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%9A%3CBR%20%2F%3E%E7%A7%81%E3%81%8C%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81imx6%20%3CSPAN%20class%3D%22SpellE%22%3Epcie%3C%2FSPAN%3E%20%E3%81%AEMAX_PAY_LOAD_SIZE%E3%81%AF128%E3%83%90%E3%82%A4%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E1%20%3CSPAN%20class%3D%22SpellE%22%3Etlp%3C%2FSPAN%3E%20%E3%81%AE%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF%E3%80%81%20%3CSPAN%20class%3D%22SpellE%22%3Epcie%3C%2FSPAN%3E%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%AE%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%90%E3%83%BC%E3%82%B9%E3%83%88%E6%A9%9F%E8%83%BD%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E6%B1%BA%E3%81%BE%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81arm%20core%20%E3%82%92%E3%83%90%E3%82%B9%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81imx6%20%3CSPAN%20class%3D%22SpellE%22%3Epcie%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22SpellE%22%3Eep%3C%2FSPAN%3E%2F%3CSPAN%20class%3D%22SpellE%22%3Erc%3C%2FSPAN%3E%20%E6%A4%9C%E8%A8%BC%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF%2032%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%81%BE%E3%81%9F%E3%80%81IPU(DMA)%E3%82%92%E3%83%90%E3%82%B9%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF64%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%83%AA%E3%83%81%E3%83%A3%E3%83%BC%E3%83%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126667%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126667%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CBR%20%2F%3E%E5%90%8C%E3%81%98%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81imx6%20%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%8B%E3%82%89%E3%83%AB%E3%83%BC%E3%83%88%20%E3%82%B3%E3%83%B3%E3%83%97%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%E3%81%B8%E3%81%AE%20PCIe%20%E3%82%B9%E3%83%AB%E3%83%BC%E3%83%97%E3%83%83%E3%83%88%E3%82%92%E6%A4%9C%E8%A8%BC%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%A2%E3%83%BC%E3%83%A0%E3%82%B3%E3%82%A2%E3%82%92%E3%83%90%E3%82%B9%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81TLP%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E7%9F%A5%E3%82%8A%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%81%95%E3%82%89%E3%81%AB%E9%87%8D%E8%A6%81%E3%81%AA%E3%81%93%E3%81%A8%E3%81%AF%E3%80%81Arm%20Core%E3%81%8C%E4%B8%80%E5%BA%A6%E3%81%AB4%E3%83%90%E3%82%A4%E3%83%88%E3%81%97%E3%81%8B%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AB%E3%80%81tlp%20paload%20size%E3%81%8C%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%B9%E3%83%AB%E3%83%BC%E3%83%97%E3%83%83%E3%83%88%E3%81%AB%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82Arm%20Core%E3%82%92%E3%83%90%E3%82%B9%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%81TLP%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%9232%E3%83%90%E3%82%A4%E3%83%88%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%99%E3%81%8B%3F%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%81TLP%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AB%E9%96%A2%E4%BF%82%E3%81%AA%E3%81%8F%E5%90%8C%E3%81%98%E7%95%AA%E5%8F%B7%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frichard.zhu%22%20target%3D%22_blank%22%3Erichard.zhu%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ei.MX6DL%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%A7%E3%81%93%E3%81%AE%E6%A4%9C%E8%A8%BC%E3%82%92%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%9D%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%BE%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%E7%90%86%E7%94%B1%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%83%AA%E3%83%B3%E3%82%AF%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%9F%E5%BE%8C%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E5%A4%9A%E3%81%8F%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%80%8C%E3%83%A9%E3%83%99%E3%83%AB%E4%BB%98%E3%81%8D%E3%80%8DiMX6Q%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81iMX6DL%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%83%AC%E3%83%93%E3%83%A5%E3%83%BC%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%98%8E%E3%82%89%E3%81%8B%E3%81%AA%E9%96%93%E9%81%95%E3%81%84%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%AE%E9%81%95%E3%81%84%E3%81%AF%E3%80%81iMX6Q%E3%81%BE%E3%81%9F%E3%81%AFiMX6DL%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%87%A6%E7%90%86%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E6%8A%95%E7%A8%BF%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F330406%22%20target%3D%22_blank%22%3Ei.MX6DL%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%A7i.MX6Q%20PCIe%20EP%2FRC%E6%A4%9C%E8%A8%BC%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%86%8D%E7%8F%BE%E3%81%97%E3%81%9F%E4%BA%BA%E3%81%AF%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%82%93%E3%81%AA%E3%83%95%E3%82%A3%E3%83%BC%E3%83%89%E3%83%90%E3%83%83%E3%82%AF%E3%82%82%E5%A4%A7%E6%AD%93%E8%BF%8E%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E6%95%AC%E5%85%B7%3C%2FP%3E%3CP%3EAndreas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126665%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126665%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22font-size%3A%2011.818181991577148px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%E7%8F%BE%E5%9C%A8%E3%80%81Xilinx%20Artix7%20FPGA%E3%81%8B%E3%82%89iMX6%E3%81%AEDDR%E3%81%B8%E3%81%AE%E9%AB%98%E5%B8%AF%E5%9F%9F%E5%B9%85%E3%83%87%E3%83%BC%E3%82%BF%E8%BB%A2%E9%80%81%E3%81%AE%E3%82%A2%E3%83%BC%E3%82%AB%E3%82%A4%E3%83%96%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%88%E3%81%86%E3%82%84%E3%81%8F%E4%BD%95%E3%81%8B%E3%81%8C%E5%8B%95%E3%81%8F%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81i.MX6%E3%81%A7%E3%81%AF%E3%83%87%E3%83%BC%E3%82%BF%E8%BB%A2%E9%80%81%E5%B8%AF%E5%9F%9F%E5%B9%85%E3%81%8C%E6%9C%9F%E5%BE%85%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%BB%E3%81%A9%E8%89%AF%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6FPGA%E5%86%85%E3%81%A7%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%80%81FPGA%E3%82%92%E3%83%90%E3%82%B9%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6iMX6%20RC%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%9C%80%E5%88%9D%E3%81%AB%E8%BB%A2%E9%80%81%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AF%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E6%9C%80%E5%BE%8C%E3%81%AB%E8%BB%A2%E9%80%81%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AF%E3%83%BC%E3%83%89%E3%82%92%E5%B7%AE%E3%81%97%E5%BC%95%E3%81%8F%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E8%BB%A2%E9%80%81%E9%80%9F%E5%BA%A6%E3%82%92%E8%A8%88%E7%AE%97%E3%81%97%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81%E8%A8%88%E7%AE%97%E3%81%AFCPU%E3%81%AE%E9%81%85%E5%BB%B6%E3%81%AB%E4%BE%9D%E5%AD%98%E3%81%97%E3%81%AA%E3%81%84%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%E7%8F%BE%E5%9C%A8%E3%80%81%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%80%A4%E3%82%92%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%20FPGA%20%E3%81%AE%20PCIe%20%E3%82%B3%E3%82%A2%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E4%B8%80%E9%83%A8%E3%81%AE%E7%B2%BE%E5%BA%A6%E3%81%8C%E5%A4%B1%E3%82%8F%E3%82%8C%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82chipscope%E3%81%A7%E3%82%8F%E3%81%8B%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81iMX6%E3%81%AF128%E3%83%90%E3%82%A4%E3%83%88%E5%BE%8C%E3%81%ABPCIe%E3%83%90%E3%82%B9%E3%81%AB%E5%B8%B8%E3%81%AB%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99(%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%83%9A%E3%82%A4%E3%83%AD%E3%83%BC%E3%83%89%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AE%E5%88%B6%E9%99%90)%E3%81%8C%E3%80%81%E7%B4%842048%E3%83%90%E3%82%A4%E3%83%88%E4%BB%A5%E9%99%8D%E3%81%ABiMX6%E3%81%AEDDR%E3%81%A7%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AF%E3%83%BC%E3%83%89%E3%81%AB%E3%82%AE%E3%83%A3%E3%83%83%E3%83%97%E3%81%8C%E8%A6%8B%E3%82%89%E3%82%8C%E3%82%8B%E3%81%A0%E3%81%91%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81Xilinx%20PCIe%E3%82%B3%E3%82%A2%E3%81%AB%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E5%80%A4%E3%81%8C%E5%AE%9F%E9%9A%9B%E3%81%AEPCIe%E3%83%87%E3%83%BC%E3%82%BF%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%A8%E5%90%8C%E6%9C%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E5%B8%AF%E5%9F%9F%E5%B9%85%E9%80%9F%E5%BA%A6%E3%81%AE%E5%85%A8%E4%BD%93%E7%9A%84%E3%81%AA%E8%A8%88%E7%AE%97%E3%81%AB%E5%A4%A7%E3%81%8D%E3%81%AA%E5%BD%B1%E9%9F%BF%E3%82%92%E4%B8%8E%E3%81%88%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2011.818181991577148px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2011.818181991577148px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%E3%81%9D%E3%82%8C%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81512KByte%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92FPGA%E3%81%8B%E3%82%89i.MX6%E3%81%AB%E8%BB%A2%E9%80%81%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81PCIe%202.0%E3%83%AC%E3%83%BC%E3%83%B3%E3%81%8C1%E3%81%A4%E3%81%82%E3%82%8Bx86%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E3%81%AF~400MB%2Fs%E3%81%A7%E3%81%82%E3%82%8B%E3%81%AE%E3%81%AB%E5%AF%BE%E3%81%97%E3%80%81270MB%2Fs%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%20%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2011.818181991577148px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%20background-color%3A%20%23f6f6f6%3B%22%3Ei.MX6%E3%81%AE%E6%9C%80%E5%A4%A7%E3%83%9A%E3%82%A4%E3%83%AD%E3%83%BC%E3%83%89%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C128%E3%83%90%E3%82%A4%E3%83%88%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E9%99%A4%E3%81%84%E3%81%A6%E3%80%81%E8%BB%A2%E9%80%81%E9%80%9F%E5%BA%A6%E3%81%8C%E3%81%9D%E3%82%8C%E3%81%BB%E3%81%A9%E4%BD%8E%E3%81%84%E3%81%A8%E3%81%84%E3%81%86%E6%98%8E%E7%A2%BA%E3%81%AA%E7%90%86%E7%94%B1%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3FFPGA%E3%81%AE%E6%9C%80%E5%A4%A7%E3%83%9A%E3%82%A4%E3%83%AD%E3%83%BC%E3%83%89%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF%E7%8F%BE%E5%9C%A8256%E3%83%90%E3%82%A4%E3%83%88%E3%81%AB%E5%88%B6%E9%99%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81x86%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%97%E3%81%A6%E3%81%9D%E3%82%8C%E3%81%BB%E3%81%A9%E5%A4%A7%E3%81%8D%E3%81%AA%E5%BD%B1%E9%9F%BF%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-size%3A%2011.818181991577148px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E6%9C%80%E5%A4%A7%E3%81%A7344MB%20%2F%20s%E3%81%AB%E3%81%97%E3%81%8B%E9%81%94%E3%81%97%E3%81%AA%E3%81%84%E7%90%86%E7%94%B1%E3%82%82%E7%96%91%E5%95%8F%E3%81%AB%E6%80%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82PCIe%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AF%E3%82%82%E3%81%86%E5%B0%91%E3%81%97%E9%AB%98%E3%81%84%E5%B8%AF%E5%9F%9F%E5%B9%85%E3%82%92%E8%A8%B1%E5%8F%AF%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%88%A5%E3%81%AE%E8%B3%AA%E5%95%8F%3APCIe%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92EP%E3%81%8B%E3%82%89RC%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AE%E4%BE%8B%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3FiATU%E3%81%A7%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E8%A8%AD%E5%AE%9A%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E4%BB%8A%E3%81%AE%E3%81%A8%E3%81%93%E3%82%8D%E7%B5%90%E6%9E%9C%E3%81%AF%E5%87%BA%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BD%95%E3%81%8B%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E5%AE%8C%E7%92%A7%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A1%E3%82%87%E3%81%A3%E3%81%A8%E3%81%97%E3%81%9F%E8%B3%AA%E5%95%8F%3ABAR0%E3%81%A74K%20IO%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81RC%E3%81%AE0x1E00000%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%A7%E3%81%84%E3%81%84%E3%82%93%E3%81%A7%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E8%87%AA%E4%BD%93%E3%81%8B%E3%82%89IO%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%82%92%E8%AA%AD%E3%81%BF%E6%9B%B8%E3%81%8D%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%3F%E3%81%A9%E3%81%93%E3%81%A7%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126662%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126662%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%3A%3C%2FP%3E%3CP%3EImx%20PCIe%E3%81%AF%E3%80%81%E5%BF%9C%E7%AD%94SW%E3%81%AE%E5%A4%89%E6%9B%B4%E5%BE%8C%E3%81%AB%E3%80%81%E5%A4%96%E9%83%A8100m%E5%8F%82%E7%85%A7clk%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%A4%89%E6%9B%B4%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AE%E5%A4%96%E9%83%A8OSC%E4%BD%BF%E7%94%A8%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%E3%82%92%E5%8F%82%E7%85%A7%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%81%E3%83%A3%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EHuawei%20Mobile%E3%81%8B%E3%82%89%E9%80%81%E4%BF%A1%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ealeksandr%20Muraviov%20%3CADMIN%3E%E7%BC%96%E5%86%99%EF%BC%9A%3C%2FADMIN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26lt%3B%26gt%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ei.MX6Q%20PCIe%20EP%2FRC%E6%A4%9C%E8%A8%BC%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%20by%20aleksandr%20Muraviov%26lt%3B%26gt%3B%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%26lt%3B%26gt%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126661%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126661%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EPC%E3%81%8B%E3%82%89%E3%81%AEPCIe%E3%81%AF%E5%B8%B8%E3%81%ABCLK%E4%BF%A1%E5%8F%B7%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E5%BF%85%E9%A0%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EEP%20%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%20CLK%20%E4%BF%A1%E5%8F%B7%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%E5%86%85%E9%83%A8%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%208b10b%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%83%AA%E3%82%AB%E3%83%90%E3%83%AA%E3%82%92%E3%83%AA%E3%83%AC%E3%83%BC%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EMX6Q%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E7%8F%BE%E5%9C%A8%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AB%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AA%E3%83%A1%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%A7%E3%81%AF%E3%80%81%E5%86%85%E9%83%A8%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EMX6%E3%81%AB%E5%A4%96%E9%83%A8%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF(PC%E3%81%8B%E3%82%89)%E3%82%92%E4%B8%8E%E3%81%88%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E5%A4%96%E9%83%A8%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AB%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%22%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3Ewhile(true)%20%3B%20do%20sleep%201%20%3B%20.%2Fmemtool%20-32%2001ffc72c%201%20%7C%20grep%20-v%20add%20%7C%20grep%200x%3B%20done%3C%2FSPAN%3E%22%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%80%81%E5%BE%97%E3%82%89%E3%82%8C%E3%82%8B%E5%80%A4%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%80%8CXXXXXX1X%E3%80%8D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%82%E3%81%AE%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%80%8CXXXXXX0X%E3%80%8D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%82%E3%81%AE%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AF%E3%83%80%E3%82%A6%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126660%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126660%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20_jive_internal%3D%22true%22%20data-avatarid%3D%221013%22%20data-externalid%3D%22%22%20data-online%3D%22false%22%20data-presence%3D%22null%22%20data-userid%3D%22207066%22%20data-username%3D%22richard.zhu%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frichard.zhu%22%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2012px%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%238b8b8b%3B%20background-color%3A%20%23f6f6f6%3B%22%20target%3D%22_blank%22%3EHongxing%20Zhu%3C%2FA%3E%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPC%E3%81%8C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%A7%E5%BF%85%E8%A6%81%E3%81%AALVDS%E5%B7%AE%E5%88%86%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3EPC%E3%81%AB%E3%81%93%E3%81%AE%E4%BF%A1%E5%8F%B7%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3FPC%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A1%E3%83%8B%E3%83%A5%E3%83%BC%E8%A8%AD%E5%AE%9A%E3%81%AB%E9%96%A2%E4%BF%82%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frichard.zhu%22%20target%3D%22_blank%22%3Erichard.zhu%3C%2FA%3E%2C%3C%2FP%3E%3CP%3EEP%E3%81%A8RC%E3%81%8C%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%82%92%E5%86%85%E9%83%A8%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81PC%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81RC%E3%81%A8%E3%81%97%E3%81%A6%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8BPC%E3%81%8CEP(%E3%81%93%E3%81%93%E3%81%A7%E3%81%AFimx)%E3%81%ABCLK%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%93%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AF%E6%A8%99%E6%BA%96%E3%81%A7100Mhz%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82(%E7%A7%81%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E9%99%90%E3%82%8A%3F%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%81%93%E3%81%93%E3%81%A7%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81IMX%20%E3%81%8C%20125Mhz%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81TX%2FRX%20%E3%81%AE%E3%81%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81100Mhz%20%E3%81%AE%20RC%20%E3%81%8B%E3%82%89%E3%81%AE%20CLK%20%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%81%A9%E3%81%86%E3%81%AA%E3%82%8B%E3%81%AE%3F%20%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%8C1%E5%8F%B0%E3%81%AEPC%E3%81%A7%E3%81%97%E3%81%8B%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%AA%E3%81%84%E7%90%86%E7%94%B1%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126658%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126658%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%82%AD%E3%83%BC2%3A%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AEPC%E3%81%AE1%E3%81%A4%E3%81%A7imx%20ep%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AE%E3%81%AF%E7%B4%A0%E6%99%B4%E3%82%89%E3%81%97%E3%81%84%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E6%9C%80%E8%BF%91%E3%81%AF%E5%86%85%E9%83%A8%E3%81%AE%E9%87%8D%E8%A6%81%E3%81%AA%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%A7%E5%BF%99%E3%81%97%E3%81%8F%E3%80%81%E3%81%93%E3%81%93%E3%81%A7%E3%81%82%E3%81%BE%E3%82%8A%E6%99%82%E9%96%93%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EImx6q%20PCIe%E3%81%AF%E3%80%81%E5%86%85%E9%83%A8%E5%8F%82%E7%85%A7clk%E3%81%A8%E3%81%97%E3%81%A6125MHz%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E3%80%81%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%A2%E3%83%AD%E3%83%B3%E3%81%AE%20ref%20clk%20%E3%81%8C%20ep%20%E3%81%A8%20rc%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%81%84%E3%81%A4%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%81%8B%E3%81%AF%E9%96%A2%E4%BF%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%88%A5%E3%81%AE%20ref%20clk%20%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%82%E3%82%8B%20imx6q%20pcie%20ep%20%E3%81%AF%E3%80%81%E7%90%86%E8%AB%96%E7%9A%84%E3%81%AB%E3%81%AF%20pc%20pcie%20rc%20%E3%81%8C%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%20100m%20clk%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%A7100m%E3%81%AE%E5%A4%96%E9%83%A8OSC%E3%81%8C%E5%AE%9F%E8%A3%85%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%E3%82%92%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%81%E3%83%A3%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%202013-11-28%EF%BC%8C%E4%B8%8B%E5%8D%886%3A38%EF%BC%8C%22key%20two%22%20%3CADMIN%3E%26gt%3B%20%E5%86%99%E9%81%93%EF%BC%9A%3C%2FADMIN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26lt%3B%26gt%3B%3C%2FP%3E%3CP%3E%26lt%3B%26gt%3B%3C%2FP%3E%3CP%3Ei.MX6Q%20PCIe%20EP%2FRC%E6%A4%9C%E8%A8%BC%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EKey%20Two%E3%81%AB%E3%82%88%E3%82%8B%E6%96%B0%E3%81%97%E3%81%84%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%26lt%3B%26gt%3B%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%26lt%3B%26gt%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126657%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126657%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%A2%E3%83%83%E3%83%97%E3%83%AA%E3%83%B3%E3%82%AF%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E3%81%97%E3%81%B0%E3%82%89%E3%81%8F%E3%83%AB%E3%83%BC%E3%83%97%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E5%A4%B1%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E3%81%A5%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%93%E3%81%A7%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AE%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%83%88%E3%83%A9%E3%83%83%E3%82%AF%E3%82%92%E4%BA%92%E3%81%84%E3%81%AB%E9%9A%A3%E6%8E%A5%E3%81%95%E3%81%9B%E3%81%A6%E9%85%8D%E7%BD%AE%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81TX%20%2F%20RX%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E8%BF%91%E6%8E%A5%E6%80%A7%E3%82%92%E5%B0%8A%E9%87%8D%E3%81%99%E3%82%8B%E6%96%B0%E3%81%97%E3%81%84%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image%20(2).jpeg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image%20(2).jpeg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F42393i9068253606BDD390%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22image%20(2).jpeg%22%20alt%3D%22image%20(2).jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%A0%E3%81%8B%E3%82%89%E3%80%81%E7%89%87%E5%81%B4%E3%81%A7%E3%81%AFSABRE%20Lite%20J23%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%81%8B%E3%82%89%E7%A7%81%E3%81%AE%E5%B0%8F%E3%81%95%E3%81%AA%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%83%BC%E3%81%AB%E6%9D%A5%E3%81%A6%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AFKZ-B21(%3CA%20href%3D%22http%3A%2F%2Fwww.bplus.com.tw%2FExtenderBoard%2FKZ-B21.html)%E3%81%AB%E8%A1%8C%E3%81%8D%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.bplus.com.tw%2FExtenderBoard%2FKZ-B21.html)%E3%81%AB%E8%A1%8C%E3%81%8D%3C%2FA%3E%3CA%20href%3D%22http%3A%2F%2Fwww.bplus.com.tw%2FExtenderBoard%2FKZ-B21.html%22%20title%3D%22http%3A%2F%2Fwww.bplus.com.tw%2FExtenderBoard%2FKZ-B21.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%81%BE%E3%81%99%3C%2FA%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%82%8C%E3%82%92%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AEPC%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A1%E3%81%AE1%E3%81%A4(1%E3%81%A4%E3%81%A0%E3%81%91)%E3%81%A7%E3%80%8Clspci%E3%80%8D%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E7%A7%81%E3%81%AEdead%3Abeaf%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8CRAM%20PCIe%E3%82%AB%E3%83%BC%E3%83%89%E3%81%A8%E3%81%97%E3%81%A6%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%BB%E3%82%A4%E3%83%90%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AFUP%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%A7%E3%81%99(0x00000310)%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E6%9C%AC%E5%BD%93%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%A0%E3%81%A3%E3%81%9F%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%A0PC%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%8C%E8%AA%AD%E3%82%81%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C100Mhz%E3%81%BE%E3%81%9F%E3%81%AF125Mhz%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%AA%E3%81%84%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E3%81%BE%E3%81%A0%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%A7%81%E3%81%8C%E7%A2%BA%E5%AE%9F%E3%81%AB%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AF%E3%80%81%E5%88%A5%E3%81%AEPC%E3%81%A7%E3%81%AF%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%8CUP%E3%81%A8Down%E3%82%92%E3%83%8E%E3%83%B3%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%81%A7%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%81%A0%E3%81%8B%E3%82%89%E3%80%81%E7%A7%81%E3%81%AF%E3%81%BE%E3%81%A0%E6%99%82%E8%A8%88%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%AA%E3%81%84%E3%81%AE%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%96%91%E5%95%8F%E3%81%AB%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frichard.zhu%22%20target%3D%22_blank%22%3E%E3%81%9F%E3%81%B6%E3%82%93richard.zhu%3C%2FA%3E%E3%81%AF%E3%81%9D%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%82%82%E3%81%A3%E3%81%A8%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%82%8C%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%3F%E7%A7%81%E3%81%8C%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AF%E3%80%81%E4%B8%80%E9%83%A8%E3%81%AE%20EP%20%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AA%E3%83%A1%E3%83%B3%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%E3%80%81%E5%85%A5%E5%8A%9B%E3%81%AE%20LVDS%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%20CLK1%20%E3%81%8C%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E5%A4%96%E9%83%A8%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%82%8F%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Faleksandrmuraviov%22%20target%3D%22_blank%22%3Ealeksandrmuraviov%3C%2FA%3E%E3%81%AE%E6%99%82%E7%82%B9%E3%81%A7%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%A9%B3%E3%81%97%E3%81%8F%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F(%E3%81%A8%E3%81%93%E3%82%8D%E3%81%A7%E3%80%81%E3%81%93%E3%81%93%E3%81%AB%E5%86%99%E7%9C%9F%E3%82%92%E6%8A%95%E7%A8%BF%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%83%89%E3%83%A9%E3%83%83%E3%82%B0%E3%82%A2%E3%83%B3%E3%83%89%E3%83%89%E3%83%AD%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126656%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126656%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fkeytwo%22%20target%3D%22_blank%22%3Ekeytwo%3C%2FA%3E%E3%81%A4%E3%81%BE%E3%82%8A%20-%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-98614%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-98614%3C%2FA%3E%3C%2FP%3E%3CP%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%81%93%E3%81%93%E3%81%AB%E7%94%BB%E5%83%8F%E3%82%92%E8%B2%BC%E3%82%8A%E4%BB%98%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%8C%E6%9B%B8%E3%81%84%E3%81%A6%E3%81%84%E3%82%8B%E7%8A%B6%E6%B3%81%E3%81%AF%E3%80%81%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%83%BC%E3%81%AB%E3%83%94%E3%83%B3%E3%82%AF%E3%81%A8%E3%82%AA%E3%83%AC%E3%83%B3%E3%82%B8%E3%81%AE%E3%83%97%E3%83%A9%E3%82%B0%E3%81%8C%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%99%82%E8%A8%88%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E4%BB%8A%E3%81%A7%E3%81%AF%E3%83%AB%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%83%97%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%E3%81%8B%E3%82%89%E3%81%AE%E4%BF%A1%E5%8F%B7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E3%81%8C%E3%80%8CPCIe%20EP%3A%20waiting%20for%20link%20up...%22.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126655%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126655%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ememtool%E3%81%A7%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%22while(true)%20%3Bdo%20sleep%201%20%3B%20.%2Fmemtool%E2%97%8F32%2001ffc72c%201%20%7Cgrep%20-v%20%E8%BF%BD%E5%8A%A0%20%7Cgrep%200x%3B%E7%B5%82%E3%82%8F%E3%82%8A%22%3C%2FP%3E%3CP%3E%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E3%80%814%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%E3%81%AF1%E3%81%8B%E3%82%890%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%82%8F%E3%82%8A%E3%80%81%E3%81%95%E3%82%89%E3%81%AB1%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%82%8F%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A0%E3%81%8B%E3%82%89%E3%80%81%E7%A7%81%E3%81%AE%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AB%E4%BD%95%E3%81%8B%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81%E9%80%9A%E5%B8%B8%E3%81%AEPCI%E3%83%90%E3%82%B9%E3%81%8C100Mhz%E3%81%A7%E5%90%8C%E6%9C%9F%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AB%E5%AF%BE%E3%81%97%E3%80%81%E7%A7%81%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF125Mhz%E3%81%A7%E5%90%8C%E6%9C%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E5%90%8C%E6%9C%9F%E3%81%8C%E8%A7%A3%E9%99%A4%E3%81%95%E3%82%8C%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%8C%E3%83%80%E3%82%A6%E3%83%B3%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frichard.zhu%22%20target%3D%22_blank%22%3Erichard.zhu125Mhz%3C%2FA%3E%20%E3%81%BE%E3%81%9F%E3%81%AF100Mhz%E3%81%AE%E3%81%A9%E3%81%A1%E3%82%89%E3%81%AB%E3%81%84%E3%82%8B%E3%81%8B%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%93%E3%81%A8%E3%81%AB%E3%80%812%E3%81%A4%E3%81%AESabre%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E9%80%9A%E5%B8%B8%E3%81%AEPC%E3%81%A7%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92EP%E3%81%AB%E5%A4%89%E3%81%88%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AE%E3%83%87%E3%83%A2%E3%83%B3%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Faleksandrmuraviov%22%20target%3D%22_blank%22%3Ealeksandrmuraviov%3C%2FA%3E%3A%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%AE%E5%86%99%E7%9C%9F%E3%82%92%E6%8A%95%E7%A8%BF%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E7%A7%81%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81%E7%89%87%E9%9D%A2PCB%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81TX%2B%2FTX-%E4%BF%A1%E5%8F%B7%E3%81%8C%E6%95%B0%E3%82%BB%E3%83%B3%E3%83%81%E5%88%86%E9%9B%A2%E3%81%95%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%84%E7%90%86%E7%94%B1%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126654%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126654%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%80%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fkeytwo%22%20target%3D%22_blank%22%3Ekeytwo%3C%2FA%3E%E3%80%8D%E3%81%A8%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%9F%AD%E3%81%84%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AF%E3%80%81%20%22PCIE%3A%20Waiting%20for%20link%20up...%22%20(%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%82%E3%81%AE)%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%8F%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%AB%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%83%97%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AB%E3%80%8Cdead_beaf%E3%80%8D%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFPC%E3%82%92%E3%83%AB%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%83%97%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%E5%81%B4%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CSTRONG%3E%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%3C%2FSTRONG%3E%20%E3%80%81%E3%80%8C%E9%80%9A%E5%B8%B8%E3%81%AELinux%203.11%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E9%80%9A%E5%B8%B8%E3%81%AEPC%E3%81%A7%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92EP%E3%81%A8%E3%81%97%E3%81%A6%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%80%8D%E3%81%A7%E3%81%99%E3%80%82%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E3%82%82%E3%81%86%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126653%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126653%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E7%AD%94%E3%81%88%E3%81%AE%E3%81%9F%E3%82%81%E3%81%ABthx%E3%80%82%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%E3%82%82%E3%81%A3%E3%81%A8%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3A%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%8CUP%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E8%A8%80%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E6%9C%AC%E5%BD%93%E3%81%ABUP%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%81RX%E3%83%91%E3%82%B9%E3%81%AB%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E9%9B%BB%E6%B0%97%E7%9A%84%E6%B4%BB%E5%8B%95%E3%81%8C%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF100Mhz%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F125Mhz%E3%81%AB%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99(%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F)%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81PC%E3%81%AE%E5%86%85%E9%83%A8%E3%81%AB%E6%8C%BF%E5%85%A5%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81PC%E3%81%AE%E3%83%90%E3%82%B9%E3%81%AE%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AF100Mhz%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81PC%E5%81%B4%E3%81%A7%E3%81%AF%E3%80%81%E3%80%8Clspci%E3%80%8D%E3%82%92%E7%99%BA%E8%A1%8C%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8BPCI%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%8C%E8%A6%8B%E5%BD%93%E3%81%9F%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%A7%E3%81%AF%E3%80%81EP%E7%94%A8%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%A8%E3%80%8C%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%8D%E3%81%AF%E3%80%81%E5%8F%8D%E5%AF%BE%E5%81%B4%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E8%A6%8B%E3%82%89%E3%82%8C%E3%82%8B%E3%83%93%E3%83%BC%E3%82%A4%E3%83%B3%E3%82%B0%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126652%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126652%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3EHi%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%81%86%E3%82%8F%E3%83%BC%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E9%A9%9A%E3%81%8F%E3%81%B9%E3%81%8D%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%81%20%3CSPAN%20class%3D%22SpellE%22%3Epcie%3C%2FSPAN%3E%20%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AF%E3%81%BE%E3%81%A0%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%81%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%81%AE%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AEHW%E3%81%AE%E5%B0%91%E3%81%97%E9%95%B7%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%8C%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF1(0x01ff_c72c)%E3%81%AE%E3%83%93%E3%83%83%E3%83%884%E3%82%92%E5%86%8D%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%80%81%E3%81%93%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8C%E3%81%B0%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%8C%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%83%AA%E3%83%81%E3%83%A3%E3%83%BC%E3%83%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126651%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126651%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%83%AA%E3%83%81%E3%83%A3%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3EIMX6Q%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FSabrelite%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92PCIeEP%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EPCIe%E3%83%9D%E3%83%BC%E3%83%88(j23)%E3%81%8B%E3%82%89%E3%83%A2%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%81%8C%E3%81%82%E3%82%8B%E5%B0%8F%E3%81%95%E3%81%AA%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%A4%E3%81%AA%E3%81%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8BPCIe%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81FPC%20Flex%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%81%8B%E3%82%89PCIe%E3%82%B4%E3%83%BC%E3%83%AB%E3%83%89%E3%83%95%E3%82%A3%E3%83%B3%E3%82%AC%E3%83%BC%E3%81%BE%E3%81%A7%E3%83%AB%E3%83%BC%E3%83%88%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%AC%E3%82%A4%E3%82%B6%E3%83%BC%E3%81%AE1%E3%81%A4%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%EF%BC%9A%20%3CA%20href%3D%22http%3A%2F%2Fwww.bplustech.com%2FKZ%2FKZ-B21.html%22%20title%3D%22http%3A%2F%2Fwww.bplustech.com%2FKZ%2FKZ-B21.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.bplustech.com%2FKZ%2FKZ-B21.html%3C%2FA%3E%20%E3%81%93%E3%81%AE%E3%83%AC%E3%82%A4%E3%82%B6%E3%83%BC%E3%81%AE%E6%A6%82%E7%95%A5%E5%9B%B3%E3%81%AF%E3%81%93%E3%81%93%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%20%3CA%20href%3D%22http%3A%2F%2Fwww.bplus.com.tw%2FPDF%2FKZ-B21_VER1_0_20130118A.pdf%22%20title%3D%22http%3A%2F%2Fwww.bplus.com.tw%2FPDF%2FKZ-B21_VER1_0_20130118A.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%EF%BC%9Ahttp%3A%2F%2Fwww.bplus.com.tw%2FPDF%2FKZ-B21_VER1_0_20130118A.pdf%3C%2FA%3E%3C%2FP%3E%3CP%3E%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AB%E3%81%AF%E3%80%81PCIe%20Goldfinger%20%E3%81%AE%E9%83%A8%E5%88%86%E3%81%AB%20PRSNT1%23%20--%20PRSNT2%23%20%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%80%81%E3%83%9B%E3%82%B9%E3%83%88%20PC%20%E3%81%AB%20x1%20pcie%20%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E4%BC%9D%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E5%86%8D%E9%96%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EGND%20--%26nbsp%3B%20GND%3C%2FP%3E%3CP%3ETXP%20--%20RXP%3C%2FP%3E%3CP%3ETXM%20--%20RXM%3C%2FP%3E%3CP%3ERXP%20--%20TXP%3C%2FP%3E%3CP%3ERXM%20--%20TXM%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image%20(1).jpeg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image%20(1).jpeg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F41453iBEAB397888E054DA%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22image%20(1).jpeg%22%20alt%3D%22image%20(1).jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E(%3CA%20href%3D%22http%3A%2F%2Fwhatsphere.com%2Fpcie.jpeg%22%20title%3D%22http%3A%2F%2Fwhatsphere.com%2Fpcie.jpeg%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwhatsphere.com%2Fpcie.jpeg%3C%2FA%3E)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8CBOOT%E3%81%AE%E3%83%93%E3%83%A5%E3%83%BC%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD%E2%80%A6%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELinux%E3%81%AE%E8%A7%A3%E5%87%8D...%E5%AE%8C%E4%BA%86%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E3%83%96%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5DLinux%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B33.0.35-2508-g54750ff(xavier%40ubuntu)(GCC%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B34.6.220110630%20(%E3%83%97%E3%83%AC%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9)%20(Freescale%20MAD%20--%20Linaro%202011.07%20--%20Built%20at%202011%2F08%2F10%2009%3A20)%20)%20%2324%20SMP%20PREEMPT%2011%2F3%20(%E6%97%A5)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5DCPU%3A%20ARMv7%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20%5B412fc09a%5D%20%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%2010%20(ARMv7)%E3%80%81cr%3D10c53c7d%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5DCPU%3A%20VIPT%20%E9%9D%9E%E3%82%A8%E3%82%A4%E3%83%AA%E3%82%A2%E3%82%B7%E3%83%B3%E3%82%B0%20%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%80%81VIPT%20%E3%82%A8%E3%82%A4%E3%83%AA%E3%82%A2%E3%82%B7%E3%83%B3%E3%82%B0%E5%91%BD%E4%BB%A4%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%E3%83%9E%E3%82%B7%E3%83%B3%3AFreescale%20i.MX%206Quad%20Sabre-Lite%E3%83%9C%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%9D%E3%83%AA%E3%82%B7%E3%83%BC%3A%20ECC%20%E3%81%8C%E7%84%A1%E5%8A%B9%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20writealloc%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5DCPU%20%E3%81%AF%20i.MX6Q%E3%80%81%E3%82%B7%E3%83%AA%E3%82%B3%E3%83%B3%20rev%201.2%20%E3%81%A8%E8%AD%98%E5%88%A5%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5DPERCPU%3A%E5%9F%8B%E3%82%81%E8%BE%BC%E3%81%BF7%E3%83%9A%E3%83%BC%E3%82%B8%2F%20CPU%20%408c008000%20s5440%20r8192%20d15040%20u32768%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%E3%82%BE%E3%83%BC%E3%83%B3%E9%A0%86%E3%81%AB1%E3%81%A4%E3%81%AE%E3%82%BE%E3%83%BC%E3%83%B3%E3%83%AA%E3%82%B9%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%83%A2%E3%83%93%E3%83%AA%E3%83%86%E3%82%A3%E3%81%AE%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E5%8C%96%E3%82%92%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%B7%8F%E3%83%9A%E3%83%BC%E3%82%B8%E6%95%B0%3A227328%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%3A%20enable_wait_mode%3Doff%20video%3Dmxcfb0%3Aoff%20video%3Dmxcfb1%3Aoff%20video%3Dmxcfb2%3Aoff%20console%3Dttymxc1%2C115200%20vmalloc%3D400M%20consoleblank%3D0%20rootwait%20root%3D%2Fdev%2Fmmcblk0p1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5DPID%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%204096%20(%E9%A0%86%E5%BA%8F%3A%202%E3%80%8116384%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5DDentry%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20131072%20(%E9%A0%86%E5%BA%8F%3A%207%E3%80%81524288%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5Dinode-cache%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%2065536%20(%E9%A0%86%E5%BA%8F%3A%206%E3%80%81262144%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%E3%83%A1%E3%83%A2%E3%83%AA%3A640MB%20256MB%20%3D%20%E5%90%88%E8%A8%88896MB%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%E3%83%A1%E3%83%A2%E3%83%AA%3A896756k%20%2F%20896756k%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%80%81151820k%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF%E3%80%810K%E9%AB%98%E3%83%A1%E3%83%A2%E3%83%AA%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%E4%BB%AE%E6%83%B3%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%3A%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%E3%83%99%E3%82%AF%E3%82%BF%E3%83%BC%20%3A%200xffff0000%20-%200xffff1000%20(%204%20kB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20fixmap%26nbsp%3B%20%3A%200xfff00000%20-%200xfffe0000%26nbsp%3B%26nbsp%3B%20(%20896%20kB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5DDMA%20%3A%200xf4600000%20-%200xffe00000%20(%20184%20MB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vmalloc%20%3A%200xc0800000%20-%200xf2000000%26nbsp%3B%26nbsp%3B%20(%20792%20MB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5Dlowmem%20%3A%200x80000000%20-%200xc0000000%20(1024%20MB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pkmap%26nbsp%3B%26nbsp%3B%20%3A%200x7fe00000%20-%200x80000000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%26nbsp%3B%202%20MB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20%3A%200x7f000000%20-%200x7fe00000%20(%2014%20MB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.init%20%3A%200x80008000%20-%200x8003b000%26nbsp%3B%26nbsp%3B%20(%20204%20kB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.text%20%3A%200x8003b000%20-%200x80aa62cc%26nbsp%3B%26nbsp%3B%20(10669%20kB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%E3%80%82%E3%83%87%E3%83%BC%E3%82%BF%3A%200x80aa8000%20-%200x80b072c0%20(%20381%20kB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.bss%20%3A%200x80b072e4%20-%200x80b556ac%26nbsp%3B%26nbsp%3B%20(%20313%20kB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5DSLUB%3A%20Genslabs%3D13%2C%20HWalign%3D32%2C%20Order%3D0-3%2C%20MinObjects%3D0%2C%20CPUs%3D4%2C%20Nodes%3D1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%E3%83%97%E3%83%AA%E3%82%A8%E3%83%B3%E3%83%97%E3%83%86%E3%82%A3%E3%83%96%E3%81%AA%E9%9A%8E%E5%B1%A4%E5%9E%8B%20RCU%20%E3%81%AE%E5%AE%9F%E8%A3%85%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20NR_IRQS%3A624%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5DMXC%20GPIO%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5Dsched_clock%3A3000kHz%E3%81%A732%E3%83%93%E3%83%83%E3%83%88%E3%80%81%E8%A7%A3%E5%83%8F%E5%BA%A6333ns%E3%80%811431655ms%E3%81%94%E3%81%A8%E3%81%AB%E3%83%A9%E3%83%83%E3%83%97%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20arm_max_freq%3D1GHz%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5DMMIO%200x21e8000%20%E3%81%AE%20MXC_Early%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20(%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%20'115200')%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%E3%83%96%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20%5Bttymxc1%5D%20%E6%9C%89%E5%8A%B9%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%3A%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%80%E3%83%9F%E3%83%BC%E3%83%87%E3%83%90%E3%82%A4%E3%82%B980x30%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.224540%5D%E9%81%85%E5%BB%B6%E3%83%AB%E3%83%BC%E3%83%97%E3%82%92%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...1581.05%20BogoMIPS(lpj%20%3D%207905280)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.312867%5Dpid_max%3A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%3A%2032768%20%E6%9C%80%E5%B0%8F%3A%20301%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.317802%5D%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%83%BB%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%83%BC%E6%95%B0%3A%20512%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.323097%5DCPU%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE%E3%82%B3%E3%83%92%E3%83%BC%E3%83%AC%E3%83%B3%E3%82%B7%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%3AOK%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.328254%5Dhw%20perfevents%3A%20ARMv7%20Cortex-A9%20PMU%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%A7%E6%9C%89%E5%8A%B9%E3%80%817%20%E3%81%A4%E3%81%AE%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.428774%5DCPU1%3A%E8%B5%B7%E5%8B%95%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.508778%5DCPU2%3A%E8%B5%B7%E5%8B%95%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.588792%5DCPU3%3A%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.628290%5D4%E3%81%A4%E3%81%AECPU%E3%82%92%E8%82%B2%E3%81%A6%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.644115%5DSMP%3A%E5%90%88%E8%A8%884%E3%81%A4%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%8C%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F(6324.22%20BogoMIPS)%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.667822%5Dprint_constraints%3A%E3%83%80%E3%83%9F%E3%83%BC%3A%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.671823%5DNET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2016%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.680477%5Dprint_constraints%3Avddpu%3A725%20%26lt%3B--%26gt%3B%201150%20mV%E3%81%AE%E9%80%9F%E3%81%84%E6%AD%A3%E5%B8%B8%E3%81%AA1300%20mV%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.688013%5Dprint_constraints%3A%20vddcore%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20at%201150%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.695751%5Dprint_constraints%3Avddsoc%3A725%26lt%3B--%26gt%3B%201300%20mV%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.703438%5Dprint_constraints%3A%20vdd2p5%3A%202000%20%26lt%3B--%26gt%3B%202400%20mV%20%E3%81%A7%202775%20mV%20%E9%AB%98%E9%80%9F%E3%83%8E%E3%83%BC%E3%83%9E%E3%83%AB%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.711197%5Dprint_constraints%3Avdd1p1%3A800%26lt%3B--%26gt%3B%201400%20mV%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.718839%5Dprint_constraints%3Avdd3p0%3A2625%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.727742%5D**%E3%83%87%E3%83%90%E3%83%83%E3%82%B0mx6_sabrelite_board_init%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.790388%5D%20**DEBUG%20imx_add_pcie%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.793966%5Dhw-breakpoint%3A%206%20%E3%81%A4%E3%81%AE%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%A8%201%20%E3%81%A4%E3%81%AE%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.800798%5Dhw-breakpoint%3A%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E7%94%A8%E3%81%AB%E4%BA%88%E7%B4%84%E3%81%95%E3%82%8C%E3%81%9F%201%20%E3%81%A4%E3%81%AE%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.808143%5Dhw-breakpoint%3A%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E6%9C%80%E5%A4%A7%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF%204%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.814042%5DL310%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%8C%E6%9C%89%E5%8A%B9%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.818071%5Dl2x0%3A%2016%20%E9%80%9A%E3%82%8A%E3%80%81CACHE_ID%200x410000c7%E3%80%81AUX_CTRL%200x02070000%E3%80%81%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%E3%82%B5%E3%82%A4%E3%82%BA%3A%201048576%20B%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.849718%5DBIO%3A0%E3%81%AB%E3%82%B9%E3%83%A9%E3%83%96%3CBIO-0%3E%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%3C%2FBIO-0%3E%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.857066%5DMXS-DMA%20MXS-DMA-APBH%3A%E5%88%9D%E6%9C%9F%E5%8C%96%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.861759%5Dprint_constraints%3Avmmc%3A3300%20mV%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.866817%5Dvgaarb%3A%20%E3%83%AD%E3%83%BC%E3%83%89%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.870369%5DSCSI%20%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.874931%5Dspi_imx%20imx6q-ecspi.0%3A%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.879688%5Dusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20usbfs%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.885314%5Dusbcore%3A%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%83%8F%E3%83%96%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.890798%5Dusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20USB%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.895867%5D%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%ABUSB%20OTG%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%80%81%24Revision%3A%201.55%20%24%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.918287%5D%20imx-ipuv3%20imx-ipuv3.0%3A%20IPU%20DMFC%20NORMAL%20mode%3A%201(0~1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.938282%5D%20imx-ipuv3%20imx-ipuv3.1%3A%20IPU%20DMFC%20NORMAL%20mode%3A%201(0~1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.946109%5Dmxc_mipi_csi2%20mxc_mipi_csi2%3A%20i.MX%20MIPI%20CSI2%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.952586%5Dmxc_mipi_csi2%20mxc_mipi_csi2%3Ai.MX%20MIPI%20CSI2%20dphy%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8C0x3130302a%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.960308%5DMIPI%20CSI2%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%83%BB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.964632%5DAdvanced%20Linux%20Sound%20Architecture%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B31.0.24%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.971833%5DBluetooth%3A%E3%82%B3%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B32.16%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.975533%5DNET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2031%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.980001%5DBluetooth%3AHCI%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E6%8E%A5%E7%B6%9A%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.986377%5DBluetooth%3AHCI%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.991277%5DBluetooth%3AL2CAP%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.996429%5DBluetooth%3ASCO%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.001760%5Dcfg80211%3A%20CRDA%20%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%A6%E4%B8%96%E7%95%8C%E3%81%AE%E8%A6%8F%E5%88%B6%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.008652%5DI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BMAX17135%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.014941%5DI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E3%83%AC%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A0%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%5BMAX17135%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.021168%5D%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9mxc_timer1%E3%81%B8%E3%81%AE%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.037670%5DNET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%202%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.042238%5DIP%20%E3%83%AB%E3%83%BC%E3%83%88%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%2032768%20(%E9%A0%86%E5%BA%8F%3A%205%E3%80%81131072%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.050180%5DTCP%20%E7%A2%BA%E7%AB%8B%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20131072%20(%E9%A0%86%E5%BA%8F%3A%208%E3%80%811048576%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.059505%5DTCP%E3%83%90%E3%82%A4%E3%83%B3%E3%83%89%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A65536(%E9%A0%86%E5%BA%8F%3A7%E3%80%81786432%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.067234%5DTCP%3A%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99(%E3%83%90%E3%82%A4%E3%83%B3%E3%83%8965536%20131072%E7%A2%BA%E7%AB%8B)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.073869%5DTCP%20reno%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.077034%5DUDP%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20512%20(%E9%A0%86%E5%BA%8F%3A%202%E3%80%8116384%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.082999%5DUDP-Lite%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20512%20(%E9%A0%86%E5%BA%8F%3A%202%E3%80%8116384%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.089789%5DNET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%201%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.094454%5DRPC%3A%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%E5%90%8D%E5%89%8D%E3%81%AE%20UNIX%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E8%BB%A2%E9%80%81%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.100408%5DRPC%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%20UDP%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.105126%5DRPC%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%20tcp%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.109852%5DRPC%3A%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%20tcp%20NFSv4.1%20%E3%83%90%E3%83%83%E3%82%AF%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.117195%5D%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%ABi.MX6%E3%81%AE%E3%82%B9%E3%82%BF%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%83%BB%E3%83%91%E3%83%AF%E3%83%BC%E3%83%BB%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A1%E3%83%B3%E3%83%88%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.122438%5Di.MX6%20%E3%81%AE%E5%BE%85%E6%A9%9F%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E7%84%A1%E5%8A%B9%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.126812%5Dcpaddr%20%3D%20c0880000%20suspend_iram_base%3Dc091c000%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.132223%5DPM%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.135722%5D%20**DEBUG%20imx_pcie_drv_init%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.174919%5D%20**DEBUG%20imx_pcie_pltfm_probe%3C%2FP%3E%3CP%3E%3CSTRONG%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.178171%5D%20iMX6%20PCIe%20PCIe%20EP%20mode%20imx_pcie_pltfm_probe%20entering.%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.184380%5DPCIE%3A%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E9%96%8B%E5%A7%8Bimx_pcie_pltfm_probe%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.189459%5DPCIe%20EP%3A%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E5%BE%85%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%5B%26nbsp%3B%26nbsp%3B%2015.540166%5DPCIe%20EP%3A%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.543512%5DIMX%20USB%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.547195%5D%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%BD%E3%83%BC%E3%82%B9IRQ%2075%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.554446%5DIMX%20USB%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.557952%5DCPU%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%A2%E3%83%BC%E3%83%89%3Aldo_enable%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.562170%5Di.MXC%20CPU%E5%91%A8%E6%B3%A2%E6%95%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.590899%5DJFFS2%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.2.(NAND)%20%C2%A9%202001-2006%20%E3%83%AC%E3%83%83%E3%83%89%E3%83%8F%E3%83%83%E3%83%88%E6%A0%AA%E5%BC%8F%E4%BC%9A%E7%A4%BE%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.597527%5Dmsgmni%20%E3%81%8C%201751%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.602766%5Dalg%3A%20stdrng%20(krng)%20%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%AA%E3%81%97%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.607030%5DIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9NOOP%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.610966%5DIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9%E3%81%AE%E7%B7%A0%E5%88%87%E6%97%A5%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.615331%5DIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9CFQ%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF(%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.621043%5DMIPI%20DSI%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.625229%5Dmxc_sdc_fb%20mxc_sdc_fb.0%3Amxcfb0%E3%81%AEfb%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93!%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.631641%5Dmxc_sdc_fb%20mxc_sdc_fb.1%3Amxcfb1%E3%81%AEfb%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93!%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.638041%5Dmxc_sdc_fb%20mxc_sdc_fb.2%3Amxcfb2%E3%81%AEfb%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93!%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.644430%5Dmxc_sdc_fb%20mxc_sdc_fb.3%3AMXC%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCLDB%E3%81%AE%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.650830%5D_regulator_get%3A%20%E8%AD%98%E5%88%A5%E5%AD%90%E3%81%AA%E3%81%97%E3%81%AE%20get()%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.667087%5D%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%3A%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9160x50%E3%81%B8%E3%81%AE%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.682241%5DIMX-SDMA%3A%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%201.1%20%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.690972%5Dimx-sdma%3A%20%E5%88%9D%E6%9C%9F%E5%8C%96%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.814091%5D%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3AIMX%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.817281%5Dimx-uart.0%3AMMIO%200x2020000%20(irq%20%3D%2058)%20%E3%81%AE%20ttymxc0%20%E3%81%AF%20IMX%20%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.824129%5Dimx-uart.1%3AMMIO%200x21e8000%20(irq%20%3D%2059)%20%E3%81%AE%20ttymxc1%20%E3%81%AF%20IMX%20%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.830620%5D%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20%5Bttymxc1%5D%20%E3%81%8C%E6%9C%89%E5%8A%B9%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%8C%E7%84%A1%E5%8A%B9%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.830620%5D%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20%5Bttymxc1%5D%20%E3%81%8C%E6%9C%89%E5%8A%B9%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%8C%E7%84%A1%E5%8A%B9%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.846998%5Dloop%3A%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.884600%5DSATA%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.888429%5D%20m25p80%20spi0.0%3A%20sst25vf016b%20(2048%20Kbytes)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.893400%5D%22m25p80%22%20%E3%81%AB%202%20%E3%81%A4%E3%81%AE%20MTD%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.898209%5D0x000000000000-0x000000100000%20%3A%20%E3%80%8C%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%80%8D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.904579%5D0x000000100000-0x000000200000%20%3A%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.910711%5DGPMI%20NAND%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82(IMX%E3%81%AE)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.916014%5Dvcan%3A%20%E4%BB%AE%E6%83%B3%20CAN%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.920464%5DCAN%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.924304%5DFlexcan%20NetDevice%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.928752%5Dflexcan%20imx6q-flexcan.0%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E7%99%BB%E9%8C%B2%20(reg_base%3DC09E8000%2C%20IRQ%3D142)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.936542%5DFEC%20%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.941717%5Dfec_enet_mii_bus%3A%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.946292%5Dehci_hcd%3A%20USB%202.0%20%E3%80%8C%E6%8B%A1%E5%BC%B5%E3%80%8D%E3%83%9B%E3%82%B9%E3%83%88%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%20(EHCI)%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.952944%5D%20fsl-ehci%20fsl-ehci.0%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.959594%5DFSL-EHCI%20FSL-EHCI.0%3A%E6%96%B0%E3%81%97%E3%81%84USB%E3%83%90%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%80%81%E3%83%90%E3%82%B9%E7%95%AA%E5%8F%B71%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2015.995767%5D%20fsl-ehci%20fsl-ehci.0%3A%20irq%2075%2C%20io%20base%200x02184000%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.015757%5D%20fsl-ehci%20fsl-ehci.0%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.022008%5D%E3%83%8F%E3%83%96%201-0%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.025780%5D%E3%83%8F%E3%83%96%201-0%3A1.0%3A%201%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.029901%5D%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%BD%E3%83%BC%E3%82%B9IRQ%2072%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.033602%5D%20fsl-ehci%20fsl-ehci.1%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.040243%5DFSL-EHCI%20FSL-EHCI.1%3A%E6%96%B0%E3%81%97%E3%81%84USB%E3%83%90%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%80%81%E3%83%90%E3%82%B9%E7%95%AA%E5%8F%B72%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.075767%5D%20fsl-ehci%20fsl-ehci.1%3A%20irq%2072%2C%20io%20base%200x02184200%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.095755%5D%20fsl-ehci%20fsl-ehci.1%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.101938%5D%E3%83%8F%E3%83%96%202-0%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.105702%5D%E3%83%8F%E3%83%96%202-0%3A1.0%3A%201%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.109947%5DUSB%E5%A4%A7%E5%AE%B9%E9%87%8F%E8%A8%98%E6%86%B6%E8%A3%85%E7%BD%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.114988%5Dusbcore%3A%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AEusb-storage%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.121010%5DUSB%E3%83%9E%E3%82%B9%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.125632%5DARC%20USBOTG%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20(2005%20%E5%B9%B4%208%20%E6%9C%88%201%20%E6%97%A5)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.132344%5Dmousedev%3A%20PS%2F2%20%E3%83%9E%E3%82%A6%E3%82%B9%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20(%E5%85%A8%E3%83%9E%E3%82%A6%E3%82%B9%E5%85%B1%E9%80%9A)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.138373%5D%E5%85%A5%E5%8A%9B%3A%20GPIO-keys%20as%20%2Fdevices%2Fplatform%2Fgpio-keys%2Finput%2Finput0%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.145762%5Degalax_ts%202-0004%3A%20egalax_ts%3A%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.152477%5Degalax_ts%3A%202-0004%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-5%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.158557%5DI2C-Core%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%5BISL29023%5D%20%E3%81%8C%E5%BE%93%E6%9D%A5%E3%81%AE%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.164830%5DI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E3%83%AC%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A0%E6%96%B9%E6%B3%95%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BISL29023%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.171586%5Dsnvs_rtc%20snvs_rtc.0%3ARTC%E3%82%B3%E3%82%A2%3ARTC0%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2snvs_rtc%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.178258%5Di2c%20%2Fdev%20entries%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.182461%5DLinux%E3%83%93%E3%83%87%E3%82%AA%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3Av2.00%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.187446%5Dmxc_v4l2_output%20mxc_v4l2_output.0%3A%E3%83%93%E3%83%87%E3%82%AA%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FV4L2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B916%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.195068%5Dmxc_v4l2_output%20mxc_v4l2_output.0%3A%E3%83%93%E3%83%87%E3%82%AA%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FV4L2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B917%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.202918%5DI2C-Core%3A%20%E5%BE%93%E6%9D%A5%E3%81%AE%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%5BMAG3110%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.209139%5DI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E3%83%AC%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A0%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BMAG3110%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.215645%5DIMX2-WDT%20IMX2-WDT.0%3AIMX2%2B%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%3D60%E7%A7%92%20(nowayout%3D1)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.223761%5DBluetooth%3A%E4%BB%AE%E6%83%B3HCI%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCver%201.3%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.228680%5DBluetooth%3AHCI%20UART%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCver%202.2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.233128%5DBluetooth%3A%20HCIATH3K%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.238105%5DBluetooth%3A%E6%B1%8E%E7%94%A8Bluetooth%20USB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCver%200.6%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.243804%5Dusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20btusb%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.249437%5Dsdhci%3A%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%BB%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%83%BB%E3%83%9B%E3%82%B9%E3%83%88%E3%83%BB%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%83%BB%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.255623%5Dsdhci%3A%20Copyright(c)%20Pierre%20Ossman%20(%E8%8B%B1%E8%AA%9E)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.260386%5Dmmc0%3A%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20%5BSDHCI-ESDHC-IMX.3%5D%20%E4%B8%8A%E3%81%AE%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BCDMA%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.267756%5Dmmc1%3A%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20%5BSDHCI-ESDHC-IMX.2%5D%20%E4%B8%8A%E3%81%AE%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BCDMA%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.275002%5Dmxc_vdoa%20mxc_vdoa%3A%20i.MX%20Video%20Data%20Order%20Adapter%20(VDOA)%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.286210%5DVPU%20%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.289955%5D%E7%99%BB%E9%8C%B2mxc_asrc%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.317073%5D%E3%82%B5%E3%83%BC%E3%83%9E%E3%83%AB%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%87%E3%83%BC%E3%82%BF0x5874c87d%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.321870%5D%E3%83%AC%E3%82%B7%E3%82%AA%20%3D%20183%20%E3%81%AE%E3%82%B5%E3%83%BC%E3%83%9E%E3%83%AB%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.345881%5DAnatop%20Thermal%20%E3%81%AF%20thermal_zone0%20%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.351169%5Danatop_thermal_probe%3A%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E5%86%B7%E5%8D%B4%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AFCPUFreq%E3%81%A7%E3%81%99!%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.358317%5Dusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20usbhid%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.363893%5Dusbhid%3A%20USB%20HID%20%E3%82%B3%E3%82%A2%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.368144%5Dusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCsnd-usb-audio%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.374848%5Dmxc_hdmi_soc%20mxc_hdmi_soc.0%3AMXC%20HDMI%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.380296%5DCirrus%20Logic%20CS42888%20ALSA%20SoC%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.385539%5DI2C-Core%3A%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BCS42888%5D%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.387149%5Dmmc0%3A%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200001%20%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E9%AB%98%E9%80%9F%20SDHC%20%E3%82%AB%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.397244%5DI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E5%86%8D%E9%96%8B%E6%96%B9%E6%B3%95%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BCS42888%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.403550%5Dmmcblk0%3A%20mmc0%3A0001%2000000%207.44%20GiB%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.404126%5Dimx-hdmi-soc-dai%20imx-hdmi-soc-dai.0%3A%E5%A4%B1%E6%95%97%3A%E6%9C%80%E5%88%9D%E3%81%ABHDMI%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.404881%5Dimx_3stack%20ASOC%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.405497%5DHDMI%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%9C%80%E5%88%9D%E3%81%ABHDMI%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84!%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.405505%5DALSA%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E4%B8%80%E8%A6%A7%3A%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.405510%5D%E3%82%B5%E3%82%A6%E3%83%B3%E3%83%89%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.405716%5DNET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2026%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.406295%5DTCP%E3%82%AD%E3%83%A5%E3%83%BC%E3%83%93%E3%83%83%E3%82%AF%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.406303%5DNET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2017%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.406320%5DCAN%3A%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%82%A8%E3%83%AA%E3%82%A2%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B3%E3%82%A2(REB%2020090105%20ABI%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.406391%5DNET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2029%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.406407%5DCAN%3ARAW%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB(Rev%2020090105)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.406413%5DCAN%3A%20%E3%83%96%E3%83%AD%E3%83%BC%E3%83%89%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%20%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20(%E6%94%B9%E8%A8%82%E7%89%88%2020090105%20T)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.425829%5Dusb%202-1%3Afsl-ehci%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E6%96%B0%E3%81%97%E3%81%84%E9%AB%98%E9%80%9FUSB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E7%95%AA%E5%8F%B72%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.470303%5DBluetooth%3ARFCOMM%20TTY%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.471595%5Dmmcblk0%3A%20p1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.477735%5DBluetooth%3ARFCOMM%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.482876%5DBluetooth%3ARFCOMM%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B31.11%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.486635%5DBluetooth%3ABNEP(%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3)ver%201.3%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.491949%5DBluetooth%3ABNEP%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%3A%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%9E%E3%83%AB%E3%83%81%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.497189%5DBluetooth%3AHIDP(%E3%83%92%E3%83%A5%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3)ver%201.2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.503241%5Dlib80211%3A%20IEEE802.11%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E5%85%B1%E9%80%9A%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.508958%5DVFP%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20v0.3%3A%20implementor%2041%20architecture%203%20part%2030%20variant%209%20rev%204%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.516994%5D%E3%83%90%E3%82%B9%E5%91%A8%E6%B3%A2%E6%95%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.521011%5D%E3%83%90%E3%82%B9%E5%91%A8%E6%B3%A2%E6%95%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%E6%9C%89%E5%8A%B9%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.526514%5Dmxc_dvfs_core_probe%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.529846%5DDVFS%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.535886%5Dsnvs_rtc%20snvs_rtc.0%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%201970-01-01%2005%3A59%3A54%20UTC%20(21594)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.549411%5DEXT3-fs%3A%20%E3%83%90%E3%83%AA%E3%82%A2%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.554225%5Dkjournald%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%E9%96%93%E9%9A%94%205%20%E7%A7%92%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.558984%5DEXT3-fs%20(mmcblk0p1)%3A%20%E5%86%85%E9%83%A8%E3%82%B8%E3%83%A3%E3%83%BC%E3%83%8A%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.558996%5DEXT3-fs%20(mmcblk0p1)%3A%20%E3%83%A9%E3%82%A4%E3%83%88%E3%83%90%E3%83%83%E3%82%AF%E3%83%BB%E3%83%87%E3%83%BC%E3%82%BF%E3%83%BB%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.559027%5DVFS%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20179%3A1%20%E3%81%AB%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E3%83%AB%E3%83%BC%E3%83%88%20(ext3%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0)%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.559086%5Dinit%20%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E8%A7%A3%E6%94%BE%3A%20204K%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.648921%5D%E3%83%8F%E3%83%96%202-1%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.652848%5D%E3%83%8F%E3%83%96%202-1%3A1.0%3A%203%20%E3%81%A4%E3%81%AE%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Epid%201354%20%E4%BB%A5%E9%99%8D%E3%80%81tty%20''%3A%20'%2Fetc%2Frc.d%2FrcS'%3C%2FP%3E%3CP%3E%2Fproc%20%E3%81%A8%20%2Fsys%20%E3%81%AE%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%20%3C%2FP%3E%3CP%3E%E3%83%9B%E3%83%83%E3%83%88%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%83%87%E3%82%A3%E3%82%B9%E3%83%91%E3%83%83%E3%83%81%E3%83%A3%E3%83%BCudevd%E3%81%AE%E8%B5%B7%E5%8B%95%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2016.886688%5Dudevd%20(1372)%3A%20%2Fproc%2F1372%2Foom_adj%20%E3%81%AF%E9%9D%9E%E6%8E%A8%E5%A5%A8%E3%81%A7%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20%2Fproc%2F1372%2Foom_score_adj%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E5%88%9D%E6%9C%9F%E3%83%9B%E3%83%83%E3%83%88%E3%83%97%E3%83%A9%E3%82%B0%E3%83%BB%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%81%AE%E5%90%88%E6%88%90%3C%2FP%3E%3CP%3E%E3%83%9B%E3%82%B9%E3%83%88%E5%90%8D%E3%82%92%E5%A2%83%E7%95%8C%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%3C%2FP%3E%3CP%3Emount%3A%20%2Fproc%2Fbus%2Fusb%20%E3%81%B8%E3%81%AE%20usbfs%20%E3%81%AE%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%84%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Esysctl%20%E3%81%AE%E5%AE%9F%E8%A1%8C%3C%2FP%3E%3CP%3E%E3%83%AB%E3%83%BC%E3%83%97%E3%83%90%E3%83%83%E3%82%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%AE%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AD%E3%83%B3%E3%82%B0%E3%81%AE%E8%A8%AD%E5%AE%9A%3A%20%3C%2FP%3E%3CP%3Eeth0%20%E3%81%A7%E3%81%AE%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AE%E8%A8%AD%E5%AE%9A%3A%20%3C%2FP%3E%3CP%3Eudhcpc%20(v1.20.2)%20%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%2019.039687%5Deth0%3A%20%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%20FEC%20PHY%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%5BMicrel%20KSZ9021%20Gigabit%20PHY%5D%20(mii_bus%3Aphy_addr%3D1%3A06%2C%20irq%3D-1)%3C%2FP%3E%3CP%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AB%E3%83%90%E3%83%BC%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FP%3E%3CP%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AB%E3%83%90%E3%83%BC%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FP%3E%3CP%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AB%E3%83%90%E3%83%BC%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AA%E3%81%97%E3%80%81%E3%83%90%E3%83%83%E3%82%AF%E3%82%B0%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%81%B8%E3%81%AE%E5%88%86%E5%B2%90%3C%2FP%3E%3CP%3Edropbear%20ssh%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AE%E8%B5%B7%E5%8B%95%3A%20%3C%2FP%3E%3CP%3Epid%203060%20%E4%BB%A5%E9%99%8D%E3%80%81tty%20''%3A%20'%2Fetc%2Frc.d%2Frc_gpu.S'%3C%2FP%3E%3CP%3Epid%203068%20%E4%BB%A5%E9%99%8D%E3%80%81tty%20''%3A%20'%2Fetc%2Frc.d%2Frc_mxc.S'%3C%2FP%3E%3CP%3Earm-none-linux-gnueabi-gcc%20(Freescale%20MAD%20--%20Linaro%202011.07%20--%202011%2F08%2F10%2009%3A20%20%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89)%204.6.220110630(%E3%83%97%E3%83%AC%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9)%3C%2FP%3E%3CP%3E%E3%83%AB%E3%83%BC%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20Tue%2C%2018%20Jun%202013%2012%3A28%3A53%20-0700%20%E3%81%AB%E6%A7%8B%E7%AF%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%BB%E3%83%9F%E3%82%B3%E3%83%B3%E3%83%80%E3%82%AF%E3%82%BF%E6%A0%AA%E5%BC%8F%E4%BC%9A%E7%A4%BE%3C%2FP%3E%3CP%3E%E5%A2%83%E7%95%8C%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%3A%20%3C%2FP%3E%3CP%3EU%E3%83%96%E3%83%BC%E3%83%88%202013.01-rc1-00120-g7c28db0(2012%E5%B9%B411%E6%9C%8812%E6%97%A5%20-%2009%3A15%3A04)%3C%2FP%3E%3CP%3ECPU%3A%20Freescale%20i.MX6Q%20rev1.2%20(792%20MHz)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E3%83%96%E3%83%BC%E3%83%88%E3%81%97%E3%80%81%E3%80%8C%3CSTRONG%3EPCIe%20EP%3A%20waiting%20for%20link%20up...%3C%2FSTRONG%3E%E3%80%8D%E3%81%A8%E8%A8%80%E3%81%84%E3%80%81PC%E3%81%AE%E9%9B%BB%E6%BA%90%E3%82%92%E5%85%A5%E3%82%8C%E3%82%8B%E3%81%A8%E3%81%99%E3%81%90%E3%81%AB%E3%80%81%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AD%E3%83%B3%E3%83%97%E3%83%88%E3%81%BE%E3%81%A7%E7%B6%9A%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E6%AE%B5%E9%9A%8E%E3%81%A7%E3%81%AF%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E3%81%AFIMX6q%E3%81%AF125Mhz%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81CLK%E4%BF%A1%E5%8F%B7%E3%81%AF%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AEPCIe%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E5%86%85%E9%83%A8PLL%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%80%81PCIe%E3%81%AE%E6%A8%99%E6%BA%96%E3%81%8C100Mhz%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%AA%E3%83%B3%E3%82%AFisr%E3%81%8C%E6%9C%AC%E5%BD%93%E3%81%ABUP%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E7%A2%BA%E3%81%8B%E3%81%A7%E3%81%99%E3%81%8B%3F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%98%8E%E3%82%89%E3%81%8B%E3%81%ABPC%E5%81%B4%E3%81%A7%E3%81%AF%E3%80%81%E3%80%8Clspci%E3%80%8D%E3%82%92%E7%99%BA%E8%A1%8C%E3%81%97%E3%81%A6%E3%82%82%E4%BD%95%E3%82%82%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CIMG%20id%3D%22smileysad%22%20class%3D%22emoticon%20emoticon-smileysad%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-sad.png%22%20alt%3D%22Smiley%20Sad%22%20title%3D%22Smiley%20Sad%22%20%2F%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81VID%2FPID%E3%82%92%E3%80%8CDEADBEAF%E3%80%8D%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%A8%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AEVID%2FPID%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%24%20.%2Fmemtool%E2%97%8F32%2001FFC000%2020%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E0x20%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x01FFC000%20%E3%81%8B%E3%82%89%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E0x01FFC000%3A%20%3CSTRONG%3EABCD16C3%3C%2FSTRONG%3E%2000100000%2000000001%2000000000%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E0x01FFC010%3A%200000000C%2000000000%2000000008%2000000001%3C%2FP%3E%3CP%3E0x01FFC020%3A%2000000000%2000000000%2000000000%2000000000%3C%2FP%3E%3CP%3E0x01FFC030%3A%2000000000%2000000040%20000000000%20000001FF%3C%2FP%3E%3CP%3E0x01FFC040%3A%20DBC35001%2000000000%2000000000%2000000000%3C%2FP%3E%3CP%3E0x01FFC050%3A%2001807005%2000000000%2000000000%2000000000%3C%2FP%3E%3CP%3E0x01FFC060%3A%2000000000%2000000000%2000000000%2000000000%3C%2FP%3E%3CP%3E0x01FFC070%3A00020010%2000008700%2000102010%200001CC12%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A0%E3%81%8B%E3%82%89%E3%80%81%E7%A7%81%E3%81%AF%E4%BD%95%E3%81%8B%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AB%E9%81%95%E3%81%84%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%A9%E3%82%93%E3%81%AA%E5%8A%A9%E3%81%91%E3%82%82%E5%A4%A7%E6%AD%93%E8%BF%8E%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%81%E7%A7%81%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%ABSabrelite%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E5%BD%93%E3%81%A6%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3D%3D%3D%3D%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%BC%E3%83%81%2F%E3%82%A2%E3%83%BC%E3%83%A0%2F%E3%83%9E%E3%83%83%E3%83%8F-MX6%2F%E3%83%9C%E3%83%BC%E3%83%89-mx6q_sabrelite.c%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2B%23define%20SABREAUTO_MAX7310_1_BASE_ADDR%26nbsp%3B%26nbsp%3B%20IMX_GPIO_NR(8%2C%200)%3C%2FP%3E%3CP%3E%2B%23define%20SABREAUTO_PCIE_RST_B_REVB%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20(SABREAUTO_MAX7310_1_BASE_ADDR%20%2B%202)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2Bstatic%20const%20%E6%A7%8B%E9%80%A0%E4%BD%93%20imx_pcie_platform_data%20mx6_sabrelite_pcie_data%20__initconst%20%3D%20%7B%3C%2FP%3E%3CP%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.pcie_pwr_en%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20-EINVAL%2C%3C%2FP%3E%3CP%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.pcie_rst%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20SABREAUTO_PCIE_RST_B_REVB%2C%3C%2FP%3E%3CP%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.pcie_wake_up%26nbsp%3B%26nbsp%3B%20%3D%20-EINVAL%2C%3C%2FP%3E%3CP%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.pcie_dis%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20-EINVAL%2C%3C%2FP%3E%3CP%3E%2B%23ifdef%20CONFIG_IMX_PCIE_EP_MODE_IN_EP_RC_SYS%3C%2FP%3E%3CP%3E%2B%20.type_ep%3D%201%E3%80%81%3C%2FP%3E%3CP%3E%2B%23else%3C%2FP%3E%3CP%3E%2B%20.type_ep%3D%200%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%3C%2FP%3E%3CP%3E%2B%23endif%3C%2FP%3E%3CP%3E%2B%7D%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B9%E3%82%BF%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%83%9C%E3%82%A4%E3%83%89__init%20mx6_sabrelite_board_init(%E3%83%9C%E3%82%A4%E3%83%89)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2B%20%2F*%20PCIe%20RC%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%20*%2F%3C%2FP%3E%3CP%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20imx6q_add_pcie(%26amp%3Bmx6_sabrelite_pcie_data)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20imx6q_add_perfmon(0)%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20imx6q_add_perfmon(1)%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20imx6q_add_perfmon(2)%3B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126650%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126650%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%20%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%3A%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F362575%23362575%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fmessage%2F362575%23362575%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126649%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126649%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%9A%3CBR%20%2F%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%A9%B1%E3%81%97%E5%90%88%E3%81%86%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%E3%82%921%E3%81%A4%E7%99%BA%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20EP%20%2F%20RC%E6%A4%9C%E8%A8%BC%E3%81%A8%E3%81%AF%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%8F%E9%96%A2%E4%BF%82%E3%81%8C%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8C%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20MSI%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E7%A7%81%E3%81%8C%E8%A6%9A%E3%81%88%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%811.1.0%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AF%E3%81%BE%E3%81%A0%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20MSI%20%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%83%AA%E3%83%81%E3%83%A3%E3%83%BC%E3%83%89%3CBR%20style%3D%22mso-special-character%3Aline-break%22%20%2F%3E%3CBR%20style%3D%22mso-special-character%3Aline-break%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126648%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126648%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F.i%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Edrivers%2Fbuilt-in.o%3A%E9%96%A2%E6%95%B0%20'default_setup_msi_irqs'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Eclkdev.c%3A(.text%2B0x10ca4)%3A'arch_setup_msi_irq'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3Edrivers%2Fbuilt-in.o%3A%E9%96%A2%E6%95%B0%20'default_teardown_msi_irqs'%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Eclkdev.c%3A(.text%2B0x10d18)%3A'arch_teardown_msi_irq'%20%E3%81%B8%E3%81%AE%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%81%AE%E5%8F%82%E7%85%A7%3C%2FP%3E%3CP%3Emake%3A%20***%20%5B.tmp_vmlinux1%5D%20%E3%82%A8%E3%83%A9%E3%83%BC%201%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126647%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126647%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%20%5B%20%5D%20make%20menuconfig%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%B7%E3%82%B0%E3%83%8A%E3%83%AB%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF(MSI%E3%81%8A%E3%82%88%E3%81%B3MSI-X)%20%3C%2FSPAN%3E%20%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126646%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126646%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Eroot%40freescale%20~%24%20lspci%3C%2FP%3E%3CP%3E00%3A00.0%20%E3%82%AF%E3%83%A9%E3%82%B9%200604%3A%2016c3%3Aabcd%3C%2FP%3E%3CP%3E01%3A00.0%20%E3%82%AF%E3%83%A9%E3%82%B9%200400%3A%2014f1%3A8580%3C%2FP%3E%3CP%3Eroot%40freescale%20~%24%20lspci%20-v%3C%2FP%3E%3CP%3E00%3A00.0%20%E3%82%AF%E3%83%A9%E3%82%B9%200604%3A%2016c3%3Aabcd%3C%2FP%3E%3CP%3E01%3A00.0%20%E3%82%AF%E3%83%A9%E3%82%B9%200400%3A%2014f1%3A8580%3C%2FP%3E%3CP%3Eroot%40freescale%20~%24%20%E7%A7%81%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%3C%2FP%3E%3CP%3E%E9%9D%99%E7%9A%84%E6%A7%8B%E9%80%A0%E4%BD%93%20pci_device_id%20cx25858_pci_tbl%5B%5D%20%3D%20%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20CX25858%20Atlas%20Plus%20*%2F%3C%2FP%3E%3CP%3E.vendor%20%3D%200x14f1%E3%80%81%3C%2FP%3E%3CP%3E.device%20%3D%200x8580%E3%80%81%3C%2FP%3E%3CP%3E.subvendor%20%3D%200x14f1%E3%80%81%3C%2FP%3E%3CP%3E.subdevice%20%3D%200x0950%E3%80%81%3C%2FP%3E%3CP%3E%7D%2C%20%3C%2FP%3E%3CP%3EID%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%83%AD%E3%82%B0%E3%81%8B%E3%82%89%E8%A6%8B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3ECX25858%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.0.111%E3%83%AD%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3ECX25858%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E5%A4%B1%E6%95%97%3C%2FP%3E%3CP%3E%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AB%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E5%8D%B0%E5%88%B7%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eif%20(!pci_register_driver(%26amp%3Bcx25858_pci_driver))%20%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pci_unregister_driver(%26amp%3Bcx25858_pci_driver)%3B%3C%2FP%3E%3CP%3Eprintk(KERN_INFO%20%22CX25858%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E5%A4%B1%E6%95%97%5Cn%22)%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20return%20-ENODEV%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FP%3E%3CP%3Eprintk(KERN_INFO%20%22CX25858%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E6%88%90%E5%8A%9F%5Cn%22)%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20return%200%3B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%AA%E3%81%9C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%E3%80%81%E4%BD%95%E3%81%8B%E6%8F%90%E6%A1%88%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F*%20%E3%83%AA%E3%82%BF%E3%83%BC%E3%83%B3%20pci_register_driver(%26amp%3Bcx25858_pci_driver)%3B*%2F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126645%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126645%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CBR%20%2F%3E%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%81EP%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%AF%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20RC%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E8%A9%B3%E7%B4%B0%E6%83%85%E5%A0%B1%E3%81%AF%E3%80%81%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%AB%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%80%8C%3CSPAN%20class%3D%22SpellE%22%3Elspci%3C%2FSPAN%3E%20-v%E3%80%8D%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%83%AA%E3%83%81%E3%83%A3%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126644%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126644%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AFstdpci%E3%82%92%E3%81%97%E3%80%81%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3EMiniPCIe%E3%81%8B%E3%82%89STD%E3%81%B8%E3%81%AEPCIe%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%84%E3%80%81%E3%80%81%3C%2FSPAN%3E%20Linux3.0.35_1.1.0_%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99121218%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%8B%E3%82%89%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%20%E3%83%AD%E3%82%B0%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EU-Boot%202009.08%20(2013%E5%B9%B49%E6%9C%8817%E6%97%A5%20-%2020%3A02%3A02)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECPU%3A%20Freescale%20i.MX6%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AATO1.2(792MHz)%3C%2FP%3E%3CP%3E%E6%B8%A9%E5%BA%A6%3A29%C2%B0C%E3%80%81%E6%A0%A1%E6%AD%A3%E3%83%87%E3%83%BC%E3%82%BF0x5784c37d%3C%2FP%3E%3CP%3Emx6q%20pll1%3A792MHz%3C%2FP%3E%3CP%3Emx6q%20pll2%3A528MHz%E3%81%AE%3C%2FP%3E%3CP%3Emx6q%20pll3%3A480MHz%3C%2FP%3E%3CP%3Emx6q%20pll8%3A50MHz%E3%81%AE%3C%2FP%3E%3CP%3Eipg%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A66000000Hz%3C%2FP%3E%3CP%3Eipg%20per%20clock%20%3A%2066000000Hz%3C%2FP%3E%3CP%3Euart%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A80000000Hz%3C%2FP%3E%3CP%3Ecspi%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A60000000Hz%3C%2FP%3E%3CP%3Eahb%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A132000000Hz%3C%2FP%3E%3CP%3E%E8%BB%B8%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A264000000Hz%3C%2FP%3E%3CP%3Eemi_slow%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A132000000Hz%3C%2FP%3E%3CP%3EDDR%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A528000000Hz%3C%2FP%3E%3CP%3Eusdhc1%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A198000000Hz%3C%2FP%3E%3CP%3Eusdhc2%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A198000000Hz%3C%2FP%3E%3CP%3Eusdhc3%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A198000000Hz%3C%2FP%3E%3CP%3Eusdhc4%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A198000000Hz%3C%2FP%3E%3CP%3ENFC%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A24000000Hz%3C%2FP%3E%3CP%3E%E5%9F%BA%E6%9D%BF%3Ai.MX6Q-SABRESD%3A%E5%9F%BA%E6%9D%BF%E4%B8%8D%E6%98%8E%20%E5%9F%BA%E6%9D%BF%3A0x63012%20%5BPOR%20%5D%3C%2FP%3E%3CP%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3AMMC%3C%2FP%3E%3CP%3EI2C%3A%20%E6%BA%96%E5%82%99%E5%AE%8C%E4%BA%86%3C%2FP%3E%3CP%3EDRAM%3A1%E3%82%AE%E3%82%AC%E3%83%90%E3%82%A4%E3%83%88%3C%2FP%3E%3CP%3EMMC%3A%26nbsp%3B%26nbsp%3B%20FSL_USDHC%3A%200%2CFSL_USDHC%3A%201%2CFSL_USDHC%3A%202%2CFSL_USDHC%3A%203%3C%2FP%3E%3CP%3E%23%23%23%20%E3%82%A4%E3%83%B3%E3%82%B5%E3%82%A4%E3%83%89lcd_enable%3C%2FP%3E%3CP%3E%E5%85%A5%E5%8A%9B%EF%BC%9A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FP%3E%3CP%3E%E5%87%BA%E5%8A%9B%EF%BC%9A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FP%3E%3CP%3EErr%3A%26nbsp%3B%26nbsp%3B%20serial%3C%2FP%3E%3CP%3EPFUZE100%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F!deviceid%3D10%2Crevid%3D11%3C%2FP%3E%3CP%3E%E3%83%8D%E3%83%83%E3%83%88%3AIIM%E3%81%8B%E3%82%89MAC%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E5%8F%96%E5%BE%97%3A00%3A00%3A00%3A00%3A00%3C%2FP%3E%3CP%3EFEC0%20%5BPRIME%5D%3C%2FP%3E%3CP%3E%E8%87%AA%E5%8B%95%E8%B5%B7%E5%8B%95%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%BB%E6%84%8F%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%9A0%20%3C%2FP%3E%3CP%3Emmc3(%E3%83%91%E3%83%BC%E3%83%880)%E3%81%AF%E7%8F%BE%E8%A1%8C%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMMC%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3A%E9%96%8B%E7%99%BA%233%E3%80%81%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%232048%E3%80%81%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%888192%20...8192%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3AOK%3C%2FP%3E%3CP%3E%23%23%20%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8B%E3%82%89%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%2010800000%20%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20...%3C%2FP%3E%3CP%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E5%90%8D%3A%20Linux-3.0.35-2310-gc27cb38%3C%2FP%3E%3CP%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20%E3%82%BF%E3%82%A4%E3%83%97%3A%20ARM%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20(%E9%9D%9E%E5%9C%A7%E7%B8%AE)%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%B5%E3%82%A4%E3%82%BA%3A%204147924%20%E3%83%90%E3%82%A4%E3%83%88%20%3D%204%20MB%3C%2FP%3E%3CP%3E%E3%83%AD%E3%83%BC%E3%83%89%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A10008000%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%3A10008000%3C%2FP%3E%3CP%3E%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%B5%E3%83%A0%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99...%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EOK%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD%E2%80%A6%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELinux%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203.0.35-2310-gc27cb38(lyc%40ubuntu)(GCC%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B34.6.220110630%20(%E3%83%97%E3%83%AC%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9)%20(Freescale%20MAD%20--%20Linaro%202011.07%20--%20Built%20at%202011%2F08%2F10%2009%3A20)%20)%20%2322%20SMP%20PREEMPT%20Wed%20Nov%2013%2000%3A56%3A32%20PST%202013%3C%2FP%3E%3CP%3ECPU%3A%20ARMv7%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20%5B412fc09a%5D%20%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%2010%20(ARMv7)%E3%80%81cr%3D10c53c7d%3C%2FP%3E%3CP%3ECPU%3A%20VIPT%20%E9%9D%9E%E3%82%A8%E3%82%A4%E3%83%AA%E3%82%A2%E3%82%B7%E3%83%B3%E3%82%B0%20%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%80%81VIPT%20%E3%82%A8%E3%82%A4%E3%83%AA%E3%82%A2%E3%82%B7%E3%83%B3%E3%82%B0%E5%91%BD%E4%BB%A4%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%3C%2FP%3E%3CP%3E%E3%83%9E%E3%82%B7%E3%83%B3%3AFreescale%20i.MX%206Quad%2FDualLite%2FSolo%20Sabre-SD%E3%83%9C%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E%E8%AA%8D%E8%AD%98%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%82%BF%E3%82%B00x54410008%E3%82%92%E7%84%A1%E8%A6%96%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%9D%E3%83%AA%E3%82%B7%E3%83%BC%3A%20ECC%20%E3%81%8C%E7%84%A1%E5%8A%B9%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20writealloc%3C%2FP%3E%3CP%3ECPU%20%E3%81%AF%20i.MX6Q%E3%80%81%E3%82%B7%E3%83%AA%E3%82%B3%E3%83%B3%20rev%201.2%20%E3%81%A8%E8%AD%98%E5%88%A5%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EPERCPU%3A%E5%9F%8B%E3%82%81%E8%BE%BC%E3%81%BF7%E3%83%9A%E3%83%BC%E3%82%B8%2F%20CPU%20%408c008000%20s5440%20r8192%20d15040%20u32768%3C%2FP%3E%3CP%3E%E3%82%BE%E3%83%BC%E3%83%B3%E9%A0%86%E3%81%AB1%E3%81%A4%E3%81%AE%E3%82%BE%E3%83%BC%E3%83%B3%E3%83%AA%E3%82%B9%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%83%A2%E3%83%93%E3%83%AA%E3%83%86%E3%82%A3%E3%81%AE%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E5%8C%96%E3%82%92%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%B7%8F%E3%83%9A%E3%83%BC%E3%82%B8%E6%95%B0%3A227328%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%3A%20console%3Dttymxc2%2C115200%20root%3D%2Fdev%2Fmmcblk0p1%20rootwait%20rw%20ldb%3Dsin0%20video%3Dmxcfb0%3Adev%3Dldb%2CLDB-WXGA%2Cif%3DRGB666%3C%2FP%3E%3CP%3EPID%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%204096%20(%E9%A0%86%E5%BA%8F%3A%202%E3%80%8116384%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3EDentry%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20131072%20(%E9%A0%86%E5%BA%8F%3A%207%E3%80%81524288%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3Einode-cache%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%2065536%20(%E9%A0%86%E5%BA%8F%3A%206%E3%80%81262144%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%A2%E3%83%AA%3A640MB%20256MB%20%3D%20%E5%90%88%E8%A8%88896MB%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%A2%E3%83%AA%3A896280k%20%2F%20896280k%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%80%81152296k%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF%E3%80%810K%E9%AB%98%E3%83%A1%E3%83%A2%E3%83%AA%3C%2FP%3E%3CP%3E%E4%BB%AE%E6%83%B3%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%3A%3C%2FP%3E%3CP%3E%E3%83%99%E3%82%AF%E3%82%BF%E3%83%BC%20%3A%200xffff0000%20-%200xffff1000%20(%204%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20fixmap%26nbsp%3B%20%3A%200xfff00000%20-%200xfffe0000%26nbsp%3B%26nbsp%3B%20(%20896%20kB)%3C%2FP%3E%3CP%3EDMA%20%3A%200xf4600000%20-%200xffe00000%20(%20184%20MB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vmalloc%20%3A%200xc0800000%20-%200xf2000000%26nbsp%3B%26nbsp%3B%20(%20792%20MB)%3C%2FP%3E%3CP%3Elowmem%20%3A%200x80000000%20-%200xc0000000%20(1024%20MB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pkmap%26nbsp%3B%26nbsp%3B%20%3A%200x7fe00000%20-%200x80000000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%26nbsp%3B%202%20MB)%3C%2FP%3E%3CP%3E%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20%3A%200x7f000000%20-%200x7fe00000%20(%2014%20MB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.init%20%3A%200x80008000%20-%200x8003d000%26nbsp%3B%26nbsp%3B%20(%20212%20kB)%3C%2FP%3E%3CP%3E%E3%80%82%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%3A%200x8003d000%20-%200x80b1309c%20(11097%20kB)%3C%2FP%3E%3CP%3E%E3%80%82%E3%83%87%E3%83%BC%E3%82%BF%3A%200x80b14000%20-%200x80b7e0c0%20(%20425%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.bss%20%3A%200x80b7e0e4%20-%200x80bccfec%26nbsp%3B%26nbsp%3B%20(%20316%20kB)%3C%2FP%3E%3CP%3ESLUB%3A%20Genslabs%3D13%2C%20HWalign%3D32%2C%20Order%3D0-3%2C%20MinObjects%3D0%2C%20CPUs%3D4%2C%20Nodes%3D1%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AA%E3%82%A8%E3%83%B3%E3%83%97%E3%83%86%E3%82%A3%E3%83%96%E3%81%AA%E9%9A%8E%E5%B1%A4%E5%9E%8B%20RCU%20%E3%81%AE%E5%AE%9F%E8%A3%85%E3%80%82%3C%2FP%3E%3CP%3ENR_IRQS%3A496%3C%2FP%3E%3CP%3EMXC%20GPIO%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FP%3E%3CP%3Esched_clock%3A3000kHz%E3%81%A732%E3%83%93%E3%83%83%E3%83%88%E3%80%81%E8%A7%A3%E5%83%8F%E5%BA%A6333ns%E3%80%811431655ms%E3%81%94%E3%81%A8%E3%81%AB%E3%83%A9%E3%83%83%E3%83%97%3C%2FP%3E%3CP%3Earm_max_freq%3D2%3C%2FP%3E%3CP%3EMMIO%200x21ec000%20%E3%81%AE%20MXC_Early%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20(%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%20'115200')%3C%2FP%3E%3CP%3E%E3%83%96%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20%5Bttymxc2%5D%20%E6%9C%89%E5%8A%B9%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%3A%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%80%E3%83%9F%E3%83%BC%E3%83%87%E3%83%90%E3%82%A4%E3%82%B980x30%3C%2FP%3E%3CP%3E%E9%81%85%E5%BB%B6%E3%83%AB%E3%83%BC%E3%83%97%E3%82%92%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...1581.05%20BogoMIPS(lpj%20%3D%207905280)%3C%2FP%3E%3CP%3Epid_max%3A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%3A%2032768%20%E6%9C%80%E5%B0%8F%3A%20301%3C%2FP%3E%3CP%3E%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%83%BB%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%83%BC%E6%95%B0%3A%20512%3C%2FP%3E%3CP%3ECPU%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE%E3%82%B3%E3%83%92%E3%83%BC%E3%83%AC%E3%83%B3%E3%82%B7%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%3AOK%3C%2FP%3E%3CP%3Ehw%20perfevents%3A%20ARMv7%20Cortex-A9%20PMU%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%A7%E6%9C%89%E5%8A%B9%E3%80%817%20%E3%81%A4%E3%81%AE%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%3C%2FP%3E%3CP%3ECPU1%3A%E8%B5%B7%E5%8B%95%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3C%2FP%3E%3CP%3ECPU2%3A%E8%B5%B7%E5%8B%95%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3C%2FP%3E%3CP%3ECPU3%3A%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3C%2FP%3E%3CP%3E4%E3%81%A4%E3%81%AECPU%E3%82%92%E8%82%B2%E3%81%A6%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3ESMP%3A%E5%90%88%E8%A8%884%E3%81%A4%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%8C%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F(6324.22%20BogoMIPS)%E3%80%82%3C%2FP%3E%3CP%3Eprint_constraints%3A%E3%83%80%E3%83%9F%E3%83%BC%3A%20%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2016%3C%2FP%3E%3CP%3Eprint_constraints%3Avddpu%3A725%20%26lt%3B--%26gt%3B%20700%20mV%E3%81%AE%E9%80%9F%E3%81%84%E6%AD%A3%E5%B8%B8%E3%81%AA700%E3%81%AEmV%E3%81%A7%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vddcore%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20at%201150%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3Eprint_constraints%3Avddsoc%3A725%26lt%3B--%26gt%3B%201300%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vdd2p5%3A%202000%20%26lt%3B--%26gt%3B%202400%20mV%20%E3%81%A7%202775%20mV%20%E9%AB%98%E9%80%9F%E3%83%8E%E3%83%BC%E3%83%9E%E3%83%AB%20%3C%2FP%3E%3CP%3Eprint_constraints%3Avdd1p1%3A800%26lt%3B--%26gt%3B%201400%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3Avdd3p0%3A2625%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3E%E3%83%A9%E3%82%A4%E3%83%B3%E5%86%85mx6_sabresd_board_init%3A1809%3C%2FP%3E%3CP%3E%E3%83%A9%E3%82%A4%E3%83%B3%E5%86%85mx6_sabresd_board_init%3A1832%3C%2FP%3E%3CP%3Ehw-breakpoint%3A%206%20%E3%81%A4%E3%81%AE%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%A8%201%20%E3%81%A4%E3%81%AE%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Ehw-breakpoint%3A%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E7%94%A8%E3%81%AB%E4%BA%88%E7%B4%84%E3%81%95%E3%82%8C%E3%81%9F%201%20%E3%81%A4%E3%81%AE%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%80%82%3C%2FP%3E%3CP%3Ehw-breakpoint%3A%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E6%9C%80%E5%A4%A7%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF%204%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EL310%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%8C%E6%9C%89%E5%8A%B9%3C%2FP%3E%3CP%3El2x0%3A%2016%20%E9%80%9A%E3%82%8A%E3%80%81CACHE_ID%200x410000c7%E3%80%81AUX_CTRL%200x02070000%E3%80%81%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%E3%82%B5%E3%82%A4%E3%82%BA%3A%201048576%20B%3C%2FP%3E%3CP%3EBIO%3A0%E3%81%AB%E3%82%B9%E3%83%A9%E3%83%96%3CBIO-0%3E%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%3C%2FBIO-0%3E%3C%2FP%3E%3CP%3EMXS-DMA%20MXS-DMA-APBH%3A%E5%88%9D%E6%9C%9F%E5%8C%96%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3Eprint_constraints%3ASPKVDD%3A4200mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3Avmmc%3A3300%20mV%20%3C%2FP%3E%3CP%3Evgaarb%3A%20%E3%83%AD%E3%83%BC%E3%83%89%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3ESCSI%20%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Espi_imx%20imx6q-ecspi.0%3A%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3C%2FP%3E%3CP%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20usbfs%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Eusbcore%3A%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%83%8F%E3%83%96%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20USB%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%ABUSB%20OTG%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%80%81%24Revision%3A%201.55%20%24%3C%2FP%3E%3CP%3Eimx-i2c%20imx-i2c.1%3A%20%3CI2C_IMX_PROBE%3E%3C%2FI2C_IMX_PROBE%3E%3C%2FP%3E%3CP%3Eimx-i2c%20imx-i2c.1%3A%20%3CI2C_IMX_PROBE%3E%20bitrate%3A100000%3C%2FI2C_IMX_PROBE%3E%3C%2FP%3E%3CP%3Emc_pfuze%201-0008%3A%20ID%3A%200%E3%80%81%E3%83%95%E3%83%AB%E3%83%AC%E3%82%A4%3A%201%E3%80%81%E3%83%A1%E3%82%BF%E3%83%AB%E3%83%AC%E3%82%A4%3A%201%3C%2FP%3E%3CP%3Emc_pfuze%201-0008%3A%20FAB%3A%200%20%2CFIN%3A%200%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_SW1A%3A300%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_SW1B%3A300%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_SW1C%3A300%26lt%3B--%26gt%3B%201875%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_SW2%3A800%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_SW3A%3A400%20%26lt%3B--%26gt%3B%201975%20mV%E3%80%811500%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_SW3B%3A400%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_SW4%3A800%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_SWBST%3A5000%26lt%3B--%26gt%3B%205150%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_VSNVS%3A1200%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_VREFDDR%3A750mV%E3%81%A7%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_VGEN1%3A800%26lt%3B--%26gt%3B%201550%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_VGEN2%3A800%26lt%3B--%26gt%3B%201550%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_VGEN3%3A1800%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_VGEN4%3A1800%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_VGEN5%3A1800%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_VGEN6%3A1800%26lt%3B--%26gt%3B%203300%20mV%20%3C%2FP%3E%3CP%3EI2C%20I2C-1%3AIRQ%2069%E3%82%92%E4%B8%BB%E5%BC%B5%3C%2FP%3E%3CP%3EI2C%20I2C-1%3A%200x21a4000%20%E3%81%8B%E3%82%89%200x21a4fff%20%E3%81%BE%E3%81%A7%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%3C%2FP%3E%3CP%3EI2C%20I2C-1%3A%200x21a4000%20%E3%81%A7%204096%20%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%20%3C%2FP%3E%3CP%3EI2C%20I2C-1%3A%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E5%90%8D%3A%E3%80%8CIMX-I2C%E3%80%8D%3C%2FP%3E%3CP%3Ei2c%20i2c-1%3A%20IMX%20I2C%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Eimx-i2c%20imx-i2c.2%3A%20%3CI2C_IMX_PROBE%3E%3C%2FI2C_IMX_PROBE%3E%3C%2FP%3E%3CP%3Eimx-i2c%20imx-i2c.2%3A%20%3CI2C_IMX_PROBE%3E%20bitrate%3A100000%3C%2FI2C_IMX_PROBE%3E%3C%2FP%3E%3CP%3EI2C%20I2C-2%3AIRQ%2070%E3%82%92%E4%B8%BB%E5%BC%B5%3C%2FP%3E%3CP%3EI2C%20I2C-2%3A%200x21a8000%20%E3%81%8B%E3%82%89%200x21a8fff%20%E3%81%BE%E3%81%A7%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%3C%2FP%3E%3CP%3EI2C%20I2C-2%3A%200x21a8000%20%E3%81%A7%204096%20%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%20%3C%2FP%3E%3CP%3EI2C%20I2C-2%3A%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E5%90%8D%3A%E3%80%8CIMX-I2C%E3%80%8D%3C%2FP%3E%3CP%3Ei2c%20i2c-2%3A%20IMX%20I2C%20%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.0%3A%20IPU%20DMFC%20NORMAL%20mode%3A%201(0~1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.1%3A%20IPU%20DMFC%20NORMAL%20mode%3A%201(0~1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3Emxc_mipi_csi2%20mxc_mipi_csi2%3A%20i.MX%20MIPI%20CSI2%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Emxc_mipi_csi2%20mxc_mipi_csi2%3Ai.MX%20MIPI%20CSI2%20dphy%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8C0x3130302a%3C%2FP%3E%3CP%3EMIPI%20CSI2%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%83%BB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EAdvanced%20Linux%20Sound%20Architecture%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B31.0.24%E3%80%82%3C%2FP%3E%3CP%3EBluetooth%3A%E3%82%B3%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B32.16%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2031%3C%2FP%3E%3CP%3EBluetooth%3AHCI%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E6%8E%A5%E7%B6%9A%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3AHCI%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3AL2CAP%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3ASCO%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Ecfg80211%3A%20CRDA%20%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%A6%E4%B8%96%E7%95%8C%E3%81%AE%E8%A6%8F%E5%88%B6%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BMAX17135%5D%3C%2FP%3E%3CP%3EI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E3%83%AC%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A0%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%5BMAX17135%5D%3C%2FP%3E%3CP%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9mxc_timer1%E3%81%B8%E3%81%AE%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%202%3C%2FP%3E%3CP%3EIP%20%E3%83%AB%E3%83%BC%E3%83%88%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%2032768%20(%E9%A0%86%E5%BA%8F%3A%205%E3%80%81131072%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3ETCP%20%E7%A2%BA%E7%AB%8B%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20131072%20(%E9%A0%86%E5%BA%8F%3A%208%E3%80%811048576%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3ETCP%E3%83%90%E3%82%A4%E3%83%B3%E3%83%89%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A65536(%E9%A0%86%E5%BA%8F%3A7%E3%80%81786432%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3ETCP%3A%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99(%E3%83%90%E3%82%A4%E3%83%B3%E3%83%8965536%20131072%E7%A2%BA%E7%AB%8B)%3C%2FP%3E%3CP%3ETCP%20reno%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EUDP%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20512%20(%E9%A0%86%E5%BA%8F%3A%202%E3%80%8116384%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3EUDP-Lite%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20512%20(%E9%A0%86%E5%BA%8F%3A%202%E3%80%8116384%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%201%3C%2FP%3E%3CP%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%E5%90%8D%E5%89%8D%E3%81%AE%20UNIX%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E8%BB%A2%E9%80%81%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%20UDP%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%20tcp%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%20tcp%20NFSv4.1%20%E3%83%90%E3%83%83%E3%82%AF%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3EPMU%3A%E3%82%BF%E3%82%A4%E3%83%970%E3%81%AE%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%E6%96%B0%E3%81%97%E3%81%84PMU%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%ABi.MX6%E3%81%AE%E3%82%B9%E3%82%BF%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%83%BB%E3%83%91%E3%83%AF%E3%83%BC%E3%83%BB%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A1%E3%83%B3%E3%83%88%3C%2FP%3E%3CP%3Ei.MX6%20%E3%81%AE%E5%BE%85%E6%A9%9F%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%3C%2FP%3E%3CP%3Ecpaddr%20%3D%20c0880000%20suspend_iram_base%3Dc091c000%3C%2FP%3E%3CP%3EPM%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3EIMX%20PCIe%E3%83%9D%E3%83%BC%E3%83%88%3A%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3EPCI%3A%20bus0%3A%20%E9%AB%98%E9%80%9F%E3%83%90%E3%83%83%E3%82%AF%E3%83%84%E3%83%BC%E3%83%90%E3%83%83%E3%82%AF%E8%BB%A2%E9%80%81%E3%81%8C%E7%84%A1%E5%8A%B9%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3EPCI%3Abus1%3A%E9%AB%98%E9%80%9F%E3%83%90%E3%83%83%E3%82%AF%E3%83%84%E3%83%BC%E3%83%90%E3%83%83%E3%82%AF%E8%BB%A2%E9%80%81%E3%81%AF%E7%84%A1%E5%8A%B9%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3EPCI%200000%3A00%3A00.0%3A%E5%B0%8F%E7%AF%80%2014%3A%20assigned%20%5Bmem%200x01200000-0x013fffff%5D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3EPCI%200000%3A00%3A00.0%3A%E5%B0%8F%E7%AF%80%200%3A%20%E4%BB%A3%E5%85%A5%20%5Bmem%200x01100000-0x011fffff%2064bit%20pref%5D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3EPCI%200000%3A00%3A00.0%3ABAR%200%3A%20%5Bmem%200x01100000-0x011fffff%2064bit%20pref%5D%20(PCI%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%5B0x1100000-0x11fffff%5D)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3EPCI%200000%3A00%3A00.0%3A%E5%B0%8F%E7%AF%80%206%3A%20assigned%20%5Bmem%200x01400000-0x0140ffff%20pref%5D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3EPCI%200000%3A01%3A00.0%3ABAR%200%3A%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E6%B8%88%E3%81%BF%20%5Bmem%200x01200000-0x013fffff%2064bit%5D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3EPCI%200000%3A01%3A00.0%3ABAR%200%3A%5Bmem%200x01200000-0x013fffff%2064bit%5D(PCI%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%5B0x1200000-0x13fffff%5D)%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3EPCI%200000%3A00%3A00.0%3APCI%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%81%8B%E3%82%89%5B%E3%83%90%E3%82%B901-01%5D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3EPCI%200000%3A00%3A00.0%3A%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%20%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%20%5BIO%20%E7%84%A1%E5%8A%B9%5D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3EPCI%200000%3A00%3A00.0%3A%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%20%5BMEM%200x01200000-0x013fffff%5D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22text-decoration%3A%20underline%3B%22%3EPCI%200000%3A00%3A00.0%3A%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%20%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%20%5BMEM%20%E8%A8%AD%E5%AE%9A%E3%81%8C%E7%84%A1%E5%8A%B9%5D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EIMX%20USB%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3C%2FP%3E%3CP%3E%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%BD%E3%83%BC%E3%82%B9IRQ%2075%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FP%3E%3CP%3EIMX%20USB%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3C%2FP%3E%3CP%3ECPU%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%20init%20ldo%3D1%3C%2FP%3E%3CP%3E_regulator_get%3A%20%E8%AD%98%E5%88%A5%E5%AD%90%E3%81%AA%E3%81%97%E3%81%AE%20get()%3C%2FP%3E%3CP%3Emx6_cpu_regulator_init%3APU%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AE%E5%85%A5%E6%89%8B%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Ei.MXC%20CPU%E5%91%A8%E6%B3%A2%E6%95%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3EJFFS2%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.2.(NAND)%20%E6%BC%8F%202001-2006%20Red%20Hat%2C%20Inc.%3C%2FP%3E%3CP%3Emsgmni%20%E3%81%8C%201750%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%3C%2FP%3E%3CP%3Ealg%3A%20stdrng%20(krng)%20%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%AA%E3%81%97%3C%2FP%3E%3CP%3EIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9NOOP%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9%E3%81%AE%E7%B7%A0%E5%88%87%E6%97%A5%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3EIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9CFQ%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF(%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88)%3C%2FP%3E%3CP%3Emxc_mipi_dsi%20mxc_mipi_dsi%3A%20i.MX%20MIPI%20DSI%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EMIPI%20DSI%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.0%3AMXC%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCLDB%E3%81%AE%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%20valid%20mode%20RGB666%3C%2FP%3E%3CP%3E_regulator_get%3A%20%E8%AD%98%E5%88%A5%E5%AD%90%E3%81%AA%E3%81%97%E3%81%AE%20get()%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%3Aldb_clk%E3%81%8B%E3%82%89di%20clk%3Aldb_di0_clk%20-%26gt%3B%20ipu1_di0_clk%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%3A%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%A2%E3%83%BC%E3%83%89%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB0%E3%81%8B%E3%82%89IPU0-DI0%E3%81%B8%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%88%3C%2FP%3E%3CP%3E%E3%82%A4%E3%83%B3%E3%82%B5%E3%82%A4%E3%83%89%20ldb_disp_setup%20pixel_clk%3A64998000%20rounded_pixel_clk%3A64653061%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.0%3A%20IPU%20DMFC%20DP%20HIGH%20RESOLUTION%3A%201(0%2C1)%2C%205B(2~5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.0%3A%23%23%23%20fb_blank%E8%A1%8C%3A1039%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.0%3A%E7%A9%BA%E7%99%BD%20%3D%200%3C%2FP%3E%3CP%3E%E3%82%A4%E3%83%B3%E3%82%B5%E3%82%A4%E3%83%89%20ldb_disp_setup%20pixel_clk%3A64998000%20rounded_pixel_clk%3A64653061%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%3A%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9170x48%E3%81%B8%E3%81%AE%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.0%3Amxcfb_pan_display%E3%83%A9%E3%82%A4%E3%83%B3%3A1399%3C%2FP%3E%3CP%3E%23%23%23%20%E5%91%BC%E3%81%B0%E3%82%8Cfb_pan_display%20%E3%82%A8%E3%83%A9%E3%83%BC%3A-22%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.1%3AMXC%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCLDB%E3%81%AE%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%20valid%20mode%20RGB666%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%3A2%E7%95%AA%E7%9B%AE%E3%81%AEldb%20displdb%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E5%88%A5%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.1%3Amxc%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F!%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.2%3AMXC%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCLCD%E3%81%AE%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.2%3AIPU0-DI0%20%E3%81%AF%E6%97%A2%E3%81%AB%E4%BD%BF%E7%94%A8%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3Emxc_sdc_fb%3A%20mxc_sdc_fb.2%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-16%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.3%3AMXC%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCLDB%E3%81%AE%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%20valid%20mode%20RGB666%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%3A2%E7%95%AA%E7%9B%AE%E3%81%AEldb%20displdb%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E5%88%A5%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.3%3Amxc%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F!%3C%2FP%3E%3CP%3EIMX-SDMA%3A%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%201.1%20%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3Eimx-sdma%3A%20%E5%88%9D%E6%9C%9F%E5%8C%96%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3AIMX%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3Eimx-uart.2%3AMMIO%200x21ec000%20(irq%20%3D%2060)%20%E3%81%AE%20ttymxc2%20%E3%81%AF%20IMX%20%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20%5Bttymxc2%5D%20%E3%81%8C%E6%9C%89%E5%8A%B9%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%8C%E7%84%A1%E5%8A%B9%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20%5Bttymxc2%5D%20%E3%81%8C%E6%9C%89%E5%8A%B9%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%8C%E7%84%A1%E5%8A%B9%3C%2FP%3E%3CP%3Eloop%3A%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3ERESET%20HBA%20%E3%81%8B%E3%82%89%E5%9B%9E%E5%BE%A9%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3ESATA%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3EM25P80%20SPI0.0%3A%E8%AA%8D%E8%AD%98%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84JEDEC%20ID%20206a56%3C%2FP%3E%3CP%3EGPMI%20NAND%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82(IMX%E3%81%AE)%3C%2FP%3E%3CP%3Evcan%3A%20%E4%BB%AE%E6%83%B3%20CAN%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3ECAN%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3C%2FP%3E%3CP%3EFlexcan%20NetDevice%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FP%3E%3CP%3EFEC%20%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3Efec_enet_mii_bus%3A%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3C%2FP%3E%3CP%3Eehci_hcd%3A%20USB%202.0%20%E3%80%8C%E6%8B%A1%E5%BC%B5%E3%80%8D%E3%83%9B%E3%82%B9%E3%83%88%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%20(EHCI)%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3EOTG%20VBus%E5%A4%89%E6%9B%B4%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%82%92%E5%BE%85%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84!%20%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3EFSL-EHCI%20FSL-EHCI.0%3A%E6%96%B0%E3%81%97%E3%81%84USB%E3%83%90%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%80%81%E3%83%90%E3%82%B9%E7%95%AA%E5%8F%B71%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20irq%2075%2C%20io%20base%200x02184000%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%96%201-0%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%96%201-0%3A1.0%3A%201%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%BD%E3%83%BC%E3%82%B9IRQ%2072%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3EFSL-EHCI%20FSL-EHCI.1%3A%E6%96%B0%E3%81%97%E3%81%84USB%E3%83%90%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%80%81%E3%83%90%E3%82%B9%E7%95%AA%E5%8F%B72%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20irq%2072%2C%20io%20base%200x02184200%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%96%202-0%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%96%202-0%3A1.0%3A%201%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EUSB%E5%A4%A7%E5%AE%B9%E9%87%8F%E8%A8%98%E6%86%B6%E8%A3%85%E7%BD%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FP%3E%3CP%3Eusbcore%3A%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AEusb-storage%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3EUSB%E3%83%9E%E3%82%B9%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EARC%20USBOTG%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20(2005%20%E5%B9%B4%208%20%E6%9C%88%201%20%E6%97%A5)%3C%2FP%3E%3CP%3Emousedev%3A%20PS%2F2%20%E3%83%9E%E3%82%A6%E3%82%B9%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20(%E5%85%A8%E3%83%9E%E3%82%A6%E3%82%B9%E5%85%B1%E9%80%9A)%3C%2FP%3E%3CP%3E%E5%85%A5%E5%8A%9B%3A%20GPIO-keys%20as%20%2Fdevices%2Fplatform%2Fgpio-keys%2Finput%2Finput0%3C%2FP%3E%3CP%3EI2C-Core%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%5BISL29023%5D%20%E3%81%8C%E5%BE%93%E6%9D%A5%E3%81%AE%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3EI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E3%83%AC%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A0%E6%96%B9%E6%B3%95%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BISL29023%5D%3C%2FP%3E%3CP%3Esnvs_rtc%20snvs_rtc.0%3ARTC%E3%82%B3%E3%82%A2%3ARTC0%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2snvs_rtc%3C%2FP%3E%3CP%3Ei2c%20%2Fdev%20entries%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3Elirc_dev%3AIR%E3%83%AA%E3%83%A2%E3%82%B3%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%80%81%E3%83%A1%E3%82%B8%E3%83%A3%E3%83%BC252%20%3C%2FP%3E%3CP%3EIR%20NEC%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EIR%20RC5(x)%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EIR%20RC6%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EIR%20JVC%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%BB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EIR%20Sony%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EIR%20RC5%20(streamzap)%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EIR%20LIRC%20%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%20%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3ELinux%E3%83%93%E3%83%87%E3%82%AA%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3Av2.00%3C%2FP%3E%3CP%3EMVC%20%E3%81%AE%E5%A0%B4%E5%90%88%3A%20init_camera_struct%3C%2FP%3E%3CP%3EMVC%20%E3%81%AE%E5%A0%B4%E5%90%88%3A%20init_camera_struct%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20prp_enc_init%E3%83%A9%E3%82%A4%E3%83%B3%E5%86%85%E9%9D%A2%3A584%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20Inside%20csi_enc_init%20line%3A423%3C%2FP%3E%3CP%3Eadv7180_init%E5%B9%B4%E3%81%AB%3C%2FP%3E%3CP%3EDBG%20%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%20%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%2080b9f718%20%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Eadv7180_probe%E3%81%A7%3C%2FP%3E%3CP%3EInside%20mx6q_csi0_io_init_adv7441%20line%3A564%3C%2FP%3E%3CP%3E%E3%83%A9%E3%82%A4%E3%83%B3%E5%86%85mx6q_csi0_io_init_adv7441%3A577%20init%20high%3C%2FP%3E%3CP%3E%E3%83%A9%E3%82%A4%E3%83%B3%E5%86%85mx6q_csi0_io_init_adv7441%3A581%E3%82%92%E3%83%AD%E3%83%BC%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3E%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E5%86%85%E5%81%B4mx6q_csi0_io_init_adv7441%3A588%E3%82%92%E9%AB%98%E3%81%8F%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3E%E3%82%A4%E3%83%B3%E3%82%B5%E3%82%A4%E3%83%89mx6q_csi0_cam_powerdown_adv7441%E3%83%A9%E3%82%A4%E3%83%B3%3A559%3C%2FP%3E%3CP%3EADV7441A%201-0021%3A%20adv7180_probe%3AADV7180%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%20I2C%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AF0x21%3C%2FP%3E%3CP%3Eadv7441a%201-0021%3A%20adv7180_probe%3A%E3%82%A2%E3%83%8A%E3%83%AD%E3%82%B0%E3%83%BB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20adv7%2000%20%E6%A4%9C%E5%87%BA!%3C%2FP%3E%3CP%3Eadv7441a%201-0021%3A%20adv7180%3Aadv7180_hard_reset%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0x0%20val%3A0xe%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20%E7%99%BB%E9%8C%B2%3A0x3%20VAL%3A0x0%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0x4%20val%3A0x47%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20%E7%99%BB%E9%8C%B2%3A0x5%20%E8%A9%95%E4%BE%A1%3A0x0%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20%E7%99%BB%E9%8C%B2%3A0x3c%20%E8%A9%95%E4%BE%A1%3A0xad%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0x17%20val%3A0x41%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20%E7%99%BB%E9%8C%B2%3A0x67%20VAL%3A0x2%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0x68%20val%3A0xf0%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20%E7%99%BB%E9%8C%B2%3A0x1d%20VAL%3A0x40%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20%E7%99%BB%E9%8C%B2%3A0x31%20%E8%A9%95%E4%BE%A1%3A0x1a%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0x32%20val%3A0x81%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20%E7%99%BB%E9%8C%B2%3A0x33%20VAL%3A0x84%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20%E7%99%BB%E9%8C%B2%3A0x34%20%E8%A9%95%E4%BE%A1%3A0x0%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20REG%3A0x35%20VAL%3A0x0%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20%E7%99%BB%E9%8C%B2%3A0x36%20VAL%3A0x7d%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0x37%20val%3A0xa1%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20%E7%99%BB%E9%8C%B2%3A0x3a%20%E8%A9%95%E4%BE%A1%3A0x7%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0x3c%20val%3A0xa8%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20REG%3A0x47%20VAL%3A0xa%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0xba%20val%3A0xa0%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0xf3%20val%3A0x7%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20%E7%99%BB%E9%8C%B2%3A0x69%20VAL%3A0x0%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0xe8%20val%3A0x41%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0xe9%20val%3A0x84%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%20adv7180_write_reg%20reg%3A0xea%20val%3A0x6%3C%2FP%3E%3CP%3Etype%20%E3%81%AF%202%20(expect%202)%20%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3Eioctls%20%E3%81%AE%E6%95%B0%E3%81%AF%2011%20%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3EADV7441A%201-0021%3A%20ADV7180%3Aioctl_s_power%3C%2FP%3E%3CP%3EADV7441A%201-0021%3A%20ADV7180%3Aioctl_g_fmt_cap%3C%2FP%3E%3CP%3E720x625%20%E3%81%AE%E6%88%BB%E3%82%8A%E5%80%A4%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%3C%2FP%3E%3CP%3Emxc_v4l2_master_attach%E5%B9%B4%E6%9C%AB%3Adevice_type%201%3C%2FP%3E%3CP%3Emxc_v4l2_master_attach%E3%81%AE%E7%B5%82%E3%82%8F%E3%82%8A%3Av2f%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E5%B9%85x%E9%AB%98%E3%81%95288%20x%20352%3C%2FP%3E%3CP%3Emxc_v4l2_master_attach%E3%81%AE%E7%B5%82%E3%82%8F%E3%82%8A%3Acrop_bounds%E5%B9%85x%E9%AB%98%E3%81%95720%C3%97625%3C%2FP%3E%3CP%3Emxc_v4l2_master_attach%E3%81%AE%E7%B5%82%E3%82%8F%E3%82%8A%3Acrop_defrect%E5%B9%85x%E9%AB%98%E3%81%95720%C3%97625%3C%2FP%3E%3CP%3Emxc_v4l2_master_attach%E3%81%AE%E7%B5%82%E3%82%8F%E3%82%8A%3Acrop_current%E5%B9%85x%E9%AB%98%E3%81%95720%C3%97625%3C%2FP%3E%3CP%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%E3%83%93%E3%83%87%E3%82%AA%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FV4L2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B916%3C%2FP%3E%3CP%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%E3%83%93%E3%83%87%E3%82%AA%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FV4L2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B917%3C%2FP%3E%3CP%3EGSPCA%3Av2.13.0%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3ECX25858%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.0.111%E3%83%AD%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3ECX25858%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E5%A4%B1%E6%95%97%3C%2FP%3E%3CP%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20uvcvideo%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3EUSB%E3%83%93%E3%83%87%E3%82%AA%E3%82%AF%E3%83%A9%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC(v1.1.0)%3C%2FP%3E%3CP%3EI2C-Core%3A%20%E5%BE%93%E6%9D%A5%E3%81%AE%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%5BMAG3110%5D%3C%2FP%3E%3CP%3EI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E3%83%AC%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A0%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BMAG3110%5D%3C%2FP%3E%3CP%3EIMX2-WDT%20IMX2-WDT.0%3AIMX2%2B%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%3D60%E7%A7%92%20(nowayout%3D1)%3C%2FP%3E%3CP%3EBluetooth%3A%E4%BB%AE%E6%83%B3HCI%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCver%201.3%3C%2FP%3E%3CP%3EBluetooth%3AHCI%20UART%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCver%202.2%3C%2FP%3E%3CP%3EBluetooth%3A%20HCIATH3K%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3A%E6%B1%8E%E7%94%A8Bluetooth%20USB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCver%200.6%3C%2FP%3E%3CP%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20btusb%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Esdhci%3A%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%BB%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%83%BB%E3%83%9B%E3%82%B9%E3%83%88%E3%83%BB%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%83%BB%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3Esdhci%3A%20Copyright(c)%20Pierre%20Ossman%20(%E8%8B%B1%E8%AA%9E)%3C%2FP%3E%3CP%3Esdhci%20sdhci-esdhc-imx.3%3Asupport_8bit%3A1%3C%2FP%3E%3CP%3Emmc0%3A%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20%5BSDHCI-ESDHC-IMX.3%5D%20%E4%B8%8A%E3%81%AE%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BCDMA%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3Esdhci%20sdhci-esdhc-imx.1%3Asupport_8bit%3A1%3C%2FP%3E%3CP%3Emmc1%3A%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20%5BSDHCI-ESDHC-IMX.1%5D%20%E4%B8%8A%E3%81%AE%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BCDMA%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3Esdhci%20sdhci-esdhc-imx.2%3Asupport_8bit%3A1%3C%2FP%3E%3CP%3Emmc2%3A%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20%5BSDHCI-ESDHC-IMX.2%5D%20%E4%B8%8A%E3%81%AE%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BCDMA%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3Emxc_vdoa%20mxc_vdoa%3A%20i.MX%20Video%20Data%20Order%20Adapter%20(VDOA)%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EVPU%20%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E7%99%BB%E9%8C%B2mxc_asrc%3C%2FP%3E%3CP%3E%E6%B8%A9%E5%BA%A6%E6%A0%A1%E6%AD%A3%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF0x5784c37d%3C%2FP%3E%3CP%3EAnatop%20Thermal%20%E3%81%AF%20thermal_zone0%20%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Eanatop_thermal_probe%3A%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E5%86%B7%E5%8D%B4%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AFCPUFreq%E3%81%A7%E3%81%99!%3C%2FP%3E%3CP%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20usbhid%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Eusbhid%3A%20USB%20HID%20%E3%82%B3%E3%82%A2%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCsnd-usb-audio%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Emxc_hdmi_soc%20mxc_hdmi_soc.0%3AMXC%20HDMI%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%3C%2FP%3E%3CP%3ECirrus%20Logic%20CS42888%20ALSA%20SoC%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3EI2C-Core%3A%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BCS42888%5D%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3EI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E5%86%8D%E9%96%8B%E6%96%B9%E6%B3%95%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BCS42888%5D%3C%2FP%3E%3CP%3Eimx-hdmi-soc-dai%3A%20imx-hdmi-soc-dai.0%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-12%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Eimx_3stack%20ASOC%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3EALSA%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E4%B8%80%E8%A6%A7%3A%3C%2FP%3E%3CP%3E%E3%82%B5%E3%82%A6%E3%83%B3%E3%83%89%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3Emmc0%3A%20%E6%96%B0%E3%81%97%E3%81%84%E9%AB%98%E9%80%9F%20DDR%20MMC%20%E3%82%AB%E3%83%BC%E3%83%89%20(%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200001)%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2026%3C%2FP%3E%3CP%3Emmcblk0%3A%20mmc0%3A0001%20SEM08G%207.39%20GiB%20%3C%2FP%3E%3CP%3Emmcblk0boot0%3A%20mmc0%3A0001%20SEM08G%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%201%202.00%20MiB%3C%2FP%3E%3CP%3Emmcblk0boot1%3A%20mmc0%3A0001%20SEM08G%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%202%202.00%20MiB%3C%2FP%3E%3CP%3ETCP%E3%82%AD%E3%83%A5%E3%83%BC%E3%83%93%E3%83%83%E3%82%AF%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%20mmcblk0%3A%20p1%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2017%3C%2FP%3E%3CP%3ECAN%3A%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%82%A8%E3%83%AA%E3%82%A2%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B3%E3%82%A2(REB%2020090105%20ABI%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2029%3C%2FP%3E%3CP%3ECAN%3ARAW%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB(Rev%2020090105)%3C%2FP%3E%3CP%3ECAN%3A%20%E3%83%96%E3%83%AD%E3%83%BC%E3%83%89%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%20%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20(%E6%94%B9%E8%A8%82%E7%89%88%2020090105%20T)%3C%2FP%3E%3CP%3E%20mmcblk0boot1%3A%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E4%B8%8D%E6%98%8E%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3EBluetooth%3ARFCOMM%20TTY%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%20mmcblk0boot0%3A%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E4%B8%8D%E6%98%8E%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3EBluetooth%3ARFCOMM%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3ARFCOMM%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B31.11%3C%2FP%3E%3CP%3EBluetooth%3ABNEP(%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3)ver%201.3%3C%2FP%3E%3CP%3EBluetooth%3ABNEP%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%3A%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%9E%E3%83%AB%E3%83%81%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%3C%2FP%3E%3CP%3EBluetooth%3AHIDP(%E3%83%92%E3%83%A5%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3)ver%201.2%3C%2FP%3E%3CP%3Elib80211%3A%20IEEE802.11%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E5%85%B1%E9%80%9A%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%3C%2FP%3E%3CP%3EVFP%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20v0.3%3A%20implementor%2041%20architecture%203%20part%2030%20variant%209%20rev%204%3C%2FP%3E%3CP%3E%E3%83%90%E3%82%B9%E5%91%A8%E6%B3%A2%E6%95%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%83%90%E3%82%B9%E5%91%A8%E6%B3%A2%E6%95%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%E6%9C%89%E5%8A%B9%3C%2FP%3E%3CP%3Emxc_dvfs_core_probe%3C%2FP%3E%3CP%3EDVFS%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Eregulator_init_complete%3A%20PFUZE100_VGEN6%3A%20%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%AA%E5%88%B6%E7%B4%84%E3%80%81%E3%82%AA%E3%83%B3%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3Eregulator_init_complete%3A%20PFUZE100_VGEN3%3A%20%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%AA%E5%88%B6%E7%B4%84%E3%80%81%E3%82%AA%E3%83%B3%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3Eregulator_init_complete%3A%20PFUZE100_VGEN2%3A%20%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%AA%E5%88%B6%E7%B4%84%E3%80%81%E3%82%AA%E3%83%B3%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3Eregulator_init_complete%3A%20PFUZE100_VGEN1%3A%20%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%AA%E5%88%B6%E7%B4%84%E3%80%81%E3%82%AA%E3%83%B3%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3Eregulator_init_complete%3A%20SPKVDD%3A%20%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%AA%E5%88%B6%E7%B4%84%E3%80%81%E3%82%AA%E3%83%B3%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Esnvs_rtc%20snvs_rtc.0%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%201970-01-01%2008%3A04%3A21%20UTC%20(29061)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3EEXT2-fs%20(mmcblk0p1)%3A%20%E8%AD%A6%E5%91%8A%3A%20%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%20fs%20%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%80%81e2fsck%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EVFS%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20179%3A1%20%E3%81%AB%E3%83%AB%E3%83%BC%E3%83%88%20(ext2%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0)%20%E3%82%92%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Einit%20%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E8%A7%A3%E6%94%BE%3A%20212K%3C%2FP%3E%3CP%3Epid%201440%20%E4%BB%A5%E9%99%8D%E3%80%81tty%20''%3A%20'%2Fetc%2Frc.d%2FrcS'%3C%2FP%3E%3CP%3E%2Fproc%20%E3%81%A8%20%2Fsys%20%E3%81%AE%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%20%3C%2FP%3E%3CP%3E%E3%83%9B%E3%83%83%E3%83%88%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%83%87%E3%82%A3%E3%82%B9%E3%83%91%E3%83%83%E3%83%81%E3%83%A3%E3%83%BCudevd%E3%81%AE%E8%B5%B7%E5%8B%95%3C%2FP%3E%3CP%3Eudevd%20(1449)%3A%20%2Fproc%2F1449%2Foom_adj%20%E3%81%AF%E9%9D%9E%E6%8E%A8%E5%A5%A8%E3%81%A7%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20%2Fproc%2F1449%2Foom_score_adj%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E5%88%9D%E6%9C%9F%E3%83%9B%E3%83%83%E3%83%88%E3%83%97%E3%83%A9%E3%82%B0%E3%83%BB%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%81%AE%E5%90%88%E6%88%90%3C%2FP%3E%3CP%3Emmc2%3A%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%201234%20%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E9%AB%98%E9%80%9F%20SDHC%20%E3%82%AB%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3Emmcblk1%3A%20mmc2%3A1234%20SA08G%207.28%20GiB%20%3C%2FP%3E%3CP%3E%20MMCBLK1%3AP1%3C%2FP%3E%3CP%3E%E3%83%9B%E3%82%B9%E3%83%88%E5%90%8D%E3%82%92%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%3C%2FP%3E%3CP%3Ecp%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%8C%E6%AE%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Ecp%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%8C%E6%AE%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Ecp%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%8C%E6%AE%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Ecp%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%8C%E6%AE%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Ecp%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%8C%E6%AE%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Ecp%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%8C%E6%AE%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Ecp%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%8C%E6%AE%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Ecp%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%8C%E6%AE%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Ecp%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%8C%E6%AE%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Ecp%3A%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A8%E3%83%A9%E3%83%BC%3A%20EXT2-fs%20(mmcblk0p1)%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20ext2_lookup%3A%20%E5%8F%82%E7%85%A7%E3%81%95%E3%82%8C%E3%81%9F%20i%20%E3%83%8E%E3%83%BC%E3%83%89%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20234449%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E7%A9%BA%E3%81%8D%E5%AE%B9%E9%87%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Ecp%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A8%E3%83%A9%E3%83%BC%3AdeviceEXT2-fs(mmcblk0p1)%E3%81%AB%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%8C%E6%AE%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3A%E3%82%A8%E3%83%A9%E3%83%BC%3Aext2_lookup%3A%E5%8F%82%E7%85%A7%E3%81%95%E3%82%8C%E3%81%9Fi%E3%83%8E%E3%83%BC%E3%83%89%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A234449%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ecp%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A8%E3%83%A9%E3%83%BC%3AEXT2-fs(mmcblk0p1)%E3%81%8C%E6%AE%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3A%E3%82%A8%E3%83%A9%E3%83%BC%3Aext2_lookup%3A%E5%8F%82%E7%85%A7%E3%81%95%E3%82%8C%E3%81%9Fi%E3%83%8E%E3%83%BC%E3%83%89%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A234449%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E4%B8%8A%3C%2FP%3E%3CP%3Ecp%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%8C%E6%AE%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Ecp%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%8C%E6%AE%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Ecp%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%8C%E6%AE%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Ecp%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%8C%E6%AE%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Eln%3A%20%2Fetc%2Fmtab%3A%20%E5%85%A5%E5%87%BA%E5%8A%9B%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FP%3E%3CP%3Emount%3A%20%2Fproc%2Fbus%2Fusb%20%E3%81%B8%E3%81%AE%20usbfs%20%E3%81%AE%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%84%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%E3%83%9D%E3%83%BC%E3%83%88%E3%83%9E%E3%83%83%E3%83%91%E3%83%BC%E3%81%AE%E8%B5%B7%E5%8B%95%3A%20%3C%2FP%3E%3CP%3Eboa%20Web%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AE%E8%B5%B7%E5%8B%95%3A%20%3C%2FP%3E%3CP%3ERPM%E3%83%87%E3%83%BC%E3%82%BF%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E5%86%8D%E6%A7%8B%E7%AF%89%3C%2FP%3E%3CP%3Erpmdb%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%3A0x7e977654%E3%80%818192%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%8C%E6%AE%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20dbenv-%26gt%3Bopen%20%E3%81%8B%E3%82%89%E3%81%AE%20db4%20%E3%82%A8%E3%83%A9%E3%83%BC%20(28)%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%8C%E6%AE%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92%E9%96%8B%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Epid%202772%20%E4%BB%A5%E9%99%8D%E3%80%81tty%20''%3A%20'%2Fetc%2Frc.d%2Frc_gpu.S'%3C%2FP%3E%3CP%3EEXT2-fs%20(mmcblk0p1)%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20ext2_lookup%3A%20%E5%8F%82%E7%85%A7%E3%81%95%E3%82%8C%E3%81%9F%20i%20%E3%83%8E%E3%83%BC%E3%83%89%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20363702%3C%2FP%3E%3CP%3EEXT2-fs%20(mmcblk0p1)%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20ext2_lookup%3A%20%E5%8F%82%E7%85%A7%E3%81%95%E3%82%8C%E3%81%9F%20i%20%E3%83%8E%E3%83%BC%E3%83%89%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20363702%3C%2FP%3E%3CP%3EEXT2-fs%20(mmcblk0p1)%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20ext2_lookup%3A%20%E5%8F%82%E7%85%A7%E3%81%95%E3%82%8C%E3%81%9F%20i%20%E3%83%8E%E3%83%BC%E3%83%89%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20363702%3C%2FP%3E%3CP%3Eln%3A%20%2Fusr%2Flib%2FlibOpenVG.so%3A%E5%85%A5%E5%87%BA%E5%8A%9B%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FP%3E%3CP%3Epid%202779%20%E3%82%92%E9%96%8B%E5%A7%8B%E3%80%81tty%20''%3A%20'%2Fetc%2Frc.d%2Frc_mxc.S'%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Earm-none-linux-gnueabi-gcc%20(Freescale%20MAD%20--%20Linaro%202011.07%20--%202011%2F08%2F10%2009%3A20%20%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89)%204.6.220110630(%E3%83%97%E3%83%AC%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9)%3C%2FP%3E%3CP%3E%E3%83%AB%E3%83%BC%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%E3%81%AB%E6%A7%8B%E7%AF%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20Sun%2C%2028%20Jul%202013%2002%3A45%3A43%20%2B0800%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%BB%E3%83%9F%E3%82%B3%E3%83%B3%E3%83%80%E3%82%AF%E3%82%BF%E6%A0%AA%E5%BC%8F%E4%BC%9A%E7%A4%BE%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%3A%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPCIe%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126643%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126643%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%81%BF%E3%82%93%E3%81%AA%E3%80%82%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERC%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%ABRoute%20Complex%20Integrated%20End%20Point%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%81RC%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%B8%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6%E5%8F%96%E5%BE%97%E3%81%97%E3%81%9F%E3%81%AE%E3%81%8B%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%8A%A9%E3%81%91%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126642%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126642%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%81%E3%83%83%E3%83%97(mcs9990)%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FPCIe%E7%B5%8C%E7%94%B1%E3%81%A7USB%E3%82%92%E6%8B%A1%E5%BC%B5%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%A5%87%E5%A6%99%E3%81%AA%E3%81%93%E3%81%A8%E3%81%AB%E3%80%81PCIe%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%8C%E8%89%AF%E5%A5%BD%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%E7%B4%8410%E7%A7%92%E5%BE%8C%E3%81%AB%E5%81%9C%E6%AD%A2%E3%81%97%E3%80%81%E3%80%8CPCIe%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%8D%E3%81%A8%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%8Cpcie%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AE%E3%83%AD%E3%82%B0%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5Dcgroup%20subsys%20cpu%20%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5DLinux%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B33.0.35-2666-gbdde708(oser%40macbook)(GCC%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B34.6.220110630%20(%E3%83%97%E3%83%AC%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9)%20(Freescale%20MAD%20--%20Linaro%202011.07%20--%202011%2F08%20%E3%81%AB%E6%A7%8B%E7%AF%89)%3C%2FP%3E%3CP%3E%2F10%2009%3A20)%20)%20%236%20SMP%20Tue%20Sep%2017%2009%3A04%3A37%20CEST%202013%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5DCPU%3A%20ARMv7%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20%5B412fc09a%5D%20%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%2010%20(ARMv7)%E3%80%81cr%3D10c5387d%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5DCPU%3A%20VIPT%20%E9%9D%9E%E3%82%A8%E3%82%A4%E3%83%AA%E3%82%A2%E3%82%B7%E3%83%B3%E3%82%B0%20%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%80%81VIPT%20%E3%82%A8%E3%82%A4%E3%83%AA%E3%82%A2%E3%82%B7%E3%83%B3%E3%82%B0%E5%91%BD%E4%BB%A4%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%E3%83%9E%E3%82%B7%E3%83%B3%3ADynsense%20DS7109%E3%83%9C%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%9D%E3%83%AA%E3%82%B7%E3%83%BC%3A%20ECC%20%E3%81%8C%E7%84%A1%E5%8A%B9%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20writealloc%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5DCPU%20%E3%81%AF%20i.MX6Q%E3%80%81%E3%82%B7%E3%83%AA%E3%82%B3%E3%83%B3%20rev%201.2%20%E3%81%A8%E8%AD%98%E5%88%A5%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5DPERCPU%3A%E5%9F%8B%E3%82%81%E8%BE%BC%E3%81%BF7%E3%83%9A%E3%83%BC%E3%82%B8%2F%20CPU%20%40cc006000%20s5728%20r8192%20d14752%20u32768%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%E3%82%BE%E3%83%BC%E3%83%B3%E9%A0%86%E3%81%AB1%E3%81%A4%E3%81%AE%E3%82%BE%E3%83%BC%E3%83%B3%E3%83%AA%E3%82%B9%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%83%A2%E3%83%93%E3%83%AA%E3%83%86%E3%82%A3%E3%81%AE%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E5%8C%96%E3%82%92%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%B7%8F%E3%83%9A%E3%83%BC%E3%82%B8%E6%95%B0%3A260096%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%3A%20console%3Dttymxc3%2C115200%20root%3D%2Fdev%2Fmmcblk0p3%20rootwait%20rw%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5DPID%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%204096%20(%E9%A0%86%E5%BA%8F%3A%202%E3%80%8116384%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5DDentry%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20131072%20(%E9%A0%86%E5%BA%8F%3A%207%E3%80%81524288%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5Dinode-cache%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%2065536%20(%E9%A0%86%E5%BA%8F%3A%206%E3%80%81262144%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%E3%83%A1%E3%83%A2%E3%83%AA%3A1024MB%20%3D%20%E5%90%88%E8%A8%881024MB%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%E3%83%A1%E3%83%A2%E3%83%AA%3A1033972k%20%2F%201033972k%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%80%8114604k%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF%E3%80%81360448K%E9%AB%98%E3%83%A1%E3%83%A2%E3%83%AA%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%E4%BB%AE%E6%83%B3%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%3A%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%E3%83%99%E3%82%AF%E3%82%BF%E3%83%BC%20%3A%200xffff0000%20-%200xffff1000%20(%204%20kB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20fixmap%26nbsp%3B%20%3A%200xfff00000%20-%200xfffe0000%26nbsp%3B%26nbsp%3B%20(%20896%20kB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5DDMA%20%3A%200xf4600000%20-%200xffe00000%20(%20184%20MB)%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vmalloc%20%3A%200xea800000%20-%200xf2000000%26nbsp%3B%26nbsp%3B%20(%20120%20MB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20lowmem%26nbsp%3B%20%3A%200xc0000000%20-%200xea000000%26nbsp%3B%26nbsp%3B%20(%20672%20MB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pkmap%26nbsp%3B%26nbsp%3B%20%3A%200xbfe00000%20-%200xc0000000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%26nbsp%3B%202%20MB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20modules%20%3A%200xbf000000%20-%200xbfe00000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%2014%20MB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.init%20%3A%200xc0008000%20-%200xc0033000%26nbsp%3B%26nbsp%3B%20(%20172%20kB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.text%20%3A%200xc0033000%20-%200xc04ce188%26nbsp%3B%26nbsp%3B%20(4717%20kB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.data%20%3A%200xc04d0000%20-%200xc05149e0%26nbsp%3B%26nbsp%3B%20(%20275%20kB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.bss%20%3A%200xc0514a04%20-%200xc05570a8%26nbsp%3B%26nbsp%3B%20(%20266%20kB)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5DSLUB%3A%20Genslabs%3D13%2C%20HWalign%3D32%2C%20Order%3D0-3%2C%20MinObjects%3D0%2C%20CPUs%3D4%2C%20Nodes%3D1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%E9%9A%8E%E5%B1%A4%E5%9E%8B%20RCU%20%E3%81%AE%E5%AE%9F%E8%A3%85%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20NR_IRQS%3A624%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5DMXC%20GPIO%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5Dsched_clock%3A3000kHz%E3%81%A732%E3%83%93%E3%83%83%E3%83%88%E3%80%81%E8%A7%A3%E5%83%8F%E5%BA%A6333ns%E3%80%811431655ms%E3%81%94%E3%81%A8%E3%81%AB%E3%83%A9%E3%83%83%E3%83%97%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%20arm_max_freq%3D1GHz%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5DMMIO%200x21f0000%20%E3%81%AE%20MXC_Early%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20(%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%20'115200')%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%E3%83%96%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20%5Bttymxc3%5D%20%E6%9C%89%E5%8A%B9%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.000000%5D%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%3A%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%80%E3%83%9F%E3%83%BC%E3%83%87%E3%83%90%E3%82%A4%E3%82%B980x30%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.217079%5D%E9%81%85%E5%BB%B6%E3%83%AB%E3%83%BC%E3%83%97%E3%82%92%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...1581.05%20BogoMIPS(lpj%20%3D%207905280)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.305391%5Dpid_max%3A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%3A%2032768%20%E6%9C%80%E5%B0%8F%3A%20301%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.310317%5D%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%83%BB%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%83%BC%E6%95%B0%3A%20512%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.315667%5DCPU%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE%E3%82%B3%E3%83%92%E3%83%BC%E3%83%AC%E3%83%B3%E3%82%B7%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%3AOK%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.320824%5Dhw%20perfevents%3A%20ARMv7%20Cortex-A9%20PMU%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%A7%E6%9C%89%E5%8A%B9%E3%80%817%20%E3%81%A4%E3%81%AE%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.330207%5DCPU1%3A%E8%B5%B7%E5%8B%95%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.361619%5DCPU2%3A%E8%B5%B7%E5%8B%95%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.401646%5DCPU3%3A%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.440862%5D4%E3%81%A4%E3%81%AECPU%E3%82%92%E8%82%B2%E3%81%A6%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.456684%5DSMP%3A%E5%90%88%E8%A8%884%E3%81%A4%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%8C%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F(6324.22%20BogoMIPS)%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.463648%5Ddevtmpfs%3A%20%E5%88%9D%E6%9C%9F%E5%8C%96%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.485974%5Dprint_constraints%3A%E3%83%80%E3%83%9F%E3%83%BC%3A%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.489947%5DNET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2016%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.498839%5Dprint_constraints%3Avddpu%3A725%20%26lt%3B--%26gt%3B%201150%20mV%E3%81%AE%E9%80%9F%E3%81%84%E6%AD%A3%E5%B8%B8%E3%81%AA1300%20mV%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.506463%5Dprint_constraints%3A%20vddcore%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20at%201150%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.514251%5Dprint_constraints%3Avddsoc%3A725%26lt%3B--%26gt%3B%201300%20mV%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.521978%5Dprint_constraints%3A%20vdd2p5%3A%202000%20%26lt%3B--%26gt%3B%202400%20mV%20%E3%81%A7%202775%20mV%20%E9%AB%98%E9%80%9F%E3%83%8E%E3%83%BC%E3%83%9E%E3%83%AB%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.529772%5Dprint_constraints%3Avdd1p1%3A800%26lt%3B--%26gt%3B%201400%20mV%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.537479%5Dprint_constraints%3Avdd3p0%3A2625%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.549656%5Dhw-breakpoint%3A%206%20%E3%81%A4%E3%81%AE%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%A8%201%20%E3%81%A4%E3%81%AE%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.556488%5Dhw-breakpoint%3A%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E7%94%A8%E3%81%AB%E4%BA%88%E7%B4%84%E3%81%95%E3%82%8C%E3%81%9F%201%20%E3%81%A4%E3%81%AE%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.563843%5Dhw-breakpoint%3A%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E6%9C%80%E5%A4%A7%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF%204%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.569727%5DL310%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%8C%E6%9C%89%E5%8A%B9%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.573764%5Dl2x0%3A%2016%20%E9%80%9A%E3%82%8A%E3%80%81CACHE_ID%200x410000c7%E3%80%81AUX_CTRL%200x02070000%E3%80%81%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%E3%82%B5%E3%82%A4%E3%82%BA%3A%201048576%20B%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.583862%5DIMX%20USB%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.587238%5DIMX%20USB%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.599086%5DBIO%3A0%E3%81%AB%E3%82%B9%E3%83%A9%E3%83%96%3CBIO-0%3E%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%3C%2FBIO-0%3E%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.606129%5DMXS-DMA%20MXS-DMA-APBH%3A%E5%88%9D%E6%9C%9F%E5%8C%96%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.610956%5Dprint_constraints%3Avmmc%3A3300%20mV%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.616092%5DSCSI%20%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.620426%5Dusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20usbfs%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.626188%5Dusbcore%3A%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%83%8F%E3%83%96%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.631680%5Dusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20USB%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.638581%5D%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9mxc_timer1%E3%81%B8%E3%81%AE%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.643177%5Dcfg80211%3A%20CRDA%20%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%A6%E4%B8%96%E7%95%8C%E3%81%AE%E8%A6%8F%E5%88%B6%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.657854%5DNET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%202%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.662438%5DIP%20%E3%83%AB%E3%83%BC%E3%83%88%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%2032768%20(%E9%A0%86%E5%BA%8F%3A%205%E3%80%81131072%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.670374%5DTCP%20%E7%A2%BA%E7%AB%8B%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20131072%20(%E9%A0%86%E5%BA%8F%3A%208%E3%80%811048576%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.679660%5DTCP%20%E3%83%90%E3%82%A4%E3%83%B3%E3%83%89%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%2065536%20(%E9%A0%86%E5%BA%8F%3A%207%E3%80%81524288%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.687383%5DTCP%3A%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99(%E3%83%90%E3%82%A4%E3%83%B3%E3%83%8965536%20131072%E7%A2%BA%E7%AB%8B)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.694025%5DTCP%20reno%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.697184%5DUDP%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20512%20(%E9%A0%86%E5%BA%8F%3A%202%E3%80%8116384%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.703180%5DUDP-Lite%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20512%20(%E9%A0%86%E5%BA%8F%3A%202%E3%80%8116384%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.710009%5DNET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%201%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.714674%5DRPC%3A%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%E5%90%8D%E5%89%8D%E3%81%AE%20UNIX%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E8%BB%A2%E9%80%81%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.720613%5DRPC%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%20UDP%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.725342%5DRPC%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%20tcp%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.730061%5DRPC%3A%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%20tcp%20NFSv4.1%20%E3%83%90%E3%83%83%E3%82%AF%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.737627%5DPMU%3A%E3%82%BF%E3%82%A4%E3%83%970%E3%81%AE%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%E6%96%B0%E3%81%97%E3%81%84PMU%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.742741%5D%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%ABi.MX6%E3%81%AE%E3%82%B9%E3%82%BF%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%83%BB%E3%83%91%E3%83%AF%E3%83%BC%E3%83%BB%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A1%E3%83%B3%E3%83%88%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.747994%5Di.MX6%20%E3%81%AE%E5%BE%85%E6%A9%9F%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.752315%5D%20cpaddr%20%3D%20ea880000%20suspend_iram_base%3Dea828000%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.757735%5DPM%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.761300%5D%20iMX6%20PCIe%20PCIe%20RC%20mode%20imx_pcie_pltfm_probe%20entering.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.873230%5DPCIE%3A%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E9%96%8B%E5%A7%8Bimx_pcie_pltfm_probe%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.896452%5DIMX%20PCIe%E3%83%9D%E3%83%BC%E3%83%88%3A%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.900472%5DPCI%3A%20bus0%3A%20%E9%AB%98%E9%80%9F%E3%83%90%E3%83%83%E3%82%AF%E3%83%84%E3%83%BC%E3%83%90%E3%83%83%E3%82%AF%E8%BB%A2%E9%80%81%E3%81%8C%E7%84%A1%E5%8A%B9%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.923438%5DPCI%3Abus1%3A%E9%AB%98%E9%80%9F%E3%83%90%E3%83%83%E3%82%AF%E3%83%84%E3%83%BC%E3%83%90%E3%83%83%E3%82%AF%E8%BB%A2%E9%80%81%E3%81%AF%E7%84%A1%E5%8A%B9%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.931153%5DPCI%200000%3A00%3A00.0%3A%E5%B0%8F%E7%AF%80%200%3A%20%E4%BB%A3%E5%85%A5%20%5Bmem%200x01000000-0x010fffff%2064bit%20pref%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.938948%5DPCI%200000%3A00%3A00.0%3ABAR%200%3A%20%5Bmem%200x01000000-0x010fffff%2064bit%20pref%5D%20(PCI%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%5B0x1000000-0x10fffff%5D)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.949687%5DPCI%200000%3A00%3A00.0%3ABAR%208%3A%20assigned%20%5Bmem%200x01100000-0x011fffff%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.956506%5DPCI%200000%3A00%3A00.0%3A%E5%B0%8F%E7%AF%80%206%3A%20assigned%20%5Bmem%200x01200000-0x0120ffff%20pref%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.963769%5DPCI%200000%3A01%3A00.0%3A%E5%B0%8F%E7%AF%80%200%3A%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E6%B8%88%E3%81%BF%20%5Bmem%200x01100000-0x01100fff%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.970587%5DPCI%200000%3A01%3A00.0%3ABAR%200%3A%20%5Bmem%200x01100000-0x01100fff%5D%20(PCI%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%5B0x1100000-0x1100fff%5D)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.980365%5DPCI%200000%3A01%3A00.1%3A%E5%B0%8F%E7%AF%80%200%3A%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E6%B8%88%E3%81%BF%20%5Bmem%200x01101000-0x01101fff%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.987190%5DPCI%200000%3A01%3A00.1%3ABAR%200%3A%20%5Bmem%200x01101000-0x01101fff%5D%20(PCI%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%5B0x1101000-0x1101fff%5D)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.996968%5DPCI%200000%3A01%3A00.2%3A%E5%B0%8F%E7%AF%80%200%3A%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E6%B8%88%E3%81%BF%20%5Bmem%200x01102000-0x01102fff%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.003804%5DPCI%200000%3A01%3A00.2%3ABAR%200%3A%20%5Bmem%200x01102000-0x01102fff%5D%20(PCI%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%5B0x1102000-0x1102fff%5D)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.013582%5DPCI%200000%3A01%3A00.3%3A%E5%B0%8F%E7%AF%80%200%3A%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E6%B8%88%E3%81%BF%20%5Bmem%200x01103000-0x01103fff%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.020399%5DPCI%200000%3A01%3A00.3%3ABAR%200%3A%20%5Bmem%200x01103000-0x01103fff%5D%20(PCI%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%5B0x1103000-0x1103fff%5D)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.030177%5DPCI%200000%3A01%3A00.4%3A%E5%B0%8F%E7%AF%80%200%3A%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E6%B8%88%E3%81%BF%20%5Bmem%200x01104000-0x01104fff%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.037001%5DPCI%200000%3A01%3A00.4%3ABAR%200%3A%20%5Bmem%200x01104000-0x01104fff%5D%20(PCI%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%5B0x1104000-0x1104fff%5D)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.046779%5DPCI%200000%3A01%3A00.5%3A%E5%B0%8F%E7%AF%80%200%3A%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E6%B8%88%E3%81%BF%20%5Bmem%200x01105000-0x01105fff%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.053603%5DPCI%200000%3A01%3A00.5%3ABAR%200%3A%20%5Bmem%200x01105000-0x01105fff%5D%20(PCI%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%5B0x1105000-0x1105fff%5D)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.063380%5DPCI%200000%3A01%3A00.6%3A%E5%B0%8F%E7%AF%80%200%3A%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E6%B8%88%E3%81%BF%20%5Bmem%200x01106000-0x01106fff%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.070198%5DPCI%200000%3A01%3A00.6%3ABAR%200%3A%20%5Bmem%200x01106000-0x01106fff%5D%20(PCI%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%5B0x1106000-0x1106fff%5D)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.079976%5DPCI%200000%3A01%3A00.7%3A%E5%B0%8F%E7%AF%80%200%3A%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E6%B8%88%E3%81%BF%20%5Bmem%200x01107000-0x01107fff%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.086799%5DPCI%200000%3A01%3A00.7%3ABAR%200%3A%20%5Bmem%200x01107000-0x01107fff%5D%20(PCI%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%5B0x1107000-0x1107fff%5D)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.096577%5DPCI%200000%3A00%3A00.0%3APCI%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%81%8B%E3%82%89%5B%E3%83%90%E3%82%B901-01%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.101819%5DPCI%200000%3A00%3A00.0%3A%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%20%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%20%5BIO%20%E7%84%A1%E5%8A%B9%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.107509%5DPCI%200000%3A00%3A00.0%3A%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%20%5BMEM%200x01100000-0x011fffff%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.114327%5DPCI%200000%3A00%3A00.0%3A%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%20%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%20%5BMEM%20%E8%A8%AD%E5%AE%9A%E3%81%8C%E7%84%A1%E5%8A%B9%5D%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.120837%5DIMX%20USB%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.124593%5DIMX%20USB%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.128126%5DCPU%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%A2%E3%83%BC%E3%83%89%3Aldo_enable%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.132342%5Di.MXC%20CPU%E5%91%A8%E6%B3%A2%E6%95%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.151254%5DHighmem%20%E3%83%90%E3%82%A6%E3%83%B3%E3%82%B9%E3%83%BB%E3%83%97%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%B5%E3%82%A4%E3%82%BA%3A%2064%20%E3%83%9A%E3%83%BC%E3%82%B8%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.169381%5Dmsgmni%20%E3%81%8C%201315%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.174837%5Dalg%3A%20stdrng%20(krng)%20%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%AA%E3%81%97%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.179101%5DIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9NOOP%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.183040%5DIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9%E3%81%AE%E7%B7%A0%E5%88%87%E6%97%A5%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.187408%5DIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9CFQ%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF(%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.192486%5DIMX-PCIe%3A%20MSI%200x3f00%20%400x0%3A0x1ff8000%E3%80%81irq%20%3D%20496%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.199230%5DIMX-SDMA%3A%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%201.1%20%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.208696%5Dimx-sdma%3A%20%E5%88%9D%E6%9C%9F%E5%8C%96%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.350226%5D%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3AIMX%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.353438%5Dimx-uart.3%3AMMIO%200x21f0000%20(irq%20%3D%2061)%20%E3%81%AE%20ttymxc3%20%E3%81%AF%20IMX%20%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.359919%5D%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20%5Bttymxc3%5D%20%E3%81%8C%E6%9C%89%E5%8A%B9%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%8C%E7%84%A1%E5%8A%B9%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.359919%5D%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20%5Bttymxc3%5D%20%E3%81%8C%E6%9C%89%E5%8A%B9%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%8C%E7%84%A1%E5%8A%B9%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.376725%5Dloop%3A%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.381551%5Dusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20asix%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.387076%5Dusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20cdc_ether%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.393037%5Dusbcore%3A%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90SMSC75xx%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.398920%5Dusbcore%3A%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCSMSC95xx%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.404788%5Dusbcore%3A%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCnet1080%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.410575%5Dusbcore%3A%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20rndis_host%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.416620%5Dusbcore%3A%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97cdc_subset%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.422669%5Dusbcore%3A%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCZaurus%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.428266%5Dcdc_ncm%3A%202011%E5%B9%B48%E6%9C%884%E6%97%A5%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.431611%5Dusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20cdc_ncm%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.437410%5Dusbcore%3A%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9Frndis_wlan%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.443872%5Dehci_hcd%3A%20USB%202.0%20%E3%80%8C%E6%8B%A1%E5%BC%B5%E3%80%8D%E3%83%9B%E3%82%B9%E3%83%88%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%20(EHCI)%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.450527%5D%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%BD%E3%83%BC%E3%82%B9IRQ%2073%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.454227%5D%20fsl-ehci%20fsl-ehci.2%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.461279%5DFSL-EHCI%20FSL-EHCI.2%3A%E6%96%B0%E3%81%97%E3%81%84USB%E3%83%90%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%80%81%E3%83%90%E3%82%B9%E7%95%AA%E5%8F%B71%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.493211%5D%20fsl-ehci%20fsl-ehci.2%3A%20irq%2073%2C%20io%20base%200x02184400%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.513186%5D%20fsl-ehci%20fsl-ehci.2%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.518851%5Dusb%20usb1%3A%20%E6%96%B0%E3%81%97%E3%81%84%20USB%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%2C%20idVendor%3D1d6b%2C%20idProduct%3D0002%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.525654%5Dusb%20usb1%3A%20%E6%96%B0%E3%81%97%E3%81%84%20USB%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E6%96%87%E5%AD%97%E5%88%97%3A%20Mfr%3D3%2C%20Product%3D2%2C%20SerialNumber%3D1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.532881%5Dusb%20usb1%3A%20%E8%A3%BD%E5%93%81%3A%20%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97EHCI%E3%83%9B%E3%82%B9%E3%83%88%E3%83%BB%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.539331%5Dusb%20usb1%3A%E3%83%A1%E3%83%BC%E3%82%AB%E3%83%BC%3ALinux%203.0.35-2666-gbdde708ehci_hcd%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.545955%5D%20usb%20usb1%3A%20SerialNumber%3A%20fsl-ehci.2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.551056%5D%E3%83%8F%E3%83%96%201-0%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.554824%5D%E3%83%8F%E3%83%96%201-0%3A1.0%3A%201%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.559261%5D%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%BD%E3%83%BC%E3%82%B9IRQ74%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.562943%5D%20fsl-ehci%20fsl-ehci.3%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.569893%5DFSL-EHCI%20FSL-EHCI.3%3A%E6%96%B0%E3%81%97%E3%81%84USB%E3%83%90%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%80%81%E3%83%90%E3%82%B9%E7%95%AA%E5%8F%B72%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.603198%5D%20fsl-ehci%20fsl-ehci.3%3A%20irq%2074%2C%20io%20base%200x02184600%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.623181%5D%20fsl-ehci%20fsl-ehci.3%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.628832%5Dusb%20usb2%3A%20%E6%96%B0%E3%81%97%E3%81%84%20USB%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81idVendor%3D1d6b%E3%80%81idProduct%3D0002%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.635632%5Dusb%20usb2%3A%20%E6%96%B0%E3%81%97%E3%81%84%20USB%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E6%96%87%E5%AD%97%E5%88%97%3A%20Mfr%3D3%2C%20Product%3D2%2C%20SerialNumber%3D1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.642858%5Dusb%20usb2%3A%20%E8%A3%BD%E5%93%81%3A%20%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97EHCI%E3%83%9B%E3%82%B9%E3%83%88%E3%83%BB%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.649306%5Dusb%20usb2%3A%E3%83%A1%E3%83%BC%E3%82%AB%E3%83%BC%3ALinux%203.0.35-2666-gbdde708ehci_hcd%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.655934%5D%20usb%20usb2%3A%20SerialNumber%3A%20fsl-ehci.3%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.660988%5D%E3%83%8F%E3%83%96%202-0%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.664755%5D%E3%83%8F%E3%83%96%202-0%3A1.0%3A%201%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.669192%5D%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%BD%E3%83%BC%E3%82%B9IRQ%2075%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.677670%5D%20fsl-ehci%20fsl-ehci.0%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.684575%5DFSL-EHCI%20FSL-EHCI.0%3A%E6%96%B0%E3%81%97%E3%81%84USB%E3%83%90%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%80%81%E3%83%90%E3%82%B9%E7%95%AA%E5%8F%B73%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.713200%5D%20fsl-ehci%20fsl-ehci.0%3A%20irq%2075%2C%20io%20base%200x02184000%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.733180%5D%20fsl-ehci%20fsl-ehci.0%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.738830%5Dusb%20usb3%3A%20%E6%96%B0%E3%81%97%E3%81%84%20USB%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81idVendor%3D1d6b%E3%80%81idProduct%3D0002%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.745631%5Dusb%20usb3%3A%20%E6%96%B0%E3%81%97%E3%81%84%20USB%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E6%96%87%E5%AD%97%E5%88%97%3A%20mfr%3D3%2C%20Product%3D2%2C%20SerialNumber%3D1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.752859%5Dusb%20usb3%3A%20%E8%A3%BD%E5%93%81%3A%20%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97EHCI%E3%83%9B%E3%82%B9%E3%83%88%E3%83%BB%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.759307%5Dusb%20usb3%3A%E3%83%A1%E3%83%BC%E3%82%AB%E3%83%BC%3ALinux%203.0.35-2666-gbdde708ehci_hcd%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.765934%5D%20usb%20usb3%3A%20SerialNumber%3A%20fsl-ehci.0%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.770988%5D%E3%83%8F%E3%83%96%203-0%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.774755%5D%E3%83%8F%E3%83%96%203-0%3A1.0%3A%201%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.779164%5D%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%BD%E3%83%BC%E3%82%B9IRQ%2072%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.782865%5D%20fsl-ehci%20fsl-ehci.1%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.789777%5DFSL-EHCI%20FSL-EHCI.1%3A%E6%96%B0%E3%81%97%E3%81%84USB%E3%83%90%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%80%81%E3%83%90%E3%82%B9%E7%95%AA%E5%8F%B74%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.823201%5D%20fsl-ehci%20fsl-ehci.1%3A%20irq%2072%2C%20io%20base%200x02184200%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.843185%5D%20fsl-ehci%20fsl-ehci.1%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.848835%5Dusb%20usb4%3A%20%E6%96%B0%E3%81%97%E3%81%84%20USB%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81idVendor%3D1d6b%E3%80%81idProduct%3D0002%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.855637%5Dusb%20usb4%3A%20%E6%96%B0%E3%81%97%E3%81%84%20USB%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E6%96%87%E5%AD%97%E5%88%97%3A%20Mfr%3D3%2C%20Product%3D2%2C%20SerialNumber%3D1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.862863%5Dusb%20usb4%3A%20%E8%A3%BD%E5%93%81%3A%20%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97EHCI%E3%83%9B%E3%82%B9%E3%83%88%E3%83%BB%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.869312%5Dusb%20usb4%3A%E3%83%A1%E3%83%BC%E3%82%AB%E3%83%BC%3ALinux%203.0.35-2666-gbdde708ehci_hcd%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.875940%5D%20usb%20usb4%3A%20SerialNumber%3A%20fsl-ehci.1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.880997%5D%E3%83%8F%E3%83%96%204-0%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.884765%5D%E3%83%8F%E3%83%96%204-0%3A1.0%3A%201%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.889282%5DPCI%3A%20%E3%82%A4%E3%83%8D%E3%83%BC%E3%83%96%E3%83%AB%E5%8C%96%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%200000%3A01%3A00.1%20(0140%20-%26gt%3B%200142)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.894989%5Dehci_hcd%200000%3A01%3A00.1%3AEHCI%20%E3%83%9B%E3%82%B9%E3%83%88%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.900490%5Dehci_hcd%200000%3A01%3A00.1%3A%E6%96%B0%E3%81%97%E3%81%84%20USB%20%E3%83%90%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%80%81%E3%83%90%E3%82%B9%E7%95%AA%E5%8F%B7%205%20%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.908034%5Dehci_hcd%200000%3A01%3A00.1%3AMosChip%20frame-index%20%E5%9B%9E%E9%81%BF%E7%AD%96%E3%81%AE%E9%81%A9%E7%94%A8%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.943222%5D%20ehci_hcd%200000%3A01%3A00.1%3A%20irq%20155%2C%20io%20mem%200x01101000%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.963182%5Dehci_hcd%200000%3A01%3A00.1%3AUSB%202.0%20%E9%96%8B%E5%A7%8B%E3%80%81EHCI%201.00%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.969010%5Dusb%20usb5%3A%20%E6%96%B0%E3%81%97%E3%81%84%20USB%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81idVendor%3D1d6b%E3%80%81idProduct%3D0002%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.975816%5Dusb%20usb5%3A%20%E6%96%B0%E3%81%97%E3%81%84%20USB%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E6%96%87%E5%AD%97%E5%88%97%3A%20Mfr%3D3%2C%20Product%3D2%2C%20SerialNumber%3D1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.983043%5Dusb%20usb5%3A%20%E8%A3%BD%E5%93%81%3A%20EHCI%20%E3%83%9B%E3%82%B9%E3%83%88%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.987930%5Dusb%20usb5%3A%E3%83%A1%E3%83%BC%E3%82%AB%E3%83%BC%3ALinux%203.0.35-2666-gbdde708ehci_hcd%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.994553%5Dusb%20usb5%3A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E7%95%AA%E5%8F%B7%3A0000%3A01%3A00.1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.999488%5D%2B%2B%2B%20hub_port_connect_change%3Audev-%26gt%3Blevel%20%3A1%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.999747%5D%E3%83%8F%E3%83%96%205-0%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.999759%5D%E3%83%8F%E3%83%96%205-0%3A1.0%3A%201%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.000187%5DPCI%3A%20%E3%82%A4%E3%83%8D%E3%83%BC%E3%83%96%E3%83%AB%E5%8C%96%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%200000%3A01%3A00.3%20(0140%20-%26gt%3B%200142)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.000214%5Dehci_hcd%200000%3A01%3A00.3%3AEHCI%20%E3%83%9B%E3%82%B9%E3%83%88%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.000509%5Dehci_hcd%200000%3A01%3A00.3%3A%E6%96%B0%E3%81%97%E3%81%84USB%E3%83%90%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%80%81%E3%83%90%E3%82%B9%E7%95%AA%E5%8F%B76%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.000737%5Dehci_hcd%200000%3A01%3A00.3%3AMosChip%20frame-index%20%E5%9B%9E%E9%81%BF%E7%AD%96%E3%81%AE%E9%81%A9%E7%94%A8%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.023241%5D%20ehci_hcd%200000%3A01%3A00.3%3A%20irq%20154%2C%20io%20mem%200x01103000%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.043189%5Dehci_hcd%200000%3A01%3A00.3%3AUSB%202.0%20%E9%96%8B%E5%A7%8B%E3%80%81EHCI%201.00%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.043272%5Dusb%20usb6%3A%20%E6%96%B0%E3%81%97%E3%81%84%20USB%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81idVendor%3D1d6b%E3%80%81idProduct%3D0002%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.043280%5Dusb%20usb6%3A%20%E6%96%B0%E3%81%97%E3%81%84%20USB%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E6%96%87%E5%AD%97%E5%88%97%3A%20Mfr%3D3%2C%20Product%3D2%2C%20SerialNumber%3D1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.043287%5Dusb%20usb6%3A%E8%A3%BD%E5%93%81%3AEHCI%E3%83%9B%E3%82%B9%E3%83%88%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.043293%5Dusb%20usb6%3A%E3%83%A1%E3%83%BC%E3%82%AB%E3%83%BC%3ALinux%203.0.35-2666-gbdde708ehci_hcd%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.043300%5Dusb%20usb6%3A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E7%95%AA%E5%8F%B7%3A0000%3A01%3A00.3%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.043862%5D%E3%83%8F%E3%83%96%206-0%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.043875%5DHub%206-0%3A1.0%3A1%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.044307%5DPCI%3A%20%E3%82%A4%E3%83%8D%E3%83%BC%E3%83%96%E3%83%AB%E5%8C%96%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%200000%3A01%3A00.5%20(0140%20-%26gt%3B%200142)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.044334%5Dehci_hcd%200000%3A01%3A00.5%3AEHCI%20%E3%83%9B%E3%82%B9%E3%83%88%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.044597%5Dehci_hcd%200000%3A01%3A00.5%3A%E6%96%B0%E3%81%97%E3%81%84USB%E3%83%90%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%80%81%E3%83%90%E3%82%B9%E7%95%AA%E5%8F%B77%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.044811%5Dehci_hcd%200000%3A01%3A00.5%3AMosChip%20frame-index%20%E5%9B%9E%E9%81%BF%E7%AD%96%E3%81%AE%E9%81%A9%E7%94%A8%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.113240%5D%20ehci_hcd%200000%3A01%3A00.5%3A%20irq%20153%2C%20io%20mem%200x01105000%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.223212%5Dusb%203-1%3Afsl-ehci%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E6%96%B0%E3%81%97%E3%81%84%E9%AB%98%E9%80%9FUSB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E7%95%AA%E5%8F%B72%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.243203%5Dehci_hcd%200000%3A01%3A00.5%3AUSB%202.0%20%E9%96%8B%E5%A7%8B%E3%80%81EHCI%201.00%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.249029%5Dusb%20usb7%3A%20%E6%96%B0%E3%81%97%E3%81%84%20USB%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%2C%20idVendor%3D1d6b%2C%20idProduct%3D0002%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.255832%5Dusb%20usb7%3A%20%E6%96%B0%E3%81%97%E3%81%84%20USB%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E6%96%87%E5%AD%97%E5%88%97%3A%20Mfr%3D3%2C%20Product%3D2%2C%20SerialNumber%3D1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.263059%5Dusb%20usb7%3A%20%E8%A3%BD%E5%93%81%3A%20EHCI%20%E3%83%9B%E3%82%B9%E3%83%88%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.267946%5Dusb%20usb7%3A%E3%83%A1%E3%83%BC%E3%82%AB%E3%83%BC%3ALinux%203.0.35-2666-gbdde708ehci_hcd%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.274570%5Dusb%20usb7%3A%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E7%95%AA%E5%8F%B7%3A0000%3A01%3A00.5%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.279804%5D%E3%83%8F%E3%83%96%207-0%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.283572%5D%E3%83%8F%E3%83%96%207-0%3A1.0%3A%201%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.287948%5DPCI%3A%20%E3%82%A4%E3%83%8D%E3%83%BC%E3%83%96%E3%83%AB%E5%8C%96%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%200000%3A01%3A00.7%20(0140%20-%26gt%3B%200142)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.293641%5Dehci_hcd%200000%3A01%3A00.7%3AEHCI%20%E3%83%9B%E3%82%B9%E3%83%88%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.299165%5Dehci_hcd%200000%3A01%3A00.7%3A%E6%96%B0%E3%81%97%E3%81%84USB%E3%83%90%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%80%81%E3%83%90%E3%82%B9%E7%95%AA%E5%8F%B78%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.306717%5Dehci_hcd%200000%3A01%3A00.7%3AMosChip%20frame-index%20%E5%9B%9E%E9%81%BF%E7%AD%96%E3%81%AE%E9%81%A9%E7%94%A8%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.343213%5Dehci_hcd%200000%3A01%3A00.7%3A%E8%A6%81%E6%B1%82%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%20152%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.349138%5Dehci_hcd%200000%3A01%3A00.7%3AUSB%20%E3%83%90%E3%82%B9%208%20%E3%81%AE%E7%99%BB%E9%8C%B2%E8%A7%A3%E9%99%A4%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.354820%5D%20ehci_hcd%200000%3A01%3A00.7%3A%20init%200000%3A01%3A00.7%20fail%2C%20-22%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.360665%5Dehci_hcd%3A%200000%3A01%3A00.7%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-22%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.366899%5DUSB%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C0%E3%81%AE%E5%A0%B4%E5%90%88%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.370703%5Dusbcore%3A%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90ARC%20hset%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.376462%5DUSB%20HST%E5%88%9D%E6%9C%9F%E5%8C%96%E6%88%90%E5%8A%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.380273%5DIMX2-WDT%20IMX2-WDT.0%3AIMX2%2B%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%3D60%E7%A7%92%20(nowayout%3D1)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.388450%5Dcpuidle%3A%E3%82%AC%E3%83%90%E3%83%8A%E3%83%BC%E3%83%A9%E3%83%80%E3%83%BC%E3%81%AE%E4%BD%BF%E7%94%A8%20%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.392551%5Dcpuidle%3A%20%E3%82%AC%E3%83%90%E3%83%8A%E3%83%BC%E3%83%A1%E3%83%8B%E3%83%A5%E3%83%BC%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.394974%5D%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3A%E3%83%9B%E3%83%AF%E3%82%A4%E3%83%88%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AB%E3%81%AA%E3%81%84%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.395019%5D%2B%2B%2B%20hub_port_connect_change%3Audev-%26gt%3Blevel%20%3A1%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.406435%5Dsdhci%3A%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%BB%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%83%BB%E3%83%9B%E3%82%B9%E3%83%88%E3%83%BB%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%83%BB%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.412619%5Dsdhci%3A%20Copyright(c)%20Pierre%20Ossman%20(%E8%8B%B1%E8%AA%9E)%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.417084%5Dsdhci%20sdhci-esdhc-imx.1%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E4%BF%9D%E8%AD%B7%E3%83%94%E3%83%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.423491%5DMMC0%20%3A%20VMMC%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.427681%5Dmmc0%3A%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20%5Bsdhci-esdhc-imx.1%5D%20%E4%B8%8A%E3%81%AE%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BCDMA%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.434999%5D%E3%82%B5%E3%83%BC%E3%83%9E%E3%83%AB%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF0x59c50d69%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.439791%5D%E3%83%AC%E3%82%B7%E3%82%AA%20%3D%20186%20%E3%81%AE%E3%82%B5%E3%83%BC%E3%83%9E%E3%83%AB%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.463188%5DAnatop%20Thermal%20%E3%81%AF%20thermal_zone0%20%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.468495%5Danatop_thermal_probe%3A%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E5%86%B7%E5%8D%B4%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AFCPUFreq%E3%81%A7%E3%81%99!%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.475415%5DNET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2026%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.480355%5DTCP%E3%82%AD%E3%83%A5%E3%83%BC%E3%83%93%E3%83%83%E3%82%AF%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.483599%5DNET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2017%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.488055%5Dlib80211%3A%20IEEE802.11%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E5%85%B1%E9%80%9A%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.494497%5DVFP%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20v0.3%3A%20implementor%2041%20architecture%203%20part%2030%20variant%209%20rev%204%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.502176%5DThumbEE%20CPU%E6%8B%A1%E5%BC%B5%E3%81%8C%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.506470%5DSWP%2FSWPB%20%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%BB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%83%BC%E3%81%AE%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.511407%5D%E3%83%90%E3%82%B9%E5%91%A8%E6%B3%A2%E6%95%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.513199%5Dusb%204-1%3Afsl-ehci%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E6%96%B0%E3%81%97%E3%81%84%E9%AB%98%E9%80%9FUSB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E7%95%AA%E5%8F%B72%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.521949%5D%E3%83%90%E3%82%B9%E5%91%A8%E6%B3%A2%E6%95%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%E6%9C%89%E5%8A%B9%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.527136%5DDVFS%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.532045%5Dregulator_init_complete%3A%20VMMC%3A%20%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%AA%E5%88%B6%E7%B4%84%E3%80%81%E3%82%AA%E3%83%B3%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%B3%E3%82%B0%E3%81%97%E3%81%A6%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81pci%20%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.761407%5D%20iMX6%20PCIe%20PCIe%20RC%20mode%20imx_pcie_pltfm_probe%20entering.%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200.873253%5DPCIE%3A%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E9%96%8B%E5%A7%8Bimx_pcie_pltfm_probe%E3%80%82%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.483143%5D%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81DB_R0%3A0xdc998200%E3%80%81DB_R1%3A0x0820f700!%3C%2FP%3E%3CP%3E%5B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.489108%5D%20IMX%20PCIe%20port%3A%20link%20down!%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E4%BB%8A%E3%81%A7%E3%81%AF%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%95%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126641%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126641%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%9E%E3%83%83%E3%83%8F%E3%81%95%E3%82%93%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82imx6%E3%81%AEpcie%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126640%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126640%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%81%99%E3%81%94%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E1%20%E3%81%A4%E3%81%AE%20%3CSPAN%20class%3D%22SpellE%22%3EPericom%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%20(PI7C9X2G303EL)%20%E3%81%8C%20imx_3.0.35.4.0%20%E3%81%8A%E3%82%88%E3%81%B3%204.1.0%20%E3%81%A7%E6%A4%9C%E8%A8%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E5%B9%B8%E9%81%8B%E3%82%92%E7%A5%88%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E6%9C%80%E9%AB%98%E3%81%AE%E3%83%AC%E3%82%AC%E3%83%89%E3%83%AB%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%83%AA%E3%83%81%E3%83%A3%E3%83%BC%E3%83%89%E3%83%BB%E3%83%81%E3%83%A5%E3%83%BC%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126639%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126639%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3Ehi%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E9%9B%BB%E6%BA%90%E5%AE%B9%E9%87%8F%E3%81%8C%E4%B8%8D%E8%B6%B3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E3%81%95%E3%81%A6%E3%80%81%E3%81%93%E3%82%8C%E3%81%8C%E3%83%AD%E3%82%B0%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3EiMX6%20PCIe%20PCIe%20RC%20mode%20imx_pcie_pltfm_probe%20entering.%3C%2FP%3E%3CP%3EOpenEmbed%E3%81%AB%E3%82%88%E3%82%8BCLK%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97---%3C%2FP%3E%3CP%3ECLK%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%80%81OpenEmbed%E3%81%AB%E3%82%88%E3%82%8B%3C%2FP%3E%3CP%3EIMX%20PCIe%20pcie_rst%2C%200.%3C%2FP%3E%3CP%3EIMX%20PCIe%20pcie_rst%2C%201.%3C%2FP%3E%3CP%3EPCIE%3A%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E9%96%8B%E5%A7%8Bimx_pcie_pltfm_probe%E3%80%82%3C%2FP%3E%3CP%3EIMX%20PCIe%E3%83%9D%E3%83%BC%E3%83%88%3A%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%80%82%3C%2FP%3E%3CP%3EPCI%3A%20bus0%3A%20%E9%AB%98%E9%80%9F%E3%83%90%E3%83%83%E3%82%AF%E3%83%84%E3%83%BC%E3%83%90%E3%83%83%E3%82%AF%E8%BB%A2%E9%80%81%E3%81%8C%E7%84%A1%E5%8A%B9%3C%2FP%3E%3CP%3EPCI%3Abus1%3A%E9%AB%98%E9%80%9F%E3%83%90%E3%83%83%E3%82%AF%E3%83%84%E3%83%BC%E3%83%90%E3%83%83%E3%82%AF%E8%BB%A2%E9%80%81%E3%81%AF%E7%84%A1%E5%8A%B9%3C%2FP%3E%3CP%3EPCI%200000%3A00%3A00.0%3A%E5%B0%8F%E7%AF%80%200%3A%20%E4%BB%A3%E5%85%A5%20%5Bmem%200x01100000-0x011fffff%2064bit%20pref%5D%3C%2FP%3E%3CP%3EPCI%200000%3A00%3A00.0%3ABAR%200%3A%20%5Bmem%200x01100000-0x011fffff%2064bit%20pref%5D%20(PCI%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%5B0x1100000-0x11fffff%5D)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3EPCI%200000%3A00%3A00.0%3A%E5%B0%8F%E7%AF%80%209%3A%20assigned%20%5Bmem%200x01200000-0x012fffff%20pref%5D%3C%2FP%3E%3CP%3EPCI%200000%3A00%3A00.0%3A%E5%B0%8F%E7%AF%80%206%3A%20assigned%20%5Bmem%200x01300000-0x0130ffff%20pref%5D%3C%2FP%3E%3CP%3EPCI%200000%3A00%3A00.0%3A%E5%B0%8F%E7%AF%80%207%3A%20assigned%20%5Bio%200x1000000-0x1000fff%5D%3C%2FP%3E%3CP%3EPCI%200000%3A01%3A00.0%3A%E5%B0%8F%E7%AF%80%204%3A%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E6%B8%88%E3%81%BF%20%5Bmem%200x01200000-0x0120ffff%2064bit%20pref%5D%3C%2FP%3E%3CP%3EPCI%200000%3A01%3A00.0%3A%E5%B0%8F%E7%AF%80%204%3A%20%5Bmem%200x01200000-0x0120ffff%2064bit%20pref%5D%20(PCI%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%5B0x1200000-0x120ffff%5D)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3EPCI%200000%3A01%3A00.0%3A%E5%B0%8F%E7%AF%80%206%3A%20assigned%20%5Bmem%200x01210000-0x0121ffff%20pref%5D%3C%2FP%3E%3CP%3EPCI%200000%3A01%3A00.0%3A%E5%B0%8F%E7%AF%80%202%3A%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E6%B8%88%E3%81%BF%20%5Bmem%200x01220000-0x01220fff%2064bit%20pref%5D%3C%2FP%3E%3CP%3EPCI%200000%3A01%3A00.0%3ABAR%202%3A%20%5Bmem%200x01220000-0x01220fff%2064bit%20pref%5D%20(PCI%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%5B0x1220000-0x1220fff%5D)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3EPCI%200000%3A01%3A00.0%3A%E3%83%90%E3%83%BC%200%3A%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E6%B8%88%E3%81%BF%20%5Bio%200x1000000-0x10000ff%5D%3C%2FP%3E%3CP%3EPCI%200000%3A01%3A00.0%3ABAR%200%3A%20%5Bio%200x1000000-0x10000ff%5D%20(PCI%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%5B0x1000000-0x10000ff%5D)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3EPCI%200000%3A00%3A00.0%3APCI%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%81%8B%E3%82%89%5B%E3%83%90%E3%82%B901-01%5D%3C%2FP%3E%3CP%3EPCI%200000%3A00%3A00.0%3A%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%20%5BIO%200x1000000-0x1000fff%5D%3C%2FP%3E%3CP%3EPCI%200000%3A00%3A00.0%3A%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%20%5BMEM%20%E7%84%A1%E5%8A%B9%5D%3C%2FP%3E%3CP%3EPCI%200000%3A00%3A00.0%3A%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%20%5BMEM%200x01200000-0x012fffff%20Pref%5D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Er8169%E3%82%AE%E3%82%AC%E3%83%93%E3%83%83%E3%83%88%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC2.3LK-NAPI%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3EPCI%3A%20%E3%82%A4%E3%83%8D%E3%83%BC%E3%83%96%E3%83%AB%E5%8C%96%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%200000%3A01%3A00.0%20(0140%20-%26gt%3B%200143)%3C%2FP%3E%3CP%3EIMX-PCIe%3A%20MSI%200x3f01%20%400x0%3A0x1ff8000%E3%80%81irq%20%3D%20497%3C%2FP%3E%3CP%3Er8169%200000%3A01%3A00.0%3A%20eth1%3A%20RTL8168c%2F8111c%20at%200xc09e4000%2C%20ff%3Aff%3Aff%3Aff%3Aff%3Aff%2C%20XID%201c4000c0%20IRQ%20497%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eroot%40imx6-luhao%3A~%23%20lspci%20-v%3C%2FP%3E%3CP%3E00%3A00.0%20%E3%82%AF%E3%83%A9%E3%82%B9%200604%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2016c3%3Aabcd%20(rev%2001)%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%82%B0%3A%20bus%20master%2C%20fast%20devsel%2C%20latency%200%3C%2FP%3E%3CP%3E01100000%20%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%20(64%20%E3%83%93%E3%83%83%E3%83%88%E3%80%81%E3%83%97%E3%83%AA%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E5%8F%AF%E8%83%BD)%20%5Bsize%3D1M%5D%3C%2FP%3E%3CP%3E%E3%83%90%E3%82%B9%3A%20primary%3D00%2C%20secondary%3D01%2C%20subordinate%3D01%2C%20sec-latency%3D0%3C%2FP%3E%3CP%3E%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%81%AE%E5%BE%8C%E3%82%8D%E3%81%AEI%2FO%3A00000000-00000ff%3C%2FP%3E%3CP%3E%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%81%AE%E5%BE%8C%E3%82%8D%E3%81%AE%E3%83%97%E3%83%AA%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%A1%E3%83%A2%E3%83%AA%3A%2001200000-012fffff%3C%2FP%3E%3CP%3E%5B%E3%83%90%E3%83%BC%E3%83%81%E3%83%A3%E3%83%AB%5D%E6%8B%A1%E5%BC%B5%20ROM%20at%2001300000%20%5B%E7%84%A1%E5%8A%B9%5D%20%5B%E3%82%B5%E3%82%A4%E3%82%BA%3D64K%5D%3C%2FP%3E%3CP%3E%E6%A9%9F%E8%83%BD%3A%20%5B40%5D%20%E9%9B%BB%E6%BA%90%E7%AE%A1%E7%90%86%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203%3C%2FP%3E%3CP%3E%E6%A9%9F%E8%83%BD%3A%20%5B50%5D%20MSI%3A%20%E6%9C%89%E5%8A%B9%20%2B%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%20%3D%201%2F1%20%E3%83%9E%E3%82%B9%E3%82%AB%E3%83%96%E3%83%AB%2B%2064%20%E3%83%93%E3%83%83%E3%83%88%2B%3C%2FP%3E%3CP%3E%E6%A9%9F%E8%83%BD%3A%20%5B70%5D%20Express%20%E3%83%AB%E3%83%BC%E3%83%88%E3%83%9D%E3%83%BC%E3%83%88%20(%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88-)%2C%20MSI%2000%3C%2FP%3E%3CP%3E%E6%A9%9F%E8%83%BD%3A%20%5B100%5D%20%E9%AB%98%E5%BA%A6%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E5%A0%B1%E5%91%8A%3C%2FP%3E%3CP%3E%E6%A9%9F%E8%83%BD%3A%20%5B140%5D%20%E4%BB%AE%E6%83%B3%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E4%B8%AD%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3A%20pcieport%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E01%3A00.0%20%E3%82%AF%E3%83%A9%E3%82%B9%200200%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2010ec%3A8168%20(%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%2002)%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B910ec%3A8168%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%82%B0%3A%20bus%20master%2C%20fast%20devsel%2C%20latency%200%2C%20IRQ%20497%3C%2FP%3E%3CP%3E1000000%20%E3%81%AE%20I%2FO%20%E3%83%9D%E3%83%BC%E3%83%88%20%5B%E3%82%B5%E3%82%A4%E3%82%BA%20%3D%20256%5D%3C%2FP%3E%3CP%3E01220000%20%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%20(64%20%E3%83%93%E3%83%83%E3%83%88%E3%80%81%E3%83%97%E3%83%AA%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E5%8F%AF%E8%83%BD)%20%5B%E3%82%B5%E3%82%A4%E3%82%BA%20%3D%204K%5D%3C%2FP%3E%3CP%3E01200000%20%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%20(64%20%E3%83%93%E3%83%83%E3%83%88%E3%80%81%E3%83%97%E3%83%AA%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E5%8F%AF%E8%83%BD)%20%5Bsize%3D64K%5D%3C%2FP%3E%3CP%3E%5B%E3%83%90%E3%83%BC%E3%83%81%E3%83%A3%E3%83%AB%5D01210000%E3%81%AE%E6%8B%A1%E5%BC%B5ROM%20%5B%E7%84%A1%E5%8A%B9%5D%20%5B%E3%82%B5%E3%82%A4%E3%82%BA%3D64K%5D%3C%2FP%3E%3CP%3E%E6%A9%9F%E8%83%BD%3A%20%5B40%5D%20%E9%9B%BB%E6%BA%90%E7%AE%A1%E7%90%86%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203%3C%2FP%3E%3CP%3E%E6%A9%9F%E8%83%BD%3A%20%5B50%5D%20MSI%3A%20Enable%2B%20Count%3D1%2F2%20Maskable-%2064bit%2B%3C%2FP%3E%3CP%3E%E6%A9%9F%E8%83%BD%3A%20%5B70%5D%20Express%20Endpoint%2C%20MSI%2001%3C%2FP%3E%3CP%3E%E6%A9%9F%E8%83%BD%3A%20%5Bb0%5D%20MSI-X%3A%20%E6%9C%89%E5%8A%B9%20-%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%20%3D%202%20%E3%83%9E%E3%82%B9%E3%82%AF%20-%3C%2FP%3E%3CP%3E%E6%A9%9F%E8%83%BD%3A%20%5Bd0%5D%20%E9%87%8D%E8%A6%81%E3%81%AA%E8%A3%BD%E5%93%81%E3%83%87%E3%83%BC%E3%82%BF%3C%2FP%3E%3CP%3E%E6%A9%9F%E8%83%BD%3A%20%5B100%5D%20%E9%AB%98%E5%BA%A6%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E5%A0%B1%E5%91%8A%3C%2FP%3E%3CP%3E%E6%A9%9F%E8%83%BD%3A%20%5B140%5D%20%E4%BB%AE%E6%83%B3%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20%3C%2FP%3E%3CP%3E%E6%A9%9F%E8%83%BD%3A%20%5B160%5D%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E7%95%AA%E5%8F%B7%2000-00-00-00-00-00-00-00%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E4%B8%AD%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3A%20r8169%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eroot%40imx6-luhao%3A~%23%20lspci%3C%2FP%3E%3CP%3E00%3A00.0%20%E3%82%AF%E3%83%A9%E3%82%B9%200604%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2016c3%3Aabcd%20(rev%2001)%3C%2FP%3E%3CP%3E01%3A00.0%20%E3%82%AF%E3%83%A9%E3%82%B9%200200%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2010ec%3A8168%20(%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%2002)%3C%2FP%3E%3CP%3Eroot%40imx6-luhao%3A~%23%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E9%95%B7%E6%9C%9F%E7%9A%84%E3%81%AA%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%E4%BB%8A%E7%A7%81%E3%81%AFpcie%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81pex8608%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E5%90%8C%E6%A7%98%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126638%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126638%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%3E%E7%A7%81%E3%81%AE%E3%83%A1%E3%83%BC%E3%83%AB%E3%81%AB%E5%90%8D%E5%88%BA%E3%82%92%E9%80%81%E3%81%A3%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%E9%83%B5%E9%80%81BCM5751%E3%81%AF%E9%9B%BB%E8%A9%B1%E7%95%AA%E5%8F%B7%E3%82%92%E8%A8%98%E5%85%A5%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AE%E9%9B%BB%E5%AD%90%E3%83%A1%E3%83%BC%E3%83%AB%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Aluhao89%40me.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eluhao89%40me.com%3C%2FA%3E%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%81%93%E3%82%8C%E3%81%8C%E7%A7%81%E3%81%AE%E4%BD%8F%E6%89%80%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E4%B8%8A%E6%B5%B7%20%3CSPAN%20class%3D%22SpellE%22%3E%E6%B5%A6%E6%9D%B1%3C%2FSPAN%3E%20%E6%96%B0%E5%8C%BA%E6%A2%81%E4%BA%AC%E8%B7%AF192%23%E3%83%93%E3%83%ABA%202F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E9%83%B5%E4%BE%BF%E7%95%AA%E5%8F%B7201203%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%83%AA%E3%83%81%E3%83%A3%E3%83%BC%E3%83%89%E3%83%BB%E3%83%81%E3%83%A5%E3%83%BC%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126636%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126636%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E6%A8%99%E6%BA%96%E3%81%AEPCIEEP%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81imx6%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E7%A7%81%E3%81%9F%E3%81%A1%E8%87%AA%E8%BA%AB%E3%81%AE%20design.so%20%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%8A%E3%80%81%E7%A7%81%E3%81%AF%E3%81%BE%E3%81%A0pcie%E3%83%90%E3%82%B9%E3%81%8C%E4%B8%8A%E3%81%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82PCIE%20NIC%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E3%81%AE%E3%83%AA%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%B7%E3%83%83%E3%83%97%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126635%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126635%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%81%82%E3%81%82%E3%80%81%E3%81%AA%E3%82%8B%E3%81%BB%E3%81%A9%E3%80%82%3CBR%20%2F%3E%E6%A8%99%E6%BA%96%E3%81%AE%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20EP%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3CSPAN%20class%3D%22SpellE%22%3ESTD-PCIe%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22SpellE%22%3E%3C%2FSPAN%3EEP%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%3CSPAN%20class%3D%22SpellE%22%3E%20mini-PCIe%20%E3%81%8B%E3%82%89STD-PCIe%E3%81%B8%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%82%88%E3%81%AD%3F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AF%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20%E3%81%AE%E5%93%81%E8%B3%AA%E3%81%AB%E6%B7%B1%E3%81%8F%E5%BD%B1%E9%9F%BF%E3%81%97%E3%81%BE%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E3%81%94%E6%B3%A8%E6%84%8F%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%81%93%E3%81%93%E3%81%AB1%E3%81%A4%E3%81%AE%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.bplus.com.tw%2FAdapter%2FPM2C.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.bplus.com.tw%2FAdapter%2FPM2C.html%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20Regards%3CBR%20%2F%3ERichard%20Zhu%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AEpcie%20nic%E3%82%92%E5%86%85%E9%83%A8%E3%81%AB%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99.BCM5751%E3%81%AA%E3%81%A9%E3%80%82%E9%83%B5%E9%80%81%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E3%81%94%E4%BD%8F%E6%89%80%E3%82%92%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Epcie%20nic%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E7%A7%81%E3%81%AFTI%E3%81%AEDM8168%E3%81%A7%E5%AE%9F%E7%8F%BE%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E6%B6%88%E8%B2%BB%E9%9B%BB%E5%8A%9B%E3%81%8C%E9%AB%98%E3%81%99%E3%81%8E%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%93%E3%81%A7%E3%80%81IMX6%E3%82%92%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%82%8B%E3%81%A4%E3%82%82%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%83%AD%E3%82%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20inherit%20%2C%20serif%20%3Bmso-bidi-font-family%3AArial%22%3EPM%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%3Boutline%3A%200%3Bfont-weight%3Ainherit%3Bfont-style%3Ainherit%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20inherit%20%2C%20serif%20%3Bmso-bidi-font-family%3AArial%22%3E%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81DB_R0%3A0x00b4f900%E3%80%81DB_R1%3A0x08200000!%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%3Boutline%3A%200%3Bfont-weight%3Ainherit%3Bfont-style%3Ainherit%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20inherit%20%2C%20serif%20%3Bmso-bidi-font-family%3AArial%22%3EIMX%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20port%3A%20link%20down!%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20EP%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E5%BF%85%E9%A0%88%E8%A6%81%E4%BB%B6%20(%E5%A4%96%E9%83%A8%E9%9B%BB%E6%BA%90%E3%81%AA%E3%81%A9)%20%E3%81%AF%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20EP%E3%82%921%E3%81%A4%E7%99%BA%E9%80%81%E3%81%97%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E7%A7%81%E3%81%AE%E5%81%B4%E3%81%A7%E5%86%8D%E7%8F%BE%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E8%A9%A6%E3%81%BF%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%AA%E3%83%81%E3%83%A3%E3%83%BC%E3%83%89%E3%83%BB%E3%83%81%E3%83%A5%E3%83%BC%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126632%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126632%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD%E2%80%A6%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELinux%E3%81%AE%E8%A7%A3%E5%87%8D...%E5%AE%8C%E4%BA%86%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E3%83%96%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ELinux%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B33.0.35-2508-g54750ff(root%40ubuntu)(GCC%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B34.6.220110630%20(%E3%83%97%E3%83%AC%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9)%20(Freescale%20MAD%20--%20Linaro%202011.07%20--%20Built%20at%202011%2F08%2F10%2009%3A20)%20)%20%231%20SMP%20PREEMPT%20Thu%20Sep%205%2012%3A46%3A34%20CST%202013%3C%2FP%3E%3CP%3ECPU%3A%20ARMv7%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20%5B412fc09a%5D%20%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%2010%20(ARMv7)%E3%80%81cr%3D10c53c7d%3C%2FP%3E%3CP%3ECPU%3A%20VIPT%20%E9%9D%9E%E3%82%A8%E3%82%A4%E3%83%AA%E3%82%A2%E3%82%B7%E3%83%B3%E3%82%B0%20%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%80%81VIPT%20%E3%82%A8%E3%82%A4%E3%83%AA%E3%82%A2%E3%82%B7%E3%83%B3%E3%82%B0%E5%91%BD%E4%BB%A4%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%3C%2FP%3E%3CP%3E%E3%83%9E%E3%82%B7%E3%83%B3%3AFreescale%20i.MX%206Quad%2FDualLite%2FSolo%20Sabre-SD%E3%83%9C%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E%E8%AA%8D%E8%AD%98%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%82%BF%E3%82%B00x54410008%E3%82%92%E7%84%A1%E8%A6%96%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%9D%E3%83%AA%E3%82%B7%E3%83%BC%3A%20ECC%20%E3%81%8C%E7%84%A1%E5%8A%B9%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20writealloc%3C%2FP%3E%3CP%3ECPU%20%E3%81%AF%20i.MX6Q%E3%80%81%E3%82%B7%E3%83%AA%E3%82%B3%E3%83%B3%20rev%201.2%20%E3%81%A8%E8%AD%98%E5%88%A5%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EPERCPU%3A%E5%9F%8B%E3%82%81%E8%BE%BC%E3%81%BF7%E3%83%9A%E3%83%BC%E3%82%B8%2F%20CPU%20%408c008000%20s5440%20r8192%20d15040%20u32768%3C%2FP%3E%3CP%3E%E3%82%BE%E3%83%BC%E3%83%B3%E9%A0%86%E3%81%AB1%E3%81%A4%E3%81%AE%E3%82%BE%E3%83%BC%E3%83%B3%E3%83%AA%E3%82%B9%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%83%A2%E3%83%93%E3%83%AA%E3%83%86%E3%82%A3%E3%81%AE%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E5%8C%96%E3%82%92%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%B7%8F%E3%83%9A%E3%83%BC%E3%82%B8%E6%95%B0%3A227328%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%3A%20console%3Dttymxc0%2C115200%20root%3D%2Fdev%2Fmmcblk0p1%20rootwait%20video%3Dmxcfb0%3Adev%3Dldb%2C1024x600M%4060%2Cif%3DRGB666%20ldb%3Dsin0%3C%2FP%3E%3CP%3EPID%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%204096%20(%E9%A0%86%E5%BA%8F%3A%202%E3%80%8116384%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3EDentry%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20131072%20(%E9%A0%86%E5%BA%8F%3A%207%E3%80%81524288%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3Einode-cache%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%2065536%20(%E9%A0%86%E5%BA%8F%3A%206%E3%80%81262144%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%A2%E3%83%AA%3A640MB%20256MB%20%3D%20%E5%90%88%E8%A8%88896MB%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%A2%E3%83%AA%3A896688k%20%2F%20896688k%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%80%81151888k%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF%E3%80%810K%E9%AB%98%E3%83%A1%E3%83%A2%E3%83%AA%3C%2FP%3E%3CP%3E%E4%BB%AE%E6%83%B3%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%3A%3C%2FP%3E%3CP%3E%E3%83%99%E3%82%AF%E3%82%BF%E3%83%BC%20%3A%200xffff0000%20-%200xffff1000%20(%204%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20fixmap%26nbsp%3B%20%3A%200xfff00000%20-%200xfffe0000%26nbsp%3B%26nbsp%3B%20(%20896%20kB)%3C%2FP%3E%3CP%3EDMA%20%3A%200xf4600000%20-%200xffe00000%20(%20184%20MB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vmalloc%20%3A%200xc0800000%20-%200xf2000000%26nbsp%3B%26nbsp%3B%20(%20792%20MB)%3C%2FP%3E%3CP%3Elowmem%20%3A%200x80000000%20-%200xc0000000%20(1024%20MB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pkmap%26nbsp%3B%26nbsp%3B%20%3A%200x7fe00000%20-%200x80000000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%26nbsp%3B%202%20MB)%3C%2FP%3E%3CP%3E%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20%3A%200x7f000000%20-%200x7fe00000%20(%2014%20MB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.init%20%3A%200x80008000%20-%200x8003d000%26nbsp%3B%26nbsp%3B%20(%20212%20kB)%3C%2FP%3E%3CP%3E%E3%80%82%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%3A%200x8003d000%20-%200x80ab36f8%20(10714%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.data%20%3A%200x80ab4000%20-%200x80b18300%26nbsp%3B%26nbsp%3B%20(%20401%20kB)%3C%2FP%3E%3CP%3E.bss%E3%81%AE%3A%200x80b18324%20-%200x80b6678c%20(%20314%20kB)%3C%2FP%3E%3CP%3ESLUB%3A%20Genslabs%3D13%2C%20HWalign%3D32%2C%20Order%3D0-3%2C%20MinObjects%3D0%2C%20CPUs%3D4%2C%20Nodes%3D1%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AA%E3%82%A8%E3%83%B3%E3%83%97%E3%83%86%E3%82%A3%E3%83%96%E3%81%AA%E9%9A%8E%E5%B1%A4%E5%9E%8B%20RCU%20%E3%81%AE%E5%AE%9F%E8%A3%85%E3%80%82%3C%2FP%3E%3CP%3ENR_IRQS%3A624%3C%2FP%3E%3CP%3EMXC%20GPIO%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FP%3E%3CP%3Esched_clock%3A3000kHz%E3%81%A732%E3%83%93%E3%83%83%E3%83%88%E3%80%81%E8%A7%A3%E5%83%8F%E5%BA%A6333ns%E3%80%811431655ms%E3%81%94%E3%81%A8%E3%81%AB%E3%83%A9%E3%83%83%E3%83%97%3C%2FP%3E%3CP%3Earm_max_freq%3D1GHz%3C%2FP%3E%3CP%3EMMIO%200x2020000%20%E3%81%AE%20MXC_Early%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20(%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%20'115200')%3C%2FP%3E%3CP%3E%E3%83%96%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20%5Bttymxc0%5D%20%E6%9C%89%E5%8A%B9%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%3A%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%80%E3%83%9F%E3%83%BC%E3%83%87%E3%83%90%E3%82%A4%E3%82%B980x30%3C%2FP%3E%3CP%3E%E9%81%85%E5%BB%B6%E3%83%AB%E3%83%BC%E3%83%97%E3%82%92%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...1581.05%20BogoMIPS(lpj%20%3D%207905280)%3C%2FP%3E%3CP%3Epid_max%3A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%3A%2032768%20%E6%9C%80%E5%B0%8F%3A%20301%3C%2FP%3E%3CP%3E%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%83%BB%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%83%BC%E6%95%B0%3A%20512%3C%2FP%3E%3CP%3ECPU%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE%E3%82%B3%E3%83%92%E3%83%BC%E3%83%AC%E3%83%B3%E3%82%B7%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%3AOK%3C%2FP%3E%3CP%3Ehw%20perfevents%3A%20ARMv7%20Cortex-A9%20PMU%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%A7%E6%9C%89%E5%8A%B9%E3%80%817%20%E3%81%A4%E3%81%AE%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%3C%2FP%3E%3CP%3ECPU1%3A%E8%B5%B7%E5%8B%95%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3C%2FP%3E%3CP%3ECPU2%3A%E8%B5%B7%E5%8B%95%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3C%2FP%3E%3CP%3ECPU3%3A%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3C%2FP%3E%3CP%3E4%E3%81%A4%E3%81%AECPU%E3%82%92%E8%82%B2%E3%81%A6%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3ESMP%3A%E5%90%88%E8%A8%884%E3%81%A4%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%8C%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F(6324.22%20BogoMIPS)%E3%80%82%3C%2FP%3E%3CP%3Eprint_constraints%3A%E3%83%80%E3%83%9F%E3%83%BC%3A%20%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2016%3C%2FP%3E%3CP%3Eprint_constraints%3Avddpu%3A725%20%26lt%3B--%26gt%3B%20700%20mV%E3%81%AE%E9%80%9F%E3%81%84%E6%AD%A3%E5%B8%B8%E3%81%AA700%E3%81%AEmV%E3%81%A7%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vddcore%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20at%201150%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3Eprint_constraints%3Avddsoc%3A725%26lt%3B--%26gt%3B%201300%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vdd2p5%3A%202000%20%26lt%3B--%26gt%3B%202400%20mV%20%E3%81%A7%202775%20mV%20%E9%AB%98%E9%80%9F%E3%83%8E%E3%83%BC%E3%83%9E%E3%83%AB%20%3C%2FP%3E%3CP%3Eprint_constraints%3Avdd1p1%3A800%26lt%3B--%26gt%3B%201400%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3Avdd3p0%3A2625%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3Ehw-breakpoint%3A%206%20%E3%81%A4%E3%81%AE%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%A8%201%20%E3%81%A4%E3%81%AE%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Ehw-breakpoint%3A%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E7%94%A8%E3%81%AB%E4%BA%88%E7%B4%84%E3%81%95%E3%82%8C%E3%81%9F%201%20%E3%81%A4%E3%81%AE%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%80%82%3C%2FP%3E%3CP%3Ehw-breakpoint%3A%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E6%9C%80%E5%A4%A7%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF%204%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EL310%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%8C%E6%9C%89%E5%8A%B9%3C%2FP%3E%3CP%3El2x0%3A%2016%20%E9%80%9A%E3%82%8A%E3%80%81CACHE_ID%200x410000c7%E3%80%81AUX_CTRL%200x02070000%E3%80%81%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%E3%82%B5%E3%82%A4%E3%82%BA%3A%201048576%20B%3C%2FP%3E%3CP%3EBIO%3A0%E3%81%AB%E3%82%B9%E3%83%A9%E3%83%96%3CBIO-0%3E%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%3C%2FBIO-0%3E%3C%2FP%3E%3CP%3EMXS-DMA%20MXS-DMA-APBH%3A%E5%88%9D%E6%9C%9F%E5%8C%96%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3Eprint_constraints%3ASPKVDD%3A4200mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3Avmmc%3A3300%20mV%20%3C%2FP%3E%3CP%3Evgaarb%3A%20%E3%83%AD%E3%83%BC%E3%83%89%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3ESCSI%20%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Espi_imx%20imx6q-ecspi.0%3A%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3C%2FP%3E%3CP%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20usbfs%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Eusbcore%3A%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%83%8F%E3%83%96%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20USB%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%ABUSB%20OTG%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%80%81%24Revision%3A%201.55%20%24%3C%2FP%3E%3CP%3Emc_pfuze%201-0008%3A%20ID%3A%200%E3%80%81%E3%83%95%E3%83%AB%E3%83%AC%E3%82%A4%3A%201%E3%80%81%E3%83%A1%E3%82%BF%E3%83%AB%E3%83%AC%E3%82%A4%3A%201%3C%2FP%3E%3CP%3Emc_pfuze%201-0008%3A%20FAB%3A%200%20%2CFIN%3A%200%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_SW1A%3A300%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_SW1B%3A300%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_SW1C%3A300%26lt%3B--%26gt%3B%201875%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_SW2%3A800%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_SW3A%3A400%20%26lt%3B--%26gt%3B%201975%20mV%E3%80%811500%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_SW3B%3A400%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_SW4%3A800%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_SWBST%3A5000%26lt%3B--%26gt%3B%205150%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_VSNVS%3A1200%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_VREFDDR%3A750mV%E3%81%A7%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_VGEN1%3A800%26lt%3B--%26gt%3B%201550%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_VGEN2%3A800%26lt%3B--%26gt%3B%201550%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_VGEN3%3A1800%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_VGEN4%3A1800%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_VGEN5%3A1800%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_VGEN6%3A1800%26lt%3B--%26gt%3B%203300%20mV%20%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.0%3A%20IPU%20DMFC%20NORMAL%20mode%3A%201(0~1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.1%3A%20IPU%20DMFC%20NORMAL%20mode%3A%201(0~1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3Emxc_mipi_csi2%20mxc_mipi_csi2%3A%20i.MX%20MIPI%20CSI2%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Emxc_mipi_csi2%20mxc_mipi_csi2%3Ai.MX%20MIPI%20CSI2%20dphy%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8C0x3130302a%3C%2FP%3E%3CP%3EMIPI%20CSI2%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%83%BB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EAdvanced%20Linux%20Sound%20Architecture%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B31.0.24%E3%80%82%3C%2FP%3E%3CP%3EBluetooth%3A%E3%82%B3%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B32.16%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2031%3C%2FP%3E%3CP%3EBluetooth%3AHCI%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E6%8E%A5%E7%B6%9A%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3AHCI%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3AL2CAP%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3ASCO%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Ecfg80211%3A%20CRDA%20%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%A6%E4%B8%96%E7%95%8C%E3%81%AE%E8%A6%8F%E5%88%B6%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EMAX17135%202-0048%3AeInk%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E7%94%A8PMIC%20MAX17135%3C%2FP%3E%3CP%3EI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BMAX17135%5D%3C%2FP%3E%3CP%3EI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E3%83%AC%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A0%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%5BMAX17135%5D%3C%2FP%3E%3CP%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9mxc_timer1%E3%81%B8%E3%81%AE%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%202%3C%2FP%3E%3CP%3EIP%20%E3%83%AB%E3%83%BC%E3%83%88%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%2032768%20(%E9%A0%86%E5%BA%8F%3A%205%E3%80%81131072%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3ETCP%20%E7%A2%BA%E7%AB%8B%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20131072%20(%E9%A0%86%E5%BA%8F%3A%208%E3%80%811048576%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3ETCP%E3%83%90%E3%82%A4%E3%83%B3%E3%83%89%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A65536(%E9%A0%86%E5%BA%8F%3A7%E3%80%81786432%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3ETCP%3A%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99(%E3%83%90%E3%82%A4%E3%83%B3%E3%83%8965536%20131072%E7%A2%BA%E7%AB%8B)%3C%2FP%3E%3CP%3ETCP%20reno%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EUDP%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20512%20(%E9%A0%86%E5%BA%8F%3A%202%E3%80%8116384%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3EUDP-Lite%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20512%20(%E9%A0%86%E5%BA%8F%3A%202%E3%80%8116384%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%201%3C%2FP%3E%3CP%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%E5%90%8D%E5%89%8D%E3%81%AE%20UNIX%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E8%BB%A2%E9%80%81%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%20UDP%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%20tcp%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%20tcp%20NFSv4.1%20%E3%83%90%E3%83%83%E3%82%AF%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3EPMU%3A%E3%82%BF%E3%82%A4%E3%83%970%E3%81%AE%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%E6%96%B0%E3%81%97%E3%81%84PMU%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%ABi.MX6%E3%81%AE%E3%82%B9%E3%82%BF%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%83%BB%E3%83%91%E3%83%AF%E3%83%BC%E3%83%BB%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A1%E3%83%B3%E3%83%88%3C%2FP%3E%3CP%3Ei.MX6%20%E3%81%AE%E5%BE%85%E6%A9%9F%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%3C%2FP%3E%3CP%3Ecpaddr%20%3D%20c0880000%20suspend_iram_base%3Dc091c000%3C%2FP%3E%3CP%3EPM%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81DB_R0%3A0x00b4f900%E3%80%81DB_R1%3A0x08200000!%3C%2FP%3E%3CP%3EIMX%20PCIe%20port%3A%20link%20down!%3C%2FP%3E%3CP%3EIMX%20USB%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3C%2FP%3E%3CP%3E%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%BD%E3%83%BC%E3%82%B9IRQ%2075%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FP%3E%3CP%3EIMX%20USB%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3C%2FP%3E%3CP%3ECPU%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%A2%E3%83%BC%E3%83%89%3Aldo_bypass%3C%2FP%3E%3CP%3E_regulator_get%3A%20%E8%AD%98%E5%88%A5%E5%AD%90%E3%81%AA%E3%81%97%E3%81%AE%20get()%3C%2FP%3E%3CP%3Emx6_cpu_regulator_init%3APU%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AE%E5%85%A5%E6%89%8B%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Ei.MXC%20CPU%E5%91%A8%E6%B3%A2%E6%95%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3EJFFS2%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.2.(NAND)%20%E6%BC%8F%202001-2006%20Red%20Hat%2C%20Inc.%3C%2FP%3E%3CP%3Emsgmni%20%E3%81%8C%201751%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%3C%2FP%3E%3CP%3Ealg%3A%20stdrng%20(krng)%20%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%AA%E3%81%97%3C%2FP%3E%3CP%3EIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9NOOP%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9%E3%81%AE%E7%B7%A0%E5%88%87%E6%97%A5%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3EIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9CFQ%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF(%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88)%3C%2FP%3E%3CP%3Emxc_mipi_dsi%20mxc_mipi_dsi%3A%20i.MX%20MIPI%20DSI%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EMIPI%20DSI%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.0%3AMXC%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCLDB%E3%81%AE%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E_regulator_get%3A%20%E8%AD%98%E5%88%A5%E5%AD%90%E3%81%AA%E3%81%97%E3%81%AE%20get()%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%3ALDB%20channel0%E3%81%AEIPU%20DI1%E3%82%92IPU%20DI0%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Efbcvt%3A%E3%82%A2%E3%82%B9%E3%83%9A%E3%82%AF%E3%83%88%E6%AF%94%E3%81%AFCVT%E6%A8%99%E6%BA%96%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Efbcvt%3A%201024x600%4060%3A%20CVT%20%E5%90%8D%20-%20CVT%20%E8%A6%8F%E6%A0%BC%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%20-%200.614%20%E3%83%A1%E3%82%AC%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E7%94%BB%E5%83%8F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.1%3A%20IPU%20DMFC%20DP%20HIGH%20RESOLUTION%3A%201(0%2C1)%2C%205B(2~5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%3A%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9128x37%E3%81%B8%E3%81%AE%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.1%3AMXC%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCLDB%E3%81%AE%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%3A2%E7%95%AA%E7%9B%AE%E3%81%AEldb%20displdb%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E5%88%A5%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.1%3Amxc%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F!%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.2%3AMXC%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCLCD%E3%81%AE%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.3%3AMXC%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCLDB%E3%81%AE%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%3A2%E7%95%AA%E7%9B%AE%E3%81%AEldb%20displdb%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E5%88%A5%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.3%3Amxc%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F!%3C%2FP%3E%3CP%3EIMX-SDMA%3A%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%201.1%20%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3Eimx-sdma%3A%20%E5%88%9D%E6%9C%9F%E5%8C%96%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3AIMX%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3Eimx-uart.2%3AMMIO%200x21ec000%20(irq%20%3D%2060)%20%E3%81%AE%20ttymxc2%20%E3%81%AF%20IMX%20%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3Eimx-uart.0%3AMMIO%200x2020000%20(irq%20%3D%2058)%20%E3%81%AE%20ttymxc0%20%E3%81%AF%20IMX%20%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20%5Bttymxc0%5D%20%E3%81%8C%E6%9C%89%E5%8A%B9%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%8C%E7%84%A1%E5%8A%B9%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20%5Bttymxc0%5D%20%E3%81%8C%E6%9C%89%E5%8A%B9%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%8C%E7%84%A1%E5%8A%B9%3C%2FP%3E%3CP%3Eloop%3A%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Eahci%3ASSS%E3%83%95%E3%83%A9%E3%82%B0%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%80%81%E3%83%91%E3%83%A9%E3%83%AC%E3%83%AB%E3%83%90%E3%82%B9%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%81%8C%E7%84%A1%E5%8A%B9%3C%2FP%3E%3CP%3EAHCI%20AHCI.0%3AAHCI%200001.0300%2032%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%80%811%E3%83%9D%E3%83%BC%E3%83%88%E3%80%813%20Gbps%200x1%20impl%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%A2%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3Eahci%20ahci.0%3A%20flags%3A%20ncq%20sntf%20stag%20pm%20led%20clo%20only%20pmp%20pio%20slum%20part%20ccc%20apst%20%3C%2FP%3E%3CP%3Escsi0%20%3A%20ahci_platform%3C%2FP%3E%3CP%3Eata1%3A%20SATA%20max%20UDMA%2F133%20mmio%20%5Bmem%200x02200000-0x02200fff%5D%20port%200x100%20irq%2071%3C%2FP%3E%3CP%3EM25P80%20SPI0.0%3A%E8%AA%8D%E8%AD%98%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84JEDEC%20ID%20ffffff%3C%2FP%3E%3CP%3EGPMI%20NAND%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82(IMX%E3%81%AE)%3C%2FP%3E%3CP%3Evcan%3A%20%E4%BB%AE%E6%83%B3%20CAN%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3ECAN%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3C%2FP%3E%3CP%3EFlexcan%20NetDevice%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FP%3E%3CP%3EFEC%20%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3Efec_enet_mii_bus%3A%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3C%2FP%3E%3CP%3Eehci_hcd%3A%20USB%202.0%20%E3%80%8C%E6%8B%A1%E5%BC%B5%E3%80%8D%E3%83%9B%E3%82%B9%E3%83%88%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%20(EHCI)%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3EFSL-EHCI%20FSL-EHCI.0%3A%E6%96%B0%E3%81%97%E3%81%84USB%E3%83%90%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%80%81%E3%83%90%E3%82%B9%E7%95%AA%E5%8F%B71%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20irq%2075%2C%20io%20base%200x02184000%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%96%201-0%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%96%201-0%3A1.0%3A%201%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%BD%E3%83%BC%E3%82%B9IRQ%2072%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3EFSL-EHCI%20FSL-EHCI.1%3A%E6%96%B0%E3%81%97%E3%81%84USB%E3%83%90%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%80%81%E3%83%90%E3%82%B9%E7%95%AA%E5%8F%B72%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20irq%2072%2C%20io%20base%200x02184200%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%96%202-0%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%96%202-0%3A1.0%3A%201%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EUSB%E5%A4%A7%E5%AE%B9%E9%87%8F%E8%A8%98%E6%86%B6%E8%A3%85%E7%BD%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FP%3E%3CP%3Eusbcore%3A%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AEusb-storage%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3EUSB%E3%83%9E%E3%82%B9%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EARC%20USBOTG%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20(2005%20%E5%B9%B4%208%20%E6%9C%88%201%20%E6%97%A5)%3C%2FP%3E%3CP%3Emousedev%3A%20PS%2F2%20%E3%83%9E%E3%82%A6%E3%82%B9%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20(%E5%85%A8%E3%83%9E%E3%82%A6%E3%82%B9%E5%85%B1%E9%80%9A)%3C%2FP%3E%3CP%3E%E5%85%A5%E5%8A%9B%3A%20GPIO-keys%20as%20%2Fdevices%2Fplatform%2Fgpio-keys%2Finput%2Finput0%3C%2FP%3E%3CP%3E%E5%85%A5%E5%8A%9B%3A%2Fdevices%2Fplatform%2Fimx-i2c.1%2Fi2c-1%2F1-0048%2Finput%2Finput1%E3%81%A8%E3%81%97%E3%81%A6max11801_ts%3C%2FP%3E%3CP%3Eegalax_ts%201-0004%3Aegalax_ts%3A%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Eegalax_ts%3A%201-0004%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-5%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Eegalax_ts%202-0004%3A%20egalax_ts%3A%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Eegalax_ts%3A%202-0004%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-5%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Eata1%3A%20SATA%20link%20up%203.0%20Gbps%20(SStatus%20123%20SControl%20300)%3C%2FP%3E%3CP%3Eata1.00%3A%20ATA-8%3A%20WDC%20WD3200BPVT-00JJ5T0%2C%2001.01A01%2C%20max%20UDMA%2F133%3C%2FP%3E%3CP%3Eata1.00%3A%20625142448%20%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%E3%80%81%E3%83%9E%E3%83%AB%E3%83%81%200%3A%20LBA48%20NCQ%20(%E6%B7%B1%E3%81%95%2031%2F32)%3C%2FP%3E%3CP%3Eata1.00%3A%20UDMA%2F133%20%E7%94%A8%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3Escsi%200%3A0%3A0%3A0%3A%20Direct-Access%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ATA%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20WDC%20WD3200BPVT-0%2001.0%20PQ%3A%200%20ANSI%3A%205%3C%2FP%3E%3CP%3Esd%200%3A0%3A0%3A0%3A%20%5Bsda%5D%20625142448%20512%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E8%AB%96%E7%90%86%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%3A%20(320%20GB%2F298%20GiB)%3C%2FP%3E%3CP%3ESD%200%3A0%3A0%3A0%3A%20%5BSDA%5D%204096%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E7%89%A9%E7%90%86%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%3C%2FP%3E%3CP%3Esd%200%3A0%3A0%3A0%3A%20%5Bsda%5D%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E4%BF%9D%E8%AD%B7%E3%81%8C%E3%82%AA%E3%83%95%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Esd%200%3A0%3A0%3A0%3A%20%5Bsda%5D%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%3A%20%E6%9C%89%E5%8A%B9%E3%80%81%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%3A%20%E6%9C%89%E5%8A%B9%E3%80%81DPO%20%E3%81%BE%E3%81%9F%E3%81%AF%20FUA%20%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%20SDA%3ASDA1%20SDA2%20SDA3%3C%2FP%3E%3CP%3Esd%200%3A0%3A0%3A0%3A%20%5Bsda%5D%20%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%9FSCSI%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%3C%2FP%3E%3CP%3Eusb%202-1%3Afsl-ehci%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E6%96%B0%E3%81%97%E3%81%84%E3%83%95%E3%83%AB%E3%82%B9%E3%83%94%E3%83%BC%E3%83%89USB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E7%95%AA%E5%8F%B72%3C%2FP%3E%3CP%3Eelan%20-%20Hello%20%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EELAN-TOUCH%3A2-0010%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC-22%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EI2C-Core%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%5BISL29023%5D%20%E3%81%8C%E5%BE%93%E6%9D%A5%E3%81%AE%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3EI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E3%83%AC%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A0%E6%96%B9%E6%B3%95%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BISL29023%5D%3C%2FP%3E%3CP%3Esnvs_rtc%20snvs_rtc.0%3ARTC%E3%82%B3%E3%82%A2%3ARTC0%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2snvs_rtc%3C%2FP%3E%3CP%3Ei2c%20%2Fdev%20entries%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3ELinux%E3%83%93%E3%83%87%E3%82%AA%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3Av2.00%3C%2FP%3E%3CP%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%E3%83%93%E3%83%87%E3%82%AA%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FV4L2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B916%3C%2FP%3E%3CP%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%E3%83%93%E3%83%87%E3%82%AA%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FV4L2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B917%3C%2FP%3E%3CP%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%E3%83%93%E3%83%87%E3%82%AA%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FV4L2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B918%3C%2FP%3E%3CP%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%E3%83%93%E3%83%87%E3%82%AA%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FV4L2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B919%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%96%202-1%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%96%202-1%3A1.0%3A%204%20%E3%81%A4%E3%81%AE%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Emag3110%202-000e%3A%20check%20mag3110%20chip%20ID%3C%2FP%3E%3CP%3Emag3110%202-000e%3A%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%83%81%E3%83%83%E3%83%97ID%200xfffffffb%E3%81%8C0xc4%E3%81%A8%E7%AD%89%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93!%3C%2FP%3E%3CP%3EMAG3110%3A2-000E%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC-22%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EI2C-Core%3A%20%E5%BE%93%E6%9D%A5%E3%81%AE%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%5BMAG3110%5D%3C%2FP%3E%3CP%3EI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E3%83%AC%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A0%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BMAG3110%5D%3C%2FP%3E%3CP%3Emma8451%200-001c%3A%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%83%81%E3%83%83%E3%83%97%20ID%200x1%20%E3%81%8C%200x1a%20%E3%81%BE%E3%81%9F%E3%81%AF%200x2a%20%E3%81%A8%E7%AD%89%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3EMMA8451%20%3A%200-001C%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-22%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3EIMX2-WDT%20IMX2-WDT.0%3AIMX2%2B%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%3D60%E7%A7%92%20(nowayout%3D1)%3C%2FP%3E%3CP%3EBluetooth%3A%E4%BB%AE%E6%83%B3HCI%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCver%201.3%3C%2FP%3E%3CP%3EBluetooth%3AHCI%20UART%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCver%202.2%3C%2FP%3E%3CP%3EBluetooth%3A%20HCIATH3K%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3A%E6%B1%8E%E7%94%A8Bluetooth%20USB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCver%200.6%3C%2FP%3E%3CP%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20btusb%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Esdhci%3A%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%BB%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%83%BB%E3%83%9B%E3%82%B9%E3%83%88%E3%83%BB%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%83%BB%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3Esdhci%3A%20Copyright(c)%20Pierre%20Ossman%20(%E8%8B%B1%E8%AA%9E)%3C%2FP%3E%3CP%3Emmc0%3A%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20%5BSDHCI-ESDHC-IMX.3%5D%20%E4%B8%8A%E3%81%AE%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BCDMA%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3Emmc1%3A%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20%5BSDHCI-ESDHC-IMX.1%5D%20%E4%B8%8A%E3%81%AE%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BCDMA%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3Emmc2%3A%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20%5BSDHCI-ESDHC-IMX.2%5D%20%E4%B8%8A%E3%81%AE%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BCDMA%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3Emxc_vdoa%20mxc_vdoa%3A%20i.MX%20Video%20Data%20Order%20Adapter%20(VDOA)%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EVPU%20%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E7%99%BB%E9%8C%B2mxc_asrc%3C%2FP%3E%3CP%3E%E6%B8%A9%E5%BA%A6%E6%A0%A1%E6%AD%A3%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C0x5894f069%3C%2FP%3E%3CP%3E%E3%83%AC%E3%82%B7%E3%82%AA%20%3D%20183%20%E3%81%AE%E3%82%B5%E3%83%BC%E3%83%9E%E3%83%AB%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%3C%2FP%3E%3CP%3EAnatop%20Thermal%20%E3%81%AF%20thermal_zone0%20%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Eanatop_thermal_probe%3A%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E5%86%B7%E5%8D%B4%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AFCPUFreq%E3%81%A7%E3%81%99!%3C%2FP%3E%3CP%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20usbhid%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Eusbhid%3A%20USB%20HID%20%E3%82%B3%E3%82%A2%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCsnd-usb-audio%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Emxc_hdmi_soc%20mxc_hdmi_soc.0%3AMXC%20HDMI%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%3C%2FP%3E%3CP%3ECirrus%20Logic%20CS42888%20ALSA%20SoC%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3EI2C-Core%3A%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BCS42888%5D%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3EI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E5%86%8D%E9%96%8B%E6%96%B9%E6%B3%95%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BCS42888%5D%3C%2FP%3E%3CP%3Eimx-hdmi-soc-dai%20imx-hdmi-soc-dai.0%3A%E5%A4%B1%E6%95%97%3A%E6%9C%80%E5%88%9D%E3%81%ABHDMI%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Emmc0%3A%20%E6%96%B0%E3%81%97%E3%81%84%E9%AB%98%E9%80%9F%20DDR%20MMC%20%E3%82%AB%E3%83%BC%E3%83%89%20(%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200001)%3C%2FP%3E%3CP%3Emmcblk0%3A%20mmc0%3A0001%20SEM04G%203.68%20GiB%20%3C%2FP%3E%3CP%3Emmcblk0boot0%3A%20mmc0%3A0001%20SEM04G%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%201%202.00%20MiB%3C%2FP%3E%3CP%3Emmcblk0boot1%3A%20mmc0%3A0001%20SEM04G%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%202%202.00%20MiB%3C%2FP%3E%3CP%3E%20mmcblk0%3A%20p1%3C%2FP%3E%3CP%3E%20mmcblk0boot1%3A%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E4%B8%8D%E6%98%8E%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%20mmcblk0boot0%3A%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E4%B8%8D%E6%98%8E%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3Eusb%202-1.3%3Afsl-ehci%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E6%96%B0%E3%81%97%E3%81%84%E4%BD%8E%E9%80%9FUSB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E7%95%AA%E5%8F%B73%3C%2FP%3E%3CP%3Ewm8962%200-001a%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%20WM8962%20%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82ID%200%20!%3D%206243%3C%2FP%3E%3CP%3Ewm8962%200-001a%3A%20asoc%3A%20CODEC%20wm8962.0-001a%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82-22%3C%2FP%3E%3CP%3EASOC%3A%20%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20WM8962-%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%3A%20-22%3C%2FP%3E%3CP%3Eimx_3stack%20ASOC%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3EHDMI%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%9C%80%E5%88%9D%E3%81%ABHDMI%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84!%3C%2FP%3E%3CP%3EALSA%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E4%B8%80%E8%A6%A7%3A%3C%2FP%3E%3CP%3E%E3%82%B5%E3%82%A6%E3%83%B3%E3%83%89%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2026%3C%2FP%3E%3CP%3ETCP%E3%82%AD%E3%83%A5%E3%83%BC%E3%83%93%E3%83%83%E3%82%AF%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2017%3C%2FP%3E%3CP%3ECAN%3A%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%82%A8%E3%83%AA%E3%82%A2%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B3%E3%82%A2(REB%2020090105%20ABI%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2029%3C%2FP%3E%3CP%3ECAN%3ARAW%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB(Rev%2020090105)%3C%2FP%3E%3CP%3ECAN%3A%20%E3%83%96%E3%83%AD%E3%83%BC%E3%83%89%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%20%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20(%E6%94%B9%E8%A8%82%E7%89%88%2020090105%20T)%3C%2FP%3E%3CP%3EBluetooth%3ARFCOMM%20TTY%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3ARFCOMM%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3ARFCOMM%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B31.11%3C%2FP%3E%3CP%3EBluetooth%3ABNEP(%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3)ver%201.3%3C%2FP%3E%3CP%3EBluetooth%3ABNEP%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%3A%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%9E%E3%83%AB%E3%83%81%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%3C%2FP%3E%3CP%3E%E5%85%A5%E5%8A%9B%3AHID%2004b3%3A310d%20as%20%2Fdevices%2Fplatform%2Ffsl-ehci.1%2Fusb2%2F2-1%2F2-1.3%2F2-1.3%3A1.0%2Finput%2Finput2%3C%2FP%3E%3CP%3E%E6%B1%8E%E7%94%A8-usb%200003%3A04B3%3A310D.0001%3Ainput%2Chidraw0%3A%20usb-fsl-ehci.1-1.3%2Finput0%20%E4%B8%8A%E3%81%AE%20USB%20HID%20v1.11%20%E3%83%9E%E3%82%A6%E3%82%B9%20%5BHID%2004b3%3A310d%5D%3C%2FP%3E%3CP%3EBluetooth%3AHIDP(%E3%83%92%E3%83%A5%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3)ver%201.2%3C%2FP%3E%3CP%3Elib80211%3A%20IEEE802.11%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E5%85%B1%E9%80%9A%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%3C%2FP%3E%3CP%3EVFP%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20v0.3%3A%20implementor%2041%20architecture%203%20part%2030%20variant%209%20rev%204%3C%2FP%3E%3CP%3E%E3%83%90%E3%82%B9%E5%91%A8%E6%B3%A2%E6%95%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%83%90%E3%82%B9%E5%91%A8%E6%B3%A2%E6%95%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%E6%9C%89%E5%8A%B9%3C%2FP%3E%3CP%3Emxc_dvfs_core_probe%3C%2FP%3E%3CP%3EDVFS%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Eregulator_init_complete%3A%20PFUZE100_VGEN6%3A%20%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%AA%E5%88%B6%E7%B4%84%E3%80%81%E3%82%AA%E3%83%B3%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3Eregulator_init_complete%3A%20PFUZE100_VGEN3%3A%20%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%AA%E5%88%B6%E7%B4%84%E3%80%81%E3%82%AA%E3%83%B3%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3Eregulator_init_complete%3A%20PFUZE100_VGEN2%3A%20%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%AA%E5%88%B6%E7%B4%84%E3%80%81%E3%82%AA%E3%83%B3%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3Eregulator_init_complete%3A%20PFUZE100_VGEN1%3A%20%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%AA%E5%88%B6%E7%B4%84%E3%80%81%E3%82%AA%E3%83%B3%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3Esnvs_rtc%20snvs_rtc.0%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%201970-01-01%2000%3A00%3A00%20UTC%20(0)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3Eusb%202-1.4%3Afsl-ehci%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E6%96%B0%E3%81%97%E3%81%84%E4%BD%8E%E9%80%9FUSB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E7%95%AA%E5%8F%B74%3C%2FP%3E%3CP%3EEXT3-fs%3A%20%E3%83%90%E3%83%AA%E3%82%A2%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Ekjournald%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%E9%96%93%E9%9A%94%205%20%E7%A7%92%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3EEXT3-fs%20(mmcblk0p1)%3A%20%E8%AD%A6%E5%91%8A%3A%20%E6%9C%80%E5%A4%A7%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E6%95%B0%E3%81%AB%E9%81%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82e2fsck%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EEXT3-fs%20(mmcblk0p1)%3A%20%E5%86%85%E9%83%A8%E3%82%B8%E3%83%A3%E3%83%BC%E3%83%8A%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3EEXT3-fs%20(mmcblk0p1)%3A%20%E5%BE%A9%E6%97%A7%E5%AE%8C%E4%BA%86%3C%2FP%3E%3CP%3EEXT3-fs%20(mmcblk0p1)%3A%20%E3%83%A9%E3%82%A4%E3%83%88%E3%83%90%E3%83%83%E3%82%AF%E3%83%BB%E3%83%87%E3%83%BC%E3%82%BF%E3%83%BB%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3C%2FP%3E%3CP%3EVFS%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20179%3A1%20%E3%81%AB%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E3%83%AB%E3%83%BC%E3%83%88%20(ext3%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0)%E3%80%82%3C%2FP%3E%3CP%3Einit%20%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E8%A7%A3%E6%94%BE%3A%20212K%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E6%96%B0%E3%81%97%E3%81%84%20uImage.It%20%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E6%AC%A1%E3%81%AE%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%20%E6%A7%8B%E6%88%90%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%20%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%9F%20%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3ECONFIG_IMX_PCIE%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%23%20CONFIG_IMX_PCIE_EP_MODE_IN_EP_RC_SYS%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%23%20CONFIG_IMX_PCIE_RC_MODE_IN_EP_RC_SYS%3Dy%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81PCIe%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3ECommend%20LSPCI%E3%81%AE%E5%BE%8C%E3%81%AB%E3%81%AF%E4%BD%95%E3%82%82%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126631%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126631%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AEconfigureatin%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%B8%B8%E3%81%AB%E5%90%8C%E3%81%98%E3%83%AD%E3%82%B0%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EUDP%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20512%20(%E9%A0%86%E5%BA%8F%3A%202%E3%80%8116384%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3EUDP-Lite%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20512%20(%E9%A0%86%E5%BA%8F%3A%202%E3%80%8116384%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%201%3C%2FP%3E%3CP%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%E5%90%8D%E5%89%8D%E3%81%AE%20UNIX%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E8%BB%A2%E9%80%81%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%20UDP%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%20tcp%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%20tcp%20NFSv4.1%20%E3%83%90%E3%83%83%E3%82%AF%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3EPMU%3A%E3%82%BF%E3%82%A4%E3%83%970%E3%81%AE%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%E6%96%B0%E3%81%97%E3%81%84PMU%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%ABi.MX6%E3%81%AE%E3%82%B9%E3%82%BF%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%83%BB%E3%83%91%E3%83%AF%E3%83%BC%E3%83%BB%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A1%E3%83%B3%E3%83%88%3C%2FP%3E%3CP%3Ei.MX6%20%E3%81%AE%E5%BE%85%E6%A9%9F%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%3C%2FP%3E%3CP%3Ecpaddr%20%3D%20c0880000%20suspend_iram_base%3Dc091c000%3C%2FP%3E%3CP%3EPM%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EiMX6%20PCIe%20PCIe%20RC%20mode%20imx_pcie_pltfm_probe%20entering.%3C%2FP%3E%3CP%3EPCIE%3A%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E9%96%8B%E5%A7%8Bimx_pcie_pltfm_probe%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81DB_R0%3A0x00ff5100%E3%80%81DB_R1%3A0x08200000!%3C%2FP%3E%3CP%3EIMX%20PCIe%20port%3A%20link%20down!%3C%2FP%3E%3CP%3EIMX%20USB%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3C%2FP%3E%3CP%3E%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%BD%E3%83%BC%E3%82%B9IRQ%2075%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FP%3E%3CP%3EIMX%20USB%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%E2%94%82%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20***%20MX6%20Options%3A%20***%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E2%94%82%20%E2%94%82%26nbsp%3B%20%3C%2FP%3E%3CP%3E%E2%94%82%20%E2%94%82%20%5B*%5D%20PCI%20Express%E5%AF%BE%E5%BF%9C%20%E2%94%82%20%3C%2FP%3E%3CP%3E%E2%94%82%20%E2%94%82%20%5B%20%5D%20IMX6%20RC%2FEP%E7%9B%B8%E4%BA%92%E6%8E%A5%E7%B6%9A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AEPCI%20Express%20EP%E3%83%A2%E3%83%BC%E3%83%89%20%E2%94%82%20%E2%94%82%20%3C%2FP%3E%3CP%3E%E2%94%82%20%E2%94%82%20%5B%20%5D%20IMX6%20RC%2FEP%E7%9B%B8%E4%BA%92%E6%8E%A5%E7%B6%9A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AEPCI%20Express%20RC%E3%83%A2%E3%83%BC%E3%83%89%20%E2%94%82%20%E2%94%82%20%3C%2FP%3E%3CP%3E%E2%94%82%20%E2%94%82%20%26lt%3B*%26gt%3B%20USB%20Host%201%20%E5%AF%BE%E5%BF%9C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E2%94%8C%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%90%20%E2%94%82%26nbsp%3B%20%3C%2FP%3E%3CP%3E%E2%94%82%20%E2%94%82%20%5B*%5D%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E4%BF%A1%E5%8F%B7%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%20(MSI%20%E3%81%8A%E3%82%88%E3%81%B3%20MSI-X)%20%E2%94%82%20%E2%94%82%20%3C%2FP%3E%3CP%3E%E2%94%82%20%E2%94%82%20%26lt%3B%20%26gt%3B%20PCI%E3%82%B9%E3%82%BF%E3%83%96%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%E2%94%82%20%E2%94%82%20%3C%2FP%3E%3CP%3E%E2%94%82%20%E2%94%82%20%5B%20%5D%20PCI%20IOV%E5%AF%BE%E5%BF%9C%20%E2%94%82%20%E2%94%82%20%3C%2FP%3E%3CP%3E%E2%94%82%20%E2%94%82%20%5B*%5D%20PCI%20Express%E5%AF%BE%E5%BF%9C%20%E2%94%82%20%3C%2FP%3E%3CP%3E%E2%94%82%20%5B*%5D%20%E3%83%AB%E3%83%BC%E3%83%88%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E9%AB%98%E5%BA%A6%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E5%A0%B1%E5%91%8A%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20%E2%94%82%20%E2%94%82%20%3C%2FP%3E%3CP%3E%E2%94%82%20%E2%94%82%20%5B%20%5D%20PCI%20Express%20ECRC%20%E8%A8%AD%E5%AE%9A%E5%88%B6%E5%BE%A1%20%E2%94%82%20%E2%94%82%20%3C%2FP%3E%3CP%3E%E2%94%82%20%E2%94%82%20%26lt%3B%20%26gt%3B%20PCIe%20AER%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%A4%E3%83%B3%E3%82%B8%E3%82%A7%E3%82%AF%E3%82%BF%E3%83%BC%E5%AF%BE%E5%BF%9C%20%E2%94%82%20%3C%2FP%3E%3CP%3E%E2%94%82%20%E2%94%82%20%5B*%5D%20PCI%20Express%20ASPM%E5%88%B6%E5%BE%A1%20%E2%94%82%20%E2%94%82%20%3C%2FP%3E%3CP%3E%26nbsp%3B%20%E2%94%82%20%E2%94%82%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B*%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Debug%20PCI%20Express%20ASPM%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%96%E3%81%AB%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126630%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126630%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3EHi%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3E%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3E%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3ECONFIG_IMX_PCIE_RC_MODE_IN_EP_RC_SYS%3Dy%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%3Boutline%3A%200%3Bfont-weight%3Ainherit%3Bfont-style%3Ainherit%3Bmin-height%3A%208pt%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E6%A7%8B%E6%88%90%E3%81%A7%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3E%E6%AD%A3%E3%81%97%E3%81%84%E8%A8%AD%E5%AE%9A%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3ECONFIG_IMX_PCIE%3Dy%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%3Boutline%3A%200%3Bfont-weight%3Ainherit%3Bfont-style%3Ainherit%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3E%23%20CONFIG_IMX_PCIE_EP_MODE_IN_EP_RC_SYS%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%3Boutline%3A%200%3Bfont-weight%3Ainherit%3Bfont-style%3Ainherit%22%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3E%23%20CONFIG_IMX_PCIE_RC_MODE_IN_EP_RC_SYS%3Dy%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22outline%3A%200%3Bfont-weight%3Ainherit%3Bfont-style%3Ainherit%3Bmin-height%3A%208pt%22%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E7%90%86%E5%AD%A6%E5%A3%AB%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%83%AA%E3%83%81%E3%83%A3%E3%83%BC%E3%83%89%E3%83%BB%E3%83%81%E3%83%A5%E3%83%BC%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126629%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126629%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2019px%3B%20background-color%3A%20%23f6f6f6%3B%22%3E%3CSTRONG%3EHi%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2019px%3B%20background-color%3A%20%23f6f6f6%3B%22%3EIMX6%E3%81%A7RTL8111E%E3%81%AA%E3%81%A9%E3%81%AE%3CSTRONG%3EPCIE%E3%82%AB%E3%83%BC%E3%83%89%3C%2FSTRONG%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-family%3A%20Arial%3B%20font-size%3A%2012px%3B%22%3E%3CSTRONG%3E%E3%82%AE%E3%82%AC%E3%83%93%E3%83%83%E3%83%88%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%82%92%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20text-decoration%3A%20underline%3B%22%3EPCIE%E7%B5%8C%E7%94%B1%E3%81%A7%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-size%3A%2012px%3B%20background-color%3A%20%23f6f6f6%3B%20font-family%3A%20Arial%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20underline%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-size%3A%2012px%3B%20background-color%3A%20%23f6f6f6%3B%20font-family%3A%20Arial%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20underline%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%AEIMX6PCIe%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-size%3A%2012px%3B%20background-color%3A%20%23f6f6f6%3B%20font-family%3A%20Arial%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20underline%3B%20font-family%3A%20arial%2C%20sans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126628%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126628%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%9A%3CBR%20%2F%3E%E3%83%AD%E3%82%B0%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%AF%E3%80%81%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%81%B4%E3%81%AB%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20style%3D%22mso-special-character%3Aline-break%22%20%2F%3E%3CBR%20style%3D%22mso-special-character%3Aline-break%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%E3%81%93%E3%81%93%E3%81%AB%E8%B2%BC%E3%82%8A%E4%BB%98%E3%81%91%E3%81%9F%E3%81%93%E3%81%AE%E6%A4%9C%E8%A8%BC%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%E3%80%81%E4%B8%BB%E3%81%ABi.MX6%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%20EP%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E6%A4%9C%E8%A8%BC%E3%81%A8%E3%80%81i.MX6%20%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%E3%81%AE%20%3CSPAN%20class%3D%22SpellE%22%3E%E3%82%B9%E3%83%AB%E3%83%BC%E3%83%97%E3%83%83%E3%83%88%3C%2FSPAN%3E%E3%83%86%E3%82%B9%E3%83%88%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A12.0pt%22%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E3%80%8C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A10.0pt%3Bfont-family%3A%20Arial%20%2C%20sans-serif%20%3Bcolor%3A%233D3D3D%22%3EPCIE%E3%82%AE%E3%82%AC%E3%83%93%E3%83%83%E3%83%88%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E5%9B%9E%E3%81%97%E3%81%9F%E3%81%84%3C%2FSPAN%3E%E3%80%8D%E3%81%A8%E8%A8%80%E3%81%A3%E3%81%9F%E3%82%B7%E3%83%8A%E3%83%AA%E3%82%AA%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A12.0pt%22%3E%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A11.0pt%22%3E%3CSPAN%20class%3D%22SpellE%22%3EPCIe%3C%2FSPAN%3E%E3%81%AE%E5%AE%9F%E8%A3%85%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A12.0pt%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A0in%3Bmargin-bottom%3A.0001pt%3Bline-height%3A18.0pt%22%3E%3CSPAN%20style%3D%22font-size%3A14.0pt%3Bmso-bidi-font-size%3A12.0pt%22%3E%E3%83%AA%E3%83%81%E3%83%A3%E3%83%BC%E3%83%89%E3%83%BB%E3%83%81%E3%83%A5%E3%83%BC%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126627%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126627%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%20%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frichard.zhu%22%20target%3D%22_blank%22%3E%E3%83%AA%E3%83%81%E3%83%A3%E3%83%BC%E3%83%89%E3%83%BB%E3%83%81%E3%83%A5%E3%83%BC%3C%2FA%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFrc.here%E3%81%AEpcie%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E6%8A%B1%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E7%A7%81%E3%81%AE%E3%83%AD%E3%82%B0%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD%E2%80%A6%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELinux%E3%81%AE%E8%A7%A3%E5%87%8D...%E5%AE%8C%E4%BA%86%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E3%83%96%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ELinux%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203.0.35(root%40ubuntu)(GCC%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B34.6.220110630%20(%E3%83%97%E3%83%AC%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9)%20(Freescale%20MAD%20--%20Linaro%202011.07%20--%20Built%20at%202011%2F08%2F10%2009%3A20)%20)%20%233%20SMP%20PREEMPT%20Wed%20Sep%204%2014%3A20%3A01%20CST%202013%3C%2FP%3E%3CP%3ECPU%3A%20ARMv7%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20%5B412fc09a%5D%20%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%2010%20(ARMv7)%E3%80%81cr%3D10c53c7d%3C%2FP%3E%3CP%3ECPU%3A%20VIPT%20%E9%9D%9E%E3%82%A8%E3%82%A4%E3%83%AA%E3%82%A2%E3%82%B7%E3%83%B3%E3%82%B0%20%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%80%81VIPT%20%E3%82%A8%E3%82%A4%E3%83%AA%E3%82%A2%E3%82%B7%E3%83%B3%E3%82%B0%E5%91%BD%E4%BB%A4%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%3C%2FP%3E%3CP%3E%E3%83%9E%E3%82%B7%E3%83%B3%3AFreescale%20i.MX%206Quad%2FDualLite%2FSolo%20Sabre-SD%E3%83%9C%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E%E8%AA%8D%E8%AD%98%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%82%BF%E3%82%B00x54410008%E3%82%92%E7%84%A1%E8%A6%96%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%9D%E3%83%AA%E3%82%B7%E3%83%BC%3A%20ECC%20%E3%81%8C%E7%84%A1%E5%8A%B9%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20writealloc%3C%2FP%3E%3CP%3ECPU%20%E3%81%AF%20i.MX6Q%E3%80%81%E3%82%B7%E3%83%AA%E3%82%B3%E3%83%B3%20rev%201.2%20%E3%81%A8%E8%AD%98%E5%88%A5%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EPERCPU%3A%E5%9F%8B%E3%82%81%E8%BE%BC%E3%81%BF7%E3%83%9A%E3%83%BC%E3%82%B8%2F%20CPU%20%408c008000%20s5440%20r8192%20d15040%20u32768%3C%2FP%3E%3CP%3E%E3%82%BE%E3%83%BC%E3%83%B3%E9%A0%86%E3%81%AB1%E3%81%A4%E3%81%AE%E3%82%BE%E3%83%BC%E3%83%B3%E3%83%AA%E3%82%B9%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%83%A2%E3%83%93%E3%83%AA%E3%83%86%E3%82%A3%E3%81%AE%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E5%8C%96%E3%82%92%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%B7%8F%E3%83%9A%E3%83%BC%E3%82%B8%E6%95%B0%3A227328%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%3A%20console%3Dttymxc0%2C115200%20root%3D%2Fdev%2Fmmcblk0p1%20rootwait%20video%3Dmxcfb0%3Adev%3Dldb%2C1024x600M%4060%2Cif%3DRGB666%20ldb%3Dsin0%3C%2FP%3E%3CP%3EPID%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%204096%20(%E9%A0%86%E5%BA%8F%3A%202%E3%80%8116384%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3EDentry%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20131072%20(%E9%A0%86%E5%BA%8F%3A%207%E3%80%81524288%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3Einode-cache%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%2065536%20(%E9%A0%86%E5%BA%8F%3A%206%E3%80%81262144%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%A2%E3%83%AA%3A640MB%20256MB%20%3D%20%E5%90%88%E8%A8%88896MB%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%A2%E3%83%AA%3A896372k%20%2F%20896372k%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%80%81152204k%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF%E3%80%810K%E9%AB%98%E3%83%A1%E3%83%A2%E3%83%AA%3C%2FP%3E%3CP%3E%E4%BB%AE%E6%83%B3%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%3A%3C%2FP%3E%3CP%3E%E3%83%99%E3%82%AF%E3%82%BF%E3%83%BC%20%3A%200xffff0000%20-%200xffff1000%20(%204%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20fixmap%26nbsp%3B%20%3A%200xfff00000%20-%200xfffe0000%26nbsp%3B%26nbsp%3B%20(%20896%20kB)%3C%2FP%3E%3CP%3EDMA%20%3A%200xf4600000%20-%200xffe00000%20(%20184%20MB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20vmalloc%20%3A%200xc0800000%20-%200xf2000000%26nbsp%3B%26nbsp%3B%20(%20792%20MB)%3C%2FP%3E%3CP%3Elowmem%20%3A%200x80000000%20-%200xc0000000%20(1024%20MB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pkmap%26nbsp%3B%26nbsp%3B%20%3A%200x7fe00000%20-%200x80000000%26nbsp%3B%26nbsp%3B%20(%26nbsp%3B%26nbsp%3B%202%20MB)%3C%2FP%3E%3CP%3E%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20%3A%200x7f000000%20-%200x7fe00000%20(%2014%20MB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.init%20%3A%200x80008000%20-%200x8003d000%26nbsp%3B%26nbsp%3B%20(%20212%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.text%20%3A%200x8003d000%20-%200x80b01d14%26nbsp%3B%26nbsp%3B%20(11028%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.data%20%3A%200x80b02000%20-%200x80b67420%26nbsp%3B%26nbsp%3B%20(%20406%20kB)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.bss%20%3A%200x80b67444%20-%200x80bb58ec%26nbsp%3B%26nbsp%3B%20(%20314%20kB)%3C%2FP%3E%3CP%3ESLUB%3A%20Genslabs%3D13%2C%20HWalign%3D32%2C%20Order%3D0-3%2C%20MinObjects%3D0%2C%20CPUs%3D4%2C%20Nodes%3D1%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AA%E3%82%A8%E3%83%B3%E3%83%97%E3%83%86%E3%82%A3%E3%83%96%E3%81%AA%E9%9A%8E%E5%B1%A4%E5%9E%8B%20RCU%20%E3%81%AE%E5%AE%9F%E8%A3%85%E3%80%82%3C%2FP%3E%3CP%3ENR_IRQS%3A624%3C%2FP%3E%3CP%3EMXC%20GPIO%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FP%3E%3CP%3Esched_clock%3A3000kHz%E3%81%A732%E3%83%93%E3%83%83%E3%83%88%E3%80%81%E8%A7%A3%E5%83%8F%E5%BA%A6333ns%E3%80%811431655ms%E3%81%94%E3%81%A8%E3%81%AB%E3%83%A9%E3%83%83%E3%83%97%3C%2FP%3E%3CP%3Earm_max_freq%3D1GHz%3C%2FP%3E%3CP%3EMMIO%200x2020000%20%E3%81%AE%20MXC_Early%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20(%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%20'115200')%3C%2FP%3E%3CP%3E%E3%83%96%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20%5Bttymxc0%5D%20%E6%9C%89%E5%8A%B9%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%3A%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%80%E3%83%9F%E3%83%BC%E3%83%87%E3%83%90%E3%82%A4%E3%82%B980x30%3C%2FP%3E%3CP%3E%E9%81%85%E5%BB%B6%E3%83%AB%E3%83%BC%E3%83%97%E3%82%92%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...1581.05%20BogoMIPS(lpj%20%3D%207905280)%3C%2FP%3E%3CP%3Epid_max%3A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%3A%2032768%20%E6%9C%80%E5%B0%8F%3A%20301%3C%2FP%3E%3CP%3E%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%83%BB%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%83%BB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%83%BC%E6%95%B0%3A%20512%3C%2FP%3E%3CP%3ECPU%3A%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AE%E3%82%B3%E3%83%92%E3%83%BC%E3%83%AC%E3%83%B3%E3%82%B7%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%3AOK%3C%2FP%3E%3CP%3Ehw%20perfevents%3A%20ARMv7%20Cortex-A9%20PMU%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%A7%E6%9C%89%E5%8A%B9%E3%80%817%20%E3%81%A4%E3%81%AE%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%3C%2FP%3E%3CP%3ECPU1%3A%E8%B5%B7%E5%8B%95%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3C%2FP%3E%3CP%3ECPU2%3A%E8%B5%B7%E5%8B%95%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3C%2FP%3E%3CP%3ECPU3%3A%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3C%2FP%3E%3CP%3E4%E3%81%A4%E3%81%AECPU%E3%82%92%E8%82%B2%E3%81%A6%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3ESMP%3A%E5%90%88%E8%A8%884%E3%81%A4%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%8C%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F(6324.22%20BogoMIPS)%E3%80%82%3C%2FP%3E%3CP%3Eprint_constraints%3A%E3%83%80%E3%83%9F%E3%83%BC%3A%20%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2016%3C%2FP%3E%3CP%3Eprint_constraints%3Avddpu%3A725%20%26lt%3B--%26gt%3B%20700%20mV%E3%81%AE%E9%80%9F%E3%81%84%E6%AD%A3%E5%B8%B8%E3%81%AA700%E3%81%AEmV%E3%81%A7%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vddcore%3A%20725%20%26lt%3B--%26gt%3B%201300%20mV%20at%201150%20mV%20fast%20normal%20%3C%2FP%3E%3CP%3Eprint_constraints%3Avddsoc%3A725%26lt%3B--%26gt%3B%201300%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3A%20vdd2p5%3A%202000%20%26lt%3B--%26gt%3B%202400%20mV%20%E3%81%A7%202775%20mV%20%E9%AB%98%E9%80%9F%E3%83%8E%E3%83%BC%E3%83%9E%E3%83%AB%20%3C%2FP%3E%3CP%3Eprint_constraints%3Avdd1p1%3A800%26lt%3B--%26gt%3B%201400%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3Avdd3p0%3A2625%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3Ehw-breakpoint%3A%206%20%E3%81%A4%E3%81%AE%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%A8%201%20%E3%81%A4%E3%81%AE%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Ehw-breakpoint%3A%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E7%94%A8%E3%81%AB%E4%BA%88%E7%B4%84%E3%81%95%E3%82%8C%E3%81%9F%201%20%E3%81%A4%E3%81%AE%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%80%82%3C%2FP%3E%3CP%3Ehw-breakpoint%3A%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E6%9C%80%E5%A4%A7%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF%204%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EL310%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%8C%E6%9C%89%E5%8A%B9%3C%2FP%3E%3CP%3El2x0%3A%2016%20%E9%80%9A%E3%82%8A%E3%80%81CACHE_ID%200x410000c7%E3%80%81AUX_CTRL%200x02070000%E3%80%81%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%E3%82%B5%E3%82%A4%E3%82%BA%3A%201048576%20B%3C%2FP%3E%3CP%3EBIO%3A0%E3%81%AB%E3%82%B9%E3%83%A9%E3%83%96%3CBIO-0%3E%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%3C%2FBIO-0%3E%3C%2FP%3E%3CP%3EMXS-DMA%20MXS-DMA-APBH%3A%E5%88%9D%E6%9C%9F%E5%8C%96%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3Eprint_constraints%3ASPKVDD%3A4200mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3Avmmc%3A3300%20mV%20%3C%2FP%3E%3CP%3Evgaarb%3A%20%E3%83%AD%E3%83%BC%E3%83%89%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3ESCSI%20%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Espi_imx%20imx6q-ecspi.0%3A%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3C%2FP%3E%3CP%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20usbfs%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Eusbcore%3A%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%83%8F%E3%83%96%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20USB%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%ABUSB%20OTG%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%80%81%24Revision%3A%201.55%20%24%3C%2FP%3E%3CP%3Emc_pfuze%201-0008%3A%20ID%3A%200%E3%80%81%E3%83%95%E3%83%AB%E3%83%AC%E3%82%A4%3A%201%E3%80%81%E3%83%A1%E3%82%BF%E3%83%AB%E3%83%AC%E3%82%A4%3A%201%3C%2FP%3E%3CP%3Emc_pfuze%201-0008%3A%20FAB%3A%200%20%2CFIN%3A%200%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_SW1A%3A300%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_SW1B%3A300%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_SW1C%3A300%26lt%3B--%26gt%3B%201875%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_SW2%3A800%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_SW3A%3A400%20%26lt%3B--%26gt%3B%201975%20mV%E3%80%811500%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_SW3B%3A400%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_SW4%3A800%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_SWBST%3A5000%26lt%3B--%26gt%3B%205150%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_VSNVS%3A1200%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_VREFDDR%3A750mV%E3%81%A7%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_VGEN1%3A800%26lt%3B--%26gt%3B%201550%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_VGEN2%3A800%26lt%3B--%26gt%3B%201550%20mV%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_VGEN3%3A1800%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_VGEN4%3A1800%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_VGEN5%3A1800%26lt%3B--%26gt%3B%20%3C%2FP%3E%3CP%3Eprint_constraints%3APFUZE100_VGEN6%3A1800%26lt%3B--%26gt%3B%203300%20mV%20%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.0%3A%20IPU%20DMFC%20NORMAL%20mode%3A%201(0~1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.1%3A%20IPU%20DMFC%20NORMAL%20mode%3A%201(0~1)%2C%205B(4%2C5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3Emxc_mipi_csi2%20mxc_mipi_csi2%3A%20i.MX%20MIPI%20CSI2%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Emxc_mipi_csi2%20mxc_mipi_csi2%3Ai.MX%20MIPI%20CSI2%20dphy%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8C0x3130302a%3C%2FP%3E%3CP%3EMIPI%20CSI2%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%83%BB%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EAdvanced%20Linux%20Sound%20Architecture%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B31.0.24%E3%80%82%3C%2FP%3E%3CP%3EBluetooth%3A%E3%82%B3%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B32.16%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2031%3C%2FP%3E%3CP%3EBluetooth%3AHCI%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E6%8E%A5%E7%B6%9A%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3AHCI%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3AL2CAP%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3ASCO%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Ecfg80211%3A%20CRDA%20%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%A6%E4%B8%96%E7%95%8C%E3%81%AE%E8%A6%8F%E5%88%B6%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EMAX17135%202-0048%3AeInk%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E7%94%A8PMIC%20MAX17135%3C%2FP%3E%3CP%3EI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BMAX17135%5D%3C%2FP%3E%3CP%3EI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E3%83%AC%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A0%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%5BMAX17135%5D%3C%2FP%3E%3CP%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9mxc_timer1%E3%81%B8%E3%81%AE%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%202%3C%2FP%3E%3CP%3EIP%20%E3%83%AB%E3%83%BC%E3%83%88%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%2032768%20(%E9%A0%86%E5%BA%8F%3A%205%E3%80%81131072%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3ETCP%20%E7%A2%BA%E7%AB%8B%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20131072%20(%E9%A0%86%E5%BA%8F%3A%208%E3%80%811048576%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3ETCP%E3%83%90%E3%82%A4%E3%83%B3%E3%83%89%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A65536(%E9%A0%86%E5%BA%8F%3A7%E3%80%81786432%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3ETCP%3A%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99(%E3%83%90%E3%82%A4%E3%83%B3%E3%83%8965536%20131072%E7%A2%BA%E7%AB%8B)%3C%2FP%3E%3CP%3ETCP%20reno%20%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EUDP%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20512%20(%E9%A0%86%E5%BA%8F%3A%202%E3%80%8116384%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3EUDP-Lite%20%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%3A%20512%20(%E9%A0%86%E5%BA%8F%3A%202%E3%80%8116384%20%E3%83%90%E3%82%A4%E3%83%88)%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%201%3C%2FP%3E%3CP%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%E5%90%8D%E5%89%8D%E3%81%AE%20UNIX%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E8%BB%A2%E9%80%81%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%20UDP%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%20tcp%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3ERPC%3A%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%20tcp%20NFSv4.1%20%E3%83%90%E3%83%83%E3%82%AF%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3EPMU%3A%E3%82%BF%E3%82%A4%E3%83%970%E3%81%AE%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%E6%96%B0%E3%81%97%E3%81%84PMU%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%ABi.MX6%E3%81%AE%E3%82%B9%E3%82%BF%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%83%BB%E3%83%91%E3%83%AF%E3%83%BC%E3%83%BB%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A1%E3%83%B3%E3%83%88%3C%2FP%3E%3CP%3Ei.MX6%20%E3%81%AE%E5%BE%85%E6%A9%9F%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%3C%2FP%3E%3CP%3Ecpaddr%20%3D%20c0880000%20suspend_iram_base%3Dc091c000%3C%2FP%3E%3CP%3EPM%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3CSTRONG%3EiMX6%20PCIe%20PCIe%20RC%20mode%20imx_pcie_pltfm_probe%20entering.%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EPCIE%3A%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E9%96%8B%E5%A7%8Bimx_pcie_pltfm_probe%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81DB_R0%3A0x009d9700%E3%80%81DB_R1%3A0x08200000!%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EIMX%20PCIe%20port%3A%20link%20down!%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EIMX%20USB%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3C%2FP%3E%3CP%3E%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%BD%E3%83%BC%E3%82%B9IRQ%2075%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FP%3E%3CP%3EIMX%20USB%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3C%2FP%3E%3CP%3ECPU%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%A2%E3%83%BC%E3%83%89%3Aldo_bypass%3C%2FP%3E%3CP%3E_regulator_get%3A%20%E8%AD%98%E5%88%A5%E5%AD%90%E3%81%AA%E3%81%97%E3%81%AE%20get()%3C%2FP%3E%3CP%3Emx6_cpu_regulator_init%3APU%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AE%E5%85%A5%E6%89%8B%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Ei.MXC%20CPU%E5%91%A8%E6%B3%A2%E6%95%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3EJFFS2%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.2.(NAND)%20%E6%BC%8F%202001-2006%20Red%20Hat%2C%20Inc.%3C%2FP%3E%3CP%3Emsgmni%20%E3%81%8C%201750%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%3C%2FP%3E%3CP%3Ealg%3A%20stdrng%20(krng)%20%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%AA%E3%81%97%3C%2FP%3E%3CP%3EIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9NOOP%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9%E3%81%AE%E7%B7%A0%E5%88%87%E6%97%A5%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3EIO%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9CFQ%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF(%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88)%3C%2FP%3E%3CP%3Emxc_mipi_dsi%20mxc_mipi_dsi%3A%20i.MX%20MIPI%20DSI%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EMIPI%20DSI%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.0%3AMXC%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCLDB%E3%81%AE%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3E_regulator_get%3A%20%E8%AD%98%E5%88%A5%E5%AD%90%E3%81%AA%E3%81%97%E3%81%AE%20get()%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%3ALDB%20channel0%E3%81%AEIPU%20DI1%E3%82%92IPU%20DI0%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Efbcvt%3A%E3%82%A2%E3%82%B9%E3%83%9A%E3%82%AF%E3%83%88%E6%AF%94%E3%81%AFCVT%E6%A8%99%E6%BA%96%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Efbcvt%3A%201024x600%4060%3A%20CVT%20%E5%90%8D%20-%20CVT%20%E8%A6%8F%E6%A0%BC%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%20-%200.614%20%E3%83%A1%E3%82%AC%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E7%94%BB%E5%83%8F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eimx-ipuv3%20imx-ipuv3.1%3A%20IPU%20DMFC%20DP%20HIGH%20RESOLUTION%3A%201(0%2C1)%2C%205B(2~5)%2C%205F(6%2C7)%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%3A%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9128x37%E3%81%B8%E3%81%AE%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.1%3AMXC%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCLDB%E3%81%AE%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%3A2%E7%95%AA%E7%9B%AE%E3%81%AEldb%20displdb%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E5%88%A5%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.1%3Amxc%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F!%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.2%3AMXC%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCLCD%E3%81%AE%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.3%3AMXC%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCLDB%E3%81%AE%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Emxc_ldb%20mxc_ldb%3A2%E7%95%AA%E7%9B%AE%E3%81%AEldb%20displdb%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E5%88%A5%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Emxc_sdc_fb%20mxc_sdc_fb.3%3Amxc%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F!%3C%2FP%3E%3CP%3EIMX-SDMA%3A%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%201.1%20%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3Eimx-sdma%3A%20%E5%88%9D%E6%9C%9F%E5%8C%96%E6%B8%88%E3%81%BF%3C%2FP%3E%3CP%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%3AIMX%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3Eimx-uart.2%3AMMIO%200x21ec000%20(irq%20%3D%2060)%20%E3%81%AE%20ttymxc2%20%E3%81%AF%20IMX%20%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3Eimx-uart.0%3AMMIO%200x2020000%20(irq%20%3D%2058)%20%E3%81%AE%20ttymxc0%20%E3%81%AF%20IMX%20%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20%5Bttymxc0%5D%20%E3%81%8C%E6%9C%89%E5%8A%B9%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%8C%E7%84%A1%E5%8A%B9%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20%5Bttymxc0%5D%20%E3%81%8C%E6%9C%89%E5%8A%B9%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%8C%E7%84%A1%E5%8A%B9%3C%2FP%3E%3CP%3Eloop%3A%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Eahci%3ASSS%E3%83%95%E3%83%A9%E3%82%B0%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%80%81%E3%83%91%E3%83%A9%E3%83%AC%E3%83%AB%E3%83%90%E3%82%B9%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%81%8C%E7%84%A1%E5%8A%B9%3C%2FP%3E%3CP%3EAHCI%20AHCI.0%3AAHCI%200001.0300%2032%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%80%811%E3%83%9D%E3%83%BC%E3%83%88%E3%80%813%20Gbps%200x1%20impl%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%A2%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3Eahci%20ahci.0%3A%20flags%3A%20ncq%20sntf%20stag%20pm%20led%20clo%20only%20pmp%20pio%20slum%20part%20ccc%20apst%20%3C%2FP%3E%3CP%3Escsi0%20%3A%20ahci_platform%3C%2FP%3E%3CP%3Eata1%3A%20SATA%20max%20UDMA%2F133%20mmio%20%5Bmem%200x02200000-0x02200fff%5D%20port%200x100%20irq%2071%3C%2FP%3E%3CP%3EM25P80%20SPI0.0%3A%E8%AA%8D%E8%AD%98%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84JEDEC%20ID%20ffffff%3C%2FP%3E%3CP%3EGPMI%20NAND%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82(IMX%E3%81%AE)%3C%2FP%3E%3CP%3Ee1000e%3A%20%E3%82%A4%E3%83%B3%E3%83%86%E3%83%AB(R)%20PRO%2F1000%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20-%201.3.10-k2%3C%2FP%3E%3CP%3Ee1000e%3A%20Copyright(c)%201999%20-%202011%20Intel%20Corporation.%3C%2FP%3E%3CP%3Evcan%3A%20%E4%BB%AE%E6%83%B3%20CAN%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3ECAN%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3C%2FP%3E%3CP%3EFlexcan%20NetDevice%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FP%3E%3CP%3EFEC%20%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3Efec_enet_mii_bus%3A%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3C%2FP%3E%3CP%3Eehci_hcd%3A%20USB%202.0%20%E3%80%8C%E6%8B%A1%E5%BC%B5%E3%80%8D%E3%83%9B%E3%82%B9%E3%83%88%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%20(EHCI)%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3EFSL-EHCI%20FSL-EHCI.0%3A%E6%96%B0%E3%81%97%E3%81%84USB%E3%83%90%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%80%81%E3%83%90%E3%82%B9%E7%95%AA%E5%8F%B71%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20irq%2075%2C%20io%20base%200x02184000%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.0%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%96%201-0%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%96%201-0%3A1.0%3A%201%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%BD%E3%83%BC%E3%82%B9IRQ%2072%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20Freescale%20On-Chip%20EHCI%20Host%20Controller%3C%2FP%3E%3CP%3EFSL-EHCI%20FSL-EHCI.1%3A%E6%96%B0%E3%81%97%E3%81%84USB%E3%83%90%E3%82%B9%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%80%81%E3%83%90%E3%82%B9%E7%95%AA%E5%8F%B72%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20irq%2072%2C%20io%20base%200x02184200%3C%2FP%3E%3CP%3Efsl-ehci%20fsl-ehci.1%3A%20USB%202.0%20started%2C%20EHCI%201.00%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%96%202-0%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%96%202-0%3A1.0%3A%201%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EUSB%E5%A4%A7%E5%AE%B9%E9%87%8F%E8%A8%98%E6%86%B6%E8%A3%85%E7%BD%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FP%3E%3CP%3Eusbcore%3A%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AEusb-storage%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3EUSB%E3%83%9E%E3%82%B9%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EARC%20USBOTG%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20(2005%20%E5%B9%B4%208%20%E6%9C%88%201%20%E6%97%A5)%3C%2FP%3E%3CP%3Emousedev%3A%20PS%2F2%20%E3%83%9E%E3%82%A6%E3%82%B9%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20(%E5%85%A8%E3%83%9E%E3%82%A6%E3%82%B9%E5%85%B1%E9%80%9A)%3C%2FP%3E%3CP%3E%E5%85%A5%E5%8A%9B%3A%20GPIO-keys%20as%20%2Fdevices%2Fplatform%2Fgpio-keys%2Finput%2Finput0%3C%2FP%3E%3CP%3E%E5%85%A5%E5%8A%9B%3A%2Fdevices%2Fplatform%2Fimx-i2c.1%2Fi2c-1%2F1-0048%2Finput%2Finput1%E3%81%A8%E3%81%97%E3%81%A6max11801_ts%3C%2FP%3E%3CP%3Eegalax_ts%201-0004%3Aegalax_ts%3A%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Eegalax_ts%3A%201-0004%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-5%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Eegalax_ts%202-0004%3A%20egalax_ts%3A%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Eegalax_ts%3A%202-0004%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-5%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Eusb%202-1%3Afsl-ehci%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E6%96%B0%E3%81%97%E3%81%84%E3%83%95%E3%83%AB%E3%82%B9%E3%83%94%E3%83%BC%E3%83%89USB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E7%95%AA%E5%8F%B72%3C%2FP%3E%3CP%3Eelan%20-%20Hello%20%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EELAN-TOUCH%3A2-0010%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC-22%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EI2C-Core%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%5BISL29023%5D%20%E3%81%8C%E5%BE%93%E6%9D%A5%E3%81%AE%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3EI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E3%83%AC%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A0%E6%96%B9%E6%B3%95%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BISL29023%5D%3C%2FP%3E%3CP%3Esnvs_rtc%20snvs_rtc.0%3ARTC%E3%82%B3%E3%82%A2%3ARTC0%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2snvs_rtc%3C%2FP%3E%3CP%3Ei2c%20%2Fdev%20entries%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3ELinux%E3%83%93%E3%83%87%E3%82%AA%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3Av2.00%3C%2FP%3E%3CP%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%E3%83%93%E3%83%87%E3%82%AA%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FV4L2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B916%3C%2FP%3E%3CP%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%E3%83%93%E3%83%87%E3%82%AA%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FV4L2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B917%3C%2FP%3E%3CP%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%E3%83%93%E3%83%87%E3%82%AA%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FV4L2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B918%3C%2FP%3E%3CP%3Emxc_v4l2_output%20mxc_v4l2_output.0%3A%E3%83%93%E3%83%87%E3%82%AA%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9FV4L2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B919%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%96%202-1%3A1.0%3AUSB%E3%83%8F%E3%83%96%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%96%202-1%3A1.0%3A%204%20%E3%81%A4%E3%81%AE%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Emag3110%202-000e%3A%20check%20mag3110%20chip%20ID%3C%2FP%3E%3CP%3Emag3110%202-000e%3A%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%83%81%E3%83%83%E3%83%97ID%200xfffffffb%E3%81%8C0xc4%E3%81%A8%E7%AD%89%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93!%3C%2FP%3E%3CP%3EMAG3110%3A2-000E%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC-22%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EI2C-Core%3A%20%E5%BE%93%E6%9D%A5%E3%81%AE%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%5BMAG3110%5D%3C%2FP%3E%3CP%3EI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E3%83%AC%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A0%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BMAG3110%5D%3C%2FP%3E%3CP%3Emma8451%200-001c%3A%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%83%81%E3%83%83%E3%83%97%20ID%200x1%20%E3%81%8C%200x1a%20%E3%81%BE%E3%81%9F%E3%81%AF%200x2a%20%E3%81%A8%E7%AD%89%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3EMMA8451%20%3A%200-001C%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-22%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3EIMX2-WDT%20IMX2-WDT.0%3AIMX2%2B%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%3D60%E7%A7%92%20(nowayout%3D1)%3C%2FP%3E%3CP%3EBluetooth%3A%E4%BB%AE%E6%83%B3HCI%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCver%201.3%3C%2FP%3E%3CP%3EBluetooth%3AHCI%20UART%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCver%202.2%3C%2FP%3E%3CP%3EBluetooth%3A%20HCIATH3K%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3A%E6%B1%8E%E7%94%A8Bluetooth%20USB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCver%200.6%3C%2FP%3E%3CP%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20btusb%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Esdhci%3A%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%BB%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%83%BB%E3%83%9B%E3%82%B9%E3%83%88%E3%83%BB%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%83%BB%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3Esdhci%3A%20Copyright(c)%20Pierre%20Ossman%20(%E8%8B%B1%E8%AA%9E)%3C%2FP%3E%3CP%3Emmc0%3A%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20%5BSDHCI-ESDHC-IMX.3%5D%20%E4%B8%8A%E3%81%AE%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BCDMA%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3Emmc1%3A%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20%5BSDHCI-ESDHC-IMX.1%5D%20%E4%B8%8A%E3%81%AE%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BCDMA%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3Emmc2%3A%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20%5BSDHCI-ESDHC-IMX.2%5D%20%E4%B8%8A%E3%81%AE%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BCDMA%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3Emxc_vdoa%20mxc_vdoa%3A%20i.MX%20Video%20Data%20Order%20Adapter%20(VDOA)%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EVPU%20%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E7%99%BB%E9%8C%B2mxc_asrc%3C%2FP%3E%3CP%3E%E6%B8%A9%E5%BA%A6%E6%A0%A1%E6%AD%A3%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C0x5894f069%3C%2FP%3E%3CP%3E%E3%83%AC%E3%82%B7%E3%82%AA%20%3D%20183%20%E3%81%AE%E3%82%B5%E3%83%BC%E3%83%9E%E3%83%AB%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%3C%2FP%3E%3CP%3EAnatop%20Thermal%20%E3%81%AF%20thermal_zone0%20%E3%81%A8%E3%81%97%E3%81%A6%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Eanatop_thermal_probe%3A%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E5%86%B7%E5%8D%B4%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AFCPUFreq%E3%81%A7%E3%81%99!%3C%2FP%3E%3CP%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20usbhid%20%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Eusbhid%3A%20USB%20HID%20%E3%82%B3%E3%82%A2%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCsnd-usb-audio%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Emxc_hdmi_soc%20mxc_hdmi_soc.0%3AMXC%20HDMI%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%3C%2FP%3E%3CP%3ECirrus%20Logic%20CS42888%20ALSA%20SoC%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3EI2C-Core%3A%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BCS42888%5D%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%E3%82%B5%E3%82%B9%E3%83%9A%E3%83%B3%E3%83%89%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3EI2C-Core%3A%E5%BE%93%E6%9D%A5%E3%81%AE%E5%86%8D%E9%96%8B%E6%96%B9%E6%B3%95%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%5BCS42888%5D%3C%2FP%3E%3CP%3Eimx-hdmi-soc-dai%20imx-hdmi-soc-dai.0%3A%E5%A4%B1%E6%95%97%3A%E6%9C%80%E5%88%9D%E3%81%ABHDMI%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Emmc0%3A%20%E6%96%B0%E3%81%97%E3%81%84%E9%AB%98%E9%80%9F%20DDR%20MMC%20%E3%82%AB%E3%83%BC%E3%83%89%20(%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200001)%3C%2FP%3E%3CP%3Emmcblk0%3A%20mmc0%3A0001%20SEM04G%203.68%20GiB%20%3C%2FP%3E%3CP%3Emmcblk0boot0%3A%20mmc0%3A0001%20SEM04G%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%201%202.00%20MiB%3C%2FP%3E%3CP%3Emmcblk0boot1%3A%20mmc0%3A0001%20SEM04G%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%202%202.00%20MiB%3C%2FP%3E%3CP%3E%20mmcblk0%3A%20p1%3C%2FP%3E%3CP%3E%20mmcblk0boot1%3A%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E4%B8%8D%E6%98%8E%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%20mmcblk0boot0%3A%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E4%B8%8D%E6%98%8E%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3Eusb%202-1.3%3Afsl-ehci%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E6%96%B0%E3%81%97%E3%81%84%E4%BD%8E%E9%80%9FUSB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E7%95%AA%E5%8F%B73%3C%2FP%3E%3CP%3Ewm8962%200-001a%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%20WM8962%20%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82ID%200%20!%3D%206243%3C%2FP%3E%3CP%3Ewm8962%200-001a%3A%20asoc%3A%20CODEC%20wm8962.0-001a%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82-22%3C%2FP%3E%3CP%3EASOC%3A%20%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20WM8962-%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%3A%20-22%3C%2FP%3E%3CP%3Eimx_3stack%20ASOC%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3EHDMI%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%9C%80%E5%88%9D%E3%81%ABHDMI%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84!%3C%2FP%3E%3CP%3EALSA%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E4%B8%80%E8%A6%A7%3A%3C%2FP%3E%3CP%3E%E3%82%B5%E3%82%A6%E3%83%B3%E3%83%89%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2026%3C%2FP%3E%3CP%3ETCP%E3%82%AD%E3%83%A5%E3%83%BC%E3%83%93%E3%83%83%E3%82%AF%E3%81%8C%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2017%3C%2FP%3E%3CP%3ECAN%3A%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%82%A8%E3%83%AA%E3%82%A2%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B3%E3%82%A2(REB%2020090105%20ABI%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3CP%3ENET%3A%20%E7%99%BB%E9%8C%B2%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%2029%3C%2FP%3E%3CP%3ECAN%3ARAW%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB(Rev%2020090105)%3C%2FP%3E%3CP%3ECAN%3A%20%E3%83%96%E3%83%AD%E3%83%BC%E3%83%89%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%20%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20(%E6%94%B9%E8%A8%82%E7%89%88%2020090105%20T)%3C%2FP%3E%3CP%3EBluetooth%3ARFCOMM%20TTY%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3ARFCOMM%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBluetooth%3ARFCOMM%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B31.11%3C%2FP%3E%3CP%3EBluetooth%3ABNEP(%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3)ver%201.3%3C%2FP%3E%3CP%3EBluetooth%3ABNEP%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%3A%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%9E%E3%83%AB%E3%83%81%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%3C%2FP%3E%3CP%3EBluetooth%3AHIDP(%E3%83%92%E3%83%A5%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3)ver%201.2%3C%2FP%3E%3CP%3Elib80211%3A%20IEEE802.11%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E5%85%B1%E9%80%9A%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%3C%2FP%3E%3CP%3EVFP%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20v0.3%3A%20implementor%2041%20architecture%203%20part%2030%20variant%209%20rev%204%3C%2FP%3E%3CP%3E%E5%85%A5%E5%8A%9B%3AHID%2004b3%3A310d%20as%20%2Fdevices%2Fplatform%2Ffsl-ehci.1%2Fusb2%2F2-1%2F2-1.3%2F2-1.3%3A1.0%2Finput%2Finput2%3C%2FP%3E%3CP%3E%E3%83%90%E3%82%B9%E5%91%A8%E6%B3%A2%E6%95%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E6%B1%8E%E7%94%A8-usb%200003%3A04B3%3A310D.0001%3Ainput%2Chidraw0%3A%20usb-fsl-ehci.1-1.3%2Finput0%20%E4%B8%8A%E3%81%AE%20USB%20HID%20v1.11%20%E3%83%9E%E3%82%A6%E3%82%B9%20%5BHID%2004b3%3A310d%5D%3C%2FP%3E%3CP%3E%E3%83%90%E3%82%B9%E5%91%A8%E6%B3%A2%E6%95%B0%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%E6%9C%89%E5%8A%B9%3C%2FP%3E%3CP%3Emxc_dvfs_core_probe%3C%2FP%3E%3CP%3EDVFS%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Eregulator_init_complete%3A%20PFUZE100_VGEN6%3A%20%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%AA%E5%88%B6%E7%B4%84%E3%80%81%E3%82%AA%E3%83%B3%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3Eregulator_init_complete%3A%20PFUZE100_VGEN3%3A%20%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%AA%E5%88%B6%E7%B4%84%E3%80%81%E3%82%AA%E3%83%B3%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3Eregulator_init_complete%3A%20PFUZE100_VGEN2%3A%20%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%AA%E5%88%B6%E7%B4%84%E3%80%81%E3%82%AA%E3%83%B3%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3Eregulator_init_complete%3A%20PFUZE100_VGEN1%3A%20%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%AA%E5%88%B6%E7%B4%84%E3%80%81%E3%82%AA%E3%83%B3%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3Esnvs_rtc%20snvs_rtc.0%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%201970-01-01%2000%3A00%3A00%20UTC%20(0)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3Eusb%202-1.4%3Afsl-ehci%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E6%96%B0%E3%81%97%E3%81%84%E4%BD%8E%E9%80%9FUSB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E7%95%AA%E5%8F%B74%3C%2FP%3E%3CP%3E%E5%85%A5%E5%8A%9B%3AUSB%E3%82%AD%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%2Fdevices%2Fplatform%2Ffsl-ehci.1%2Fusb2%2F2-1%2F2-1.4%2F2-1.4%3A1.0%2Finput%2Finput3%E3%81%A8%E3%81%97%E3%81%A6%3C%2FP%3E%3CP%3E%E6%B1%8E%E7%94%A8-usb%200003%3A04D9%3A1702.0002%3Ainput%2Chidraw1%3A%20usb-fsl-ehci.1-1.4%2Finput0%20%E4%B8%8A%E3%81%AE%20USB%20HID%20v1.10%20%E3%82%AD%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%20%5B%20USB%20%E3%82%AD%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E%E5%85%A5%E5%8A%9B%3AUSB%E3%82%AD%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%2Fdevices%2Fplatform%2Ffsl-ehci.1%2Fusb2%2F2-1%2F2-1.4%2F2-1.4%3A1.1%2Finput%2Finput4%E3%81%A8%E3%81%97%E3%81%A6%3C%2FP%3E%3CP%3E%E6%B1%8E%E7%94%A8-usb%200003%3A04D9%3A1702.0003%3Ainput%2Chidraw2%3A%20usb-fsl-ehci.1-1.4%2Finput1%20%E4%B8%8A%E3%81%AE%20USB%20HID%20v1.10%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%5B%20USB%20%E3%82%AD%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3Eata1%3A%20SATA%20%E3%83%AA%E3%83%B3%E3%82%AF%20%E3%83%80%E3%82%A6%E3%83%B3%20(SStatus%201%20SControl%20300)%3C%2FP%3E%3CP%3EEXT3-fs%3A%20%E3%83%90%E3%83%AA%E3%82%A2%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Ekjournald%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%E9%96%93%E9%9A%94%205%20%E7%A7%92%3C%2FP%3E%3CP%3EEXT3-fs%20(mmcblk0p1)%3A%20%E5%86%85%E9%83%A8%E3%82%B8%E3%83%A3%E3%83%BC%E3%83%8A%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3EEXT3-fs%20(mmcblk0p1)%3A%20%E5%BE%A9%E6%97%A7%E5%AE%8C%E4%BA%86%3C%2FP%3E%3CP%3EEXT3-fs%20(mmcblk0p1)%3A%20%E3%83%A9%E3%82%A4%E3%83%88%E3%83%90%E3%83%83%E3%82%AF%E3%83%BB%E3%83%87%E3%83%BC%E3%82%BF%E3%83%BB%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3C%2FP%3E%3CP%3EVFS%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20179%3A1%20%E3%81%AB%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E3%83%AB%E3%83%BC%E3%83%88%20(ext3%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0)%E3%80%82%3C%2FP%3E%3CP%3Einit%20%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E8%A7%A3%E6%94%BE%3A%20212K%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB(0001-ENGR00257661-pcie-imx-pcie-ep-rc-validation.patch)%E3%81%AB%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E6%89%93%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%8F%8A%E3%81%B3%20%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%26nbsp%3B%20CONFIG_IMX_PCIE%3Dy%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%23%20CONFIG_IMX_PCIE_EP_MODE_IN_EP_RC_SYS%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20CONFIG_IMX_PCIE_RC_MODE_IN_EP_RC_SYS%3Dy%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3EPCIE%E3%82%AE%E3%82%AC%E3%83%93%E3%83%83%E3%83%88%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E5%9B%9E%E3%81%97%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126626%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126626%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%88%E3%81%86%E3%81%93%E3%81%9D%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%81%E3%83%A3%E3%83%BC%E3%83%89%E3%83%BB%E3%83%81%E3%83%A5%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126625%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6Q%20PCIe%20EP%2FRC%20Validation%20System%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126625%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Frichard.zhu%22%20target%3D%22_blank%22%3Erichard.zhu%3C%2FA%3E%E3%81%95%E3%82%93%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%AE%E7%B4%A0%E6%99%B4%E3%82%89%E3%81%97%E3%81%84%E7%AD%94%E3%81%88%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%AE%E3%81%AB%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%80%81%E3%83%80%E3%83%BC%E3%82%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎06-20-2013 06:36 PM
更新者:
